Hi Guys,
Just purchased a new to me Australian delivered Audi TTRS Plus (2013). I have attached a copy of the Scan below. When we picked up the car we did a scan ( not the one below). We had a TMPS error come up on testing and owner said he had the issue a few times and he would just turn the car on and off and it would go away. We got the car home without issue (800km drive), once home we did a full inspection. Found driver side wheel bearing was shot so we promptly replaced the bearing/hub and that sorted the issue. Also had to replace the front pad which were a little low.
Post changing the pads and wheel bearing we got ABS / Traction control / TMPS errors on the dash. We tried clearing codes several times with no luck. Managed to clear the abs light by doing the 20+ km/h turn in circle. We are left with TMPS and Traction lights on dash.
Scan indicates the code 01130 - ABS operation, 01316 - ABS Control ( Susp elec), 01316 - ABS Control ( Tire Pressure II)
We have done a drive in straight line to verify all the wheel sensors read exactly the same - All working and reading the same.
Car had coil overs with mag-ride delete resistors originally. I have restored the Factory Mag-ride suspension into the car as the Coilovers were only good for track. The original wiring has been cut and had the bypass resistors fitted. I have just found some original plugs which I will restore into the car to get the factory setup working again.
We have done a full brake bleed procedure and this seems to work as expected. ABS pump primes and bleeds the brakes without issue. Also done and emergency stop and the ABS seems to work ok.
There are some other codes related to after market sound system which we are not worried about.
Was hoping that some of the experts here could have a look over the scan to see if there are any clues as to the issue. I have done a fair bit of Googling the ABS code 01130 and it appears that it's likely the ABS module will need to be replaced or repaired.
Warm Regards
Ryan
Warm Regards
Ryan
Tuesday,10,March,2026,21:39:35:49307
VCDS Version: 25.3.3.0 (x64) HEX-V2 CB: 0.4671.4
Data version: 20260227 DS365.0
VIN: TRUZZZ8J0D1900708 License Plate:
Chassis Type: 8J-AU35 (7N0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 22 25 2E 37 42 44 46 47 4C
52 55 56 61 77
VIN: TRUZZZ8J0D1900708 Mileage: 89070km-55345miles
2E-Media Player 3 -- Status: Cannot be reached 1100
4C-Tire Pressure II -- Status: Malfunction 0010
Address 01: Engine (CEP) Labels:. 07K-907-404-CEP.clb
Part No SW: 8J0 907 404 P HW: 8J0 907 404 M
Component: 2.5l R5/4V TFSI 0030
Revision: F7H07--- Serial number: AUX7Z0L8FNO02N
Coding: 0113000C240F0160
Shop #: WSC 74565 000 00000
VCID: 3A2D212B0053906A80F-806E
VINID: 92296AAAA21A0140490001C020A854CF86
Readiness: 0110 0101
Part No SW: 0BH 300 012 HW: 0BH 927 711 C
Component: DSG DQ500-7A H07 1812
Revision: 00H07V01 CVN: B4856668
ROD: EV_TCMDQ500021.rod
VCID: 6099B343CACFAABAEEB-8034
Address 03: ABS Brakes Labels: 8J0-614-517.clb
Part No SW: 8J0 910 517 A HW: 8J0 614 517 G
Component: ESP MK60E1 0030
Revision: 00H60001
Coding: 0618391
Shop #: WSC 01236 785 00200
VCID: 2A0D116BF0F320EAF0F-807E
01130 - ABS Operation
Reset counter: 149
Mileage: 89079 km
Date: 2026.03.06
Time: 11:44:11
Count: 8517
Count: 394
Count: 44800
Address 08: Auto HVAC Labels: 8J0-820-043.clb
Part No SW: 8J0 820 043 BA HW: 8J0 820 043 BA
Component: J255 Klima 1 Zone 0110
Revision: 00H09006 Serial number: 00000001224577
Coding: 1573957
VCID: 6695A55B246BC48A147-8032
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 AB HW: 8P0 907 063 AB
Component: BCM PQ35 H 112 0715
Revision: AB112715
Coding: 4E000B2FA8051A202070C0E00180084C50F658AA3020D928DC000E440045
Shop #: WSC 01236 758 00200
VCID: 74B1CF136EB7261A9A3-8020
Subsystem 1 - Part No SW: 8J2 955 119 A HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: Wischer AU354 H10 0080
Coding: 00FD10
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 02492C
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 M HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0140
Revision: 11001001 Serial number: 36861226200140
Coding: 00010B
VCID: 48C94BE342BFF2FA06B-801C
Address 14: Susp. Elect. Labels: 8P0-907-376.lbl
Part No SW: 8J0 910 376 E HW: 8J0 907 376 E
Component: J250 Raddaempfung 0110
Revision: --H22--- Serial number: 190DPH 2240276
Coding: 0000072
VCID: 313F0607DD255332315-8064
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 149
Mileage: 89079 km
Date: 2026.03.06
Time: 11:44:13
Voltage: 12.36 V
Voltage: 4.95 V
Address 15: Airbags Labels: 8J0-959-655.lbl
Part No SW: 8J0 959 655 HW: 8J0 959 655
Component: -r Airbag 9.43 H03 0020
Revision: 93H03002 Serial number: 0036K0067BW%
Coding: 0011634
VCID: 79AFFE2745D55B72C95-802C
Subsystem 1 - Serial number: 6332DRB408498AB2Z
Subsystem 2 - Serial number: 6342DRB40ED28E20.
