gr8shot10
hey guys,
New to this forum as a user usually a lurker, Ive got a 2013 S4 0b5 dsg that belongs to my buddy , there was a previous thread about this specific car if interested ill link it below, long story short it was at another shop and the ecu was replaced or one reason or another im not totally clear on, we no longer have the old ecu, the previous shop was able with the help of this forum to get the ecu coded but i believe it still may need programming can anyone look at the data i have and confirm? the suspicious items are in address 01 advanced measure values chassis number is ----------------- and number of adapted keys 0 , ins 05 auth chassis number shows correctly and number of keys adapted 3. The car is a no crank with p08500 setting in the ecu i believe it may be in CP due to no chassis number and keys and therefore not interpreting the can messages from the trans as in ECU gear reads 0 but in the trans gear position brake pedal dash all signals appear ok.
- ecu advanced id
- ecu advanced id
Saturday,07,February,2026,16:39:19:42675
VCDS Version: 25.3.2.0 (x64)
VIN: WAUKGAFL3DA089460 License Plate:
Mileage: Repair Order:
Address 01: Engine
Control Module Part Number: 8K5 907 551 E
Component and/or Version: 3.0l V6 TFSIH07 0002
Software Coding: 0A250034052600060000
Work Shop Code: WSC 12345
VCID: 3874C49583F5385B2B-806C
Advanced Identification/FAZIT
Identification: SME-RBG
Revision: --H07---
Date: 24.10.19
Manufacturer number: 0038
Test stand number: 0096
Flash Status
Programming Attempts(application): 3/1/1
Successful Attempts(application): 1/1/1
Programming Status: 00000000
Flash Date-Workshop ID-Status:
20.06.17 00001 001 04940 (OK) | 20.06.17 00001 001 04940 (OK) | 20.06.17 00001 001 04940 (OK)
Software
HiSpd Net: 01.12.01
Misc.
Hardware number: 4G0 907 551 A
Workshop System Name: J623
Workshop ID (Adaptation): 00001 001 04940
Workshop ID (Coding): 23456 444 12345
ASAM Dataset: EV_ECM30TFS0218K5907551E
ASAM Dataset Revision: 001002
Car Info
Chassis Number: -----------------
Engine code: CGXC
Immobilizer
General immobilizer info :
Life status: 1
Identity counter: 0
Brand identification: 3
Power class: 0
Count of adapted keys: 0
Count of keys to be adapted by adaptation: 0
Minutes remaining for Terminal 15 ON: 0
Configuration status: 0
Reserved: 0
Lock times in minutes :
Lock time password reset: 0
Lock time login/Terminal 15 ON: 0
Lock time key adaptation: 0
Lock time leaving key adaptation: 0
Lock time login special function: 0
Immo Challenge: B7ECF422
VCDS Info:
Labels: 06E-907-551-CGW.clb
Readiness: No script available
ROD: EV_ECM30TFS0218K5907551E.rod
Address 01: Engine (8K5 907 551 E)
16:27:42
ENG101579 CAN messages: status for gearbox 0.000 s
ENG98594 Gear 0
ENG103368 Gearbox -CAN bus messages 126839
ENG102883 Gearbox: status 00000000
Saturday,07,February,2026,15:56:38:42675
Mileage: 96480km-59949mi Repair Order:
15:56:31
IDE00078 Time since engine start 0 s
IDE00349 Throttle valve position: normed 99.6 %
IDE03584-ENG103498 Engine starting requirements-Binary 8 Bit 00000000
ENG98594 Gear 0
ENG100919 Starter control: interlock switch 00000000
ENG100800 Starter: start relay 1 00000000
ENG99979 Starter: start relay 2 00000000
ENG99368 Starter: starter request terminal 50 00000000
Saturday,07,February,2026,15:16:19:42675
VIN: WAUKGAFL3DA089460 License Plate: MIRZA
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 36 3C 42 44 46 47 52 53 56
5F 62 6C 72 A9
VIN: WAUKGAFL3DA089460 Mileage: 96480km-59949miles
Address 01: Engine (J623-CGXC) Labels:. 06E-907-551-CGW.clb
Part No SW: 8K5 907 551 E HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0002
Revision: --H07--- CVN: 146729D3
Shop #: WSC 12345 444 23456
ASAM Dataset: EV_ECM30TFS0218K5907551E 001002
ROD: N/A (VIN: N/A)
Unsupported vehicle.Please upgrade to a current Ross-Tech interface.
