I have just swapped transmissions from auto to 5 speed. After reading every forum I could find on the subject, I have not found anyone who has had this problem after performing the swap so I think that it may be somewhat unrelated. The ecu accepted recoding so my instrument cluster now instructs me to depress the clutch to start instead of displaying the shifter position.
There is no response when the accelerator pedal is depressed.
Also no change in VCDS readings when the pedal is manipulated. It does, however, seem to respond favorably to adaption but nothing changes after the adaption is complete. (Please see the following)
VIN WAUKC68D71A0429889, engine code AWM
This is the screen I get after running adaption:
Address 01: Engine (4B0 906 018 M)
13:50:36
800 /min Engine Speed (G28)
16.5 % Engine Load
4.3 % Throttle Valve Angle
1.2 % Accel. Pedal Pos. Sensor 1 (G79)
0.0 % Accel. Pedal Pos. Sensor 2 (G185)
86.7 % Kick-Down Alignment Value
Kick-Down Switch
ADP. O.K. Kick-Down Alignment Status
Monday,15,February,2016,17:13:34:21552
17:13:31 Group 060: Throttle Body Alignment
16.4 % Throttle Valve Sensor 1 (G187)
83.6 % Throttle Valve Sensor 2 (G188)
8 Throttle Adaptation Steps Counter
ADP. O.K. Throttle Body Alignment Status
VCDS Version: Release 15.7.2 (x64) Running on Windows 7 x64
Data version: 20151124
Monday,15,February,2016,16:47:29:21552
Chassis Type: 8D - Audi A4/S4/RS4 B5 (1995 > 2001)
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine Labels: 058-906-018-ATW.lbl
Part No: 4B0 906 018 M
Component: 1.8L R4/5VT G 0003
Coding: 16201
Shop #: WSC 00402
VCID: 2B5B0A0BD9510066EE-515A
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Shop #: BB 24334
VCID: 1C39D9D78CFFF7DE97-515A
Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
Part No: 8D0 820 043 Q
Component: A4 KLIMAAUTOMAT D58
Coding: 00140
Shop #: WSC 06435
VCID: 2E5D031FEA43754EC9-25B2
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 G
Component: Airbag Front+Kopf 1002
Coding: 00306
Shop #: WSC 06435
VCID: 3A753F4F260BA9EE65-5178
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 980 Q
Component: B5-KOMBIINSTR. VDO D12
Coding: 02244
Shop #: WSC 20209
VCID: 39772043230DA2F66C-515A
00849 - S-contact at Ignition/Starter Switch (D)
31-10 - Open or Short to Ground - Intermittent
49-00 - No Communications
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 N
Component: CV-Pump D11
Coding: 16140
Shop #: WSC 06435
VCID: 40814DA740D7F33E2B-4EE6
7 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01365 - Lock/Unlock Switch; Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00102
Shop #: WSC 06435
VCID: 60C1AD27E017933E0B-4B4A
01381 - Alarm triggered by Anti-Theft Sensor; Rear Right
35-00 - -
01382 - Alarm triggered by Anti-Theft Sensor; Front Left
35-00 - -
01383 - Alarm triggered by Anti-Theft Sensor; Front Right
35-00 - -
Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 06435
VCID: 65CFBC33FF35F616F8-51D0
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 8D0 035 195 A
Component: Radio D00
Coding: 00110
Shop #: WSC 06435
VCID: 2449E137B48FCF1E2F-4B4A
End-------------------------(Elapsed Time: 03:27)--------------------------
