Octavia 3 2015 1.4 tsi 16434 - Charge Pressure Control Actuator P334B 00 - Mechanical Malfunction
freemanjack
London, UK
C?ID=631727
Car driving absolutey fine but keeps throwing a bunch of of codes, sometimes after a few miles, sometimes straight away
Monday,23,February,2026,19:03:09:20291
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4671.5
VIN: TMBKC7NE5G0041361   License Plate:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: TMBKC7NE5G0041361   Mileage: 192537km-119636miles
Address 01: Engine (J623-CZDA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HD    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H22 2325
   Revision: R7H22---    CVN: 4B2C1D94
   Coding: 01190032232419080000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM14TFS01104E906027HD 001004
   ROD: EV_ECM14TFS01104E906027HD.rod
   VCID: 6D8015F9FD150A52555-8038
   VINID: 91D49B4C77951570001010C604481D924D
          P334B 00 [11101000] - Mechanical Malfunction
                    Mileage: 192520 km
                    Date: 2026.02.23
                    Time: 14:26:31
                    Engine speed: 470.00 /min
                    Normed load value: 12.9 %
                    Vehicle speed: 5 km/h
                    Coolant temperature: 75 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 12.392 V
                    Charge pressure actuator: specified position: 140.00 %
                    Bypass valve f high press turboch turbine inlet: actual value: 96.67 %
                    Charge pressure actuator: adaptation for lower stop: 2621.2 mV
                    Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 0
                    Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 55
                    Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 66
                    Bypass valve for high press turboch turbine inlet: uncond volt: 2529.8 mV
Readiness: 0010 0001
   Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
   Component: ESC           H32 0393
   Revision: 00000000    Serial number: 61755000000145
   Coding: 1C078A912424296D007A060641C4243851249400608224F200230070C002
   Shop #: WSC 73430 031 00063
   VCID: 4BC4BB61A341E4622B1-801E
   Part No SW: 5E0 907 044 Q    HW: 5E0 907 044 Q
   Component: Climatronic   H04 1002
   Revision: 00001K07
   Coding: 02110004000100011005000000101000
   ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 3334C381DBB19CA2431-8066
   Air quality sensor:
   Part No SW: 5Q0 937 086 AH    HW: 5Q0 937 086 AH
   Revision: --------    Serial number: 86581806151444 Dataset Number: 5E0063t____ 0072
   Coding: 0F000842424702FB07A04082B10407280000000000000000000000000000
   Shop #: WSC 73430 790 00000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 005E5C4DDA87F73A8E3-8054
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 150528  041 0570
   Serial number:         150608153800
   Coding: 065DDD
   Component: RLHS  037 0059
   Serial number: S3Y15M06D30H06M54S47
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY151042PXD
   Serial number: 00000000000062587408
   Humidity sensor: interior:
   Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0054
   Revision: --------    Serial number: 39291516904791 Dataset Number: 5E0039t____ 0001
   Coding: 0001050001
   VCID: 3C26E8BDF6EF53DA92B-8068
   Part No SW: 3Q0 959 655 AS    HW: 3Q0 959 655 AS
   Component: Airbag VW20   013 0200
   Revision: --------    Serial number: 003SQPCAMGS+ Dataset Number: 5E0003t____ 0057
   Coding: 98CCC000000000005C5400CC008800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 0F7C6F7197D99842079-805A
   Subsystem 1 - Part No SW: -----------    HW: 454 001 506 15
   Serial number: 3576U00000066090C413
   Subsystem 2 - Part No SW: -----------    HW: 454 001 506 15
   Serial number: 3586U00000047B20051$
   Subsystem 3 - Part No SW: -----------    HW: 454 801 406 15
   Serial number: 3516RDBEA2807000000L
   Subsystem 4 - Part No SW: -----------    HW: 454 802 206 15
   Serial number: 3526RCD532D07000000C
   Subsystem 5 - Part No SW: -----------    HW: 454 801 505 15
   Serial number: 3556V4DA354060000009
   Part No SW: 5Q0 953 521 M    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20150630400418
   Coding: 1400
   ROD: EV_SMLSVALEOMQB.rod
   Part No SW: 5E0 920 980 B    HW: 5E0 920 980 B
   Component: KOMBI         206 7640
   Coding: 27A40A002180A60001082A001000000000000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 009005
   ROD: EV_DashBoardJCIMQBAB_009_SK37.rod
   VCID: 280E24ED1277EF7AE63-807C
16777024 - Function Restricted due to Interrupted Communications
          U1110 00 [00001000] - -
