Comfort module 46 - Long coding helper almost empty?
epicx
Romania
C?ID=197347
Hello support.
I have a 2012 Passat and my module coding helper displays very little helpful information. Here is the module:
Address 46: Central Conv. Labels: 3C0-959-799-46.clb
Part No SW: 3AA 959 799 C HW: 3AA 959 799 C
Component: 02 KESSY PQ47 090 0359
Revision: 00090000 Serial number: VWZCZ000000000
Coding: 0091020052C30E76340C94157E004F0B605801030434B8
Shop #: WSC 05311 000 00000
VCID: 489FAEAC3B21077EDE-801C
The following Bytes have ZERO help on them: 1 3 4 5 20 21 22
Also very limited help is available on: 2 9 18
None of these bytes is "empty" so I am wondering how come there is no useful information for us to be able to decode the programmed features?
Thanks!
It is not realistic to expect every bit of every byte in current model cars to be fully documented. The info simply isn't available, not even in the dealers' tools.
Is there something in particular you are trying to accomplish and can't?
epicx
Romania
C?ID=197347
Thanks Uwe, i am trying to add the electric power trunk closing, already have all the hardware, need to find the bit to change to enable. so far i haven't found anything...
Just for clarity: This is the same car you have an Auto-Scan posted from here?
I fixed your location so people don't think this is a US (NMS) Passat -- those are rather different than RDW Passats.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Your new coding incl. Virtual Pedal (ViP) should be 0091020052C30E76340C94157E004F0B605801030437B8. Please note, not all Comfort Control Modules (CCM) may support this option! A properly coded ViP Control Module will show as a new LIN Slave / Subsystem. If it keeps saying "ViP not mounted" and you're certain you did the hardware right, it's most likely your CCM which doesn't contain the necessary Dataset/Firmware.
FWIW, I have enhancing the related label file on my todo-list.
epicx
Romania
C?ID=197347
Yes, thank you.
epicx
Romania
C?ID=197347
Sebastian, i am guessing by virtual pedal you are referring to the two sensors in the bumper for hands free opening. please note this is NOT required for power trunk, it has a separate PR number, 4E7 is the power trunk, 4E6 is the sensor controlled power trunk. i am not looking to install the sensor pair only the actuators and electric latch mechanism. does this info change the coding in 46?
epicx
Romania
C?ID=197347
Just so we can track progress, this is my 46 reading as of now, have not started any work on the retrofit yet.
Subsystem 4 - Component: ViP n.mounted
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Sorry, I got confused. You're correct, Easy Open aka. Virtual Pedal (ViP) and Electric Rear Lid isn't the same. Please post the complete Auto-Scan and revert your #46 Coding back to the original, we should be able to provide the proper Coding then. There's only a minor change necessary the CCM coding if I remember correctly, but we need to see the full picture/Auto-Scan to be certain.
epicx
Romania
C?ID=197347
Here is the full scan, NO modifications have been operated to any of the module codings except 52-Driver door to enable auto fold mirrors.
VIN: WVWZZZ3CZDE0xxxxx   Mileage: 97110km-60341miles
Address 01: Engine (J623-CFGB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 PC    HW: 03L 907 309 AE
   Component: R4 2,0L EDC   H27 4011
   Revision: 41H27---    Serial number: 00000000000000
   Coding: 001D003A046601080000
   Shop #: WSC 00015 115 00000
   ASAM Dataset: EV_ECM20TDI01103L906018PC 003005
   ROD: EV_ECM20TDI01103L906018NT.rod
   VCID: 7AFB0464FD4DA5EE18-802E
   Part No SW: 02E 300 015     HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3521
   Revision: 05551213    Serial number: 00001209181639
   VCID: 50AF86CCC371CFBE86-8004
   Part No SW: 3AA 614 109 BL    HW: 3AA 614 109 BL
   Component: J104   C2 450M VE8C 0024
   Revision: --H07---    Serial number: 00000006300231
   Coding: 0122303
   VCID: 78FF1E6C0B41B7FE6E-802C
   Part No SW: 3AA 907 044 AJ    HW: 3AA 907 044 AJ
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 0014004803
   VCID: 78FF1E6CC341B7FE6E-802C
Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
