B9.5 SQ5, Engine light, limp mode, no codes??
dkavanagh
C?ID=9235
I've been trying to troubleshoot this problem that only seems to occur when it's really cold out (like between 5 and 15F, more or less). I had the car a the dealer, but it was warmer earlier this week when it was there (like in the 20s) and they couldn't reproduce it, or fathom what the issue was.
Today, it's 5 degrees out and I went out driving while monitoring some measuring blocks. First time, timing related (crank and cam positions). Next, oil temp/pressure related, then fuel pressures, then evap related. Each time, the car would flash the engine light, run really rough and not have any throttle control. I'd pull over, get it in park and shut it off. Turning it on generally let me drive away. A couple of times, it would throw the light again, but eventually, I'd get going normally.
I was not driving hard, in fact RPMs were usually less than 2000 when it happens. No codes, and I did a full scan!
I checked readiness and there was "Evaporative Emissions" saying "failed or Incomplete" (which is why I drove, logging various evap measuring blocks).
I would also check the logs, even graphing some sets of values to look for anomalies Things seemed normal, no sudden change when the engine light went on.
What goes into that engine light? What control it and would cut power like that? I figure something not ECU-related since no codes were stored. I'd appreciate any insights since this makes it very hard to trust the car on the road! I'm happy to go driving and collect more data, and share what I already have.
David
dkavanagh
C?ID=9235
I forgot to add, I have upgraded the intercooler, HPFP and added a flex fuel sensor, with my IE stage 1+ tune. Been running that tune for over a year and stage 1 prior to that. The dealer didn't have any concerns about that, though the tech gave me the standard line "we recommend you put it back to stock", but the service department is cool with minor work like this.
Dr Sheldon
Windsor UK
C?ID=334979
Post an Autoscan first !!
Dr Sheldon
Windsor UK
C?ID=334979
Probably a shit tune ! that has deleted DTC's ! Put it back to stock !!
Westbury, UK
Even though there are no codes we still need to know how your SQ5 is equipped, so please post a complete Auto-Scan
dkavanagh
C?ID=9235
Saturday,07,February,2026,13:55:20:30367
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4671.4
Dealer/Shop Name: DAK
VIN: WA1C4AFY5M2028417   License Plate:
Chassis Type: FY-AU49 (80C)
Scan: 01 02 03 08 09 13 15 16 17 19 32 36 3C 42 44 46 52 5F 69 6C
          6D 74 75 81 82 8B A5 A9 BB BC CA CF D6 D7 DE
VIN: WA1C4AFY5M2028417   Mileage: 79913km-49655miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CWGD)       Labels:. 06M-907-309-V1.clb
   Part No SW: 80A 907 559 G    HW: 06M 907 309 G
   Component: V6 3.0l TFSI  H11 0002
   Revision: B8H11000    CVN: ED383746
Coding: 2A2A0032257E090E34380000000000000000000000000000
   ASAM Dataset: EV_ECM30TFS01180A907559G 001002
   ROD: EV_ECM30TFS01180A907559G.rod
   VCID: 333313F2ABB20162431-8066
VINID: 9D10531115A915D0800881011C88E633F4
Readiness: 0000 0100
   Part No SW: 80A 927 158 K    HW: 0D5 927 156 N
   Component: 0D5 30TFSINAR H05 0002
   Revision: --H05---    CVN: F385A366
 Coding: 100000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMALX52011 002016
   ROD: EV_TCMALX52011.rod
   VCID: 343110EEAEBC065A5AB-8060
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-V1.clb
