When I bought my 2008 R8 in USA, its tpms functionality was disabled. I was sorting out few other things and now have time to address tpms issue.
So it seems that tpms was deleted from module '17- Instruments' and in module '65-Tire Pressure' the adaptation channel 1 was set to zero. Even though car' tpms sensors were removed at that time, there was no tpms warning on the screen because tpms was deleted in '17- Instruments'.
So I changed coding for '17- Instruments' from 0069272 to 0085272 and for module '65-Tire Pressure' I changed the adaptation value of channel 1 from 0 to 1. And now I am getting tpms malfunction error in the dash. Then I bought aftermarket tpms sensors which were 433 Mhz models and pre-programed for 2008 R8. After I installed the tpms sensors, I took the car to a local tire shop where they used Autel tpms tool to activate the sensors. Their tool picked up all 4 sensors and recognized that tpms sensors are compatible with that particular vehicle.
However this year of R8 has no tpms relern or reset procedure after tpms sensor is changed. Car is supposed to autodetect the new sensors after driving for 10-20 minutes. I have been driving the car for 1 week but tpms warning has not gone away. VCDS scan showed that tpms module still has IDs of factory tpms sensors stored and it is trying to communicate with old factory sensors.
1) Do I need to change any other setting than what I did in '17- Instruments' & '65-Tire Pressure' modules to enable tpms functionality?
2) I am wondering if there is a procedure in VCDS where I can force tpms module to 'start looking' for new sensors IDs instead of keep looking for old sensors IDs?
3) Is there any way to update MBVs in the tpms module so that I can restore/flash IDs of new tpms sensors to the tpms module?
Thanks for reading.
Measuring Block Values form TPMS module:
Thanks for reading.
Saturday,07,March,2026,20:38:25:42728
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4671.4
VIN: WUAAU34268N004626 License Plate:
Mileage: 121070km-75229mi Repair Order:
Chassis Type: 42 (1K0)
Scan: 01 03 08 09 0F 11 31 14 15 16 17 19 25 37 42 46 47 52 56 65
6C 76 77
VIN: WUAAU34268N004626 Mileage: 121070km-75229miles
Address 01: Engine ( ) Labels:. 079-910-560-BYH1.clb
Part No SW: 420 910 560 A HW: 420 907 560
Component: 4.2L V8/4V FSI ª0100
Revision: 5DH06--- Serial number: AUX7Z0H0FNF0R2
Coding: 01100009180F0120
Shop #: WSC 08354 444 84041
VCID: 0C41B57A7A4139EAE2B-8058
VINID: 9E54519431021887800041821856D96042
Address 03: ABS Brakes Labels: 420-910-517.lbl
Part No SW: 420 907 379 HW: 420 614 517 D
Component: ESP8 quattro H01 0200
Coding: 0000258
Shop #: WSC 02197 785 00200
VCID: 59EF9C2E85131C42A9D-800C
Address 08: Auto HVAC Labels: 420-820-043.clb
Part No SW: 420 820 043 C HW: 420 820 043 C
Component: J255 Klima 1 Zone 0070
Revision: 00H04005 Serial number: 00000001076483
Coding: 1572904
VCID: 0A4DB362703527DAD07-805E
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 L HW: 8P0 907 279 L
Component: Bordnetz-SG H45 1901
Revision: 00H45000 Serial number: 00000008004823
Coding: F4041E83C01424000B0000000A800000000000005B06D282000000000000
Shop #: WSC 02556 785 00200
