Wednesday,11,March,2026,17:39:06:16055
VCDS Version: 25.3.3.0 (x64) HEX-NET CB: 0.4671.4
Data version: 20260227 DS365.0
VIN: WVWZZZ3CZJE110087 License Plate: PEGGY
Mileage: 209039km-129890mi Repair Order:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 23 42 44 51 52 55 5F 65
6C 75 8C A9 BB BC C6
VIN: WVWZZZ3CZJE110087 Mileage: 209039km-129890miles
8C-HV Battery -- Status: Malfunction 0010
Address 01: Engine (J623-CUKC) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 023 BM HW: 04E 907 309 F
Component: 1.4l TFSI hy H22 4522
Revision: X3H22--- CVN: ED605E65
Coding: 011D0012636405083008
Shop #: WSC 05311 115 00310
ASAM Dataset: EV_ECM14TFS01104E906023BM 008006
ROD: EV_ECM14TFS01104E906023BM.rod
VCID: 6C9418C087B540FB17-8038
VINID: 9E69EAAAA0D3A9A5410400081C5B549460
Address 02: Auto Trans (J743) Labels: Redir Fail!
Part No SW: 0DD 300 046 H HW: 0DD 927 770 C
Component: GSG DQ400E H32 1601
Revision: 00032056 Serial number: TFK01710300154 CVN: 7893765C
Shop #: WSC 00046 000 00000
ROD: EV_TCMDQ400021_VW41.rod
VCID: 2D12D5C47C2F89F340-8078
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-OMG-V1.clb
Part No SW: 5Q0 614 517 BL HW: 5Q0 614 517 AH
Component: ESC H62 0855
Revision: 00000000 Serial number: 62997000000389 CVN: A3622558
Coding: 0FEC408F3821236C4777060861CA49F0021CC4E26086927138A1F008420202
Shop #: WSC 00015 115 08193
ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
ROD: EV_Brake1UDSContiMK100OMG_003.rod
VCID: 7CB42880F7D5D07B87-8028
Part No SW: 3Q0 959 435 F HW: 3Q0 959 435 F
Component: VWKESSYMQB 027 0907
Revision: 00027000 Serial number: 0459860962 Dataset Number: V03935260TX 0001
Coding: 102F0F0723
VCID: 3D32E584AC4F1973F0-8068
Part No SW: 5GE 907 044 AR HW: 5GE 907 044 AR
Component: Climatronic H04 1702
Revision: 00001K01
Coding: 12021004200110010815100000101822
VCID: 0C547840A775E0FBB7-8058
Subsystem 3 - Part No SW: 3Q0 963 231 E HW: 3Q0 963 231 E
Component: J848 HV-PTC 200 0204
Serial number: -00104.5U.2B20340377
Air quality sensor:
Humidity sensor: exterior:
A/C compressor sub:
H02
328196 - Motor for Right Temperature Flap
B108D 71 [00001000] - Actuator Stuck
Reset counter: 60
Mileage: 208578 km
Date: 2026.03.08
Time: 14:41:54
Voltage terminal 30: 12.9 V
Outside temperature: 17.0 °C
Inside temperature: 28.0 °C
Right temperature flap: actual value: 89
Right temperature flap: actual value: 30.0 %
Temperature door right - Specified value: 47
328199 - Position Sensor for Right Temperature Flap Motor
B1095 15 [00001000] - Open or Short to Plus
Reset counter: 73
Mileage: 208546 km
Date: 2026.03.08
Time: 10:23:14
Voltage terminal 30: 13.1 V
Outside temperature: 7.0 °C
Inside temperature: 19.2 °C
Right temperature flap: actual value: 218
Right temperature flap: actual value: 94.5 %
Temperature door right - Specified value: 218
Part No SW: 5Q0 937 086 BM HW: 5Q0 937 086 BH
Component: BCM PQ37BOSCH 034 0245
Revision: -------- Serial number: 865804111701HZ Dataset Number: V03935267PZ 0001
ROD: EV_BCMBOSCH_018.rod
VCID: 06404A68B9199AABE1-8052
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 171009 042 0607
Serial number: 171014060352
Component: RLHS 047 0105
Serial number: S9Y17M11D13H10M02S05
Coding: 00A8DD
Subsystem 3 - Part No SW: 3G0 941 633 J HW: 3G0 941 633 J
Component: E1 - LDS MQB H01 0032
Serial number: 16 06 2017 10000684
Humidity sensor: interior:
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Serial number: 000308418617307 Dataset Number: V03935258CH 0001
Coding: 1471151811
Shop #: WSC 05311 115 00086
VCID: 4BD6BB5CE2FBA7C37E-801E
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 C HW: 3Q0 907 572 C
Component: ACC BOSCH MQB H04 0195
Dataset Number: V03935243QB 0001
