05 allroad 6mt swap
Philson
Lancaster, PA, USA
KII-2H
hello, I am doing a 6speed 01E swap into my 05 allroad. I have everything all together and running and driving pretty well but I need to get it to pass PA inspection. While doing the swap I also put SRM RS6 turbos on with 550cc injectors. I’ve gotten everything pretty well sorted I just can’t get the ABS, brake, traction control, and right height lights to clear. I got it to take the soft coding as a manual but it hasn’t changed anything. Below is my autoscan. Thank you in advance for helping
VIN: WA1YD64B75N001110   License Plate: 0000
Mileage: 89599   Repair Order:
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
          75 76 77
Address 01: Engine        Labels: 078-907-551-AZA.lbl
   Part No: 4Z7 907 551 R
   Component: 2.7L V6/5VT     G   0003
   Coding: 07755
   Shop #: WSC 06121
   VCID: 52A585559E1B670B35-515A
   WA1YD64BX3N001115     AUZ7Z0B2141411
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96)
            P0106 - 35-00 - Implausible Signal
16538 - Oxygen (Lambda) Sensor B2 S1
            P0154 - 35-00 - No Activity
18034 - Powertrain Data Bus
            P1626 - 35-00 - Missing Message from TCU
16622 - Manifold Pressure / Boost Sensor (G31)
            P0238 - 35-00 - Signal too High
17528 - Oxygen (Lambda) Sensor Heating; B2 S1
            P1120 - 35-00 - Open Circuit
Readiness: 0110 0100
Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
   Part No: 4Z7 907 389 A
   Component: ABS/ESP allrad      D56
   Coding: 06395
   Shop #: WSC 12345
   VCID: 4A959D35764B2FCB4D-513C
            35-00 - -
Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
   Part No: 4B0 820 043 AR
   Component: A6-Klimavollautomat 0208
   Coding: 00010
   Shop #: WSC 02335
   VCID: 6AD53DB5168BCFCB6D-258C
            30-00 - Open or Short to Plus
Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
   Part No: 4Z7 959 655 N
   Component: Airbag 8.4EP        1000
   Coding: 0000607
   Shop #: WSC 02335 785 00200
   VCID: 5AB56D7596EB5F4BFD-515A
Address 16: Steering wheel        Labels: 4B0-907-487.lbl
   Part No: 4B0 907 487 F
   Component: Lenkradelektronik   D01
   Coding: 01002
   Shop #: WSC 02335
   VCID: 2F63ECA1EDE96AE37A-515A
Address 17: Instruments        Labels: None
   Part No: 4B° 920 983 F
   Component: KOMBI+WEGFAHRS. VDO D16
   Coding: 20264
   Shop #: WSC 00001
   VCID: 2B5BF8B1D9F116C356-515A
   WA1YD64B75N001110     AUZ7Z0D2630455
Address 34: Level Control        Labels: 4Z7-907-553.lbl
   Part No: 4Z7 907 553 F
   Component:  - 2C1A1          X060
   Coding: 25500
   Shop #: WSC 02335
   VCID: 4891A73D6847DDDB5B-515A
            79-00 - Please Check Fault Codes
Address 35: Centr. Locks        Labels:. 4B0-962-258.clb
   Part No: 4B0 962 258 M
   Component: Central Lock/Alarm  D38
   Coding: 15885
   Shop #: WSC 02335
   VCID: 336BE0D101C14E031E-4EE6
01369 - Alarm triggered by Hood Switch
            35-00 - -
01559 - Drivers Door
            58-00 - Can't Lock
   Part No: 4B0 959 760 B
   Component: Sitzmemory R1 F     0204
   Coding: 00001
   VCID: 2C59FBADDCFF11FB5F-4B00
            06-10 - Signal too High - Intermittent
Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D09
   Coding: 00030
   Shop #: WSC 02335
   VCID: 0409730D14EF39BBF7-4B32
   Part No: 4B0 035 195 N
   Component: symphony II NP2    0410
   Coding: 02005
   Shop #: WSC 08192
   VCID: 2B5BF8B1D9F116C356-5072
            37-10 - Faulty - Intermittent
End-------------------------(Elapsed Time: 04:32)--------------------------
------------------------------21 Faults Found------------------------------
Saturday,07,February,2026,10:16:48:62502
VCDS Version: 25.3.2.0
          75 76 77
   Coding: 07755
   Shop #: WSC 06121
Readiness: 0110 0000
   Coding: 06395
   Shop #: WSC 12345
   VCID: 4A959D35764B2FCB4D-515A
            35-00 - -
   Coding: 00010
   Shop #: WSC 02335
   Coding: 0000607
   Coding: 01002
   Shop #: WSC 02335
   Coding: 20264
   Shop #: WSC 00001
   Coding: 25500
   Shop #: WSC 02335
   Coding: 15885
   Shop #: WSC 02335
            35-00 - -
            58-00 - Can't Lock
   Coding: 00001
   VCID: 2C59FBADDCFF11FB5F-4B18
   Coding: 00030
   Shop #: WSC 02335
   Coding: 02005
   Shop #: WSC 08192
   VCID: 2B5BF8B1D9F116C356-50AC
End-------------------------(Elapsed Time: 04:31)--------------------------
Nice work, but the forum only supports Genuine VCDS hardware. Is your VCDS a Legitimate version of VCDS?
Since some of us here on the forum don't know (confidential information) if your Auto-Scan is from a genuine VCDS, you really should not crop off the header (as you did). So, I would post that information along with a screen shot of the "About" page on VCDS. Its the tab to the left of the Exit tab on the main VCDS landing page.
Once your scan is analyzed by RT Admin. , you may get some helpful replies.
BTW, I'm curious why you posted in the "Reference scans and maps of Non-Broken cars" ??
Philson
Lancaster, PA, USA
KII-2H
Saturday,07,February,2026,10:08:34:62502
Sorry here it is, I forgot to get the number in the about section before I finished working on it. I bought the cable off my neighbor.
Part No: 4B° 920 983 F Component:
What's up with that?
What do you have in Adaptation channel 060 of the Instrument Cluster?
