- May 14, 2025
- 7
- 2
- Syracuse, NY, USA
- C?ID=568690
Hello all, my A6 has had the 24194 PCV code since the end of 2023, cleared a few times and it kept returning. I guess this is related with crankcase ventilation shut-off valve N548 being stuck open. However, I recently observed a separate code that seems related but not mentioned before. I am pasting the full scan and the separate module fault codes:
And the freeze frame of 24193 was only logged after I manually performed the test of crankcase ventilation valve in Basic Settings, which said not OK, and the counter of 24194 also increased 1 after this test.
Any other possible issues besides N548 being stuck?
Thanks in advance!
Thursday,26,February,2026,20:22:21:01348
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4671.4
VIN: WAUHGAFC1GN101810 License Plate:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 28 36 3B 3C 42 44 46 47
52 53 55 5F 62 65 6C 6D 72 82 85 8B 8E 8F 90
VIN: WAUHGAFC1GN101810 Mileage: 137565km-85478miles
17-Instruments -- Status: Cannot be reached 0100
47-Sound System -- Status: Cannot be reached 0100
Address 01: Engine (J623-CREC) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G2 907 551 A HW: 4H2 907 551 A
Component: 3.0l V6 TFSI H10 0004
Revision: --H10--- CVN: 437AB6F0
Coding: 0A2A00340566010D3000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TFS0214G2907551A 002001
ROD: EV_ECM30TFS0214G2907551A_002.rod
VCID: 290FED24B9797602F9D-807C
VINID: 9D19585D159305778100120100B8759755
24193 - PCV Valve Malfunction
P052E 00 [01100000] - -
24194 - PCV Valve Malfunction
P052E 00 [01101101] - -
Mileage: 132411 km
Date: 2025.09.07
Time: 18:06:40
Engine speed: 698.50 /min
Normed load value: 19.6 %
Coolant temperature: 68 C
Intake air temperature: 52 C
Voltage terminal 30: 14.316 V
Air mass: actual value (mg/stroke): 126.03 mg/stroke
Throttle valve angle: 2.619
Oxygen sensor control factor with with pre-control correction: 1.57 %
Oxygen control factor with precontrol correction: bank 2: 1.18 %
Engine status: Idle
Charge air pressure: actual value: 0.389 bar
Ambient air pressure: 1.002 bar
Part No SW: 4G0 927 158 AM HW: 0BK 927 156 AM
Component: 0BK 30TFSIUSA H19 1004
Revision: --H19--- CVN: 7F3C0CA0
VCID: 79AFFD6409590682C9D-802C
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 44A7924922E549929B00
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 41DF558421099E42C1D-8014
36352 - Function Restricted due to Insufficient Voltage
U1400 00 [00100000] - -
[HydraulicSupplyUndervoltage]
Part No SW: 4H0 907 064 GR HW: 4H0 907 064 GR
Component: BCM2 2.0 H37 0572
Coding: 0DA86F4E000000000000
VCID: 7F5B137C17FD28B2F79-802A
Serial number: 0215000200130005
Part No SW: 4G0 820 043 CE HW: 4G0 820 043 CE
Serial number: 20101500040478
Coding: 668131BA5D0000
VCID: 6491BC109EDBEB6A0AB-8030
Part No SW: 4H0 907 063 DM HW: 4H0 907 063 AM
Component: BCM1 2.0 H20 0311
Revision: 21020001 Serial number: 00001176713802
Coding: 01050011043C9FE2C1004884A0003800CF9CD208AE08022580000894F10015020060002D0B0000
VCID: 76B5F65838C769FAA4F-8022
Component: WWS57X 150808 H38 0080
Serial number: 150914003931
Coding: 0045F7
Component: G397_RLFS H06 0004
Serial number: 20792061
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 AN HW: 4G0 941 531 AN
Component: E1 - LDS H07 0044
Serial number: 14 10 2015 00000205
Component: USHL4.2 H30 0030
Serial number: 00000000095Z0214AD14
Subsystem 5 - Part No SW: 8K0 959 772 E HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0167977738
Coding: 853000
Subsystem 6 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA121823000015897511
Coding: 020300
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: D5F804D7000000000001
Component: ACC3 H21 0053
Serial number: 00000000000000 Dataset Number: 4G0909863D 0040
Coding: 7E01010202
ASAM Dataset: EV_AdaptCruisContrAU57X 002014
ROD: EV_AdaptCruisContrAU57X_002_AU57.rod
Part No SW: 4G0 959 655 B HW: 4G0 959 655 B
Component: Airbag10.43 H62 0086