Coding: 5200670251FFC428949C8045
ASAM Dataset: EV_ACCBOSCHVW48X 001009
ROD: EV_ACCBOSCHVW48X.rod
VCID: 3522FDA4947FC13338-8060
Part No SW: 5Q0 959 655 S HW: 5Q0 959 655 S
Component: AirbagVW20 010 0870
Serial number: 003MFR03N28H Dataset Number: 3G0003V____ 0040
Coding: 88CCC000002000005C5400CF004800000065
Shop #: WSC 05311 000 08193
ROD: EV_AirbaVW20SMEVW37X_VW48.rod
VCID: 50ECAC300BDD841B0B-8004
Subsystem 1 - Part No SW: ----------- HW: 480 002 010 17
Serial number: 35700000000850F0682G
Subsystem 2 - Part No SW: ----------- HW: 480 002 010 17
Serial number: 35800000000E9C01682P
Subsystem 3 - Part No SW: ----------- HW: 480 402 410 17
Serial number: 3510001A1275C8A1D6ED
Subsystem 4 - Part No SW: ----------- HW: 480 401 210 17
Serial number: 3520001BF2685243B2A4
Subsystem 5 - Part No SW: ----------- HW: 480 402 410 17
Serial number: 3550001A52742B0362BY
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF033033 Serial number: 20171104200849
Coding: 0410
ASAM Dataset: EV_SMLSVALEOMQB 001016
ROD: EV_SMLSVALEOMQB.rod
VCID: 044450608F25A8BBFF-8050
Part No SW: 3G0 920 754 C HW: 3G0 920 754 C
Component: KOMBI 302 0310
Coding: 07A40B882EC0000801886B151201002800000000
VCID: 281C24D053CDACDBB3-807C
Part No SW: 3Q0 907 530 M HW: 3Q0 907 530 D
Component: GW MQB EV 618 6322
Serial number: 01111710520423 Dataset Number: V03935261BG 0001
Coding: 020300172CE21000FB0052785C1D00000001070100010000000300000000
GVL: 015C3C1000000408500C90008002C81800000000000000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 393AF194B8672553DC-806C
Subsystem 1 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0040
Serial number: 39170002629780097441
Coding: 2DFFFF
Subsystem 2 - Part No SW: 3Q0 915 181 B HW: 3Q0 915 181 B
Serial number: 2698785604
Analog clock:
Subsystem 3 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Address 23: Brake Booster (J539) Labels:| 5QE-909-059.clb
Part No SW: 5QE 909 059 G HW: 5QE 909 059 B
Component: EBKV H14 0211
Serial number: 085460012442
Coding: 05720100431900030002060500
Shop #: WSC 05311 115 00315
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004003
ROD: EV_BrakeBoostBoschMQBOMG_004_VW37.rod
VCID: 52E8A63805D1F60B3D-8006
Brake pressure reservoir:
Subsystem 1 - Part No SW: 5QE 909 057 D HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0155
Serial number: 05802861081117065754
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-DCD-V1.clb
Component: TSG FS 020 0041
Serial number: 271017EJR1046A Dataset Number: V03935272KC 0001
Coding: 003F0F20D000020000001000
VCID: 43C6937CCAAB6F8386-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-910-143.clb
Part No SW: 5Q0 910 143 B HW: 5Q0 910 143
Component: MQB_VWBS_GEN2 212 2201
Serial number: 759003 00 Dataset Number: V03935270CX 0001
Coding: 0100001000C10010
Shop #: WSC 00015 115 00310
ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002115
ROD: EV_SteerAssisVWBSMQBGen2.rod
VCID: 2A18DED84DC19ECBA5-807E
Address 51: Electric Drive (J841) Labels:. 3G0-907-080.clb
Part No SW: 3G0 907 080 E HW: 3G0 907 080 E
Component: LE Gen 3.3H15 0071
Revision: 00H15000 CVN: 76B49E2A
Coding: C0020000000000000000
ASAM Dataset: EV_DMCM08530113G0907080E 001017
ROD: EV_DMCM08530113G0907080E.rod
VCID: 271E27EC5ED3A3A3BA-8072
Component: TSG BFS 020 0041
Serial number: 231017EJM25872 Dataset Number: V03935268PR 0001
Coding: 003F0120DE00020000001000
VCID: 42C89678D5B1668B8D-8016
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 03DA000009000000
ROD: EV_HeadlRegulVWLWRMQB_VW37.rod
VCID: 75A23DA4D4FF8133F8-8020
Part No SW: 3Q0 035 874 C HW: 3Q0 035 874 C
Component: MU-S-ND-ER 851 0867
Serial number: Dataset Number: V03935264UK 0001
Coding: 02840201FF0000005111010100880A001F0509C401200100CE
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 3228C6B86511D60B1D-8066
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZHT3080133
Subsystem 2 - Part No SW: 3G0 919 866 BC HW: -----------
Component: ECE1 2017/18 --- 0820
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 30000000123585 Dataset Number: V03935272FJ 0001
ROD: EV_RDKBERU30_006_VW37.rod
VCID: 3424C0A09F05D83B0F-8060
Component: RVC Compact H12 0231
Dataset Number: V03935230RV 0001
Coding: 0184020162002017000041
Part No SW: 5NA 035 284 B HW: 5NA 035 284 B
Component: OCULowMQBLGE H17 0718
Revision: -------- Dataset Number: V03935278EW 0001
Coding: 02847201EA42980D3FFCBE000045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004044
ROD: EV_OCULowMQBLGE_004_VW25.rod
VCID: 3C34E880B755107BC7-8068
Address 8C: HV Battery (J840) Labels:. 5QE-915-227.clb
Part No SW: 3Q0 915 227 P HW: 3Q0 915 227 N
Component: K8C H05 0520
Serial number: 12101718010157 CVN: 8BE8FA63B757E5F8DC659A657E764ED97E764ED97E764ED97E764ED97E764ED9
ASAM Dataset: EV_BECM09620213Q0915227P 002009
ROD: EV_BECM09620213Q0915227P.rod
VCID: 3E30E288A149026BE9-806A
Battery interrupt switch:
Subsystem 1 - Part No SW: 3Q0 915 227 J HW: 3Q0 915 227 J
Component: A2 HVSMBJBECU H08 0410
Serial number: 00000029091716010026
Cell module control module 1:
Subsystem 2 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC1 H04 0442
Serial number: 17807ZKK311A01050938
Cell module control module 2:
Subsystem 3 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC2 H04 0442
Serial number: 17807ZKK311A01050794
Cell module control module 3:
Subsystem 4 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC3 H04 0442
Serial number: 17807ZKK311A01050780
Cell module control module 4:
Subsystem 5 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC4 H04 0442
Serial number: 17807ZKK311A01050449
Cell module control module 5:
Subsystem 6 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC5 H04 0442
Serial number: 17807ZKK311A01050972
Cell module control module 6:
Subsystem 7 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC6 H04 0442
Serial number: 17725ZKK311A01050514
Cell module control module 7:
Subsystem 8 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC7 H04 0442
Serial number: 17727ZKK311A01050071
Cell module control module 8:
Subsystem 9 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC8 H04 0442
Serial number: 17727ZKK311A01050820
28537 - Positive Contactor for HV Battery
P0AA2 00 [01101101] - Stuck Open
Mileage: 209039 km
Date: 2026.03.11
Time: 16:23:22
Current of H-V / hybrid battery: 0.000 A
Part No SW: 3G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0006
Serial number: 170921201132
VCID: 699A61D4884755D36C-803C
Address BB: Door Rear Drv (J388) Labels:* 5QX-959-DCR-V1.clb
Component: TSG HFS 020 0041
Serial number: 180917EII11249 Dataset Number: V03935272KD 0001
Coding: 000E01200100020000001000
ROD: EV_DCURearDriveMAXKLO.rod
VCID: 45C28D64C49F51B3A8-8010
Address BC: Door Rear Pass (J389) Labels:* 5QX-959-DCR-V1.clb
Component: TSG HBFS 020 0041
Serial number: 180917EII10217 Dataset Number: V03935272QC 0001
ROD: EV_DCURearPasseMAXKLO.rod
Address C6: Batt. Chrg. (J1050) Labels:* None
Part No SW: 5QE 915 682 AF HW: 5QE 915 682 AF
Component: OBC KOSTAL H40 4114
Revision: -------- Serial number: 2610170JP0000S Dataset Number: V03935250JM 0001
Coding: 115068222000
ASAM Dataset: EV_OBCSinglPhaseKLOMQB12P 001001
ROD: EV_OBCSinglPhaseKLOMQB12P.rod
VCID: 116A6934C057CD1344-8044
End----------(Elapsed Time: 02:26, VBatt start/end: 12.2V/12.0V)-----------
------------------------------3 Faults Found-------------------------------