   Part No SW: 80A 907 379 S    HW: 80A 907 379 H
   Component: ESP9 Premium  H17 0838
   Dataset Number: 80B909504AB 0011 CVN: 60FC8FD5
Coding: 1CAA14BE30A40A9E93A258925A8452A2E5359A38280C50C91A5A4A45A7AC59
   Shop #: WSC 18950 005 1048576
   ROD: EV_ESP9BOSCHCMP_004_AU49.rod
   VCID: 3FDB4FC297FAD502B79-806A
   Part No SW: 80A 820 043 T    HW: 80A 820 043 T
   Component: Klima Zone 3  H60 0270
Coding: 6608090D5548010D10000100080000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 2E05028640902C8A2CF-807A
   Subsystem 1 - Part No SW: 4M1 820 021 C    HW: 4M1 820 021 C
   Component: J126 FLuftV  H09 0004
   Serial number: 00000000000005298698
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4H0 907 658 C    HW: 4H0 907 658 C
   Component: G935 MuFu  H04 0010
   Serial number: A46C862A00PAG0MUFU04
   Subsystem 3 - Part No SW: 80A 919 158 A    HW: 80A 919 158 A
   Component: E265 Kli Fond  H40 0080
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W1 907 063 AG    HW: 8W1 907 063 G
   Component: BCM1 MLBevo   H10 0712
   Dataset Number: 80C909514A  0011
Coding: 07000360C0291CDD050D57899CBF9CB9130B75490000009801010A0060001601086302BB22B70A0800000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 017002
   ROD: EV_BCM1BOSCHAU651_017.rod
   VCID: 015F893AA18E63F281D-8054
   Subsystem 1 - Part No SW: 80B 955 119 A    HW: 80B 955 119
   Component: 426 LL 201013  040 0581
   Serial number: 00000002010112108944
 Coding: FFC7F7
   Serial number: 25271617X81A955555A0
 Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AP    HW: 4M0 941 531 AP
   Component: E1 - LDS  H07 0008
   Serial number: 01 10 2020  02750174
   Subsystem 4 - Part No SW: 4N0 907 410 C    HW: 4M0 907 410 A
   Component: USHL5     GX1  H12 0300
   Serial number: 0000009600373Z002C02
 Coding: 250000
   Subsystem 5 - Part No SW: 4KE 857 511 C    HW: 4KE 857 511
   Component: Y7_Innenspieg  H05 0003
   Serial number: GX1NR120102023310245
   Interior Light Module:
   Subsystem 6 - Part No SW: 80A 947 135 BJ    HW: 80A 947 135
   Component: Dachmodul  H42 0415
   Serial number: Q00029738
 Coding: 0D0101
   Subsystem 7 - Part No SW: 80A 907 705 A    HW: 80A 907 705
   Component: J866-EVLS-SG  H07 0200
   Serial number: WA143685000089477558
 Coding: 0A0700
   Cup holder with heating and cooling element:
   Subsystem 8 - Part No SW: 80A 864 981 F    HW: 80A 864 981 F
Component: Q5 THERMO CUP H07 0020
   Serial number: 0016662491
Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
   Part No SW: 80A 907 561 C    HW: 8W0 907 561
   Component: LRR4          H12 0451
   Dataset Number: 80B909863J  0004
 Coding: B5779FFB58FFEC06757B61A1
   ASAM Dataset: EV_ACCBOSCHAU49X 003024
   ROD: EV_ACCBOSCHAU49X_003_AU49.rod
   VCID: 2809F49E627472BAE63-807C
   Part No SW: 80A 959 655 T    HW: 80A 959 655 T
   Component: AirbagVW30    004 0703
   Serial number: 0032SM00R354 Dataset Number: 80A909602AA 0016
Coding: AECCFCC000800000A000003FF20C400000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001044
   VCID: 44D1402EFE1CB6DAEAB-8010
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
   Component: BeltPretRevFL  306 2040
   Serial number: 80A857705M0259U00335
 Coding: 80000D
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
   Component: BeltPretRevFR  306 2040
   Serial number: 80A857706M0275U01268
 Coding: 80000D
   Component: BF-Gewichtss.  H12 0022
   Serial number: IBH0000D20000ENC040S
 Coding: 303039
   Subsystem 4 - Part No SW: -----------    HW: 480 000 709 20