VCID: 46D5475224AD83BAF4F-8012
Subsystem 1 - Part No: 423 955 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiR8 H22 0040
Coding: 00022802
Shop #: WSC 02556
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0002
Coding: 00154418
Shop #: WSC 02556
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0241749
Coding: 0000100
VCID: 33330E86473F0612431-8066
Reset counter: 221
Mileage: 120554 km
Date: 2026.01.05
Time: 20:03:00
Address 11: Engine II Labels:. 079-910-560-BYH2.clb
Address 14: Susp. Elect. Labels: 8P0-907-376.lbl
Part No SW: 420 910 376 HW: 420 907 376
Component: J250 Raddaempfung 0080
Revision: --H13--- Serial number: 190DPH 7306002
Coding: 0000062
VCID: 50F9610AD6E95D0A5E3-8004
Address 15: Airbags Labels: 420-959-655.lbl
Part No SW: 420 959 655 HW: 420 959 655
Component: SN Airbag 9.43 H01 0020
Revision: 93H01002 Serial number: 003B80004PY%
Coding: 0021326
VCID: 5DE7883E913BE062C55-8008
Subsystem 1 - Part No: 8J0 910 339 A
Component: BF-Gewichtsens. H02 0030
Subsystem 2 - Serial number: 01JNT
Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†63328RB403465C5DQÿ†63
Subsystem 5 - Serial number: 65C5DQÿ†63428RB403465BD8Tÿ†63
Subsystem 6 - Serial number: 65BD8Tÿ†63747RB40369997D$ÿ†63
Subsystem 7 - Serial number: 9997D$ÿ†63847RB403699EBC5ÿ
Subsystem 8 - Serial number: 99EBC5ÿ
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004041
Shop #: WSC 01236 785 00200
VCID: 41DF544E0D83A482C1D-8014
Component: E0221 H06 0030
Address 17: Instruments Labels: 420-920-xxx-17.clb
Part No SW: 420 920 980 E HW: 420 920 980 E
Component: KOMBIINSTR. VDO H35 0160
Revision: D0H35002 Serial number: 2240H002100222
Coding: 0085272
Shop #: WSC 08354 067 57207
VCID: 176BDA163387CA325F9-8042
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 P HW: 1K0 907 951
Component: J533__Gateway H16 0192
Revision: H16 Serial number: 2500K0831681FD
Coding: AB881F0F5047024100
Shop #: WSC 08214 444 58965
VCID: 34310D9A4231012A5AB-8060
Revision: D0H35002 Serial number: AUX7Z0H0FNF0R2
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 423 035 192 F HW: 423 035 192 F
Component: RNS-E US H13 0260
Revision: 06S Serial number: AUZBZ7H3900016
Coding: 0710677
VCID: 1373AE06277FE612231-8046
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
Reset counter: 226
Mileage: 120554 km
Date: 2026.01.05
Time: 20:03:08
Mileage: 120630 km
Count: 901
Clock: 19:10
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX1.lbl
Part No: 420 959 801
Component: Tuer-SG H02 0060
Coding: 0001141
VCID: 56F59712F40D333A84F-8002
Address 46: Central Conv. Labels:. 8J0-959-433.lbl
Part No: 8J0 959 433 C
Component: KSG H11 0080
Coding: 1B90228001382D090F0FC88A0473
VCID: 36353792544D133A64F-8062
Address 47: Sound System Labels: 420-035-223.lbl
Part No SW: 420 035 223 D HW: 420 035 223 A
Component: J525 Amp High H14 0230
Revision: 00H14001 Serial number: 34842000519004
Coding: 0246111
VCID: 094F8C6E75332CC2D9D-805C
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX1.lbl
Part No: 420 959 802
Coding: 0001141
VCID: 57EB9A16F3070A329F9-8002
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0710677
Reset counter: 226
Mileage: 120554 km
