Audi Q3 and A1 - Remote Porgrammer
easydiagnosticos
Brasil
C?ID=191069
Hello
Friend
Id like to know how I can Matching the Remote at Audi Q3!
I try 09, I try 46 all no works.
Can you help me?
regards.
Please post an Auto-Scan so people can see how this car is equipped and configured.
easydiagnosticos
Brasil
C?ID=191069
No!   Even if you are a registered user and have a real VCDS, data from pirated copies are NOT ACCEPTABLE HERE!
easydiagnosticos
Brasil
C?ID=191069
Fail.   Please don't play games with us.
easydiagnosticos
Brasil
C?ID=191069
Hello
Are here
Monday,22,February,2016,14:56:58:63125
VCDS Version: 15.7.4.1
Data version: 20160216
VIN: WAURYA8XXDB035224 License Plate:
Mileage: 35270km-21915mi Repair Order:
Chassis Type: 8X (8U0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 3D 42 44 46 52 55 5F 62 72
VIN: WAURYA8XXDB035224 Mileage: 35270km-21915miles
3D-Special Function -- Status: OK 0000
Address 01: Engine (J623-CAXA) Labels: 03C-906-016-CAX2.clb
Part No SW: 03C 906 016 DN HW: 03C 906 016 BG
Component: 1.4l R4/4V TS H11 2298
Revision: LEH11--- Serial number:
Coding: 00250012002400000000
Shop #: WSC 00046 790 00000
ASAM Dataset: EV_ECM14TFS01103C906016DN 001003
ROD: EV_ECM14TFS01103C906016DN.rod
VCID: 6ED65BEFB161904E9C-803A
18118 - Fuel Quality
P30C0 00 [032] - Inadequate
14751 - EVAP Emission Control Sys
P0441 00 [096] - Incorrect Flow
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 054 M HW: 0AM 927 769 D
Component: GSG DSG AG7 431 3640
Revision: 00043014 Serial number: CU501208245987
Shop #: WSC 00046 000 00000
VCID: 3778BE8B45BB11868F-5120
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BB HW: 6R0 907 379 AH
Component: ESP8.2i front H07 0001
Revision: --------
Coding: 310448E9417000B78C2712E482D500410D00
VCID: 7F0896ABEA0BE9C607-802A
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 8X0 820 043 B HW: 8X0 820 043 B
Component: Klima 1 Zone H12 0070
Serial number: 00000000147314
Coding: 6403200010
ASAM Dataset: EV_AirCondiFrontAU210 006035
ROD: EV_AirCondiFrontAU210.rod
VCID: 33608A9B9AC3FDA6B3-8066
0005 - Motor for Central Flap
B11AB 07 [009] - Mechanical Failure
Reset counter: 145
Mileage: 35253 km
Date: 2016.02.21
Time: 13:34:15
Address 09: Cent. Elect. (J519) Labels: 8X0-907-063.clb
Part No SW: 8X0 907 063 G HW: 8X0 907 063 G
Component: BCM PQ35 M 110 0655
Revision: 00110 AE
Coding: 06000A2FA80FF3C0201843E02100094CD3FF720AA1EF5922E40800870040
Shop #: WSC 00473 998 179988
VCID: 408AD557D375563E3E-8014
Subsystem 1 - Part No SW: 8K0 955 559 HW: 8K0 955 559
Component: RLS H04 0003
Coding: 02562D
Subsystem 2 - Part No: 8X0 951 177
Component: DWA-Sensor H0 H01 0020
00332 - Control Circuit for Tank Flap
Fault Status: 00100111
Fault Frequency: 74
Reset counter: 185
Mileage: 31402 km
Date: 2015.10.29
Time: 09:53:30
Term 15 Off
Voltage: 12.45 V
Term 50 Off
Address 10: Park/Steer Assist (J446) Labels: 8X0-919-475.clb
Part No SW: 8X0 919 475 M HW: 8X0 919 475
Component: PARKHILFE 4K H03 0051
Revision: 11001001 Serial number: 37031223602727
Coding: 000101
ASAM Dataset: EV_EPHVA14AU21X0000 002005
ROD: EV_AU210ParkAssis4K.rod