   Serial number: 357000000007AC7C9A40
   Subsystem 5 - Part No SW: -----------    HW: 480 000 709 20
   Serial number: 358000000009006C9A4N
   Subsystem 6 - Part No SW: -----------    HW: 480 030 708 20
   Serial number: 351002C080A1F9F108DH
   Subsystem 7 - Part No SW: -----------    HW: 480 030 808 20
   Serial number: 352002C089837180791%
   Subsystem 8 - Part No SW: -----------    HW: 480 031 408 20
   Serial number: 355002C089B930A14F0B
   Subsystem 9 - Part No SW: -----------    HW: 480 031 408 20
   Serial number: 356002C0899876807FEX
   Central crash sensor X/Y:
   Subsystem 10 - Part No SW: -----------    HW: 480 021 009 20
   Component: CentrSensorXY  005 0108
   Serial number: I0O0001C4F52BCD7F70H
   Part No SW: 80A 907 129 DH    HW: 80A 907 129 DH
   Component: Lenks.Modul   H03 0009
   VCID: 71BFD9FA912E737271D-8024
   Part No SW: 8W5 920 790 L    HW: 8W5 920 790 L
   Component: FBenRDW------ H10 0161
Coding: 8BEF3EC57EA8D7050280636018006B0008003000
   ASAM Dataset: EV_DashBoardAU65X 002025
   ROD: EV_DashBoardAU65X_002_AU49.rod
   VCID: 4BC36B12D34279A22B1-801E
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 80C 907 468 F    HW: 80B 907 468 B
   Component: Gateway       H06 0613
   Serial number: 1JF04192642201 Dataset Number: 8W0909515VC 0002
Coding: 03030001000006405407000000590032FC9A0001980000000100008E00000000
GVL: 01503C5808000000C0DCC8008002C800110C0000000000000000000000006500
   ASAM Dataset: EV_Gatew31xAU65x 003250
   ROD: EV_Gatew31xAU65x_AU49.rod
   Subsystem 1 - Part No SW: 83A 951 523 L    HW: 83A 951 523 L
   Component: J453 MFL  H07 0004
   Serial number: 20201009100312 31195
   Serial number: 6251237600
   Subsystem 3 - Part No SW: 4M8 419 508 A    HW: 4M8 419 508 A
   Component: J1158 KLR  H10 0008
   Serial number: 00000000000000043873
 Coding: FFFFFF
8519683 - Energy Management Active
          U140B 00 [00001000] - -
                    Reset counter: 125
                    Mileage: 79788 km
                    Date: 2026.02.02
                    Time: 16:51:11
                    EM_vehicle_state: 02 1C
                    Static current shut-off stage: Deactivation stage 1
                    Auxiliary heater activation restriction request-Parking heater: Permitted
                    Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
Address 32: Differential Locks (J187)       Labels: None
   Part No SW: 8W0 907 163     HW: 8W0 907 163
   Component: QSP QCU Gen2  H08 0060
   Revision: 5WK12700    Serial number: 605040502200207
 Coding: 0001
   ASAM Dataset: EV_TVDCQSP22 001008
   ROD: EV_TVDCQSP22.rod
   VCID: 79AFE1DAC95E3B32C9D-802C
   Part No SW: 4M6 959 760     HW: 4M4 959 760
   Component: MEM-FS        009 0064
   Serial number: 12A14030002223 Dataset Number: 80B909856C  0014
Coding: 015C1A000000B0010003010101010000000000000000000000000000004000
   VCID: 7BA3FBD2C3620922DB1-802E
Address 3C: Lane Change (J769)       Labels:| 4M0-907-566.clb
   Part No SW: 80A 907 566 B    HW: 80A 907 566
   Component: MRR1Rear      H22 0441
   Revision: --------    Dataset Number: 80B909535C  0006
 Coding: 1EC002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   VCID: 2C01088E768C5E9A02B-8078
   Part No SW: 4M1 959 793 J    HW: 4M1 959 793 D
   Component: TSG FS002 0425
   Serial number: CLSM1TJC001V8 Dataset Number: 80B909872F  0044
 Coding: 005D8B015E00148000010032
ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
   VCID: 46D55A26C82084CAF4F-8012