   Part No SW: 3AA 937 087 H    HW: 3AA 937 087 H
   Component: BCM PQ47 H+   421 0465
   Revision: BC421001
   Coding: 000A000000000000009C00887400297423D50088676DAD60E480C7240049
   VCID: 3F8DB570AEEF40C66F-806A
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 19091  10  0603
   Coding: 00B795
   Component: RLS 101012 05  54  0403
   Coding: 02302A
Address 10: Park/Steer Assist (J791)       Labels: 3AA-919-475.clb
   Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0025
   Revision: --------    Serial number: 56261228300981
   Coding: 348306
   ASAM Dataset: EV_EPHVA2C000000000 002008
   ROD: EV_EPHVA2C000000000_SE36.rod
   VCID: 4487BA9CCF09231E32-8010
Address 13: Auto Dist. Reg        Labels: None
   Part No SW: 3AA 907 567 A    HW: 3AA 907 567
   Component: AC201  RDW A    036 0170
   Revision: 00036000    Serial number: 00000000563751
   Coding: 0010000
   Shop #: WSC 05311 000 08193
   VCID: 387FDE6C4BC177FEAE-806C
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 05101205190002
   Coding: 030180
   Shop #: WSC 05314 000 00000
   VCID: 275D0D10567FE80637-8072
   Part No SW: 5N0 959 655 T    HW: 5N0 959 655 T
   Component: J234__11R VW10 HI   2118
   Revision: 24017000    Serial number: 003LDPM3ZWJ1
   Coding: 0012626
   VCID: 4E9398B4D945D94E94-801A
   Subsystem 1 - Serial number: 6332MTS640372542
   Subsystem 2 - Serial number: 6342MTS679892542
   Subsystem 3 - Serial number: 6351HTS6AJK5FBKR
   Subsystem 4 - Serial number: 6361HTS6QI5SEBKR
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C9 953 501 BM    HW: 5K0 953 569 T
   Revision: FF010041    Serial number: 20121011200391
   Coding: 399AA50001
   VCID: 75E11758D453CA9675-8020
   Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
   Component: E221__MFL-TK6  H07 0022
   Coding: E30000
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3AA 920 880 H    HW: 3AA 920 880 H
   Component: KOMBI         H05 0505
   Coding: 161F01
   Shop #: WSC 05314 115 00000
   VCID: 387FDE6C83C177FEAE-806C
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 7N0 963 272 C
   Component: Standheizer     044 4840
   Revision: 00044000    Serial number: 09024302000000
   Coding: 0031032
   VCID: 3561D7585CD38A96B5-8060
   Part No SW: 7N0 907 530 AE    HW: 7N0 907 530 AE
   Component: J533  Gateway H46 1633
   Revision:   H46       Serial number: 081012F1000853
   Coding: 462006
   VCID: 73E52940D227D4A65B-8026
   Part No SW: 0BS 907 554 C    HW: 0BS 907 554 C
   Component: Haldex 4Motion      4016
   Coding: 0000005
   VCID: 4683A0943135110E2C-8012
   Component:    IMMO         090 0404
   Revision: A1001003    Serial number: 7663616953
   Coding: 010100
   VCID: 2A5BF424456DD56E28-807E
   Part No SW: 1T0 035 680 H    HW: 1T0 035 680 H
   Component: RNS-MID       H72 4120
   Revision: AB001001    Serial number: VWZ6Z7P7069043
   Coding: 04010002010000A02011
   Shop #: WSC 00001 001 1048576
   VCID: 3365E94092A794A69B-8066
   Component: EU West V8  7690
   Part No SW: 3AA 907 566 C    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0010
   Revision: 00H02000    Serial number: 6PZ 010 316-09
   Coding: 0000172
   VCID: 3979DB6870CB6EF651-806C
   Subsystem 1 - Part No: 3AA 907 568 C
   Component: J0770_SWA_Slave_H02 0010
   Subsystem 2 - Serial number: 6PZ 010 316-29
   Subsystem 3 - Serial number: 5F11.10.1200H020003C931086ÿ
   Subsystem 4 - Serial number: 931086ÿ
02853 - Warning Lamp for Lane Change Assistance (in left exterior mirror) (K233)
                    Fault Status: 00101010
                    Fault Frequency: 18
                    Reset counter: 180
                    Mileage: 94344 km
                    Date: 2012.01.01
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0533
   Revision: 12110009    Serial number: 0005852770
   Coding: 0210FF
   Shop #: WSC 05311 115 00000
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 3561D75894D38A96B5-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3AA 959 703 B    HW: 3C8 959 794
   Component: J388__TSG-HL  004 0503
   Serial number: 00000003103658
   Coding: 0100D8
   Part No SW: 5N1 909 144 N    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.337 1101
