VW Sharan AdBlue heater problem
automech
Poland
C?ID=14925
I'm having following DTC on VW Sharan 2.0TDI:
9656 - Control Circuit for Reductant Tank Heating
P202B 00 [101] - Short to GND
According to WD, this means something is wrong with the Z102 element which heats up the reductant in tank, so I dissasembled the rear left mudguard, check the connectors, voltages, also I swaped procesor mounted to the tank which controls AdBlue tank elements, efect is the same, fault stored.
Things I checked so far:
Fuses- OK
Wiring from ECU to processor, done by VAS procedure- OK
Processor- OK (swaped unit reacts same as original)
Heating element Z102 resistance- 10 Ohms??? (other two, the Z103/Z104 4.7 Ohms)
Tommorow I'm disassembling rear bumper to get to the harness of the tank to take a look at it, I don't think that the problem is the heating element itself, but I don't have more ideas.
Does any of you came across with same problem? Or maybe the 10 Ohm resistance means that the heater is faulty?? Please help if anyone have some ideas.
Wednesday,17,February,2016,22:04:06:49923
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
Workshop Code: 444 00001 012345
VIN: WVWZZZ7NZBV034466   License Plate:
Mileage: 270380km-168006mi   Repair Order:
Chassis Type: 7N (7N0)
Scan: 01 03 05 08 09 10 15 16 17 18 19 25 2B 37 42 44 46 52 53 56
          61 62 6D 72 BE BF
VIN: WVWZZZ7NZBV034466   Mileage: 270380km-168006miles
37-Navigation -- Status: Cannot be reached 1100
BE-Sliding Door Rear Left -- Status: OK 0000
BF-Sliding Door Rear Right -- Status: OK 0000
Address 01: Engine (J623-CFFA)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 H    HW: 03L 907 309 Q
   Component: R4 2,0L EDC   H24 9958
   Revision: 44H24---    Serial number:
   Coding: 0019001A042401080000
   Shop #: WSC 08744 001 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018H 003009
   ROD: EV_ECM20TDI01103L906018F_VW36.rod
   VCID: 2F677AC076DE4F46D8-807A
                    Mileage: 270389 km
                    Date: 2016.02.17
                    Time: 21:59:20
Address 03: ABS Brakes        Labels: 7N0-614-109.clb
   Part No SW: 7N0 614 109 M    HW: 7N0 614 109 M
   Component: J104   C3 450M VDDF 0009
   Revision: --H07---    Serial number: 00000003919780
   Coding: 0018967
   Shop #: WSC 00020 790 00000
   VCID: 377742A0468E878680-8062
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Part No SW: 5K0 959 434 A    HW: 5K0 959 434 A
   Component: VWKESSYPQ35GP 085 0802
   Revision: 00085000    Serial number: 0144933323
   Coding: 03100C
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_KESSY_PQ35GP A01018
   ROD: EV_KESSY_PQ35GP.rod
   VCID: 336F76B09AF66BA6BC-8066
   Part No SW: 5K0 907 044 F    HW: 5K0 907 044 F
   Component: Clima-Sharan  H11 0104
   Coding: 0000000109
   ROD: EV_ClimaAutoSharaBasis_VW36.rod
   VCID: 2E5967C471D4464ED3-807A
   Slave 1:
   Subsystem 1 - Part No SW: 7N0 907 049 B    HW: 7N0 907 049 B
   Component: KBT-H  004 0102
   Serial number: 20110315000000018777
   Part No SW: 5K0 937 084 F    HW: 5K0 937 084 F
   Component: BCM PQ35 B    011 0046
   Revision: BA011001
   Coding: 40590A3B89251AC0500800C0140000E443511308466D29F264808720A2C1
   VCID: 356B48A89C82759692-8060
   Subsystem 1 - Part No SW: 7N1 955 119 A    HW: 7N1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    110314  31  0031
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
   Component: RLFS  021 0022
   Coding: 0380BB
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 8
                    Reset counter: 223
                    Mileage: 270285 km
                    Date: 2016.02.16
                    Time: 10:34:00
                    Voltage: 12.35 V
                    Fault Status: 00101010
                    Reset counter: 8
                    Mileage: 270316 km
                    Date: 2016.02.17
                    Time: 10:32:42
                    Voltage: 11.80 V
Address 10: Park/Steer Assist (J446)       Labels: 1Q0-919-475.clb
   Part No SW: 7N0 919 475     HW: 7N0 919 475
   Component: PARKHILFE 8K  H04 0010
   Revision: --------    Serial number: 28291106336352
   Coding: 108001
   ASAM Dataset: EV_EPHVA18VW4280000 001005
   ROD: EV_EPHVA18VW4280000.rod
   VCID: 78F5819CC31048FE49-802C
   Part No SW: 7N0 959 655 B    HW: 7N0 959 655 B
   Component: VW10Airbag012 H07 0013
   Serial number: 003GFP49A152
   Coding: 003132
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01002