   Dataset Number: 80B909852M  0001
 Coding: B0112101000101
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 323D16F654A8086A487-8066
   Part No SW: 4N0 907 064 EP    HW: 4N0 907 064 P
   Component: BCM2 MLBevo H16 0224
   Dataset Number: 80C909501A  0008
Coding: 013400004FB100C0650BA0006C01D802030040008104A6502F0000000F04803F001E0681100A11
   ASAM Dataset: EV_BCM2CONTIAU651 011009
   ROD: EV_BCM2CONTIAU651_011.rod
   ID - sensor:
   Serial number: 000000000ZY202202PSA
   Serial number: 00000000000048603427
   Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 14813666
   Rear spoiler control module:
   left tail lamp 2:
   Subsystem 6 - Part No SW: 80A 945 429 C    HW: 80A 945 429 C
   Component: T2 LH SAE  H09 0403
   Serial number: 03A
   Right rear tail lamp 2:
   Subsystem 7 - Part No SW: 80A 945 430 C    HW: 80A 945 430 C
   Component: T2 RH SAE  H09 0403
   Serial number: 06L
   Part No SW: 4M1 959 792 J    HW: 4M1 959 792 D
   Component: TSG BFS002 0425
   Serial number: CLSM1TJ1004AM Dataset Number: 80B909873F  0044
 Coding: 005D8B015E00148000010030
ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
   VCID: 45D75D2AF5268FD2FD5-8010
   Part No SW: 80A 035 050 H    HW: 80A 035 050
   Component: MU-TH-NS-US   042 3696
   Serial number: 8VV-DDM03.11.20 Dataset Number: 8W1909545G  0038
Coding: 14260000804220000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: EV_MUTI_VW53.rod
   VCID: 1E65D2463030BC0A9CF-804A
   Multimedia display unit 1:
   Subsystem 1 - Part No SW: 80B 919 620     HW: 80B 919 620
   Component: CenterDisplay  H41 0160
   Serial number: AUZ8Z9L6H00QRL
   Subsystem 2 - Part No: V03 959 820 KT
   Component: MIB3_NA_       0986
   Compact disc data bank:
   Component: Gracenote2     3004
   Volume Control 1:
   Subsystem 4 - Part No SW: 80B 919 616 A    HW: 80B 919 616 A
   Component: LSR-Q5PA       H20 0103
   Serial number: ALJAL214072000060245
   Media socket:
   Subsystem 5 - Part No: 8W0 035 708 A
009 0007
   Digital Sound System Control Module 2:
   Subsystem 6 - Part No SW: 8Y0 035 465     HW: 8Y0 035 465
   Component: B_A_3_P_0_AU   H10 0140
   Serial number: YJL-26003.11.2066610
Address 69: Trailer (J345)       Labels:| 5H0-907-383.clb
   Part No SW: 8W1 907 383 A    HW: 8W1 907 383
   Component: Anhaenger     H10 0040
   Serial number: 000000000005910 Dataset Number: 8Y0909527B  0007
 Coding: 0200000200001100
   ASAM Dataset: EV_TrailFunctGener3Hella 001009
ROD: EV_TrailFunctGener3Hella_VW27.rod
   Part No SW: 8W0 907 428 A    HW: 4M0 907 428
   Component: Areaview 2    H16 0106
   Serial number: C854609JI004609 Dataset Number: 80B909460L  0020
 Coding: 02240602BF0FA10038004000
   ASAM Dataset: EV_CamSysRVAV2CE2MLBPA 001001
   ROD: EV_CamSysRVAV2CE2MLBPA_001.rod
   VCID: 3E2532C690F0DC0ABCF-806A
   Part No SW: 8W8 959 107 E    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0172
   Revision: --------    Serial number: A2-C748-5750-9 Dataset Number: 80B909541D  0010
 Coding: 07B0
Address 74: Chassis Control (J775)       Labels:* Redir Fail!
   Part No SW: 80A 907 777 AK    HW: 80A 907 777 C
   Component: Fahrwerk-SG   H37 1253
   Serial number: 1408200525  Dataset Number: 80B909576S  0002
 Coding: 94603832F8
   ASAM Dataset: EV_ChassContrContiAU426 001004
   ROD: EV_ChassContrContiAU426.rod
   VCID: 7AADFED6CC58302AC07-802E
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004132016725
 Coding: 303030
Address 75: Telematics (J949)       Labels:* Redir Fail!
