Fuel Pump Adaptation 3.2FSI - new user
bojanmw
C?ID=271169
Hi all, brand new to ross-tech and just used my brand new HEX-USB+CAN do some basic adaptations since I'm getting 12.5mpg around the city in my 2008 A6 C6 3.2FSI. The only question I had was regarding the fuel pump adaptation, I followed the instructions from http://wiki.ross-tech.com/wiki/index...WA)#Adaptation
The instructions are:
Fuel Pump
Prerequisites:
Ignition ON
Engine ON
System voltage at least 11.0 V.
[Select]
[01 - Engine]
[Basic Settings - 04]
Group 103
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
Wait until Field 4 shows "ADP. O.K.".
[Done, Go Back]
Switch Ignition OFF.
Now the fuel pump field 4 never shows ADP.O.K. instead it shows "ADP Run" only when clicking on on/off/next. Are the above instructions correct? Or is the fuel pump continuously adjusting and thats why it never shows ADP.O.K? Because when monitoring vehicle in real time the field 4 will either show OFF or ADP Run. Please advise I'm hoping that the above instructions are incorrect and that I didn't put my fuel pump in some sort of continuous adaptation loop. Thanks in advance!
Andy
Sector 7G
HC424490
I don't think this procedure is meant to be used to address poor fuel economy but rather when replacing the fuel pump. Please post a complete AutoScan though, so we can see the details of your car.
Keithuk
Stoke on Trent, England
C?ID=122432
Welcome to the forum.
This is a double post and the Adaption link doesn't work in your other post so it may as well be deleted. ;)
As with all problems/query you ALWAY post a full AutoScan of the vehicle in question whether there are any error codes or not, as there is more system info in there. How to post an Auto-Scan
Moving this to Car Repair Support, and the duplicate thread has been deep-sixed.
DrPeter
16.4905° S, 151.7375° W
- How are calculating the fuel economy?
This Ross-Tech wiki page maybe more applicable to your concerns.
Fuel Trim Info
- When replacing the HPFP(High Pressure Fuel Pump), the factory repair manual does not state the need for any adaptations and Andy is correct, this procedure would not be used (if applicable) to correct fuel economy.
The Ross-Tech wiki page you linked above is specifically for the 2.0l TFSI (AXX/BGB/BPJ/BPY/BWA) engines, some information may or may not apply to other engines.
- You maybe able to try the BS-103 test again, this time see if you can raise the engine rpm a little, if the accelerator pedal has no response, when the Basic Setting is [On], try again, this time depress the brake pedal and hold, while depressing the accelerator pedal to the floor , the ECM should regulate the engine speed and the test should complete. I have not done this in a while so the afore mentioned procedure may not apply.
Hope this helps,
drpeter
bojanmw
C?ID=271169
Thanks for the replies everyone, this looks like an amazing forum and awesome product! Sorry for posting 2 separate threads.
I will post the AutoScan as soon as I can.
The fuel economy was calculated per the old school miles driven/gallons of fuel, so I didn't use the on board computer for the data.
The idea was to perform throttle adaptation and then I got carried away. There are couple of reasons really why I wanted to perform throttle adaptation, one was due to the poor gas mileage, and the other was due to sluggish response or delay from mashing the pedal to getting a reaction from the engine. This seems to be common problem for the C6 and I have read that throttle adaptation corrects this issue. I should mention that I never noticed this with the car in the 2 years I owned it, mostly because I was doing 99% of driving on the highway, I got a new job thats about 5 miles each way and I'm starting to notice things mentioned above - I mean it could it be possible that 12.5mpg is to be expected for such a short run, but all the research I did came up with 15 mpg as the lowest figure, and according to fueleconomy.gov 18mpg is what this car is supposed to do in the city.
The initial monitoring of the fuel pump operation shows 5BAR and about 22% (I'll post all the details), and this changes when the gas pedal position is changed so clearly everything is working fine, really my only concern was that ADP OK was not being displayed as per the directions. So I thought maybe I screwed up, or the instructions were like mentioned previously for installation of the new pump only.