          [BAP_BCME_0x23 keine Kommunikation]
                    Reset counter: 160
                    Mileage: 192537 km
                    Date: 2026.02.23
                    Time: 17:36:23
   Part No SW: 5Q0 907 530 AE    HW: 5Q0 907 530 E
   Component: GW MQB Mid    127 1224
   Revision: --------    Serial number: 0003670077 Dataset Number: 5E0067t____ 0030
   Coding: 030100042F085700EB000248080F00010001050000000000000000000000
   GVL: 01543C0000000000400C00000000480000000000000000000000000000000000
   ROD: EV_GatewLear_013_VW37.rod
   VCID: 74B6009D9E3FDB9A9AB-8020
   Generator:
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000D0657180615
   Subsystem 3 - Part No SW: 5Q0 915 181 F    HW: 5Q0 915 181 F
   Component: J367-BDM  H08 0223
   Serial number: 52173M52334291331444
   Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
   Component: TSG FS        010 0032
   Serial number: 0000156374922  Dataset Number: V03935252QV 0001
   Coding: 001000208001040000001100
   Shop #: WSC 42209 002 1048576
   VCID: 45D08D5985251212FD5-8010
   Serial number: 00000000000006526330
   Coding: 1D0200
65593 - Switch for Central Locking
          B122D 29 [00001001] - Signal Implausible
                    Reset counter: 118
                    Mileage: 192519 km
                    Date: 2026.02.22
                    Time: 17:44:09
   Component: EPS_MQB_ZFLS  125 1061
   Dataset Number: 5E0074t____ 0018
   Coding: 8103
   VCID: 43D493418B112C22D31-8016
   Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
   Component: TSG BFS       010 0032
   Serial number: 0000156627981  Dataset Number: V03935252QY 0001
   VCID: 44D6905D8E1F2B1AEAB-8010
   Serial number: 00000000000006619254
   Coding: 050200
   Part No SW: 5Q0 035 842 A    HW: 5Q0 035 842 A
   Component: MU-S-D-ER     H24 0241
   Serial number: SKZAZ2R8638183 Dataset Number: 5E0CV1t____ 0247
   Coding: 03730200FF00000011111201008800002F0200C60120010002
   Shop #: WSC 73430 790 00063
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 2D00D5F93D95CA52155-8078
   Subsystem 1 - Part No SW: 5E0 919 605 H    HW: 5E0 919 605 H
   Component: ABT_Std-2  H41 1028
   Serial number: SKZ8Z9RBS00A74
7203 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [Efficiency program (0x23) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 158
                    Mileage: 192519 km
                    Date: 2026.02.22
                    Time: 17:39:27
                    Voltage terminal 30: 12.5 V
                    BAP-BAP_Function_ID: 0D
1637 - Interface for External Media
          U11B8 00 [00001000] - No Communications
          [USB - communication error]
                    Reset counter: 160
                    Mileage: 192527 km
                    Date: 2026.02.23
                    Time: 15:41:06
                    Interface for external media: status-Status: Open circuit
End----------(Elapsed Time: 01:29, VBatt start/end: 12.8V/12.8V)-----------
------------------------------5 Faults Found-------------------------------
[CODE/]
Dr Sheldon
Windsor UK
C?ID=334979
P334B 00 [11101000] - Mechanical Malfunction MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
I would guess that the Control Actuator is lazy or stiff - You need to test it and know how it has failed.
freemanjack
London, UK
C?ID=631727
I was kinda suspecting the mechanical side more than the electrical, this skoda is really very tidy for its age, I don't get the sense that much of any of it is particularly worn. Would you know if it can be operated from vcds to be able to establish where the fault is likely to be?
Dr Sheldon
Windsor UK
C?ID=334979
Not a bad shout - The DTC
16434 - Charge Pressure Control Actuator P334B 00 [11101000] - Mechanical Malfunction
Is shouting from the rooftops that it could be a Mechanical Malfunction !!!
Look in output tests
They are dogshit - Very common failure !
Is it Electric or Vacuum operated ? Is the feedback sensor internal or ?
Dr Sheldon
Windsor UK
C?ID=334979
That fault is set at cranking before the engine has properly fired up !!
freemanjack
London, UK
C?ID=631727
It has what looks to be a motor drive with an electical harness, not seen any vac tubes but thought I'd read it used both? I looked in output tests and tried the 'exhaust bypass' as it was the only possibly likely candidate, the rest in the dropdown list were fuel or fans but it returned a command refused notice. (words to that effect)
Dr Sheldon
Windsor UK
C?ID=334979
I am no expert on why VCDS refused your wishes.
One way or another you will need to make it operate and measure both the feedback signal and the current required to operate the component.