   Part No SW: 4KE 035 283 F    HW: 4KE 035 283 B
   Component: CB_H_NAR      039 0372
   Serial number: A971H0LS046921 Dataset Number: 8W0909612F  0023
 Coding: 01E0E0F8C04080F6E0
   ASAM Dataset: EV_ConBoxHighAU49X 001004
   ROD: EV_ConBoxHighAU49X_AU49.rod
   Part No SW: 80B 713 041 M    HW: 80B 713 041 M
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 20201015000905
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 270BF7A26F6A7DC2EF9-8072
Address 82: Head Up Display (J898)       Labels:| 4M0-919-617-V1.clb
   Part No SW: 80A 919 617 D    HW: 80A 919 617 D
   Component: HeadUpDisplay H16 1952
 Coding: 4F01E0
   ASAM Dataset: EV_HudNSEIKAU736 001017
   ROD: EV_HudNSEIKAU736_AU49.rod
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 80A 907 541 C    HW: 8W0 907 541
   Dataset Number: 80B909885F  0002
   ASAM Dataset: EV_ACC2BOSCHAU49X 003024
   ROD: EV_ACC2BOSCHAU49X_003_AU49.rod
   VCID: 2615FAA6686064CAD4F-8072
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 80A 907 217 F    HW: 80A 907 217 D
   Component: BVS           H24 0070
   Dataset Number: 80B909466F  0036
Coding: 0404020600000204022023AFCD0000FEB0F0C020E280
   ASAM Dataset: EV_BVSMLBevKOSTAAU736 002028
ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
   VCID: 290FF19A797E4BB2F9D-807C
   Part No SW: 80A 907 159     HW: 4H0 907 159 A
   Serial number: 200912201557
   VCID: 6889B49EA2F4B2BA263-803C
   Part No SW: 4M1 959 795 J    HW: 4M1 959 795 D
   Component: TSG HFS004 0425
   Serial number: CLSM1TJH002GS Dataset Number: 80B909897G  0046
 Coding: 000D89000000148040000020
   VCID: 48C9541EC23492BA063-801C
   Component: TSG HBFS004 0425
   Serial number: CLSM1TJH002C1 Dataset Number: 80B909896G  0046
   Dataset Number: 80B909469G  0012
 Coding: 22804004260C
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: 75B7EDEAE5465F52AD5-8020
Address CF: Lane Chge Asst 2 (J770)       Labels:. 4M0-907-566.clb
   Part No SW: 80A 907 590 B    HW: 80A 907 590
   Revision: --------
 Coding: 1EC002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
   Part No SW: 4K0 941 591 BD    HW: 4K0 941 591 B
   Component: LMS_MLBevo    H11 0040
   Dataset Number: 80B909471E  0010
   ASAM Dataset: EV_LMSLeftHELLAAU58X 001015
   ROD: EV_LMSLeftHELLAAU58X_AU37.rod
   VCID: 72BDD6F69428486A887-8026
   Dataset Number: 80B909472E  0010
   ASAM Dataset: EV_LMSRightHELLAAU58X 001015
   ROD: EV_LMSRightHELLAAU58X_AU37.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:| 4N0-035-502.clb
   Part No SW: 80A 035 502 B    HW: 80A 035 502 B
   Component: WLC Front     H14 0061
 Coding: 800000
   VCID: 1A6DDE562C18D02A607-804E
End----(Elapsed Time: 02:36, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
-------------------------------1 Fault Found-------------------------------
dkavanagh
C?ID=9235
I can certainly re-flash back to stock. Have you seen a brand-name tune like IE clear codes?
