P1889 and P2185 Driver bloes luke warm. Passenger hot
cbello5
Plymouth, MA, USA
C?ID=642521
Hey All,
First post to the forum.
My 15 a3 2.0t single zone clinate is having an issue with no driver side heat but passenger side is getting hot.
I have P1889 N82 coolant shut off valve and P2185 ect coolant tempnsensor at radiator.
I replaced the g83 sensor and the wires about 3 inches up. Once I did this the p2185 came on. It wasn't on before. Changed it initially because the coolant temp at radiator output is -48c and the oulet is -38c. Also hooked the ground up to the chasis where the tpms and hill assist is.
Also replaced the coolant shut off valve and sensor. But the fault still there.
Did a coolant flush and heater core flush.
This is my first Audi and I am banging my head against the wall. Any thing will help.
Thanks all.
Dr Sheldon
Windsor UK
C?ID=334979
To get any help here you must post a VCDS Autoscan.
cbello5
Plymouth, MA, USA
C?ID=642521
Attached is the scan. It is showing alot of databus errors now.
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 22 42 44 52 55 5F BB BC
VIN: WAUBFGFF1F1013478   Mileage: 211223km-131247miles
Address 01: Engine (J623-CNTC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
   Revision: --H13---    CVN: 7E07A61D
   Coding: 0A1D00124426000F2000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0205G0906259A 001004
   ROD: EV_ECM20TFS0205G0906259A.rod
   VCID: 2C06E7F7368A9C1A02B-8078
   VINID: 9D1952597596056040043107201BD061B2
15446 - Blocking Valve for Coolant (N82)
          P1889 00 [00101111] - Open or Short to Ground
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 15:37:15
                    Engine speed: 798.25 /min
                    Normed load value: 10.2 %
                    Coolant temperature: 62 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 14.648 V
                    Engine: operating status: IS
                    STATE_LS_SAE[1]: OL_INTR
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 32 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.978 V
                    FAC_TPS_1_SAE: 12.890625 %
                    FUP_H_SAE: 4930.0 kPa
16837 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
          P2185 00 [10101111] - Signal too High
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 15:37:13
                    Engine speed: 788.50 /min
                    Normed load value: 10.6 %
                    Voltage terminal 30: 14.570 V
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 33 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.958 V
                    FUP_H_SAE: 4830.0 kPa
21425 - Secondary Air Injection System: Bank 1
          P0491 00 [11101101] - Insufficient Flow
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 15:31:14
                    Engine speed: 1094.00 /min
                    Normed load value: 19.6 %
                    Coolant temperature: 17 °C
                    Intake air temperature: 11 °C
                    Voltage terminal 30: 14.433 V
                    Charge air pressure control valve position: actual value: 0.19 %
                    T_AST_SAE: 16 s
                    STATE_BPA[0]: OPM
                    Lambda probes actual: bank1: 1.2002
                    VLS_DOWN_SAE[1]: 1.275 V
                    TEMP_CAT_UP_1_SAE: 769.8 °C
Readiness: 1010 0101
   Part No SW: 0D9 300 011 S    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H52 4312
   Revision: 05852204    Serial number: TFK01403042928 CVN: 0000348D
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 251012D35560AD52DD5-8070
          P1734 00 [00000010] - -
   Revision: 00000000    Serial number: 60694000000421
   Coding: 13FF6A9234210A6F017B030781CB29C8562C5080C08194B4024100588608
   VCID: 7BA414AB8364CBA2DB1-802E
8286 - Databus
          [FCAN: MO_Timeout_ESP signal is invalid]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:19
Address 08: Auto HVAC (E87)       Labels:| 8V0-820-047.clb
   Part No SW: 8V0 820 047 E    HW: 8V0 820 047 E
   Component: AC Manuell el H11 0052
   Revision: 20021000    Serial number: 00000000055709
   Coding: 03000004000000000000000000000000
   ASAM Dataset: EV_AirCondiFrontManAU37X 008018
   ROD: EV_AirCondiFrontManAU37X.rod
   VCID: 382ECBA7F2D220BA763-806C
459012 - Databus
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:14
   Part No SW: 5Q0 937 085 S    HW: 5Q0 937 085 S
   Component: BCM MQBAB MNA H16 0124
   Serial number: 00011407800299 Dataset Number: 8V0909514H  0073
   Coding: 04141A46C041227541C04004511007000000000000000000000000000000
   ROD: EV_BCMBOSCH_012.rod
   VCID: 49C8BE639938A93219D-801C
   Component: WWS371 140307  041 0585
   Serial number:         140313093858
   Coding: 0A47F7
   Subsystem 2 - Part No SW: 8U0 955 559 A    HW: 8U0 955 559 A  Labels: 8U0-955-559.CLB
   Component: G397_RLS  H06 0002
   Serial number: 20143503
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 K    HW: 8V0 941 531 K
   Serial number: 17 12 2013  00001565
   Serial number: 00000000000059156959
   Sunroof control module:
   Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.014  H02 0007
   Serial number:     WOO27912612
   Coding: 101F00
533269 - Databus
          [ESP_20 Datenbus fehlende Botschaft]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:02:50
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 11.8 V
                    Outside temperature: 1.0 °C
533525 - Databus
          [ESP_07_alt aktiv]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:14
