Passat ABS code required
Ewan MacNee
C?ID=88042
Hi, was changing the rear pads on a 2010 passat & after finishing the ABS/ESP light was on. Turns out the ABS code has got wiped some how. Is there anybody here that can help or do i need to contact Ross Tech directly to get the correct ABS coding?
Many thanks.
here is a scan of the error
VCDS Version: Release 15.7.3 (x64) Running on Windows 7 x64
Data version: 20151216
Wednesday,17,February,2016,11:12:22:23326
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 62 72 77
VIN: WVWZZZ3CZAE182228   Mileage: 141200km-87737miles
Address 01: Engine (CBB)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 QF    HW: 03L 907 309
   Component: R4 2,0L EDC G000SG  6211
   Revision: 13H08---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 84224 036 682055
   VCID: 79FDB2B830824CF636-802C
   Part No SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
   Component: J104    C4 440 V2   0015
   Revision: --026---    Serial number: 00000705860542
   Coding: 0000000
   Shop #: WSC 05311 000 00000
   VCID: 62CFF5D4BD14AF2E07-8036
            000 -  -
                    Reset counter: 202
                    Mileage: 141208 km
                    Date: 2010.07.10
                    Time: 11:07:56
                    Hex Value: 0x0000
                    Voltage: 11.75 V
                    Bin. Bits: 00011111
                    Count: 149
                    Hex Value: 0x0000
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3C8 907 336 AG    HW: 3C8 907 336 AG
   Revision: 00009001
   Coding: 0000000002
   Shop #: WSC 05311 115 00000
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 72EF8594A5F43FAE77-8026
   Part No SW: 3C8 937 049 F    HW: 3C8 937 049 F
   Revision: 00H54000    Serial number: 00000003983731
   Coding: 01888F0700041A00470A00000F000000000C5D435C000120000000000000
   Shop #: WSC 05124 000 00000
   VCID: 3463438C5760719EA5-8060
   Subsystem 1 - Part No: 3C2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 310510 022  0612
   Coding: 00046997
   Shop #: WSC 05124
   Part No SW: 5N0 959 655 N    HW: 5N0 959 655 N
   Component: J234__006 VW10 HI   1916
   Revision: 21014000    Serial number: 003GHPBWLEAK
   Coding: 0012342
   VCID: 489B077C3BE8E57EF9-801C
   Subsystem 1 - Serial number: 6332MTS612081450
   Subsystem 2 - Serial number: 6342MTS624301470
   Subsystem 3 - Serial number: 6351HTS6V4S3A9KJ
   Subsystem 4 - Serial number: 6361HTS64684A9KJ
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C9 953 501 BN    HW: 5K0 953 569 AB
   Component: LENKS.MODUL   009 0135
   Revision: FF010036    Serial number: 20100622200502
   Coding: 1182270002
   VCID: 76E7B984C99C238E5B-8022
   Coding: E20000
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3C0 920 972 J    HW: 3C0 920 972 J
   Component: KOMBI         H03 0305
   Coding: 461F00
   Shop #: WSC 05314 115 00000
   VCID: 2D5556E87C4A2056EA-8078
Address 19: CAN Gateway        Labels: 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 Q    HW: 3C0 907 951
   Component: J533  Gateway   H13 0172
   Revision:   H13       Serial number: 3620P106150174
   Coding: F9807F06400602002003
   Shop #: WSC 05314 000 00000
   VCID: 2F694CE0BE465246D8-807A
   Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
   Component:    IMMO         043 0383
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: 7AFFADB4358447EE3F-802E
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
02861 - Electronic Steering Column Lock Check Sum Error
                    Reset counter: 225
                    Mileage: 139713 km
                    Date: 2010.07.01
                    Time: 10:48:45
Address 37: Navigation
   Part No SW: 3C0 959 701     HW: 3C0 959 793
   Component: TUER-SG FT    002 0306
   Revision: 13101005    Serial number: 0001032396
   Coding: 0002B5
   ROD: EV_DCU42BroseDriveSide.rod
   VCID: 65C5EEC8643AD816E2-8030
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0401
   Serial number: 00000001528851
   Coding: 000290
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 196    3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 316D4A98A87244B6CE-8064
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 043 0612
   Coding: 0191020051030E763004941570085FCE107C01
   Subsystem 1 - Part No: 1K8 951 605 A
   Component: LIN BACKUP HORN H11 9004
   Component: Neigungssensor  004 0611
   Part No SW: 3C0 959 702     HW: 3C0 959 792
   Component: TUER-SG BT    002 0306
   Revision: 15101005    Serial number: 0001044571
   Coding: 0002B4
   ROD: EV_DCU52BrosePasseSide.rod
   VCID: 66C7E9C4993CD30EEB-8032
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0401
   Serial number: 00000001535261
   Coding: 000290
   Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
   Component: J540 EPB3  VW-15417 0007
   Revision:   011       Serial number: 00000000320570
   Coding: 0000057
   VCID: 2C535BEC8F50295EFD-8078
Address 56: Radio
Address 77: Telephone (J738)       Labels: 1K8-035-730.clb
   Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
   Component: Telefon       H08 6900
   Revision: 00008000    Serial number: 00000A07896433
   Coding: 012120
   VCID: 2A5F5DF445A4376E0F-807E
End-------------------------(Elapsed Time: 02:28)--------------------------
You did a scan before you started the work, right?
If so, that scan was auto-saved to your Scans sub-folder....
Gone But Not Forgotten
Coding: 0002341 This one matched the part #and ecu part #
Coding: 0003370
Coding: 0000298
0002346
0010533
0000293
Ewan MacNee
C?ID=88042
I will look in the scan sub folder out of interest. I managed to get the code (0003365) from a customer who has a friend who works for VW so its sorted now. As a precaution we will take a note of the ABS number before doing any brake related work in case this happens again. Hopefully just a friday afternoon gremlin!
Ewan
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Proper coding for this car is indeed is 0003365.
Jef
HQ
As a precaution we will t̶a̶k̶e̶ ̶a̶ ̶n̶o̶t̶e̶ ̶o̶f̶ ̶t̶h̶e̶ ̶A̶B̶S̶ ̶n̶u̶m̶b̶e̶r̶ run a full Auto-Scan before doing any b̶r̶a̶k̶e̶ ̶r̶e̶l̶a̶t̶e̶d̶ work on VW/Audi vehicles, in case this happens again.
Fixed that for you. :)
And now to recycle a joke:
