2012 VW Passat ROW Mirror dip
epicx
Romania
C?ID=197347
Hello all.
Just recently I have tried to make the passenger mirror dip when in reverse but I am unable to enter the 09-Cent.elect. module security access. I found a thread for a Golf MK7 as there was no info for a Passat.
52 Passenger door
07 coding
Byte 4 -----------------< i dont have a byte 4...
Enable bit 2 and 3
THEN
09 Central Electronics
31347 -----------------< code not accepted
Adaptations
17-Access control 2 Spiegelabsenkung bei Rueckwaertsfahrt (change to “active”)
THEN
(22) Access control 2-Menuesteuerung Spiegelabsenkung (change to “active”)
this puts the option in the menu screen.
Here is the VCDS read for the car:
Chassis Type: 3C (7N0)
Scan: 01 02 03 08 09 10 13 14 15 16 17 18 19 22 25 2E 37 3C 42 44
          46 47 4C 4F 52 53 55 56 61 62 6C 72 77 A5
VIN: WVWZZZ3CZDE0XXXXXX   Mileage: 97110km-60341miles
Address 01: Engine (J623-CFGB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 PC    HW: 03L 907 309 AE
   Component: R4 2,0L EDC   H27 4011
   Revision: 41H27---    Serial number: 00000000000000
   Coding: 001D003A046601080000
   Shop #: WSC 00015 115 00000
   ASAM Dataset: EV_ECM20TDI01103L906018PC 003005
   ROD: EV_ECM20TDI01103L906018NT.rod
   VCID: 7AFB0464FD4DA5EE18-802E
   Part No SW: 02E 300 015     HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3521
   Revision: 05551213    Serial number: 00001209181639
   Shop #: WSC 05311 000 00000
   VCID: 50AF86CCC371CFBE86-8004
   Part No SW: 3AA 614 109 BL    HW: 3AA 614 109 BL
   Component: J104   C2 450M VE8C 0024
   Revision: --H07---    Serial number: 00000006300231
   Coding: 0122303
   VCID: 78FF1E6C0B41B7FE6E-802C
02214 - Tire Pressure Warning
                    Fault Frequency: 41
                    Reset counter: 180
                    Mileage: 95051 km
                    Date: 2015.10.09
                    Time: 09:30:40
                    Speed: 182.0 km/h
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 14.25 V
                    Bin. Bits: 00011111
                    Count: 185
                    Hex Value: 0x0000
   Part No SW: 3AA 907 044 AJ    HW: 3AA 907 044 AJ
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 0014004803
   VCID: 78FF1E6CC341B7FE6E-802C
9473137 - Motor for Left Temperature Flap
          B108C 71 [008] - Actuator stuck
                    Reset counter: 173
                    Mileage: 95385 km
                    Date: 2016.01.26
                    Time: 14:49:39
9473393 - Motor for Right Temperature Flap
          B108D 71 [008] - Actuator stuck
                    Reset counter: 173
                    Mileage: 95385 km
                    Date: 2016.01.23
                    Time: 09:47:15
9474161 - Motor for Defroster Flap
          B1090 71 [008] - Actuator stuck
                    Reset counter: 173
                    Mileage: 95385 km
                    Date: 2016.01.26
                    Time: 14:49:39
9484401 - Motor for Indirect Ventilation Flap
          B10B8 71 [008] - Actuator stuck
                    Reset counter: 175
                    Mileage: 95385 km
                    Date: 2016.01.26
                    Time: 14:49:39
Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
   Part No SW: 3AA 937 087 H    HW: 3AA 937 087 H
   Component: BCM PQ47 H+   421 0465
   Revision: BC421001
   Coding: 000A000000000000009C00887400297423D50088676DAD60E480C7240049
   VCID: 3F8DB570AEEF40C66F-806A
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 19091  10  0603
   Coding: 00B795
   Component: RLS 101012 05  54  0403
   Coding: 02302A
Address 10: Park/Steer Assist (J791)       Labels: 3AA-919-475.clb
   Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0025
   Revision: --------    Serial number: 56261228300981
   Coding: 348306
   ASAM Dataset: EV_EPHVA2C000000000 002008
   ROD: EV_EPHVA2C000000000_SE36.rod
   VCID: 4487BA9CCF09231E32-8010
Address 13: Auto Dist. Reg        Labels: None
   Part No SW: 3AA 907 567 A    HW: 3AA 907 567
   Component: AC201  RDW A    036 0170
   Revision: 00036000    Serial number: 00000000563751
   Coding: 0010000
   Shop #: WSC 05311 000 08193
   VCID: 387FDE6C4BC177FEAE-806C
                    Reset counter: 173
                    Mileage: 95378 km
                    Date: 2016.01.20