Five miles each way, starting with the engine cold, and in winter... I hate to say it, but I don't think that 12.5 mpg is indicative of a problem under these circumstances.
bojanmw
C?ID=271169
Yea Uwe I was starting to guess that too, might need to get a beater around town! Interestingly enough my brother drives 3.9L V8 Lincoln LS and his trips are about 12 miles each way and he is getting about 16mpg. Thats why I was thinking combined with the slow engine response that either my throttle was out of whack or the transmission is not learning.
12 miles each way is a LOT more than 5 miles each way when the trip begins with a cold start in winter.
Gone But Not Forgotten
I would make sure your MAF/IAT/MAP/ECT are functioning correctly and inspect plugs for maybe a leaky injector or the burn quality followed by compression check and leak down.
Check oil sump for fuel contamination by smelling the stick if supported or oil fill area.
bojanmw
C?ID=271169
Here is Autoscan:
Thursday,18,February,2016,17:36:55:10154
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WAUDH74FX8N14xxxx   License Plate:
Mileage: 184090km-114388mi   Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 36 37 42 46 47 4F
          52 53 55 56 61 62 65 72 77
VIN: WAUDH74FX8N143891   Mileage: 184090km-114388miles
Address 01: Engine (AUK)       Labels: 06E-910-559-BKH.lbl
   Part No SW: 4F2 910 559 H    HW: 4F1 907 559 E
   Component: 3.2l V6 FSI         0040
   Revision: --H21---    Serial number:
   Coding: 01050109190F0120
   Shop #: WSC 07109 444 08081
   VCID: 31697F32A80EF0B6C1-8064
   Part No SW: 4F5 910 156     HW: 09L 927 156 C
   Component: AG6 09L 3.2 FSI USA 0010
   Revision: --H04---    Serial number:        4448680
   Coding: 0000002
   Shop #: WSC 02325 785 00200
   VCID: 65C1DB62AC466C16ED-8030
Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
   Part No SW: 4F0 910 517 AD    HW: 4F0 614 517 AA
   Component: ESP8 quattro    H01 0070
   Coding: 0020895
   VCID: 66C3DC6E5140670EE4-8032
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0240
   Revision: 07020801    Serial number: 10601901059667
   Coding: 0000003
   Shop #: WSC 03010 002 1048576
   VCID: 63C5C57AA272122603-8036
   Subsystem 1 - Part No: 4F0 910 131 J
   Component: FBSAUDIC6 EZS   H46 0080
   Subsystem 2 - Part No: 4F0 910 220 A
   Component: FBSAUDIC6 IDG   H01 0054
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
   Part No SW: 4F0 910 732 C    HW: 4E0 035 729
   Component: Interfacebox    H43 4140
   Revision: 00000000    Serial number: 303DL087561228
   Coding: 0000003
   Shop #: WSC 02335 785 00200
   VCID: 2345857AE2F2522643-8076
   Component: Bedienteil MMIC6H01 0060
   Subsystem 2 - Serial number: 00000001055983
   Subsystem 3 - Serial number: 0117.04.080000000100010945ÿ
   Subsystem 4 - Serial number: 010945ÿ
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043 A    HW: 4F1 820 043 AG
   Component: KLIMABETAETIGUNGH30 0020
   Revision: 00000053    Serial number: 00000030350025
   Coding: 0532518
   VCID: 1C37BE86DF8C6DDE82-8048
   Part No SW: 4F0 910 279 K    HW: 4F0 907 279
   Component: ILM Fahrer      H18 0250
   Coding: 0012123
   Subsystem 1 - Part No: 4F1 910 113 C  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H06 0210
   Coding: 00064784
   Shop #: WSC 07109
   Subsystem 2 - Part No: 4E0 910 557 B  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0100
   Coding: 00146221
   Shop #: WSC 07109
Address 0E: Media Player 1 (R192)       Labels: 4E0-035-785.lbl
   Part No SW: 4E0 035 785 B    HW: 4E0 035 785 B
   Component: SG ext.Player H15 0700
   Revision: 00000000
   VCID: 275D916A56CABE061F-8072
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 K    HW: 4E0 035 593 F
   Component: SDAR SIRIUS     H07 0140
   Revision: 00000000    Serial number: AUZ4Z7H0318669
   Coding: 0000100
   VCID: 2F6D794ABE3AE646D7-807A
            000 -  -
                    Reset counter: 133
                    Mileage: 184094 km
                    Date: 2016.02.18
                    Time: 17:35:27
Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
   Part No SW: 4F0 910 655 F    HW: 4F0 959 655 A
   Component: 6N AIRBAG AUDI8RH30 0300
   Revision: 15H30000    Serial number: 00359D0GFP55
   Coding: 0013902
   VCID: 2A5B685E85D8836E00-807E
   Subsystem 1 - Part No: 4F0 910 339 B
   Component: BF-Gewichtsens. H03 0060