Subsystem 3 - Serial number: 63747RB406C4697F%
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H38 0070
Coding: 0014141
VCID: 46D545DB44ABE48AF47-8012
Component: E0221 H06 0030
Address 17: Instruments Labels: 8J0-920-xxx-17-MY8.clb
Part No SW: 8J0 920 931 F HW: 8J0 920 931 F
Component: KOMBIINSTR. VDO H04 0780
Revision: D0H04005 Serial number: 2248L005000432
Coding: 0113728
VCID: 30390303D62F5A3A3EB-8064
Part No SW: 7N0 907 530 AC HW: 7N0 907 530 AC
Component: J533 Gateway H48 1633
Revision: H48 Serial number: 220912F2002672
Coding: 354101
VCID: 71BFC60711A51332715-8024
03272 - Control Module for Audio Interface
Reset counter: 149
Mileage: 89079 km
Date: 2026.03.06
Time: 11:44:15
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 2K0 907 554 B HW: 2K0 907 554 B
Component: Haldex 4Motion 5007
Coding: 0000005
VCID: 2D071A77C11D37D215D-8078
Revision: D0H04005 Serial number: AUX7Z0L8FNO02N
Address 2E: Media Player 3
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8J0 035 193 D HW: 8J0 035 193 D
Component: RNS-E PU EU H07 0220
Revision: 0000013S Serial number: AUZBZ7MD403972
Coding: 0619725
VCID: 2B03146FFF0939E20B9-807E
Reset counter: 149
Mileage: 89079 km
Date: 2026.03.06
Time: 11:44:13
Bin. Bits: 00000000 00000000
Bin. Bits: 10000000 00000000
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8J8 959 801 E HW: 8J8 959 801 E
Component: Tuer-SG H03 0080
Coding: 0000533
VCID: 3FDB503F1B71B542B71-806A
Part No: 8J0 909 144 P
Component: EPS_ZFLS Kl. 239 3305
Revision: 00H22000
VCID: 3D272A37117DA752A5D-8068
Address 47: Sound System Labels: 8J0-035-223.lbl
Part No SW: 8J0 035 223 D HW: 8J0 035 223 D
Component: J525 Amp High H04 0160
Revision: PROD_01 Serial number: 00000000041276
Coding: 0246317
VCID: 2517E25799ED0F92DDD-8070
16349 - Control Module - Error in Output Stage
Fault Status: 00101110
Reset counter: 244
Mileage: 46462 km
Address 4C: Tire Pressure II Labels: 8J0-907-274.lbl
Part No SW: 8J0 907 274 C HW: 4F0 907 274
Component: J793 RKA+ H04 0190
Revision: 00000518 Serial number: 00005180000295
Coding: 0614100
VCID: 323D090BD823682A48F-8066
Fault Status: 11101101
Reset counter: 149
Mileage: 89079 km
Date: 2026.03.06
Time: 11:44:11
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 12.30 V
Temperature: 26.0 C
(no units): 0.0
Part No SW: 8J8 959 802 J HW: 8J8 959 802 J
Component: Tuer-SG 004 0102
Coding: 0000532
VCID: 45D742D779ADEF92FDD-8010
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Coding: 0000025
Subsystem 1 - Part No: 8E0 941 329 A
Component: AFS-Modul links H05 0030
Subsystem 2 - Part No: 8E0 941 329 A
Component: AFS-Modul rechtsH05 0030
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0619725
Reset counter: 149
Mileage: 89079 km
Date: 2026.03.06
Time: 11:44:13
Part No SW: 7N0 907 534 HW: 7N0 907 530 AC
Component: Batt.regelung H48 1633
Coding: F326015A
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790159468
Part No SW: 8P1 862 335 A HW: 8P1 862 335
Component: FSE_256x BT H44 0660
Revision: 00000000 Serial number: 00000005579554
Coding: 0011422
Shop #: WSC 35405 000 1048576
VCID: 35373217294D7F126DD-8060
End----------(Elapsed Time: 01:36, VBatt start/end: 12.4V/12.4V)-----------
------------------------------7 Faults Found---------