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 11.8 V
533781 - Databus
          [ESP_02 Datenbus fehlende Botschaft]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:14
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 11.9 V
554517 - Databus
          [ESP_05_alt aktiv]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:14
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 11.8 V
554773 - Databus
          [EPB_01_alt aktiv]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:14
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 11.8 V
555029 - Databus
          [ESP_21_alt aktiv]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:14
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 11.8 V
   Serial number: 003GCR008RSZ Dataset Number: 8V0909602B  0019
   VCID: 47CCB85B8F2C5F420F9-8012
   Left seat belt tensioner:
   Serial number: 34178311A19021440796
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34178312A13031440139
   Coding: 333135
   Serial number: 6940000Y1400012CVT04
   Coding: 303139
   Subsystem 4 - Part No SW: -----------    HW: 480 001 803 14
   Serial number: 35700000000959913F0N
   Subsystem 5 - Part No SW: -----------    HW: 480 001 803 14
   Serial number: 35800000000439913F0H
   Subsystem 6 - Part No SW: -----------    HW: 480 401 303 14
   Serial number: 3510002BF14476B1415
   Subsystem 7 - Part No SW: -----------    HW: 480 401 303 14
   Serial number: 3520002AD14476B3035-
   Subsystem 8 - Part No SW: -----------    HW: 480 401 702 14
   Serial number: 355000299107DB42C175
   Subsystem 9 - Part No SW: -----------    HW: 480 401 702 14
   Serial number: 3560002C914D3E704221
1055232 - Databus
          [NWD: 0x11E ESP_08 Timeout]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:15
1052928 - Databus
          [NWD: 0x0FD ESP_21 Timeout]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:15
1049088 - Databus
          [NWD: 0x101 ESP_02 Timeout]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:15
1052416 - Databus
          [NWD: 0x106 ESP_05 Timeout]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:15
1052672 - Databus
          [NWD: 0x392 ESP_07 Timeout]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:15
1049095 - Databus
          [NWD: 0x101 ESP_02 error value ESP_Gierrate]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:02:49
   Part No SW: 8V0 953 521 CB    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 18031408490849
   Coding: A018
   ROD: EV_SMLSKLOMQB_017.rod
   VCID: 7CA617B7866ACC9AD2B-8028
617752 - Selector Lever Park Position Lock Switch
          B1162 29 [00011000] - Signal Implausible
                    Reset counter: 200
                    Mileage: 210297 km
                    Date: 2026.01.30
                    Time: 12:20:31
                    Operating time: 255091 min
                    Terminal 30 power supply: 14.9 V
                    Vehicle speed: 10 km/h
                    Voltage at switch: 5.02 V
                    Terminal 15 status: active
                    System status: 30
   Part No SW: 8V0 920 960 B    HW: 8V0 920 960 B
   Component: KOMBI         H02 2220
   Coding: 0BF418092B80D7050200A800180000
   VCID: 3A2AD1AFCCDE32AA807-806E
16776967 - Databus
          [EPB_02 keine Kommunikation]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:14
16776968 - Databus
          [ESP_24 keine Kommunikation]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:14
16776973 - Databus
          [RKA_01 keine Kommunikation]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:02:54
16776993 - Databus
          [ESP_21 keine Kommunikation]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:14
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2163
   Revision: --------    Serial number: 22031410801310 Dataset Number: 8V0909515D  0049
   Coding: 0101000820085A005B00020C180B00000001000000000000000000000000
   GVL: 01D03C0000000000400C10000000C80000000000000000000000000000000000
   ASAM Dataset: EV_GatewConti 010015
   ROD: EV_GatewConti_010.rod
   VCID: 3FDCA0BBD7FC1782B79-806A
   Generator:
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 10 03 2014  E0358890
131603 - No Communication with ABS Brake Control Module
          U0121 00 [00001000] - -
          [Timeout Knoten 0x13 / 03 - Steuergerät für ABS Bremse]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:02:53
                    Terminal 30 power supply: 11.9 V
                    Terminal 15: On
   Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
   Component: Haldex4Motion H52 7076
   Serial number: HA1-00030.01.14 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_002_VW37.rod
   VCID: 46D2B55F8826464AF4F-8012
8 Faults Found:
16670 - All-Wheel Drive
          C1113 07 [00001000] - Mechanical Failure
                    Reset counter: 175
                    Mileage: 209888 km
                    Date: 2026.01.26
                    Time: 07:57:58
16655 - Databus
          [Bremsensteuergerät - TO -- ESP_02]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:15
17468 - Databus
          [Bremsensteuergerät - TO -- ESP_05]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:15
17495 - Databus
          [Bremsensteuergerät - TO -- ESP_07]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:15
17471 - Databus
          [Bremsensteuergerät - TO -- ESP_14]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:02:54
17469 - Databus
          [Bremsensteuergerät - TO -- ESP_19]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:15
