Nothing of the above worked out
Please explain what you did and how you did it. Making statements like this is not helpful.Nothing of the above worked out
Don’t take notice of anything I say after around 7pm…It doesn't hurt lad just surprised by your stupid comment considering your a professional business. It's a small world kidda
sometimes you have to try connecting, disconnecting, connecting and reading. not always the correct contact is made with the eeprom pinsFF FF means no read at all. Note Unless you modified the CH341A programmer you will not get a good read as that programmer is setup for 5v logic out of the box. Some have a jumper pin to switch between 3.3v logic and 5v logic. Note most automotive eeproms uses 3.3v logic. Also note majority of those cheap china programmers have a fatal flaw and a nasty bug where voltage levels on data lines remain at 5V despite the programmer being set to 3.3V. Usually a physical modification of the board is necessary. No need to remove any resistor, I read these on the bench without the need to open them, then again my tools are much different than what you have as I do this type of work on the daily.
I am well aware yes, but this is also the reason why it's best practice to alway remove eeprom from the board.sometimes you have to try connecting, disconnecting, connecting and reading. not always the correct contact is made with the eeprom pins
We use essential cookies to make this site work, and optional cookies to enhance your experience.
