Hello all.
Just recently I have tried to make the passenger mirror dip when in reverse but I am unable to enter the 09-Cent.elect. module security access. I found a thread for a Golf MK7 as there was no info for a Passat.
52 Passenger door
07 coding
Byte 4 -----------------< i dont have a byte 4...
Enable bit 2 and 3
THEN
09 Central Electronics
31347 -----------------< code not accepted
Adaptations
17-Access control 2 Spiegelabsenkung bei Rueckwaertsfahrt (change to “active”)
THEN
(22) Access control 2-Menuesteuerung Spiegelabsenkung (change to “active”)
this puts the option in the menu screen.
Here is the VCDS read for the car:
52 Passenger door
07 coding
Enable bit 2 and 3
THEN
Adaptations
THEN
Chassis Type: 3C (7N0)
Scan: 01 02 03 08 09 10 13 14 15 16 17 18 19 22 25 2E 37 3C 42 44
46 47 4C 4F 52 53 55 56 61 62 6C 72 77 A5
VIN: WVWZZZ3CZDE0XXXXXX Mileage: 97110km-60341miles
Address 01: Engine (J623-CFGB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 PC HW: 03L 907 309 AE
Component: R4 2,0L EDC H27 4011
Revision: 41H27--- Serial number: 00000000000000
Coding: 001D003A046601080000
Shop #: WSC 00015 115 00000
ASAM Dataset: EV_ECM20TDI01103L906018PC 003005
ROD: EV_ECM20TDI01103L906018NT.rod
VCID: 7AFB0464FD4DA5EE18-802E
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 015 HW: 02E 927 770 AL
Component: GSG DSG AG6 512 3521
Revision: 05551213 Serial number: 00001209181639
Shop #: WSC 05311 000 00000
VCID: 50AF86CCC371CFBE86-8004
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 BL HW: 3AA 614 109 BL
Component: J104 C2 450M VE8C 0024
Revision: --H07--- Serial number: 00000006300231
Coding: 0122303
VCID: 78FF1E6C0B41B7FE6E-802C
02214 - Tire Pressure Warning
Fault Frequency: 41
Reset counter: 180
Mileage: 95051 km
Date: 2015.10.09
Time: 09:30:40
Speed: 182.0 km/h
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 14.25 V
Bin. Bits: 00011111
Count: 185
Hex Value: 0x0000
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3AA 907 044 AJ HW: 3AA 907 044 AJ
Component: Climatronic H03 0303
Revision: 00001K02
Coding: 0014004803
VCID: 78FF1E6CC341B7FE6E-802C
9473137 - Motor for Left Temperature Flap
B108C 71 [008] - Actuator stuck
Reset counter: 173
Mileage: 95385 km
Date: 2016.01.26
Time: 14:49:39
9473393 - Motor for Right Temperature Flap
B108D 71 [008] - Actuator stuck
Reset counter: 173
Mileage: 95385 km
Date: 2016.01.23
Time: 09:47:15
9474161 - Motor for Defroster Flap
B1090 71 [008] - Actuator stuck
Reset counter: 173
Mileage: 95385 km
Date: 2016.01.26
Time: 14:49:39
9484401 - Motor for Indirect Ventilation Flap
B10B8 71 [008] - Actuator stuck
Reset counter: 175
Mileage: 95385 km
Date: 2016.01.26
Time: 14:49:39
Address 09: Cent. Elect. (J519) Labels: 3AA-937-087.clb
Part No SW: 3AA 937 087 H HW: 3AA 937 087 H
Component: BCM PQ47 H+ 421 0465
Revision: BC421001
Coding: 000A000000000000009C00887400297423D50088676DAD60E480C7240049
VCID: 3F8DB570AEEF40C66F-806A
Subsystem 1 - Part No SW: 3AB 955 419 HW: 3AB 955 419 Labels: 1KX-955-119.CLB
Component: Wischer 19091 10 0603
Coding: 00B795
Component: RLS 101012 05 54 0403
Coding: 02302A
Address 10: Park/Steer Assist (J791) Labels: 3AA-919-475.clb
Part No SW: 3AA 919 475 L HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0025
Revision: -------- Serial number: 56261228300981
Coding: 348306
ASAM Dataset: EV_EPHVA2C000000000 002008
ROD: EV_EPHVA2C000000000_SE36.rod