Revision: -------- Serial number: 003G0002MC4G Dataset Number: 4G0909602N 0002
Coding: 303331343135303334354A55304C34473053
VCID: 34310C506EBB3BEA5AB-8060
Serial number: 6940000Y150001EKG80W
Serial number: 3575HRB405V3LHKE9PLU
Serial number: 3585HRB40633LHKIC0LT
Serial number: 3515JRB40573JK6280O/
Serial number: 3525JRB405D3K164A87O
Serial number: 3554VRB401E553V4Q9GW
Serial number: 3564VRB401C553V4SP5
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Revision: -------- Serial number: 90372OJO0001Q
Coding: 0004FC
VCID: 382938607253DF8A763-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Serial number: 05 08 2015 A0007209
Part No SW: 4G8 920 987 B HW: 4G8 920 987 B
Component: TBenUsaAcc H11 0106
Revision: 08001098 Serial number: 658241015596012
Coding: 0BCF09040F51D705020000
ASAM Dataset: EV_RBD4K 004055
ROD: EV_RBD4K_AU57.rod
VCID: 3829386072D3DF8A763-806C
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G8 907 468 F HW: 4G8 907 468
Component: J533--Gateway H14 0083
Revision: -------- Serial number: 00000002017874 Dataset Number: 4G0909515K 0021
Coding: C0CD073010
GVL: FD8DE94CFCAB680D40040000
ASAM Dataset: EV_GatewPkoUDS 001028
VCID: 3B23276C43E5F4929B1-806E
Serial number: 6417587903
Voltage stabilizer:
Serial number: 15080600000000000152
Part No SW: 4H0 857 511 HW: 4H0 857 511
Component: FLA H04 0021
Revision: AA001002
VCID: 678BAB1C6F6D80722F9-8032
Part No SW: 4G0 919 158 R HW: 4G0 919 158 R
Component: KLIMA FOND H08 0112
Serial number: 21101500041038
Coding: 20
VCID: 3E252E7850F7E1BABCF-806A
Part No SW: 4G8 959 760 A HW: 4G8 959 760 A
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000170317053
Coding: C0581B008F006001000001010101102030303232203232
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H04 0056
Revision: -------- Serial number: EJ1BPA820AD1XI Dataset Number: 4G0909573C 0006
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3635365878C729FA64F-8062
Component: SWA Master H07 0060
Serial number: 0383826297 Dataset Number: 4G0909535C 0009
Coding: 040211
ROD: EV_LaneChangAssis_AU48.rod
VCID: 392F3D6449D9C68289D-806C
Component: SWA Slave H07 0060
Serial number: 0384005423
Coding: 040211
Component: TSG FA H04 0511
Coding: 011F17015E00628002000013
VCID: 45D7419435A1B262FD5-8010
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H53 0202
Revision: 00000003 Serial number: 0000309283 Dataset Number: 4G0909852L 0037
Coding: 101001010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A2D22684CDFCD9A807-806E
Revision: 00002001 Serial number: 0384096052
Coding: 0106063A00FA718580B0088402070E470000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0081
Serial number: 00000000000000317381
Subsystem 3 - Part No SW: 4G8 959 591 A HW: 8V3 959 591 A
Component: J245 PS40.402 H03 0004
Serial number: 0000FST000LHPQH00000
Coding: 101F02
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Serial number: 0000000AP00015661356
Subsystem 5 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Serial number: 93643722
Part No SW: 4G5 035 223 C HW: 4G5 035 223
Component: MIB2_amp_P H02 0420
Serial number: 00000000000280 Dataset Number: 4G1909510L 0011
Coding: 0175010A018AF02A5A0000010000
ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
ROD: EV_AMPMst16C4Gen2BOSE_AU57.rod
VCID: 221DFA08C44FA55AB87-8076
Component: TSG BF H03 0511
Coding: 011F17015E00628002000002
VCID: 46D5469808A7B97AF4F-8012
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001631969 Dataset Number: 4G0909522E 0008
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D0719348D916A22155-8078
Component: MxB-ECU 001 0100
Revision: -------- Serial number: -------------- Dataset Number: 4G0909865D 0017
Coding: 04FA021122600400
Coding: E01E00
Coding: E01E00
13705487 - Databus
[Timeout CAN-Botschaft Systeminfo_01 (0x585)]
Reset counter: 233
Mileage: 137061 km
Date: 2026.02.12
Time: 10:10:31
Address 5F: Information Electr. (J794) Labels:| 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 025 J HW: 4G1 035 025