I ONCE had an ECU specialist delete a manifold error from an EDC16 ECU as nothing I did would shut it up, even with a different ECU.
dkavanagh
C?ID=9235
The first time I noticed this, I pulled these engine codes. It was odd because there was no date or frequency data:
Saturday,24,January,2026,09:37:22:30367
VCDS Version: Release 25.3.2 (x64) Running on Windows 10 x64
DAK
Address 01: Engine Labels: 06M-907-309-V1.clb
Control Module Part Number: 80A 907 559 G HW: 06M 907 309 G
Component and/or Version: V6 3.0l TFSI H11 0002
Software Coding: 2A2A0032257E090E34380000000000000000000000000000
Work Shop Code: WSC 00000 000 00000
ASAM Dataset: EV_ECM30TFS01180A907559G 001002 (AU49)
4066 - Engine Torque Monitor
P1336 00 [01100000] - Control Limit Exceeded
30935 - Internal Control Module
P060C 00 [01100000] - Main Processor Performance
I would flash it back and see what the results are. You may also have to install the oem parts as well.
Unfortunately (and this is only a suspicion) there were most likely codes "shut off" or removed from the ECU , hence the clean scan but CEL present.
That is because most of the codes which trigger a fault for your mods were "coded out" ; IMO. Also, it would be rare , but the ECU may now have a faulty circuit .
Let us know how it goes.
dkavanagh
C?ID=9235
I flashed the ECU back to stock. I took it for a drive, my laptop and VCDS ready to read anything. I drove it twice as far as yesterday's outings and nothing happened! Now, it's 10F out, 5 degrees warmer than yesterday. It's either the software made the difference, or the conditions to create the problem didn't exist today. I will drive it this evening and tomorrow morning when it's cooler out and see how it goes.
dkavanagh
C?ID=9235
Went out again, 8F now, no problems. Will try in the morning with lower temps expected. Leaning towards having a conversation with IE!
Glad you are making progress! Many, not all, of these "tuners" are simply trying to sell a product and IMO they take advantage of the owners/buyers enthusiasm. Make promises that simply are not true. Sure, there will be horsepower gains , but at what cost ; they don't have to live with the car, you do. (ie fault codes and CEL lights). They conveniently keep these problems quiet.
You have learned a lesson (Beware!) ;)
Ziddywerks
Northern NJ USA
C?ID=208579
Shit IE tune as usual nothing new.
dkavanagh
C?ID=9235
ok, yup. I drove the car on the stock tune at 5-6 degrees this morning, no issues. I flashed back to the "IE True Flex" tune and got the problem twice on the test drive.
I've given IE a heads up about this and will let them know I won't recommend their TrueFlex tune to anyone in the cold. Of course, maybe they can fix it, but not throwing a code? That's not cool. If it's your own error catching code, at least make up a DTC we can trace back to you.
I may reflash to their Stage 1+ 93 octane tune, which I ran before installing the flex fuel sensor last spring-summer. I'd really like to test that to narrow it down.
That said, is there any tuner you guys do like? 034? Unitronic? I did enjoy the extra HP and torque, but 100% do want a reliable vehicle above all else.
dkavanagh
C?ID=9235
I just did a test drive with the Stage1+ 93 octane tune. It was up to 14 degree. No issues whatsoever. I'm not calling that conclusive, but a positive sign (and that I ran this tune last winter with no issues). I'll leave that for now as temps are coming up and I won't have a good testing environment.
I'm pushing on IE to do better. Not sure if I'll trust their TrueFlex tune anyway.
Ziddywerks
Northern NJ USA
C?ID=208579
I'll bite, I do not like any tuner, I think they are all garbage to a degree, cookie cutter tunes are generic at best their marketing teams do a good job of pushing the product. These EA839 engines have had a hard enough time staying together in stock form as it is, I wouldn't dare mess with one that I will be using as a daily driver. If you want to modify a vehicle, buy a dedicated weekend car throw standalone in it and get a base file for it and tune it yourself by learning or by paying someone with experience to do it on a dyno. Also saying reliable and owning a EA839 equipped vehicle is like saying Chrysler makes great cars. Nothing could be further from the truth. Not being a dick that's just the reality of it.
dkavanagh
C?ID=9235
Probably not want I want to hear, but what I need to hear. I went from a Gen1 EA888 A5, which had a ton of issues, more than half weren't under warranty. I know I need to keep an eye on the water pump, soon-ish. It has updated rocker arms. There is that piston skirt issue that some have. I'm not sure what other known issues there are.
