16711 - Knock Sensor 1 (G61): Signal too Low on 1.8T
vdubdezl
SC
C?ID=192065
I have an 01 Jetta Wolfsburg 1.8T with 5MT. I have a 16711 - Knock Sensor 1 (G61): Signal too Low code and I am lost as to what to due next. I first torqued the sensor without change. I then bought another sensor and replaced it. Mine has only 2 wires since it is a manual. I thought the "knock" was caused by a misfire so I changed all of the plugs. I called VW and the previous owner(I just bought it used from a lot) had the warranty done on the coil packs and they look new. I replaced the fuel filter also. What should I do next? I have researched it for about 3 weeks now and I'm stumped. The only code I have is for this. Could it possibly be a bad fuel pump? Also, when I speed up it sputters badly. It is so bad, that when at night with the headlights on, it shakes them badly. The engine makes no knocking noise revved up sitting still. It sounds great in my garage, but when I drive it, it starts in 2nd, worse in 3rd, bad in 4th, and really bad in 5th. Any ideas???
NostraJackAss
It would be a good idea to post the full auto-scan.
I would monitor the pump and regulator for proper function and volume tested along with MAF is suspect FOD.
vdubdezl
SC
C?ID=192065
okay. What section do I do this under? Is it a certain measuring block number?
NostraJackAss
It is done with a fuel pump tester and volume measuring device.
Verification of MAF part # can be determined with the auto-scan.
vdubdezl
SC
C?ID=192065
Here is the latest scan that is currently on the car with the knock sensor code.
Tuesday,29,April,2014,20:32:41:29190
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN:    License Plate: IBM620
Mileage: 120867   Repair Order:
                Address 01: Engine       Labels: 06A-906-032-AWW.lbl
Control Module Part Number: 06A 906 032 DL
  Component and/or Version: 1.8L R4/5VT     G   0003
           Software Coding: 07500
            Work Shop Code: WSC 00066
                      VCID: 6BD52F3319F7F6465E5-515C
            P0327 - 35-00 - Signal too Low
Readiness: 0000 1001
vdubdezl
SC
C?ID=192065
Here is another scan before the other one with all of the codes on the whole car for reference. I had to repair the wiring harness to make the speedometer work. I then cleared the codes and got only the knock sensor code back. Hopefully this is relevant.
Saturday,26,April,2014,12:01:29:29190
Mileage: 194510km-120862mi   Repair Order:
Chassis Type: 9M - VW Jetta IV (1998 > 2014)
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
          75 76
   Mileage: 194510km/120862miles
   Part No: 06A 906 032 DL
   Component: 1.8L R4/5VT     G   0003
   Coding: 07500
   Shop #: WSC 00066
   VCID: 6BD52F3319F7F6465E5-5140
16885 - Vehicle Speed Sensor
            P0501 - 35-00 - Implausible Signal
18010 - Power Supply Terminal 30
            P1602 - 35-10 - Voltage too Low - Intermittent
Readiness: 0000 0100
Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
   Part No: 1C0 907 379 D
   Component: ASR FRONT MK60      0103
   Coding: 0018945
   Shop #: WSC 00066 000 00000
   VCID: 2B55EF33897736461E5-5140
   Part No: 6Q0 909 605 F
   Component: 04 AIRBAG VW6  0202 0004
   Coding: 12340
   Shop #: WSC 00066
   VCID: 3A7BDA77262D9FCE953-515C
   Part No: 1J0 920 905 J
   Component: A4-KOMBIINSTR. VDO V53
   Coding: 07232
   Shop #: WSC 52684
   VCID: 2E53E627EA65436E39B-515C
   Subsystem 1 - Part No: IMMO
   Component: IDENTNR: VWZ7Z0A3478498
   IMMO-IDENTNR: VWZ7Z0A3478498
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00066
   VCID: F0EFB85FB0D1959EEB7-515C
   Part No: 1J0 959 799 AJ
   Component: 61 Zentral-SG Komf. 0001
   Coding: 04096
   Shop #: WSC 00066
   VCID: 8603FE87A255AB2E21B-4B1E
   Subsystem 1 - Part No: 1J1959801C
   Component: 61 Tõrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J1959802D
   Component: 61 Tõrsteuerger. BF0002r
   Subsystem 3 - Part No: 1J4959811C
   Component: 61 Tõrsteuerger. HL0002r
   Subsystem 4 - Part No: 1J4959812C
   Component: 61 Tõrsteuerger. HR0002r
            35-00 - -
            35-00 - -
   Part No: 1JM 035 157 A
   Component:  Radio DE2         0005
   Coding: 02043
   Shop #: WSC 11100
   VCID: 3E73D6673A05B3EEA9B-51F0
Address 01: DTCs cleared
NostraJackAss
AWW 06A-906-461L or LX for MAF
Check wiring from knock sensor to engine ecu.
