AUDI Q5
Germanzues
South Africa
C?ID=327780
I need assistance as vehicle does not switch on display on dash and no communication on all control units.
Is there a process to programme this unit first as I have attached a photo below - Comfort control module - 4N907064CP.
If yes can i get the programming procedure.
Saturday,14,March,2026,15:27:02:45632
VCDS Version: 25.3.3.0 (x64) HEX-V2 CB: 0.4671.4
Data version: 20260227 DS365.0
VIN: WAUZZZFY9K2033453 License Plate: SYMOND
Gateway Installation List: 4M4 907 468 H
01-Engine -- Status: Cannot be reached 0100
02-Auto Trans -- Status: Cannot be reached 0100
03-ABS Brakes -- Status: Cannot be reached 0100
08-Auto HVAC -- Status: Cannot be reached 0100
09-Cent. Elect. -- Status: Cannot be reached 0100
13-Auto Dist. Reg -- Status: Cannot be reached 0100
15-Airbags -- Status: Cannot be reached 0100
16-Steering wheel -- Status: Cannot be reached 0100
17-Instruments -- Status: Cannot be reached 0100
36-Seat Mem. Drvr -- Status: Cannot be reached 0100
3C-Lane Change -- Status: Cannot be reached 0100
42-Door Elect, Driver -- Status: Cannot be reached 0100
44-Steering Assist -- Status: Cannot be reached 0100
46-Central Conv. -- Status: Cannot be reached 0100
52-Door Elect, Pass. -- Status: Cannot be reached 0100
6C-Back-up Cam. -- Status: Cannot be reached 0100
6D-Trunk Elect. -- Status: Cannot be reached 0100
74-Chassis Control -- Status: Cannot be reached 0100
81-Gear Shift -- Status: Cannot be reached 0100
82-Head Up Display -- Status: Cannot be reached 0100
8B-Adaptive Cruise 2 -- Status: Cannot be reached 0100
A5-Frt Sens. Drv. Assist -- Status: Cannot be reached 0100
A9-Struct. Borne Sound -- Status: Cannot be reached 0100
CA-Sunroof -- Status: Cannot be reached 0100
CF-Lane Chge Asst 2 -- Status: Cannot be reached 0100
Ziddywerks
Northern NJ USA
C?ID=208579
This unit is immo master. You need to adapt this unit to immobilizer in the vehicle. VCDS will not be able to do this. You need other tools like im508 or legit ODIS if using autel you need original data form original module to transfer.
What has been done to it or did the problem randomly appear?
Germanzues
South Africa
C?ID=327780
Hi,
Apparently customer took vehicle for fitment of aftermarket tow bar.After 3 day or so vehicle shut down.
Only hazards working and lights.
They did disconnect the tow bar module and wiring.
Regards
siLc
Tallinn, Estonia
C?ID=330192
Disconnect aftermarket towbar module and reassess?
It looks like all the ECU's are not getting a line 15 signal, sat there.
Ziddywerks
Northern NJ USA
C?ID=208579
Yes because BCM2 is mounted in the rear. Most likely damaged during install, or water ingress into module and vehicle from the towbar install. Common issue when it's not done right. End of story. With a new or used bcm2 installed. Nothing will work as mentioned in post#2. BCM2 is immo master.
