- Feb 25, 2014
- 2,879
- 4,656
- Garrettsville, OH
- C?ID=25607
My 2006 Phaeton has been sitting for about a year and a half with a blown air strut. Runs great and moves, but can't really leave my driveway. If I put it back on the road (and I'm teetering on that) I'd want to refresh the airbags on all four corners, not just the blown one. I am good friends with the Phaeton suspension controller and am perfectly comfortable doing the swap, but I'm having a bit of decision paralysis around the replacement.
Options:
1. Factory replacements, NLA.
2. Bilstein B4 OE replacements. $2000 per corner, $8000 total. I can swing it but I'd have to sleep on the couch for a week.
3. Have RMT rebuild my existing struts. $500/corner, $2000 total. Feel fine about the rebagging, but the dampers have 120k on them...
4. eBay mystery brand air struts. $250/corner, $1000 total. Who knows, and I **do not** like the huge claimed cross-reference range for cars that originally had different part numbers for a reason.
5. Retrofit coilovers. Not sure who makes a good kit. I'm willing to lose height adjustment, prefer to keep adjustable damping, not willing to lose luxobarge ride quality.
6. Chuck it in the fuck-it bucket. I love the car and I can spare the money, but I could use the life-priority simplification.
What are people doing these days for Bentley / Phaeton suspension overhauls?
Obligatory Auto-Scan. There's a couple other issues in there. Don't worry about them.
Options:
Friday,13,March,2026,14:54:32:50497
VCDS Version: 26.2.0.1 (x64) HEX-NET2 CB: 0.4709.5
Data version: 20251222 DS375.0
VIN: WVWAK03D868005728 License Plate:
Mileage: 202210km-125647mi Repair Order:
Chassis Type: 3D (3D - VW Phaeton (2002 > 2006))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 27 28 29 2E
34 36 37 38 39 46 47 55 56 57 65 66 68 69 71 75 76 77
VIN: WVWAK03D868005728 Mileage: 202210km-125647miles
Address 01: Engine Labels: 07C-906-018-BAP1.lbl
Part No SW: 07C 906 018 AJ HW: 000 000 000 00
Component: D1-6.0L-AT-LEV2 G ª8188
Revision: --H01--- Serial number: VWZ3Z0F7470400
Coding: 0000173
Shop #: WSC 03738 444 38140
VCID: 6D8CA2FDD18DAA72104-5160
VINID: 9E69D16C00D42062000051C2200EC208EB
001072 - Catalyst System; Bank 2
P0430 - 002 - Efficiency Below Threshold - Intermittent
Fault Status: 00110010
Mileage: 200029 km
RPM: 1443 /min
Load: 36.8 %
Speed: 60.0 km/h
Temperature: 108.0°C
Temperature: 42.0°C
Absolute Pres.: 970.0 mbar
Voltage: 12.446 V
001299 - Incorrect Immobilizer Key
P0513 - 008 - - Intermittent
Mileage: 200173 km
RPM: 1506 /min
Load: 29.0 %
Temperature: 17.0°C
Temperature: 21.0°C
Voltage: 10.668 V
005668 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 008 - - Intermittent
Mileage: 202214 km
RPM: 1317 /min
Load: 36.5 %
Temperature: 15.0°C
Temperature: 20.0°C
Voltage: 10.160 V
001152 - Coolant Fan Control Circuit 1
P0480 - 004 - Electrical Malfunction - Intermittent
Mileage: 202214 km
RPM: 1319 /min
Load: 34.5 %
Temperature: 17.0°C
Temperature: 27.0°C
Voltage: 9.525 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Fault Status: 01101000
Mileage: 202214 km
Temperature: 4.0°C
Temperature: 7.0°C