   Revision: 1AH03735    Serial number: 00122860042701
   Coding: 0000258
   VCID: 3D71CF7864E352D67D-8068
   Part No SW: 5K0 035 456 C    HW: 5K0 035 456 C
   Component: KonzernAmp 8K H07 0202
   Revision: --------    Serial number: EAA086A0019776
   ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003
   ROD: EV_AudioVerst10KanalBNO1.rod
   VCID: 2A5BF4244D6DD56E28-807E
Address 4C: Tire Pressure II
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AE
   Component: EZE_2         H46 1633
   Coding: 050B0508
   VCID: 6FED2530BE0FF046BF-803A
   Component: J245EE20SKB13  H03 0220
   Component: J394EE20SKB13  H03 0220
   Subsystem 3 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0004
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0533
   Revision: 14110009    Serial number: 0005876404
   Coding: 0210FE
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 3663D05489D5818EBC-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3AA 959 704 B    HW: 3C8 959 795
   Component: J389__TSG-HR  004 0503
   Serial number: 00000003158429
   Coding: 0100D8
   Revision:   H19       Serial number: 00000000504642
   Coding: 0022167
   VCID: 3663D05441D5818EBC-8062
Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
   Component: AFS-ECU       H04 0111
   Coding: 02BA00104F000200
   ROD: EV_HeadlRegulVWAFSPt_SK46.rod
   VCID: 377DDD508EDF7886A7-8062
   Subsystem 1 - Part No SW: 3D0 941 329 C    HW: 3D0 941 329 C  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H04 0012
   Coding: 2C0000
   Subsystem 2 - Part No SW: 3D0 941 329 C    HW: 3D0 941 329 C  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H04 0012
   Coding: 2C0000
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AE
   Component: Batt.regelung H46 1633
   Coding: 330F1859
   VCID: 71E92348A83BE6B6A9-8024
   Component: J367-BDM  H07 0180
   Part No SW: 3C9 907 441     HW: 3C9 907 441
   Component: J772__Rearview      0020
   Revision: 00H11000    Serial number: 525PA8-J292848
   Coding: 0020007
   VCID: 68DF4E2C5BE1277EFE-803C
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 C    HW: 3C8 035 730 C
   Component: Telefon       012 0822
   Revision: --------    Serial number: 35909603471010
   Coding: 020004000100111100000000
   ASAM Dataset: EV_UHVPremi A02705
   ROD: EV_UHVPremi_SE36.rod
   VCID: 234519002A4704266B-8076
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3AA-980-654.clb
   Part No SW: 3AA 980 654 D    HW: 3AA 980 654 A
   Component: MFK_Gen1      H08 0300
   Serial number: 0185624257
   Coding: 010102000102020D0200040000010000
   ASAM Dataset: EV_47X 001639
   ROD: EV_47X.rod
   VCID: 3979DB68B8CB6EF651-806C
End-------------------------(Elapsed Time: 05:16)--------------------------
PS. We should probably move this thread to Retrofit section and rename it :)
epicx
Romania
C?ID=197347
Just received a document from a friend of mine, stating 46 - Byte 2, Bit 3 has to be set to 1 to enable PR 4E7. Would you be able to confirm? Long coding helper does not show any information for this bit.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Correct, that would have been my suggestion as well. This isn't explicitly related to the electric rear lid, it's about how the lock is actuated (directly vs. soft touch).
epicx
Romania
C?ID=197347
Great news, appreciate the help. My last question regarding this - although it might be outside of VCDS realm - is whether tapping into CAN high and CAN low connections are mandatory for this retrofit to work? As per the factory wiring diagrams the right actuator is hooked up to the J519 CAN l / CAN h ports. Any insight would be more than helpful here :)
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Yes, this should (partially) explain why. ;)
Address 6D: Trunk Elect.
   Part No SW: 3AF 827 383 A    HW: 3AF 827 383 A
   Component: J605  HECKDECKEL    0860
   Revision: 00H52001
   VCID: 3A7B088C75D317EE7F-806E
   Subsystem 1 - Part No: 3AF 827 383 A
   Subsystem 2 - Part No: 3AF 827 384 A
   Component: J756  HECKDECKEL    0860
epicx
Romania
C?ID=197347
Again, thank you for your help, i will check back once i completed the retrofit.