   Subsystem 2 - Serial number: 6332CSME3A14401F%
   Subsystem 3 - Serial number: 6342CSME3A14420A$
   Subsystem 4 - Serial number: 6352QSME5F4F4675
   Subsystem 5 - Serial number: 6362QSME657013314
   Subsystem 6 - Serial number: 63734SME60577715$
   Subsystem 7 - Serial number: 63834SME5D191A233
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0410
   Revision: 00H03000    Serial number: 90055080970016
   Coding: 0002041
   Shop #: WSC 02324 785 00200
   VCID: 275D916A96CABE061F-8072
   Component: E0221           H02 0030
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4F0 920 983
   Component: KOMBIINSTR. M73 H23 0240
   Revision: 00000000    Serial number: 72X77YN48
   Coding: 2065288
   Shop #: WSC 40548 001 1048576
   Coding: 2065288
Address 19: CAN Gateway        Labels: 4L0-910-468.clb
   Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
   Component: J533__Gateway   H06 0060
   Revision: 00H06000    Serial number: 1100B084208171
   Coding: E5D59E77703A0600
   VCID: 2D516342B4369456E5-8078
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 C    HW: 4E0 035 110 A
   Component: MP3-Changer     H46 0350
   Revision: 00046007    Serial number: AUZ5ZBH8395158
   VCID: 183FA2962BB401FEA6-804C
   Part No SW: 4F0 910 760     HW: 4F0 959 760
   Component: Sitzmemory FS   H04 0050
   Revision: 00000000    Serial number: 00000000896400
   Coding: 0082946
   VCID: 61C9CF72B86E003611-8034
   Part No SW: 4E0 910 888 F    HW: 4E0 919 887 M
   Component: MNS US          H51 0990
   Revision: 00000000    Serial number: 395DU087513616
   Shop #: WSC 07117 444 84047
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 793 E
   Component: TSG FA          H12 0210
   Revision: 00000000    Serial number: Ye
   Coding: 0035563
   Shop #: WSC 02327 785 00200
   VCID: 2C576E468F2C9D5EF2-8078
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Part No SW: 4F0 910 289 J    HW: 4F0 907 289 J
   Component: Komfortgeraet   H27 0220
   Revision: 02200027    Serial number: 01112068690000
   Coding: 4619293
Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
   Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
   Component: DSP-High C6     H10 0240
   Revision: PROD_01     Serial number: 00000000087050
   Coding: 0000016
   VCID: 25419B62ECC6AC162D-8070
   Part No SW: 4F0 910 280     HW: 4F0 907 280 C
   Component: ILM Beifahrer   H12 0100
   Revision:             Serial number: 00000000185291
   Coding: 0002014
   VCID: 5EB3F48E89103FCE2C-800A
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 792 E
   Component: TSG BF          H12 0210
   Revision: 00000000    Serial number: p&e
   Coding: 0035563
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
   Component: EPB  CDEC0080   H04 0080
   Revision: --H04---
   Coding: 0005022
   Shop #: WSC 02145 785 00200
   VCID: 204F8A76F3E4493E5E-8074
   Part No: 8P0 907 357 H
   Coding: 0000003
   VCID: 3F8D290A6E5A16C647-806A
   Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 394D+087893365
   Coding: 0000002
   VCID: 2E53644EB930EF4EDC-807A
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 F    HW: 4F0 915 181 B
   Component: J0644 BEM       H12 0760
   Revision: 00000000    Serial number: 00000000072807
   VCID: 24478666E7FC551E3A-8070
   Subsystem 1 - Part No: 4F0 915 105 D
   Component: von VA0  2804250369
   Coding: 344630393135313035442056413032383034323530333639
   Shop #: WSC 00000 512 00290
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 795 E
   Component: TSG HL          H21 0210
   Coding: 0035370
Address 65: Tire Pressure        Labels: 4F0-910-273-BA.lbl
   Part No SW: 4F0 910 273 B    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05 0100
   Revision: 00050100    Serial number: 00000700071609
   Coding: 0062221
   VCID: 224B807EFDE85B2E48-8076
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
   Component: TSG HR          H21 0210
   Coding: 0035370
   Part No SW: 4F0 910 336 E    HW: 4E0 862 335
   Component: Handyvorb2      H18 0950
   Revision: 00000000    Serial number: 00000005031211
   Coding: 0010900
End-------------------------(Elapsed Time: 02:58)--------------------------
and here is what I'm talking about the pump, its constantly adapting or it goes off but it never says ADP OK
So I was concerned that I might have screwed something up or this is actually correct function displayed. Thanks everyone!