VCID: 4487BA9CCF09231E32-8010
Address 13: Auto Dist. Reg Labels: None
Part No SW: 3AA 907 567 A HW: 3AA 907 567
Component: AC201 RDW A 036 0170
Revision: 00036000 Serial number: 00000000563751
Coding: 0010000
Shop #: WSC 05311 000 08193
VCID: 387FDE6C4BC177FEAE-806C
00532 - Supply Voltage B+
Reset counter: 173
Mileage: 95378 km
Date: 2016.01.20
Time: 14:02:03
Count: 94
01316 - ABS Control Module
Fault Status: 00100001
Reset counter: 174
Mileage: 95388 km
Date: 2016.02.05
Time: 14:46:08
Count: 103
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0071
Revision: 00000000 Serial number: 05101205190002
Coding: 030180
Shop #: WSC 05314 000 00000
VCID: 275D0D10567FE80637-8072
Part No SW: 5N0 959 655 T HW: 5N0 959 655 T
Component: J234__11R VW10 HI 2118
Revision: 24017000 Serial number: 003LDPM3ZWJ1
Coding: 0012626
VCID: 4E9398B4D945D94E94-801A
Subsystem 1 - Serial number: 6332MTS640372542
Subsystem 2 - Serial number: 6342MTS679892542
Subsystem 3 - Serial number: 6351HTS6AJK5FBKR
Subsystem 4 - Serial number: 6361HTS6QI5SEBKR
Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb
Part No SW: 3C9 953 501 BM HW: 5K0 953 569 T
Revision: FF010041 Serial number: 20121011200391
Coding: 399AA50001
VCID: 75E11758D453CA9675-8020
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
Component: E221__MFL-TK6 H07 0022
Coding: E30000
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3AA 920 880 H HW: 3AA 920 880 H
Component: KOMBI H05 0505
Coding: 161F01
Shop #: WSC 05314 115 00000
VCID: 387FDE6C83C177FEAE-806C
Address 18: Aux. Heat Labels: 1K0-815-007.clb
Part No: 7N0 963 272 C
Component: Standheizer 044 4840
Revision: 00044000 Serial number: 09024302000000
Coding: 0031032
VCID: 3561D7585CD38A96B5-8060
Part No SW: 7N0 907 530 AE HW: 7N0 907 530 AE
Component: J533 Gateway H46 1633
Revision: H46 Serial number: 081012F1000853
Coding: 462006
VCID: 73E52940D227D4A65B-8026
Part No SW: 0BS 907 554 C HW: 0BS 907 554 C
Component: Haldex 4Motion 4016
Coding: 0000005
VCID: 4683A0943135110E2C-8012
01155 - Clutch
Fault Status: 00100011
Reset counter: 34
Mileage: 95397 km
Date: 2016.02.08
Time: 10:12:25
Part No SW: 3AA 959 799 C HW: 3AA 959 799 C
Component: IMMO 090 0404
Revision: 00090000 Serial number: VWZCZ000000000
VCID: 489FAEAC3B21077EDE-801C
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0546
Revision: A1001003 Serial number: 7663616953
Coding: 010100
VCID: 2A5BF424456DD56E28-807E
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 H HW: 1T0 035 680 H
Component: RNS-MID H72 4120
Revision: AB001001 Serial number: VWZ6Z7P7069043
Coding: 04010002010000A02011
Shop #: WSC 00001 001 1048576
VCID: 3365E94092A794A69B-8066
Component: EU West V8 7690
Address 3C: Lane Change Labels: None
Part No SW: 3AA 907 566 C HW: 4G0 907 566
Component: J769 SWA MasterH02 0010
Revision: 00H02000 Serial number: 6PZ 010 316-09
Coding: 0000172
VCID: 3979DB6870CB6EF651-806C
Subsystem 1 - Part No: 3AA 907 568 C
Component: J0770_SWA_Slave_H02 0010
Subsystem 2 - Serial number: 6PZ 010 316-29
Subsystem 3 - Serial number: 5F11.10.1200H020003C931086ÿ
Subsystem 4 - Serial number: 931086ÿ
02853 - Warning Lamp for Lane Change Assistance (in left exterior mirror) (K233)
Fault Status: 00101010
Fault Frequency: 18
Reset counter: 180
Mileage: 94344 km
Date: 2012.01.01
Time: 00:00:00
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0533
Revision: 12110009 Serial number: 0005852770