Absolute Pres.: 950.0 mbar
Voltage: 11.684 V
Readiness: 0010 1001
Address 02: Auto Trans Labels: 3D0-927-156.lbl
Part No: 3D0 927 156 AB
Component: AG5 01L 6.0lW12 USA 1010
Coding: 0000002
VCID: 6882D3E9FE6F8F5A632-5160
18265 - Load Signal
P1857 - 003 - Error Message from ECU - Intermittent
17090 - Transmission Range Sensor (F125)
P0706 - 003 - Implausible Signal - Intermittent
18161 - Tiptronic Switch (F189)
P1753 - 003 - Implausible Signal - Intermittent
Address 03: ABS Brakes Labels: 3D0-614-517.lbl
Part No: 3D0 614 517 AK
Component: ESP 5.7 allrad H33 0047
Coding: 0008397
Shop #: WSC 01065 000 00000
VCID: 6B88ACE5EF99A4420E0-51A8
01119 - Gear Recognition Signal
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 C HW: 5WK 484 97
Component: G1 Kessy 6700
Revision: 67006015 Serial number: VWZ3Z0F7470400
Coding: 0213228
VCID: 270090D533F14022AA8-5160
Component: ELV XXXX
00087 - Terminal 30 for Starting Relevant Consumers
00184 - Control Circuit for Engine Start/Stop Switch
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
Address 06: Seat Mem. Pass Labels: 3D0-959-759.lbl
Part No: 3D0 959 759 CA
Component: Sitzmemory D1 BF 1720
Coding: 0000003
VCID: 77A08095A3D110A2FA8-5160
Address 07: Control Head Labels: 3D0-035-00x-07.lbl
Part No: 3D0 035 008 QX
Component: ZAB COCKPIT 9923
Coding: 0500305
Shop #: WSC 03207 444 84420
VCID: 0052EB49F61F571ACB2-5160
9 Faults Found:
00384 - Optical Databus
00385 - Positive Output Audio Channel for Speech/Telephone
00386 - Negative Output Audio Channel for Speech/Telephone
00387 - Plus Output Audio Channel for Navigation Announcements
00388 - Negative Output Audio Channel for Navigation Messages
00856 - Radio Antenna
00823 - Line-Output; Front Left
00859 - Line-Output; Front Right
Address 08: Auto HVAC Labels: 3D0-907-040.lbl
Part No: 3D0 907 040 J
Component: Climatronic D1 2031
Coding: 0000002
VCID: 251C9ADD49FD5232984-5160
00710 - Defroster Flap Positioning Motor (V107)
00022 - Motor for Warm-Air Flap; Center Console Rear Right (V201)
00716 - Air recirculation Flap Positioning Motor (V113)
00445 - Loss of Refrigerant
Address 09: Cent. Elect. Labels: 3D0-937-049-V1.clb
Part No: 3D0 937 049 H
Component: STG.Bordnetz 5101
Coding: 0000003
VCID: 2F3078F51B011862628-5160
01117 - Generator Terminal DF Load Signal
Address 11: Engine II Labels: 07C-906-018-BAP2.lbl
Coding: 0000173
012952 - Catalyst System; Bank 3
P3298 - 002 - Efficiency Below Threshold - Intermittent
Mileage: 200029 km
RPM: 1395 /min
Load: 49.8 %
Speed: 56.0 km/h
Temperature: 105.0°C
Temperature: 43.0°C
Voltage: 12.573 V
012953 - Catalyst System; Bank 4
P3299 - 002 - Efficiency Below Threshold - Intermittent
Mileage: 200029 km
RPM: 1403 /min
Load: 41.9 %
Speed: 57.0 km/h
Temperature: 43.0°C
Voltage: 12.446 V
Mileage: 200173 km
RPM: 1498 /min
Load: 27.0 %
Temperature: 17.0°C
Temperature: 22.0°C
Absolute Pres.: 980.0 mbar
Voltage: 10.668 V
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 H
Component: 04 Airbag 8.4E++H01 0554
Revision: BB38727 Serial number: 0006635<
Coding: 0012340
VCID: 280293E93EEF4F5AA32-5160
Subsystem 1 - Part No: 3D0 959 339
Component: BF-Gewichtsens. 006 0005