Component: MU-H-LNS-US 043 1426
Serial number: A278J0FB016963 Dataset Number: 4G1909545D 0029
Coding: 017501020000000013220002041A00102F0006E5F17001047E
VCID: 2517E114D5615262DD5-8070
Subsystem 1 - Part No SW: V03 959 803 B HW: -----------
Component: NAR 2025 --- 0397
Multimedia display unit 1:
Subsystem 2 - Part No SW: 4G1 919 605 A HW: 4G1 919 605 A
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9FY8035AF
Serial number: 90349OJF000CU
Compact disc data bank:
Component: Gracenote2--- --- 3006
Reset counter: 100
Mileage: 131609 km
Date: 2025.08.12
Time: 19:10:52
Voltage terminal 30: 14.2 V
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
Component: TSG HL H03 0511
Coding: 010F17004000628002000002
VCID: 49CF4DA419B9560219D-801C
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 N HW: 5Q0 907 273
Component: RDKBERU30 H04 0004
Serial number: 40000000028718 Dataset Number: V03935244BV 0001
ASAM Dataset: EV_RDKBERU30 005005
ROD: EV_RDKBERU30_005.rod
VCID: 47CB4B9C0F2DA0720F9-8012
Part No SW: 4H0 907 428 E HW: 7P6 907 441 G
Component: TopView H08 0361
Revision: 11001001 Serial number: 82330JG0121116
Coding: 0211000001010000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
VCID: 2F3B033C879D1832279-807A
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 4G5 959 107 C HW: 4G5 959 107 A
Component: HDSG-Modul H02 0049
Revision: 13002001 Serial number: 282500674 Dataset Number: 4G1909541C 0002
Coding: 111104C120
ASAM Dataset: EV_HDSGAu571 001022
ROD: EV_HDSGAu571_AU57.rod
VCID: 323D0A4894AF35DA487-8066
Component: TSG HR H03 0511
Address 82: Head Up Display (J898) Labels:| 4G0-919-604.clb
Part No SW: 4G0 919 604 M HW: 4G0 919 604 M
Component: HeadUpDisplay H07 0306
Coding: C60000
ASAM Dataset: EV_HUDContiC7 001027
ROD: EV_HUDContiC7_AU57.rod
VCID: 3537315465C122E26D5-8060
Component: DPC-SG H27 0081
Revision: -------- Serial number: 262130025421000 Dataset Number: 4G0909547D 0007
Coding: 6A060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C011430B68B632A02B-8078
Coding: 7E01010202
ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
ROD: EV_AdaptCruisContr2AU57X_002_AU57.rod
VCID: 270BEB1CAF6D4072EF9-8072
Component: BV-SG H33 0090
Serial number: 005000622610157 Dataset Number: 4G0909548G 0008
Coding: 04C1B8180111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Component: RGS-VL H14 0080
Dataset Number: 4G0909614C 0001
Coding: 0066E608031F0376070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313F054491A90EC231D-8064
Component: RGS-VR H14 0080
Dataset Number: 4G0909615C 0001
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End----------(Elapsed Time: 02:57, VBatt start/end: 14.6V/14.6V)-----------
------------------------------5 Faults Found-------------------------------
Saturday,07,March,2026,21:23:09:01348
VCDS Version: 25.3.3.0 (x64) HEX-V2 CB: 0.4671.4
Data version: 20260227 DS365.0
VIN: WAUHGAFC1GN101810 License Plate: HCC7669
Mileage: 85750 Repair Order:
Address 01: Engine Labels: 06E-907-551-CGW.clb
Control Module Part Number: 4G2 907 551 A HW: 4H2 907 551 A
Component and/or Version: 3.0l V6 TFSI H10 0004
Software Coding: 0A2A00340566010D3000
Work Shop Code: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TFS0214G2907551A 002001 (AU57)
VCID: 290FED24B9797602F95-807C
P052E 00 [00100110] - -
Mileage: 138004 km
Date: 2026.03.07
Time: 21:16:43
Engine speed: 698.75 /min
Normed load value: 15.3 %
Coolant temperature: 91 C
Intake air temperature: 43 C
Voltage terminal 30: 14.531 V
Air mass: actual value (mg/stroke): 98.02 mg/stroke
Throttle valve angle: 2.210
Oxygen sensor control factor with with pre-control correction: 0.48 %
Oxygen control factor with precontrol correction: bank 2: 0.88 %
Engine status: Idle
Charge air pressure: actual value: 0.326 bar
Ambient air pressure: 0.992 bar
P052E 00 [00101111] - -
Fault Frequency: 11
Mileage: 132411 km
Date: 2025.09.07
Time: 18:06:40
Engine status: Idle
Thanks in advance!