Coding: 0210FF
Shop #: WSC 05311 115 00000
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 3561D75894D38A96B5-8060
Slave Driver:
Subsystem 1 - Part No SW: 3AA 959 703 B HW: 3C8 959 794
Component: J388__TSG-HL 004 0503
Serial number: 00000003103658
Coding: 0100D8
Part No SW: 5N1 909 144 N HW: 5N1 909 148 G
Component: J500__APA-BS KL.337 1101
Revision: 1AH03735 Serial number: 00122860042701
Coding: 0000258
VCID: 3D71CF7864E352D67D-8068
Address 46: Central Conv. Labels: 3C0-959-799-46.clb
Component: 02 KESSY PQ47 090 0359
Coding: 0091020052C30E76340C94157E004F0B605801030434B8
Subsystem 4 - Component: ViP n.mounted
Part No SW: 5K0 035 456 C HW: 5K0 035 456 C
Component: KonzernAmp 8K H07 0202
Revision: -------- Serial number: EAA086A0019776
ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003
ROD: EV_AudioVerst10KanalBNO1.rod
VCID: 2A5BF4244D6DD56E28-807E
Address 4C: Tire Pressure II
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AE
Component: EZE_2 H46 1633
Coding: 050B0508
VCID: 6FED2530BE0FF046BF-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H03 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H03 0220
Subsystem 3 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
Component: Analoguhr 004 0004
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0533
Revision: 14110009 Serial number: 0005876404
Coding: 0210FE
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 3663D05489D5818EBC-8062
Slave Passenger:
Subsystem 1 - Part No SW: 3AA 959 704 B HW: 3C8 959 795
Component: J389__TSG-HR 004 0503
Serial number: 00000003158429
Coding: 0100D8
Revision: H19 Serial number: 00000000504642
Coding: 0022167
VCID: 3663D05441D5818EBC-8062
Address 55: Headlight Range (J745) Labels: 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 02BA00104F000200
ROD: EV_HeadlRegulVWAFSPt_SK46.rod
VCID: 377DDD508EDF7886A7-8062
Subsystem 1 - Part No SW: 3D0 941 329 C HW: 3D0 941 329 C Labels: 3D0-941-329.CLB
Component: LeiMo links H04 0012
Coding: 2C0000
Subsystem 2 - Part No SW: 3D0 941 329 C HW: 3D0 941 329 C Labels: 3D0-941-329.CLB
Component: LeiMo rechts H04 0012
Coding: 2C0000
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 AE
Component: Batt.regelung H46 1633
Coding: 330F1859
VCID: 71E92348A83BE6B6A9-8024
Component: J367-BDM H07 0180
02256 - Quiescent Current
Fault Status: 00110001
Reset counter: 174
Mileage: 95395 km
Date: 2016.02.05
Time: 21:14:28
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3C9 907 441 HW: 3C9 907 441
Component: J772__Rearview 0020
Revision: 00H11000 Serial number: 525PA8-J292848
Coding: 0020007
VCID: 68DF4E2C5BE1277EFE-803C
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3C8 035 730 C HW: 3C8 035 730 C
Component: Telefon 012 0822
Revision: -------- Serial number: 35909603471010
Coding: 020004000100111100000000
ASAM Dataset: EV_UHVPremi A02705
ROD: EV_UHVPremi_SE36.rod
VCID: 234519002A4704266B-8076
U1400 00 [008] - -
Reset counter: 171
Mileage: 95378 km
Date: 2016.01.20
Time: 14:02:00
13636352 - Control module not coded
U1013 00 [009] - -
Reset counter: 12
Mileage: 90519 km
Date: 2015.08.15
Time: 14:13:54
Address A5: Frt Sens. Drv. Assist (R242) Labels: 3AA-980-654.clb
Part No SW: 3AA 980 654 D HW: 3AA 980 654 A
Component: MFK_Gen1 H08 0300
Serial number: 0185624257
Coding: 010102000102020D0200040000010000
ASAM Dataset: EV_47X 001639
ROD: EV_47X.rod
VCID: 3979DB68B8CB6EF651-806C