Date: 2026.01.05
Time: 20:03:08
Mileage: 120630 km
Count: 901
Clock: 19:10
Address 65: Tire Pressure Labels: None
Part No SW: 420 910 273 HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0030
Revision: 00050030 Serial number: 00000700002937
Coding: 0462426
Shop #: WSC 01405 444 59564
VCID: 4CC1757A3AC179EA22B-8018
Fault Status: 11100100
Reset counter: 249
Mileage: 121075 km
Date: 2026.03.06
Time: 15:11:31
(no units): 0.0
Voltage: 13.80 V
(no units): 61.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
02214 - Tire Pressure Warning
Reset counter: 0
Mileage: 121075 km
Date: 2026.03.06
Time: 15:11:31
(no units): 0.0
Temperature: 25.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 6C: Back-up Cam. Labels: 420-910-441.clb
Part No SW: 420 910 441 HW: 7L6 907 441 C
Revision: --H13--- Serial number: 525PA8-J7Z603M
Coding: 1000412
VCID: 49CF4C6E35B36CC219D-801C
02203 - Audio / Video Input 1
Reset counter: 221
Mileage: 120554 km
Date: 2026.01.05
Time: 20:02:48
Reverse OFF
Count: 3
Address 76: Park Assist Labels: 8P0-919-283.lbl
Part No SW: 8P0 919 283 B HW: 8P0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: 00H12000 Serial number: 00067767830730
Coding: 0000251
VCID: 3A2D23A26055F75A807-806E
Part No SW: 8P0 862 335 R HW: 8P0 862 335 R
Component: FSE_255x BT H26 0350
Revision: 00000000 Serial number: 00000005057040
Coding: 0011477
VCID: 45D7405E19AB88A2FD5-8010
End----------(Elapsed Time: 01:26, VBatt start/end: 12.4V/12.4V)-----------
------------------------------7 Faults Found-------------------------------
;SW:420-910-273 HW:4F0-907-273-A --- Tire Pressure ;Component:Reifendruck 3 H05 0030 Coding:0462426 ;Saturday March 20:40:47:42728 ;VCDS Version: Release 25.3.2 (x64) Data version: 20250822 DS365.0 ;VCID: 4CC1757A3AC179EA22B-8018 Group Field 1 Data type Field 2 Data type Field 3 Data type Field 4 Data type no Value 2.40 bar Pressure no Value N/A N/A 1.401.934.561 Status 00h no Value 2.40 bar Pressure no Value N/A N/A 1.401.890.850 Status 00h no Value 2.40 bar Pressure no Value N/A N/A 1.401.909.567 Status 00h no Value 2.40 bar Pressure no Value N/A N/A 1.401.930.618 Status 00h no Value 2.40 bar Pressure no Value N/A N/A 0.000.000.000 Status 00h 1.521.033.749 Status 01h UB. iO 2.42bar 0448 0001 0001 00 00 00 D8F3 0.100 V Voltage 2.240 V Voltage 0.080 V Voltage 2.180 V Voltage 8E0907277 Voltage 8E0907277 Voltage 1401930618 1401909567 1401890850 1401934561 0000000000 0000000000 0000000000 0000000000 0000000000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 Enabled 41.00 s Time (no units) ERROR 0.0 km/h Speed ABS 1 0 /min RPM Engine 1 23.5 C Temperature HVAC 1 Term 15 On 12.30 V Voltage 2-Wire N/A N/A N/A Door Closed ON N/A
[td width="26.9889%"]
7
[/td]
[td]
2026
[/td]
[td]
[/td]
[td]
[/td]
[td]
3
[/td]
[td]
4
[/td]
[td]
5
[/td]
[td]
6
[/td]
[td]
7
[/td]
[td]
8
[/td]
[td]
9
[/td]
[td]
10
[/td]
[td]
11
[/td]
[td]
12
[/td]
[td]
13
[/td]
[td]
14
[/td]
[td]
15
[/td]
[td]
16
[/td]
[td]
17
[/td]
[td]
20
[/td]
[td]
21
[/td]
[td]
22
[/td]
[td]
40
[/td]
[td]
41
[/td]
[td]
42
[/td]
[td]
50
[/td]
[td]
51
[/td]
[td]
52
[/td]
[td]
255
[/td]
[td]
125
[/td]
[td]
126
[/td]
[td]
127
[/td]
[td]
130
[/td]