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 3E795784A1B4B6CE43-806A
   Serial number: 3493ETS6097A3BB13DD5
   Serial number: 3503ETS6069B9C313DD$
   Serial number: 3513ETS60BCA0BB13DD2
   Serial number: 3523ETS6077D8C3139D,
   Serial number: 35540TS60B7D6B413DDX
   Part No SW: 5K0 953 501 BM    HW: 5K0 953 569 L
   Revision: FF010040    Serial number: 20110316300463
   Coding: 1102240000
   VCID: 76E98FA4C9043E8E5B-8022
   Coding: E20000
   Part No SW: 7N0 920 870 A    HW: 7N0 920 870 A
   Coding: 140F00
   VCID: 306579BC6BE050BEC1-8064
   Part No: 7N0 963 271 C
   Component: Zuheizer        051 2730
   Revision: 00051000    Serial number: 09022126000000
   Coding: 0000111
   Shop #: WSC 12234 778 12300
   VCID: 346D75AC57F86C9EA5-8060
   Part No SW: 7N0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H35 0614
   Revision:   H35       Serial number: 270311F2001580
   Coding: 468002
   VCID: 31637CB868EA59B6CE-8064
                    Reset counter: 218
                    Mileage: 270285 km
                    Date: 2016.02.16
                    Time: 10:17:34
01304 - Radio
                    Fault Frequency: 25
                    Reset counter: 7
                    Mileage: 270285 km
                    Date: 2016.02.16
                    Time: 10:19:41
   Component: IMMO          H20 0420
   Coding: 000007
   VCID: 6AD1ABD48DBCEA6ECF-803E
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000077906001
   Coding: 4100000000000000
   ROD: EV_ELVMarquMPVW36X.rod
Address 37: Navigation
Address 42: Door Elect, Driver (J386)       Labels: 7N0-959-793.clb
   Part No SW: 7N0 959 793 E    HW: 7N0 959 793 A
   Component: TSG FA        H04 0400
   Revision:             Serial number: 0000113752277
   Coding: 01113E20D000411011
   VCID: 448D256CC758DC1E15-8010
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.323 0802
   Revision: 1AH03729    Serial number: 00110690116601
   Coding: 0000258
   VCID: 3B7F5E907AA6A3E664-806E
Address 52: Door Elect, Pass. (J387)       Labels: 7N0-959-792.clb
   Part No SW: 7N0 959 792 E    HW: 7N0 959 792 A
   Component: TSG BF        H04 0400
   Revision:             Serial number: 0000113732962
   Coding: 01113E20DE00411011
   VCID: 438F2670C256DB262C-8016
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000249979
   Coding: 0024066
   VCID: 336F76B052F66BA6BC-8066
Address 56: Radio
   Component: Batt.regelung H35 0614
   Coding: 030B185A
   VCID: 71E3BCB8A86A19B68E-8024
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
Address 62: Door, Rear Left (J388)       Labels: 7N0-959-794.clb
   Part No SW: 7N0 959 794 F    HW: 7N0 959 795 B
   Component: TSG HL        H03 0400
   Revision:             Serial number: 0000113867786
   Coding: 01007C200000411001
   VCID: 46893F64F164EE0E0B-8012
Address 6D: Trunk Elect. (----)       Labels: 7N0-959-107.clb
   Part No SW: 7N0 959 107 B    HW: 7N0 959 107 A
   Component: HDSG-Modul    H11 0803
   Revision: 41011001    Serial number: 069100188
   Coding: 0733334002
   ASAM Dataset: EV_HDSGVW428 201133
   ROD: EV_HDSGVW428_SE36.rod
   VCID: 36694FA489847E8E9B-8062
Address 72: Door, Rear Right (J389)       Labels: 7N0-959-794.clb
   Component: TSG HR        H03 0400
   Revision:             Serial number: 0000113649907
Address BE: Sliding Door Rear Left (J558)       Labels: 7N0-959-244.clb
   Part No SW: 7N0 959 244     HW: 7N0 959 244
   Component: Schiebetuer_l 005 2213
   Serial number: 11037024
   ASAM Dataset: EV_AST A03002
   ROD: EV_AST.rod
Address BF: Sliding Door Rear Right (J731)       Labels: 7N0-959-244.clb
   Component: Schiebetuer_r 005 2213
   Serial number: 11036793
   ROD: EV_AST.rod
End-------------------------(Elapsed Time: 03:42)--------------------------
Gone But Not Forgotten
Get WD and trace wiring to reluctant sensor.........verify short to ground.
Further take variable resistor, and simulate a sensor while observing VCDS blocks and DTC memory being able to be cleared.
FYI : Reluctant likes to crystalize and becomes conductive crating false shorts.
automech
Poland
C?ID=14925
I took off the tank, AdBlue is clear, no crystalisation. I have measured all wires on the tank, checked the car wiring once again, nothing. Any other ideas?? Change whole tank???
automech
Poland
C?ID=14925
I think, I found the source of problem, if it confirms, I'll let know tommorow.
And yes, if processor is unplugged the codes change to open circuit.