bojanmw
C?ID=271169
Thanks Jack at European Parts, but maybe I wasen't very clear. Outside of what I mentioned before the car works perfectly fine, the kickdown engages properly, its shifts smoothly at takeoff after the 1-2 second delay, the engine has no issues at all that would indicate anything wrong with it other than the mileage and the sluggishness in the city driving. From everything that I read out there as it pertains to C6 and this issue in particular everything points to either throttle adaptation, or looking to see whats the latest version of trans software. Trans software would be my next guess since in the city driving situations the car seems to hold the gears for longer than necessary. So in other words if throttle is out of whack and trans shift points are an issue than I think I'm on the right track.
Sure until it carbons up, from running real rich even inherently stock.........
Run the test in basic settings active in one block 0x01-04-103 ON
You can also select a gear before turning on in a parking lot and give slight gas such as Peter aforementioned.
This is known as forcing a test ADP while in operation and not just idle.......this can also be done in command of other readiness tests.
With the exception of a few such as kick down and TV ETC.
Bojan emailed asking us to confirm or deny if the BS > 103 > [On/Off/Next] > Test Off and ADP Run results were normal.
Although I do not have access to a (4F) 3.2FSI in good working order to test on ...I would not consider that normal. Generally, when a FSI engine uses a G410 LP fuel sensor in conjunction with a G247 HP fuel sensor BS group 103 applies. Basic Setting results such as ADP OK -or- Syst. OK are the most common indications that a test ran and passed successfully.
I would check some of the things mentioned above (such as fuel trim, carbon, cleanliness of TB, etc) and pull the spark plugs, check air filter/maintenance items to see if that resolves the fuel economy or performance. If it looks like the engine is lean you may want to check the low side fuel pressure with a gauge to confirm something close to 6.0 bar (key on, engine off) is reaching the engine compartment. If you test low side fuel pressure at idle it may vary between 5 and 5.5 bar based on the on-time command from the FPCM which is seen in MVB 106.
bojanmw
C?ID=271169
Thanks Dana, looks like the ADP Run is the normal function for the 3.2FSI Engine
http://forums.ross-tech.com/showthread.php?918-2007-audi-A6-low-fuel-pressure
Scroll down to post #5 - just want to point this out in case anyone else came across my post
I appreciate everyone's help, it doesn't appear that anythings wrong with my car or indicating that there are underlying issues - I ran the fuel pump adaptation by mistake and that resulted in this post because I was looking for clarification. As to the surging from the start this is common issue with the 3.2FSI and I didn't do my homework before looking for possible reasons, and the low fuel econ is to be expected as per Uwe's post because I'm making very short trips and with lower vap point of winter fuel blend what I'm experiencing is the expected 15-20% drop in mpg.
cheers!
If doing those short trips.......... it is advised you change the oil more frequent...........:popcorn:
bojanmw
C?ID=271169
Full synthetic every 10k :cool:
That's crazy..........Get ready for a big surprise.
A NostraJackAss Quatrain............
How does the poor engine deal with fuel in the diluted synthetic oil over 10K; & with short baby trips.......?
I hope you take it out on the highway, to burn off the water and vapors in the block weekly.
I will get you started.
bojanmw
C?ID=271169
Ok thanks for sharing. I have a catch-can, and did a ton of research on synthetic oils to know the many advantages of it and I also send my oil for full chemical analysis every 2nd interval - doesnt cost me anything either.
Cool......... sounds like bullshit, however, than again .......so does some of the stuff I shoot my mouth off about....:p
