- May 13, 2014
- 51
- 9
- C?ID=214777
Hello Guys,
I need your urgent assistence please!!
I changed the "BCM" since the original fail on my front left turn signal (It was turned ON permanently even if the car was Off)
Both, the original and the new one are the same number (087J)
After I changed the unit, I just copy and then paste the Original Code from the Module 09 to the New one
Made the tunning on the Adaptation as it was on the old one and Wala ! I fix the turning light issue.
But I found an issues,
1) The reverse (backup light) left - driver side Light not working when reversing. I figure this out since my reverse sensor connected to this light and it stopped working.
BUT! The interesting point is that the bulbs test when turning on the ignition (the blinking)works fine on this light. I hear the Bip-Bip from the reversing sensor unit and if i am putting a LED instead of regular bulb I see it blinking three time. From my side, this mean the the "channel" is OK.
2) I don't know if this is an issue with my configuration after the change of the BCM or after some config changes (after the change of BCM) but when my trunk is open, the parking lights (the small tail bulbs) not works . They are turning on only when I am closing the trunk !!!!!
3) I have now a warning light about washing liquid when I even dont have the sensor I don't know how to turn off this light.
The car is SKODA Octavia 1.8 TSI model 2011 Elegance.
I am attaching the full-scan.
Thanks
Thanks
Wednesday,14,May,2014,20:21:03:40508
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
Dealer/Shop Name: Big-Byte
VIN: TMBBK61Z7B8022701 License Plate:
Chassis Type: 1Z (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
Address 01: Engine (CDA) Labels: 06J-907-115-CDA.clb
Part No SW: 3T0 907 115 G HW: 1Z0 907 115 F
Component: 1.8l R4/4V TFSI 0030
Revision: AAH18--- Serial number:
Coding: 0203000C24070060
Shop #: WSC 64888 768 16448
VCID: 356136445CDF4AB6781-8060
001089 - EVAP Emission Control Sys
P0441 - 000 - Incorrect Flow
Mileage: 65255 km
Date: 2001.14.18
Time: 20:00:35
RPM: 834 /min
Load: 15.7 %
Temperature: 90.0°C
Temperature: 39.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.716 V
Readiness: 0010 0000
Address 02: Auto Trans Labels: 0AM-300-04x.lbl
Part No SW: 0AM 300 050 E HW: 0AM 927 769 D
Component: GSG DSG AG7 431 2673
Revision: 00043014 Serial number: CU501307285442
Shop #: WSC 00029 730 29360
VCID: 2B55103C8A9B0C461E5-807E
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 113B401C092400FC881202E4901A0041350800
Shop #: WSC 73430 790 00000
VCID: 76E3F148C15901AEB1B-8023
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 AR HW: 3T0 907 044 AR
Component: Climatronic H15 0401
Revision: 00005001
Coding: 0000000002
Shop #: WSC 73430 790 00999
ROD: EV_ClimaAutoBasis_SE36.rod
VCID: 820B1D981591AD0E0D3-80D7
Part No SW: 1K0 937 087 J HW: 1K0 937 087 J
Component: BCM PQ35 H 103 0615
Revision: 00103 AD
Coding: 40180AB8AC3708C04008008111008DE442FD00EE504D89205C0440000040
VCID: 387F3F708BCDB7DE637-806D
Subsystem 1 - Part No: 1Z1 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 18101 26 0601
Coding: 00DFB7
014 - Defective
Fault Status: 01101110
Reset counter: 178
Mileage: 65255 km
Date: 2001.14.18
Time: 20:17:29
Term 15 On
Voltage: 13.70 V
Term 50 Off
00985 - Right Tail Light (M2)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 178
Mileage: 65255 km
Date: 2001.14.18
Time: 20:17:30
Term 15 On
Voltage: 13.75 V
Term 50 Off
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q6 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PC212XEE
Coding: 0020790
VCID: 3D712E6464EF92F6B01-8068
Subsystem 1 - Serial number: 6332MSME583233702
Subsystem 2 - Serial number: 6342MSME583233679
Subsystem 3 - Serial number: 6351HSME24654321.
Subsystem 4 - Serial number: 6361HSME24635D078
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 AR HW: 5K0 953 569 A
Component: LENKS.MODUL 009 0136
Revision: FF010039 Serial number: 20101008301625
Coding: 1882000000
ASAM Dataset: EV_SMLSNGVOLWS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 7CF7E360F7755BFEC7F-8029
Subsystem 1 - Part No SW: 3T0 959 537 HW: 3T0 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H07 0012
Coding: 800000
Part No SW: 1Z0 920 843 K HW: 1Z0 920 843 K
Component: KOMBI H20 0420
Coding: 110D01
Shop #: WSC 73430 031 12345
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 408F5790DB1DFF1EDB7-8015
Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 5603
Revision: H27 Serial number: 161010F2002537
Coding: ED807F0600020200001302
VCID: EDD15E24F40F4276C01-80B8
Component: IMMO H20 0420
ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
VCID: EADB55380DE1554EA53-80BF
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 AA HW: 1T0 959 701 AA
Component: Tuer-SG 009 2119
Coding: 0004342
VCID: 76E3F148015901AEB1B-8023
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
VCID: 31690254A8B76696249-8064
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 S HW: 1T0 959 702 S
Coding: 0004342
VCID: 489F4FB03B2DC75E137-801D
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1Z0 035 161 F HW: 1Z0 035 161 F
Component: SWING 009 0065
Revision: 0I001001 Serial number: SKZ1Z2K8411072
Coding: 050004000004
VCID: 3169025468B76696249-8064
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 326B0D58ADB15D8E5D3-8067
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 3365085C52AB5486565-8066