VCID: 50AAE5170B15A6BEAE-8004
Address 15: Airbags (J234) Labels: 8X0-959-655.clb
Part No SW: 8X0 959 655 B HW: 8X0 959 655 B
Component: Airbag10.41 H05 0009
Revision: -------- Serial number: 003KZ002JJ0C
Coding: 30323236303230303031554A304C38583053
ASAM Dataset: EV_Airba1041BPAAU210 001018
ROD: EV_Airba1041BPAAU210.rod
VCID: 499CC873E84F9776E9-801C
Serial number: 3554VRB405J1AP62P17J
Serial number: 3575HRB405D1G1DMA0SG
Serial number: 3585HRB405V1G0QMG9B2
Rear Impact Crash Sensor:
Serial number: 3515ZRB405H18AICH8L-
Address 16: Steering wheel (J527) Labels: 8X0-953-569.clb
Part No SW: 8X0 953 501 D HW: 5K0 953 569 H
Component: LENKS.MODUL 014 0140
Revision: FF010017 Serial number: 20120821300004
Coding: 1994204000
VCID: 3B70A2BBB29335E66B-806E
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Address 17: Instruments (J285) Labels: 8X0-920-xxx-17.clb
Part No SW: 8X0 920 930 G HW: 8X0 920 930 G
Component: KOMBI_MEDIUM H03 0252
Coding: 11CE00
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04396
VCID: 3E76ABAFA18120CE4C-806A
Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
Part No SW: 8U0 907 468 J HW: 8U0 907 468 J
Component: GAT 4CAN 2L M H13 0058
Revision: 1R110032 Serial number: 3241R128220181
Coding: F0C40064010301010253
VCID: 499CC873E04F9776E9-801C
Subsystem 1 - Part No SW: 8X0 959 591 B HW: 8V3 959 591
Component: J245 PS70.022 H02 0007
Coding: 901E00
Component: IMMO H03 0252
Coding: 000002
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 3D: Special Function Labels: 8K0-907-440.clb
Part No SW: 8K0 907 440 A HW: 8K0 907 440
Component: STS H04 0030
Revision: S0H04000 Serial number: 00000000065281
Coding: 01010101000000000001000102
VCID: 2C5291E78FFDA25EF2-8078
Address 42: Door Elect, Driver (J386) Labels: 8X0-959-793.clb
Part No SW: 8X0 959 793 K HW: 8X0 959 793 K
Component: TSG FA H10 0415
Coding: 011E02200120000000
VCID: 55A414033CF7C3967D-8000
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11251
Shop #: WSC 00046
VCID: 2F6886EBEAEBD946D7-807A
Address 52: Door Elect, Pass. (J387) Labels: 8X0-959-792.clb
Part No SW: 8X0 959 792 K HW: 8X0 959 792 K
Component: TSG BF H10 0415
VCID: 54A2E907370DDA9E8A-8000
Address 55: Headlight Range (J431) Labels: 8X0-907-357.clb
Part No SW: 8X0 907 357 B HW: 8X0 907 357 A
Component: ****LWR12**** H02 0021
Serial number: 120831-0004-049
Coding: 1133941010022400
ROD: EV_HeadlRegulBasic.rod
VCID: 418CD053D07F5F3631-8014
Part No SW: 8X0 035 182 J HW: 8X0 035 182 H
Component: RMC Cnct Plus H53 0775
Coding: 01000400008053070023020102010000000000
VCID: 3D74ACA3A4873BD655-8068
Subsystem 1 - Part No SW: 8X0 919 603 HW: 8X0 919 603
Component: DU6 Basic H42 0084
02982 - Connection between Radio and Impedance Converter 2
Reset counter: 114
Mileage: 13546 km
Date: 2014.04.01
Time: 09:04:06
Voltage: 12.40 V
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 8X0 959 795 D HW: 8X0 959 795 D
Component: TSG HL H07 0415
Coding: 010802200020000000
VCID: 50AAE5170315A6BEAE-8004
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H07 0415
End-------------------------(Elapsed Time: 03:36)--------------------------