No ASAM data for: "EV_ECM30TFS0218K5907551E" (AU48)
6516 - ROD - Unknown Error Code
- 00 [10100101]
Mileage: 96484 km
Date: 2026.02.07
Time: 15:10:43
6408 - ROD - Unknown Error Code
- 00 [10100101]
Mileage: 96484 km
Date: 2026.02.07
Time: 15:10:42
Readiness: 1110 1101
Part No SW: 8K2 927 156 M HW: 0B5 927 156 J
Component: 0B5 30TFSINAR H01 0004
Revision: --H01--- CVN: 00007AC3
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMDL501021 001010
ROD: EV_TCMDL501021.rod
VCID: 4084AC75DB25709B93-8014
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CK HW: 8K0 907 379 CK
Component: ESP8 quattro H09 0100
Coding: 291D1A
VCID: 040C606587BDACBBF7-8050
Part No SW: 8K0 907 064 GM HW: 8K0 907 064 FM
Component: BCM2 2.0 H11 0621
Coding: 0D814000000000000000
VCID: 0102697198AFB993DC-8054
Subsystem 1 - Part No SW: 8K0 959 754 BB HW: 8K0 959 754 BB
Serial number: 0512000040596020
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 2312000118100002
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Revision: C1000000 Serial number: 01190620120017
Coding: 6600228000
VCID: 3972C191B0FF2153D4-806C
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000435868102
Coding: 26000091863CAFE0210048C300003D0D0F9CD308A2090221000008004000010200020030000000
Shop #: WSC 20955 004 1048576
VCID: 7AF01E9DF579EA4B9D-802E
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 140612 H07 0080
Serial number: SWF12060145165
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 20343665
Coding: 02005D
Component: E1 - LDS H03 0031
Serial number: 00000000001206124045
Subsystem 4 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 5 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 73888436000000000001
02258 - Door Opener Transmitter
Reset counter: 222
Mileage: 96484 km
Date: 2026.02.07
Time: 15:10:42
Part No SW: 8K0 959 655 P HW: 8K0 959 655 P
Serial number: 003KJD90C2LD Dataset Number: 8K0909602VA 0001
Coding: 303844354730303030304A55304C384B3053
Shop #: WSC 25711 001 1048576
VCID: 4A908E5DED19BACB4D-801E
Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R1200009PD9
Serial number: 6334MSME67516706B
Serial number: 6344MSME69116749H
Serial number: 6352QSME20171060.
