Hello good people,
Hoping someone might proffer direction or clarity re. the below two fault codes:
21583 loss of crankshaft synchronisation crank
4814 - System voltage.
Codes present with engine running and with engine off.
Please note this is a car I am considering purchasing after my previous Tiguan was written off, so can't tinker or clear codes at this stage, just hoping someone might speak to cause/potential solutions. May be able to clear codes before a second test drive to see if they return but not immediately, and would appreciate some direction prior to further test drives.
Also note car drove well, engine didn't seem to falter under normal driving conditions.
Thanks!
A
Thanks!
A
Thursday,12,March,2026,20:59:01:09707
VCDS Version: 25.3.3.0 (x64) HEX-V2 CB: 0.4671.4
Data version: 20260227 DS365.0
VIN: WV1ZZZ2HZLA022397 License Plate: IG ON
Mileage: 57840km-35940mi Repair Order:
Chassis Type: 2H-VN81 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 22 25 32 5F 61 69 0B
VIN: WV1ZZZ2HZLA022397 Mileage: 57840km-35940miles
Address 01: Engine (J623-DDXD) Labels:. 059-907-309-V1.clb
Part No SW: 2H6 907 311 C HW: 059 907 309 J
Component: 3.0l V6 TDI H23 0003
Revision: 9AH23--- CVN: 682125A0
Coding: 01594032233608020001
Shop #: WSC 18309 005 1048576
ASAM Dataset: EV_ECM30TDI0112H6907311C 001006
ROD: EV_ECM30TDI0112H6907311C.rod
VCID: 2809EF2F927145FAE6B-807C
VINID: 9E606AAAA098A9C4400820C91CE47F7C26
4814 - System Voltage
P0562 00 [00100000] - Too Low
21583 - Loss of Crankshaft Synchronization
P191A 00 [00100000] - -
Address 03: ABS Brakes (J104) Labels: 2H6-907-37x-MK100ESC.clb
Part No SW: 2H6 907 379 A HW: 2H6 907 379
Component: ESC H06 0310
Revision: 00000000 Serial number: 60090000000704
Coding: 207344B64996B69704A522AC92576D85390000
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN817GP 008001
ROD: EV_Brake1ESCCONTIVN817GP_008.rod
VCID: 34310B5F5EB9311A5A3-8060
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 21012013470150
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5E97720752B4AFC7-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 2H6 907 047 A HW: 2H6 907 047 A
Component: Climatic-T5 H24 0610
Revision: 00001005
Coding: 0000000002
Shop #: WSC 00059 790 00002
ASAM Dataset: EV_ClimaticT5 A01715
ROD: EV_ClimaT5Basis_VN81.rod
VCID: 2C01133F868969DA023-8078
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 089 D HW: 7E0 937 089 D
Component: BCM PQ25 MMI4 H84 0772
Revision: BB084001 Serial number: 05007273190992
Coding: 620002380C210000003800102C4B84C42F80610F60C24160310000020803
Shop #: WSC 00000 1008 321166
VCID: 34310B5F5E39311A5A3-8060
Subsystem 1 - Part No SW: 6R0 959 802 CR HW: 6R0 959 802 CR Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 022 1323
Serial number: 13202700190924080128
Subsystem 2 - Part No SW: 6R0 959 801 CQ HW: 6R0 959 801 CQ Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 022 1323
Serial number: 13202701190924084926
Subsystem 3 - Part No SW: 2H0 959 442 HW: 2H0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-MD9 H02 0103
Serial number: 39190003725810040023
Coding: A4FFFF
Subsystem 4 - Part No SW: 6R0 959 811 P HW: 6R0 959 811 P
Component: J388__TSG_HL 022 1323
Serial number: 13202709200108012119
Subsystem 5 - Part No SW: 6R0 959 812 P HW: 6R0 959 812 P
Component: J389__TSG_HR 022 1323
Serial number: 13102708200108041901
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 T HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0212
Revision: -------- Serial number: 32931921700823
Coding: 31800E
ASAM Dataset: EV_VW75XParkAssis4K 001013
ROD: EV_VW75XParkAssis4K_001_VN81.rod
VCID: 43D358830B1786A2D39-8016
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 R HW: 6C0 959 655 R
Component: Airbag VW12 001 0503
Revision: -------- Serial number: 003G0AKLIHYA Dataset Number: V03935317HH 0001
Coding: 88C0C0000000000040000000008800000065
ASAM Dataset: EV_AirbaVW12TS6VW25X 001001
ROD: EV_AirbaVW12TS6VW25X_SK31.rod
VCID: 42DD5D87140D8FAAD8F-8016
Serial number: 34900C2CC4E1A000000/
Serial number: 35000A0F3791A000000K
Serial number: 355008163CA1A000000L
Serial number: 356003649DB1A000000S
Part No SW: 2H6 920 871 A HW: 2H6 920 871 A
Component: KOMBI H03 2030
Coding: 131A000300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 089 D
Component: GW-K-CAN TP20 H84 0772
Revision: BB084001
Coding: 742301
VCID: 6889AF2F527185FA26B-803C
Address 22: AWD Labels: None
Part No SW: 2H0 927 755 D HW: 2H0 927 755 D
Component: SG offroad VTG 0156
Revision: 00H07000 Serial number: T89YC22293SAQ3
Coding: 0000013
VCID: 313F024BAD2B0432315-8064
Component: IMMO H03 2030
Coding: 000002
VCID: 6A8DD5274CFDB7EA30F-803E
Address 32: Differential Locks (J647) Labels:* 2H0-927-771.clb
Part No SW: 2H0 927 771 B HW: 2H0 927 771
Component: Quersperre H04 0018
Revision: 11001001 Serial number: 4DG 29.02.20 00
ASAM Dataset: EV_QuersUDSAAMVN817 002001
ROD: EV_QuersUDSAAMVN817.rod
VCID: 2D071E3BBD9360D215D-8078
Part No SW: 5K7 035 200 L HW: 5K7 035 200 L
Component: MU-S--ER H42 0478
Serial number: VWZAZ2Y0205902 Dataset Number: V03935270BE 0001
Coding: 06180700BE00000011510001000808001F0100D60020010003
ROD: EV_MUStd4CTSAT_VN81.rod
Part No SW: 7E0 907 534 HW: 7E0 937 089 D
Component: Batt.regelung H84 0772
Coding: E10008AF
Component: Anhaenger H12 0100
Revision: 3A001001 Serial number: 00000539330059
Coding: 010D000100000000
VCID: 3039074FAA210D3A3EB-8064
End----------(Elapsed Time: 01:36, VBatt start/end: 13.6V/13.7V)-----------
------------------------------2 Faults Found-------------------------------