Firing 12v up it's shirt would not be the right thing to do !
freemanjack
London, UK
C?ID=631727
Just looked back thru a few previous scans and looks to be triggered under 600rpm but pretty sure I've had it throw a code at highway speeds
Dr Sheldon
Windsor UK
C?ID=334979
Not all use both but some do - Establish what you have first.
Dr Sheldon
Windsor UK
C?ID=334979
The good thing with that is that the fault can be replicated in the workshop - Hence easy to fix.
freemanjack
London, UK
C?ID=631727
So, these are 3 days worth of scan output for the boost controller;
          P334B 00 [11101101] - Mechanical Malfunction
                    Mileage: 192462 km
                    Date: 2026.02.20
                    Time: 16:56:34
                    Engine speed: 540.00 /min
                    Normed load value: 13.3 %
                    Vehicle speed: 2 km/h
                    Coolant temperature: 92  C
                    Intake air temperature: 39  C
                    Voltage terminal 30: 12.934 V
                    Bypass valve f high press turboch turbine inlet: actual value: 89.44 %
                    Charge pressure actuator: adaptation for lower stop: 2701.0 mV
                    Bypass valve for high press turboch turbine inlet: uncond volt: 2407.6 mV
                    Mileage: 192514 km
                    Date: 2026.02.22
                    Time: 12:30:53
                    Engine speed: 560.00 /min
                    Normed load value: 14.9 %
                    Coolant temperature: 42  C
                    Intake air temperature: 13  C
                    Voltage terminal 30: 12.510 V
                    Bypass valve f high press turboch turbine inlet: actual value: 90.81 %
                    Charge pressure actuator: adaptation for lower stop: 2645.2 mV
                    Bypass valve for high press turboch turbine inlet: uncond volt: 2388.0 mV
                    Mileage: 192520 km
                    Date: 2026.02.23
                    Time: 14:26:31
                    Coolant temperature: 75  C
                    Intake air temperature: 16  C
[CODE/]
freemanjack
London, UK
C?ID=631727
Looks like I was being a noob, found a helpful video says I was pressing the wrong buttons. Will try again on the morrow and report any findings. I'm very much feeling a little tappy tap tap on the wastegate lever is what is called for, I suspect my driving style might not provoke it into moving very often.
Also, while those might look like fault at cranking rpm, they are all actually on the move, just at very low speed, I'm not used to stop start engine management and have noticed my habit of slipping into nuetral while barely coasting in traffic seems to upset the computer.
freemanjack
London, UK
C?ID=631727
Shot a few seconds of video of the actuator rod looking to be doing actuation things, cleared the code and it has not reset yet. Any of you good people wanna cast an experienced eye over the vid and see if it looks actuatory enough to you (it certainly looks ok to me)
Dr Sheldon
Windsor UK
C?ID=334979
Videos are a waste of time !!
There you go !! I have said it again !
Dr Sheldon
Windsor UK
C?ID=334979
That video adds no value
We have no idea if that component is bolloxed or it is just not commanded correctly ??
A video cannot tell you that hence Good Garages and Master Technicians dont walk around with cameras !!
  • Disagree
freemanjack
London, UK
C?ID=631727
My endoscope doesn't record sound but the actuator rod appeared to be responding appropriately to sufficient revs and quick let offs, it seems to be the electrical unit, no sign of vacuum and it's general appearance was as new as is most of the car despite being high milage. Looking at those snapshots, I'm thinking it is my drivi9ng style triggering them;
Engine speed: 540.00 /min<br> Normed load value: 13.3 %<br> Vehicle speed: 2 km/h
Engine speed: 560.00 /min<br> Normed load value: 14.9 %<br> Vehicle speed: 5 km/h
Engine speed: 470.00 /min<br> Normed load value: 12.9 %<br> Vehicle speed: 5 km/h
I am in the habit of knocking cars into neutral just as I'm coming to a stop, I've got dodgy knees and holding the clutch on the floor can be damned painful at times so I habitually avoid it. Looking at those above numbers and the evident actuator, actuating and not throwing any new codes stood running, I'm thinking this might be a me thing and the computer just hates my driving!
freemanjack
London, UK
C?ID=631727
You were (of course) completely correct sir, the actuator was nfg, finally fully shat the bed a few weeks later, the servo or internal gears were partially seized, replaced with a OEM part for a reasonable cost, thanks and sorry if I frustrate you on occassion.
TTT
C?ID=547002
Freeze frame data had it all.
That's mid-scale for a standard position reference voltage.
freemanjack
London, UK
C?ID=631727
5v signal then? Is that a kinda baseline for a lot of the modules or are there a mix of signal voltages? I've done loads of digital control systems but always designed and built myself, never had cause to deal with this many ecu controlled modules.
Points ignition and drum brakes anyone?
No?
Just me then! :)