                    Time: 14:02:03
                    Count: 94
                    Fault Status: 00100001
                    Reset counter: 174
                    Mileage: 95388 km
                    Date: 2016.02.05
                    Time: 14:46:08
                    Count: 103
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 05101205190002
   Coding: 030180
   Shop #: WSC 05314 000 00000
   VCID: 275D0D10567FE80637-8072
   Part No SW: 5N0 959 655 T    HW: 5N0 959 655 T
   Component: J234__11R VW10 HI   2118
   Revision: 24017000    Serial number: 003LDPM3ZWJ1
   Coding: 0012626
   VCID: 4E9398B4D945D94E94-801A
   Subsystem 1 - Serial number: 6332MTS640372542
   Subsystem 2 - Serial number: 6342MTS679892542
   Subsystem 3 - Serial number: 6351HTS6AJK5FBKR
   Subsystem 4 - Serial number: 6361HTS6QI5SEBKR
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C9 953 501 BM    HW: 5K0 953 569 T
   Revision: FF010041    Serial number: 20121011200391
   Coding: 399AA50001
   VCID: 75E11758D453CA9675-8020
   Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
   Component: E221__MFL-TK6  H07 0022
   Coding: E30000
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3AA 920 880 H    HW: 3AA 920 880 H
   Component: KOMBI         H05 0505
   Coding: 161F01
   Shop #: WSC 05314 115 00000
   VCID: 387FDE6C83C177FEAE-806C
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 7N0 963 272 C
   Component: Standheizer     044 4840
   Revision: 00044000    Serial number: 09024302000000
   Coding: 0031032
   VCID: 3561D7585CD38A96B5-8060
   Part No SW: 7N0 907 530 AE    HW: 7N0 907 530 AE
   Component: J533  Gateway H46 1633
   Revision:   H46       Serial number: 081012F1000853
   Coding: 462006
   VCID: 73E52940D227D4A65B-8026
   Part No SW: 0BS 907 554 C    HW: 0BS 907 554 C
   Component: Haldex 4Motion      4016
   Coding: 0000005
   VCID: 4683A0943135110E2C-8012
01155 - Clutch
                    Fault Status: 00100011
                    Reset counter: 34
                    Mileage: 95397 km
                    Date: 2016.02.08
                    Time: 10:12:25
   Part No SW: 3AA 959 799 C    HW: 3AA 959 799 C
   Component:    IMMO         090 0404
   Revision: 00090000    Serial number: VWZCZ000000000
   VCID: 489FAEAC3B21077EDE-801C
   Revision: A1001003    Serial number: 7663616953
   Coding: 010100
   VCID: 2A5BF424456DD56E28-807E
   Part No SW: 1T0 035 680 H    HW: 1T0 035 680 H
   Component: RNS-MID       H72 4120
   Revision: AB001001    Serial number: VWZ6Z7P7069043
   Coding: 04010002010000A02011
   Shop #: WSC 00001 001 1048576
   VCID: 3365E94092A794A69B-8066
   Component: EU West V8  7690
   Part No SW: 3AA 907 566 C    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0010
   Revision: 00H02000    Serial number: 6PZ 010 316-09
   Coding: 0000172
   VCID: 3979DB6870CB6EF651-806C
   Subsystem 1 - Part No: 3AA 907 568 C
   Component: J0770_SWA_Slave_H02 0010
   Subsystem 2 - Serial number: 6PZ 010 316-29
   Subsystem 3 - Serial number: 5F11.10.1200H020003C931086ÿ
   Subsystem 4 - Serial number: 931086ÿ
02853 - Warning Lamp for Lane Change Assistance (in left exterior mirror) (K233)
                    Fault Status: 00101010
                    Fault Frequency: 18
                    Reset counter: 180
                    Mileage: 94344 km
                    Date: 2012.01.01
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0533
   Revision: 12110009    Serial number: 0005852770
   Coding: 0210FF
   Shop #: WSC 05311 115 00000
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 3561D75894D38A96B5-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3AA 959 703 B    HW: 3C8 959 794
   Component: J388__TSG-HL  004 0503
   Serial number: 00000003103658
   Coding: 0100D8
   Part No SW: 5N1 909 144 N    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.337 1101
   Revision: 1AH03735    Serial number: 00122860042701
   Coding: 0000258
   VCID: 3D71CF7864E352D67D-8068
Address 46: Central Conv.        Labels: 3C0-959-799-46.clb
   Component: 02 KESSY PQ47   090 0359
   Coding: 0091020052C30E76340C94157E004F0B605801030434B8
   Subsystem 4 - Component:       ViP n.mounted
   Part No SW: 5K0 035 456 C    HW: 5K0 035 456 C
   Component: KonzernAmp 8K H07 0202
   Revision: --------    Serial number: EAA086A0019776
   ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003
   ROD: EV_AudioVerst10KanalBNO1.rod
   VCID: 2A5BF4244D6DD56E28-807E
Address 4C: Tire Pressure II
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AE
   Component: EZE_2         H46 1633
   Coding: 050B0508
   VCID: 6FED2530BE0FF046BF-803A
   Component: J245EE20SKB13  H03 0220
   Component: J394EE20SKB13  H03 0220
   Subsystem 3 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0004
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0533
   Revision: 14110009    Serial number: 0005876404
   Coding: 0210FE
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 3663D05489D5818EBC-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3AA 959 704 B    HW: 3C8 959 795
   Component: J389__TSG-HR  004 0503
   Serial number: 00000003158429
   Coding: 0100D8
   Revision:   H19       Serial number: 00000000504642
   Coding: 0022167
   VCID: 3663D05441D5818EBC-8062
Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
   Component: AFS-ECU       H04 0111
   Coding: 02BA00104F000200
   ROD: EV_HeadlRegulVWAFSPt_SK46.rod
   VCID: 377DDD508EDF7886A7-8062
   Subsystem 1 - Part No SW: 3D0 941 329 C    HW: 3D0 941 329 C  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H04 0012
   Coding: 2C0000
   Subsystem 2 - Part No SW: 3D0 941 329 C    HW: 3D0 941 329 C  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H04 0012
   Coding: 2C0000
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AE
   Component: Batt.regelung H46 1633
   Coding: 330F1859
   VCID: 71E92348A83BE6B6A9-8024
   Component: J367-BDM  H07 0180
02256 - Quiescent Current
                    Fault Status: 00110001
                    Reset counter: 174
                    Mileage: 95395 km
                    Date: 2016.02.05
                    Time: 21:14:28
   Part No SW: 3C9 907 441     HW: 3C9 907 441
   Component: J772__Rearview      0020
   Revision: 00H11000    Serial number: 525PA8-J292848
   Coding: 0020007
   VCID: 68DF4E2C5BE1277EFE-803C
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 C    HW: 3C8 035 730 C
   Component: Telefon       012 0822
   Revision: --------    Serial number: 35909603471010
   Coding: 020004000100111100000000
   ASAM Dataset: EV_UHVPremi A02705
   ROD: EV_UHVPremi_SE36.rod
   VCID: 234519002A4704266B-8076
          U1400 00 [008] - -
                    Reset counter: 171
                    Mileage: 95378 km
                    Date: 2016.01.20
                    Time: 14:02:00
13636352 - Control module not coded
          U1013 00 [009] - -
                    Reset counter: 12
                    Mileage: 90519 km
                    Date: 2015.08.15
                    Time: 14:13:54
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3AA-980-654.clb
   Part No SW: 3AA 980 654 D    HW: 3AA 980 654 A
   Component: MFK_Gen1      H08 0300
   Serial number: 0185624257
   Coding: 010102000102020D0200040000010000
   ASAM Dataset: EV_47X 001639
   ROD: EV_47X.rod
   VCID: 3979DB68B8CB6EF651-806C
I replied via email but wanted to post here so it becomes searchable.
SA 31347 applies to Mk7 Golf based (MQB) vehicles but this PQ47 BCM should not require a security access code for Coding or documented Adaptation channel modifications.
Mirror Lowering with Reverse Rear (only with Memory Seats) Coding appears to live in address 46.
epicx
Romania
C?ID=197347
Thanks Dana, I have enabled the setting but the mirror still wont dip :( Not super important but would have been nice :)
golfi_vend
Tartu, Estonia
C?ID=195131
Is your right mirror with memory?
epicx
Romania
C?ID=197347
Well there are a lot of contradictory opinions and results out there, no my seats are NOT memory, however neither are my B8 A4 seats and mirror dip works like a charm. On the Passat i have enabled the the Mirror dip option on the MFD and the function itself in the controller ( Central Conv. Byte 14 Bit 7 - "Mirror Lowering with Reverse Rear (only with Memory Seats)" ), and did the adaptation to memorize the dip position. At this point I will call it quits, would have been nice, but not a must.
RRPassat13
Montana, USA
C?ID=242709
Try putting the mirror selector to right mirror and then put car in reverse. That's how I got it to work in my car. 2013 Passat TDI SEL
