- May 20, 2015
- 63
- 18
- South Africa
- C?ID=163752
hi guys
car is a 2012 q5 3.0 v6 tdi
customer claims all three lights (dpf , mil and glowplug spiral) appears on dash every now and then ..car goes ino a limp.he takes it out on the open road for a few miles and then all is ok for a while...someone before me cleared all faults on the vehicle so Im assuming this thing just needs a dpf regen ..soot mass is measured 28g and calculated 21g ..I must say they are constantly rising..maybe the values were reset before I got vehicle? (also if someone could point out the difference between these values to me?measured vs calculated)
so I go into basic settings..elec loads on .engine idling etc
activate "service regen of particle filter" and all I get is "not running- 41.056" ..after some time it says "aborted safety reasons"
also tried doing it under adaption
enter security code given 27971..go to adaption..change value from 0 to 1 ...it then still says security access required
am I doing something wrong?
VCDS Version: Release 15.7.4 (x64) Running on Windows 7 x64
Data version: 20160216
Thursday,18,February,2016,17:09:00:48700
Chassis Type: 8R (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2E 42 46 47 52 53 55 56 62
72 77
VIN: WAUZZZ8RXAA108543 Mileage: 91900km-57104miles
Address 01: Engine (J623-CCWA) Labels: 059-907-401-V1.clb
Part No SW: 8R0 907 401 J HW: 8K1 907 401 A
Component: 3.0TDI EDC17 H07 0005
Revision: 15H07---
Coding: 0121002C240F0128
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_ECM30TDI0118R0907401J 001005
ROD: EV_ECM30TDI0118R0907401J.rod
VCID: 397F9563B8E7AEF679-806C
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 8R0 927 156 L HW: 0B5 927 156 E
Component: 0B5 30 TDIRdW H03 0002
Revision: --H03--- Serial number: 0000000748
ASAM Dataset: EV_TCMDL501 A02044
ROD: EV_TCMDL501.rod
VCID: 4481F497CF25E31E1A-8010
Address 03: ABS Brakes (J104) Labels: 8R0-907-379-V1.clb
Part No SW: 8R0 907 379 L HW: 8R0 907 379 L
Component: ESP8 quattro H07 0010
Coding: 0F1540
VCID: 499FE5A3E0073E76E9-801C
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
Component: BCM2 1.1 H02 0328
Coding: 011500
VCID: 010F3D8398B7363671-8054
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H50 0070
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Part No SW: 8T2 820 043 AF HW: 8T2 820 043 AF
Revision: D0000000 Serial number: 01270420100009
Coding: 36050000
VCID: 76E55E5FC179018E54-8022
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
Component: BCM1 1.0 H29 0380
Revision: 09029001 Serial number: 00000000657695
Coding: 2600D0914034AF010001000000001D0D0F1D470802010141000000
VCID: 3A7D8A6FB5E1A5EE70-806E
Subsystem 1 - Part No SW: 8R2 955 119 A HW: 8R2 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 100318 H10 0041
Coding: 01DD13
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 024D25
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 R HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0070
Revision: 11001001 Serial number: 50941012312210
Coding: 100105
VCID: 4899E0A7FB0DC77EF6-801C
Address 15: Airbags (J234) Labels: 8R0-959-655.clb
Part No SW: 8R0 959 655 C HW: 8R0 959 655 C
Component: AirbagVW-AU10 H39 0560
Serial number: 003FQD0F253$
Coding: 30433331313030303030554A305238523053
ROD: EV_AirbaAU10SMEAU416.rod
Serial number: 6334MSME5322184FD
Serial number: 6344MSME5274351AB
Serial number: 6352QSME145E331CK
Serial number: 6362QSME3B5E0734P
Serial number: 63732SME6D5D57229
Serial number: 63832SME025E5632.
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90315JE40006Z
Coding: 000037
VCID: 3D778173A4CF92D655-8068
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels: 8R0-920-xxx-17.clb
Part No SW: 8R0 920 930 D HW: 8R0 920 930 D
Component: KOMBIINSTR. H11 0255
Revision: 00400000 Serial number: CJL24DX4A
Coding: 2F06220002000008010000
VCID: 356799539CFF4A969D-8060
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0117
Revision: GB800053 Serial number: 5300G1042581D5
Coding: 00C303
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0140
Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
Part No SW: 8T0 035 785 A HW: 8T0 035 785
Component: SG ext.Player H08 0290
Revision: 00000000
Coding: 020202
VCID: 397F9563B0E7AEF679-806C
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000010589955
Coding: 011D02204001440004
VCID: 4587E993CC1FDA160D-8010
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0129746982
Coding: 013A0622203904140520053280000000
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H01 0220
Subsystem 4 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H01 0220
Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
Part No SW: 8R0 035 223 F HW: 8R0 035 223 E
Component: DSP STD H11 0440
Revision: 00000000 Serial number: 00000000000001
Coding: 0203010102
VCID: 2F6BAB3B7EA37046D7-807A
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000010574429
VCID: 4481F497C725E31E1A-8010
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000628203
VCID: 3461A4579785539EAA-8060
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H02 0010
Coding: 0000006
Shop #: WSC 06334 000 00000
VCID: 3461A4575785539EAA-8060
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T2 035 186 P HW: 8T2 035 186 P
Component: Concert3 H06 0350
Revision: 00000010 Serial number: AUZ5Z6J1397789
Coding: 0402008201058D00035B070800
Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
Component: Display
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000103831930
Coding: 010C02204001240004
VCID: 428DF28FDD31ED2E28-8016
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000103831927
Part No SW: 8T0 862 335 D HW: 8T0 862 335 D
Component: FSE_256x BT H39 0600
Revision: 00000000 Serial number: 00000005186934
Coding: 0010390
VCID: 3B738F6B7ADB9CE66B-806E
End-------------------------(Elapsed Time: 03:12)--------------------------