Knock sensor could be faulty or incorrect TQ/contamination between surface of sensor or possible bad engine ecu.
vdubdezl
SC
C?ID=192065
I torqued the sensor when I replaced it. I read that it is supposed to have an AWW but my sticker says it's an AWP. Would that be the same part number for the MAF? The block was very clean before I put the sensor on.
vdubdezl
SC
C?ID=192065
verified MAF is correct. I don't know what pin numbers the ECM uses for the knock sensor so I will have to find them since I can't pay for a Bently right now. Do the wires from the knock sensor run to the connector behind the battery? I know that is where the VSS ran to and that is where I repaired the wire for it.
vdubdezl
SC
C?ID=192065
I finally got time to get back to this today and checked the wiring to ECM. I pulled everything apart to get to the ECM pins and had no continuity. I pulled the plastic lock (the piece from the connector to the wire loom) off and both wires were pulled out of the connector. I had pulled on it before and they were tight. So I got them out, soldered them in, and reinstalled everything. I test drove it with no CEL on, but it still has the sputtering issue. I have an extra MagnaFlow cat I bought for another car that I might try as a possible solution.
NostraJackAss
Is there any misfires during sputter in VCDS 0x01-08-014 ?
Check or run enhanced grounds to the coil packs.
Check grounds at ECU and under battery mount cover.
vdubdezl
SC
C?ID=192065
Checked the grounds under battery and at ECM when I had both apart.
I can see the ground wires cracking near the coil packs.
How do I check this VCDS 0x01-08-014? Is this a measuring block I can look at?? I'm just not familiar with this.
vdubdezl
SC
C?ID=192065
Thanks guys. This is very helpful!
vdubdezl
SC
C?ID=192065
Ran the test tonight and this is what I have now. Not an active code, but still in there. It never made the CEL come on from this. Also, when I was looking for the misfires, it showed the engine load at 123% wide open in 5th at 60. It also showed a misfire detected on cyls 1, 2, & 3, but didn't keep it in the log. I guess I will have to troubleshoot this code now.
Tuesday,27,May,2014,19:14:55:29190
VIN: License Plate: WOLFSBURG
Mileage: 121724 Repair Order: 4
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-10 - - Intermittent
Readiness: 0000 0001
Address 01: Engine (06A 906 032 DL)
19:14:17 Group 014: Ignition (Misfire Recognition)
760 /min Engine Speed
27.1 % Engine Load
0 Misfire (total)
Enabled Misfire recognition
19:14:17 Group 015: Misfire Recognition
0 Cylinder 1
0 Cylinder 2
0 Cylinder 3
Enabled Malfunction Recognition
19:14:17 Group 016: Misfire Recognition
0 Cylinder 4
Bin. Bits
NostraJackAss
Ok you have a boost leak......log block 0x01-08-115 look at request vs actual
Look for torn pipes cracked/boots torn, intercooler and go find the leak, bad waste-gate, N75 noid or faulty DV valve or the controller via the noid under intake for the diverter.
Foaming glass cleaner and a rev of engine helps find leaks.
You are also in need of firmware update.......
vdubdezl
SC
C?ID=192065
Thanks for the info and will update my firmware also. I have checked for boost leaks a few weeks back when it blew off the boost hose right in front of the tire. I made up a pressure regulator and pressurized the intake side like several people have on vwvortex. I found several other leaks and repaired them, but won't hurt to check again. Maybe the wastegate. I might try checking it with my Mighty-vac.