Address 16: Steering wheel Labels: 3D0-953-549.lbl
Part No: 3D0 953 549 E
Component: Lenksäulenmodul 3401
Coding: 0000232
Address 17: Instruments Labels: None
Part No: 3D0 920 982 B
Component: KOMBIINSTRUMENT RB8 0521
Coding: 0004221
Shop #: WSC 08607 444 00001
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70B2BB89C6BF479A3B2-5160
Address 28: HVAC, Rear Labels: 3D0-919-158.lbl
Part No: 3D0 919 158 F
Component: Klima-Bedienteil D1 0117
VCID: 2E0E65F11C0B116A69E-5160
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) 0001
Coding: 0000001
VCID: 669EDDD1F47B992A51E-513C
Address 34: Level Control Labels: 3D0-907-553-V2.clb
Part No: 3D0 907 553 C
Component: LUFTFDR.-CDC- 3C3V0 1122
Coding: 0005531
Shop #: WSC 53212 053 999999
01598 - Drive Battery Voltage
013 - Check DTC Memory
00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
01400 - Suspension Level Control
Address 36: Seat Mem. Drvr Labels: 3D0-959-760.lbl
Part No: 3D0 959 760 CA
Component: Sitzmemory D1 F 1720
Coding: 0000004
VCID: 6FB0B8F5DB815862228-5160
Address 37: Navigation Labels: 3D0-919-887.lbl
Part No: 3D0 919 887 F
Component: NAVIGATION 9968
Coding: 0400000
VCID: 37204095E351D0A23A8-5160
Address 38: Roof Electronics Labels: 3D0-907-135.lbl
Part No: 3D0 907 135 C
Component: Dachmodul 0708
Coding: 0000015
VCID: 231884C547C9AC02F60-5160
00220 - Connection to Sunroof
00926 - Terminal 30
00308 - Supply Voltage for Motors for Sunroof/sunroof Shade
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) 0001
Coding: 0000001
VCID: 6780D0D5F37180226A8-513C
Address 46: Central Conv. Labels: 3D0-959-933.clb
Part No: 3D0 959 933 F
Component: X3 HSG 0102
Coding: 0000040
Shop #: WSC 03325 444 13946
VCID: 33387485F7293C82060-4B00
Subsystem 1 - Part No: 3D1 959 701 L
Component: Tuersteuergeraet FS 6001
Subsystem 2 - Part No: 3D1 959 702 L
Component: Tuersteuergeraet BF 6001
Subsystem 3 - Part No: 3D0 959 703 K
Component: Tuersteuergeraet HL 6001
Subsystem 4 - Part No: 3D0 959 704 K
Component: Tuersteuergeraet HR 6001
Subsystem 5 - Part No: 3D0 909 610 C
Component: 3L HDSG 2330
Subsystem 6 - Part No: 7L0 907 719 A
Component: Neigungssensor 0020
8 Faults Found:
01816 - Exterior Door Handle Switch in Drivers Door (F272)
00318 - Supply Voltage for Rear Lid Control Module
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 3D0 035 466 A
Component: 12K-AUDIOVERST 0118
VCID: 20128BC956DFB71AEB2-5160
Address 65: Tire Pressure Labels: 3D0-907-273-V2.clb
Part No: 3D0 907 273 G
Component: Reifendruckueberw. 0026
Coding: 0411224
Shop #: WSC 08607 444 08607
VCID: 2A0669E120E37D4AB56-5160
Address 68: Wiper Electr. Labels: 3Dx-955-1xx-V1.clb
Part No: 3D1 955 119 A
Component: Front Wiper 2005
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 D
Component: Batteriemanagement 2800
VCID: 241A87D942C7AB3A8FA-5160
00086 - Parallel Battery Connection Relay (J581)
Address 76: Park Assist Labels: None
Part No: 3D0 919 283 D
Component: 03 Einparkhilfe 0907
VCID: 2B086CE52F1964424E0-5160
End----(Elapsed Time: 07:33, VBatt start/end: 12.8V/13.0V. VIgn 0.0V)------
------------------------------60 Faults Found------------------------------