Serial number: 6362QSME3F170D44P
Serial number: 63732SME7314064E
Serial number: 63832SME7314075C$
Part No SW: 8R0 953 568 S HW: 8R0 953 568 S
Component: Lenks.Modul H07 0171
Revision: 00000000 Serial number: 20120621000100
Coding: 000036
VCID: 51A29931084F89130C-8004
Component: E221 - MFL H03 0003
Part No SW: 8K0 920 982 L HW: 8K0 920 982 L
Component: KOMBIINSTR. H35 0553
Revision: 00000000 Serial number: RBN644J6D
Coding: 8BB709008B01D705020000
VCID: 3D7AD581A4D71D73F8-8068
Part No SW: 8R0 907 468 J HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0051
Revision: 1Z090025 Serial number: 2541Z1252800F8
Coding: 80C303FF00
VCID: 4688BA6DF1015EABA9-8012
Serial number: 1984827601
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H13 0100
Serial number: 000806120001039 Dataset Number: 8K0909104D 0025
VCID: 2F66FFC976BBFFE37A-807A
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0076
Revision: AA000000 Serial number: 00000031306339
Coding: 00581B00000000000000
VCID: 3B7EDB99BAC31343C6-806E
Part No SW: 8T0 907 566 A HW: 8T0 907 566
Component: SWA Master H16 0040
Serial number: 0174367323 Dataset Number: 8K0909535E 0020
Coding: 010211
Shop #: WSC 06324 000 00000
ROD: EV_LaneChangAssis_AU48.rod
VCID: 3E78D28DA1D1066BE1-806A
Subsystem 1 - Part No SW: 8T0 907 568 A HW: 8T0 907 568
Component: SWA Slave H16 0040
Serial number: 0177657983
Coding: 010211
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0304
Coding: 011C13204E00410001
VCID: 56A86A2D21A1EE2BD9-8002
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H36 0507
Revision: 00001000 Serial number: 0004627784 Dataset Number: 8K0909852H 0023
Coding: 100000010001
ROD: EV_RCEPSAU48X_008.rod
VCID: 346CF0A59F9DDC3B07-8060
5258753 - Steering End Stops Not Learned
C10AC F0 [10001001] -
Reset counter: 222
Mileage: 96484 km
Date: 2026.02.07
Time: 15:10:41
16 00 00 00
Revision: 00002001 Serial number: 0178662636
Coding: 0106023A00FA400580B0013200000000
Component: GTO BF H01 0080
Serial number: 00000000000000534915
Subsystem 2 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
Component: J245 PS050 H08 0043
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 222
Mileage: 96484 km
Date: 2026.02.07
Time: 15:10:42
03020 - Local databus 2
Fault Status: 01101100
Reset counter: 222
Mileage: 96484 km
Date: 2026.02.07
Time: 15:10:47
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813004073402
VCID: 2D5AE5C174B78DF348-8078
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0304
VCID: 55AA6D213CA7E533D0-8000
Part No SW: 8K0 907 801 K HW: 8K0 907 801 J
Component: EPB-4 H01 0002
Revision: -------- Serial number: 10000000060449
ROD: EV_ParkiBrake_AU48.rod
VCID: 3776C7A98EEB372322-8062
Part No SW: 4G0 035 082 D HW: 4G0 035 082
Component: Radio U SIRIU H60 0112
Revision: AB001007 Serial number: 156F 0C7606445
Coding: 020007010000000001
VCID: 214209F1386F5993FC-8074
Part No SW: 8R1 035 746 B HW: 8R1 035 746 B
Component: H-BNT-NA H43 0552
Revision: -------- Serial number: 204FU0C7506327
Coding: 110200000206A1EF55028B4E00000403140000000000000000
VCID: 3668CAAD81E1CE2B39-8062
Subsystem 1 - Part No: 8R0 060 884 AM
Component: NAR 2012 0605
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Serial number: A130FB0CS191629
Subsystem 3 - Part No SW: 8T0 919 611 C HW: 8T0 919 611 C
Component: E0380 Bedient H02 0020
Serial number: 00000001192606
Subsystem 4 - Part No: 8R0 060 961 D
Component: CD-Database 4353
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H07 0304
Coding: 010C13204000210001
VCID: 59B2611150BFC153F4-800C
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Revision: --H07--- Serial number: 525PA8-J2491LZ
Coding: 1000006
VCID: 3874C4954BF5385B2B-806C
Component: TSG HR H07 0304
Part No SW: 8K0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0005
Serial number: 120527201377
ASAM Dataset: EV_SoundActuaGen2AU64X 002005
ROD: EV_SoundActuaGen2AU64X_002_AU48.rod
VCID: 72E036BDA509920BD5-8026
End-------------------------(Elapsed Time: 04:10)--------------------------
------------------------------6 Faults Found-------------------------------