17472 - Databus
          [Bremsensteuergerät - TO -- ESP_20]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:02:54
17470 - Databus
          [Bremsensteuergerät - TO -- ESP_21]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:15
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 23031403110363 Dataset Number: 8V0909872E  0030
   Coding: 00100F204000048000000002
   VCID: 3E22DDBFD0F61E8ABCF-806A
458776 - Databus
          [Gateway_71 Datenbus fehlende Botschaft]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:15
   Component: EPS_MQB_ZFLS  123 1043
   Dataset Number: 8V0909852G  0018
   Coding: 0102
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41D8A643A1086172C1D-8014
7 Faults Found:
19712 - Databus
          [ESP_10 Botschaft - CAN-Timeout]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:15
                    Motor status: 00
                    System status: Driving mode
                    Supply voltage: 11.75 V
                    Temperature: 11.0 °C
                    KFC: 4D
                    KFA: 00 00
                    Freeze frame conditions: 21
                    uioUdNotFilt_xdu16: 11.98 V
                    uAdSensI_SwitchedKl30_xdu16: 11.99 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
20224 - Databus
          [ESP_19 Botschaft - CAN-Timeout]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:15
                    Motor status: 00
                    KFC: 4F
                    KFA: 00 00
19456 - Databus
          [ESP_05 Botschaft - CAN-Timeout]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:15
                    Motor status: 00
                    KFC: 4C
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 11.81 V
                    uAdSensI_SwitchedKl30_xdu16: 11.82 V
19204 - Databus
          [ESP_02 Botschaft - SNA_Check]
                    Fault Frequency: 144
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:15
                    Motor status: 00
                    KFC: 4B
                    KFA: 00 04
20992 - Databus
          [ESP_24 Botschaft - CAN-Timeout]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:15
                    Motor status: 00
                    KFC: 52
                    KFA: 00 00
19968 - Databus
          [ESP_14 Botschaft - CAN-Timeout]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:02:54
                    Motor status: 00
                    KFC: 4E
                    KFA: 00 00
20480 - Databus
          [ESP_20 Botschaft - CAN-Timeout]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:02:54
                    Motor status: 00
                    KFC: 50
                    KFA: 00 00
   Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
   Serial number: 21031403110254 Dataset Number: 8V0909873E  0029
   Coding: 001007204000048000000002
   VCID: 3D20DAB3DDF00592A55-8068
458776 - Databus
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:15
   Revision: --------    Serial number: -------------- Dataset Number: 8V0909865H  0034
   Coding: 012A000101000000
   ROD: EV_HeadlRegulVWLWRMQB_VW37.rod
   VCID: 75B00293A5409DD2AD5-8020
13705472 - Databus
          [ESP_19 Datenbus fehlende Botschaft]
                    Reset counter: 204
                    Mileage: 211223 km
                    Date: 2026.02.07
                    Time: 08:01:14
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 844     HW: 8V0 035 844
   Component: MU-S-S-US     012 0626
   Serial number: A7A02303142258 Dataset Number: 8V1909545C  0038
   Coding: 01730100FF0A000011220001001A00002F0001040100010002
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE.rod
   VCID: 76B2059FB84696CAA4F-8022
   Multimedia display unit 1:
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0013
   Serial number: AUZ8Z9EY302QV3
   Subsystem 2 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
   Component: ControlUnit_B  H33 0037
   Serial number: C1000028011400010099
                    Reset counter: 83
                    Mileage: 207618 km
                    Date: 2026.01.03
                    Time: 13:35:44
                    Voltage terminal 30: 14.5 V
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
   Part No SW: 5Q0 959 395 B    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0025
   Serial number: 18031404080580 Dataset Number: 8V0909897C  0017
   Coding: 000007204000048000000002
   ROD: EV_DCURearDriveMAXKLO.rod
   VCID: 40DEA347AA02687ACE3-8014
   Component: TSG HBFS      020 0025
   Serial number: 18031404080575 Dataset Number: 8V0909896C  0017
   ROD: EV_DCURearPasseMAXKLO.rod
End----------(Elapsed Time: 01:35, VBatt start/end: 14.9V/15.0V)-----------
------------------------------43 Faults Found------------------------------
Fit a new N82
cbello5
Plymouth, MA, USA
C?ID=642521
I replaced the N82 and the connector in summer 2025. Once I replaced them the code did not go away. Think its a bad part?
What did you fit?
cbello5
Plymouth, MA, USA
C?ID=642521
Replaced the coolant shut off valve N82 with part #4 H0121671D.
That is the old part number, it is now 4H0 121 671 G so did you fit a second hand part?
cbello5
Plymouth, MA, USA
C?ID=642521
It was a new part from a reputable supplier.
Apart from testing the wiring back to the ECU, all you can do is plug in a new valve and see what happens. Do you know which make it is?
cbello5
Plymouth, MA, USA
C?ID=642521
It was from FCP Euro. The site doesn't show the manufacturer anymore.
