2015 Flying Spur will cluster relearn radio code?
JeffYoung
Ireland
C?ID=632815
I’ve had to replace my radio as it kept crashing/rebooting. The repaired one asked for a PIN code when I fired it up, which I entered. Will the cluster now learn the new code so I don’t have to enter it again (if I have to disconnect the battery for something), or is there something I need to do to kick off a relearn?
(I’m assuming that my cluster stores it as I never had to enter it with the old radio.)
Wednesday,28,January,2026,12:01:38:42506
VCDS Version: 25.3.2.0 (x64)  HEX-NET2 CB: 0.4671.5
VIN: SCBEB53W4FC043800   License Plate: 142D28712
Mileage: 37500km-23301mi   Repair Order:
Chassis Type: 3W-BY62 (3W0)
Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 19 28 2E 34 36 37 38
          46 47 48 53 56 57 5D 65 66 68 6C 6D 71 76 77
VIN: SCBEB53W4FC043800   Mileage: 37500km-23301miles
38-Roof Electronics -- Status: OK 0000
48-Seat, Rear, DS -- Status: OK 0000
5D-Operations -- Status: OK 0000
66-Seat, Rear -- Status: OK 0000
68-Wiper Electr. -- Status: OK 0000
71-Battery Charger -- Status: OK 0000
Address 01: Engine (J623-CVAA)       Labels: None
   Part No SW: 07C 906 023 AD    HW: 07C 907 309
   Component: ME17.1.6      H16 0302
   Revision: MHH16---    Serial number: VWX3Z0N3011379 CVN: 943FC4B8
   Coding: 0D2A0032432F00010003
   Shop #: WSC 00083 790 00196
   ASAM Dataset: EV_ECM60TMP11107C906023AD 001005
   ROD: EV_ECM60TMP07C906023AD.rod
   VCID: 6398DEA0FBDFD8B2F31-8036
   VINID: 8D34954850E71164C0103200008A7B3782
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 4W0 927 158 D    HW: 0CU 927 760 A
   Component: OBL 60 MPIRdW H18 0001
   Revision: --H18---    Serial number: VWX3Z0N3011379 CVN: 4F158342
   Shop #: WSC 00083 790 00191
   ASAM Dataset: EV_TCMAL450211 002010
   ROD: EV_TCMAL450211_BY62.rod
   VCID: 3FD032D037F7DC52B79-806A
Address 03: ABS Brakes        Labels: None
   Part No SW: 4W0 614 517 C    HW: 4W0 614 517 C
   Component: ESP 8.1 4WD     H01 1200
   Coding: 0002543
   Shop #: WSC 00083 790 00175
   VCID: 363E57F4140D1D1A64F-8062
   Part No SW: 3D0 909 137 F    HW: 3D0 909 137 F
   Component: C0 Kessy            6850
   Revision: 00H24072    Serial number: VWX3Z0N3011379
   Coding: 0422125
   Shop #: WSC 00083 790 00187
   VCID: 2A067384D0B549FAF07-807E
   Part No SW: 4W0 959 760 A    HW: 4W0 959 760
   Component: MEM-BFS       H04 0700
   Revision: AA000000    Serial number: 00000100912004
   Coding: D0281F0085070090090001010101012100012727000000
   Shop #: WSC 00083 790 00236
   VCID: 40D2312C4AC9A3AACE3-8014
Address 07: Control Head        Labels: 3D0-907-048.clb
   Part No SW: 3D0 907 048     HW: 3D0 907 048
   Component: J127 KBT vorn       0100
   Revision: ABH25001    Serial number: VWZ6Z7P0190032
   VCID: 6398DEA0F71FD8B2F31-8036
   Part No: 3W5 907 040 K
   Component: Climatronic BY621   3030
   Coding: 0000101
   VCID: 3E2E4FD43C3DD55ABCF-806A
00016 - Motor for Footwell/Defrost Flap; Rear Right (V195)
            014 - Defective
Address 09: Cent. Elect.        Labels:. 3D0-937-049-V2.clb
   Part No SW: 3D0 937 049 Q    HW: 3D0 937 049 Q
   Component: J519                7700
   Revision: -4007---    Serial number: --------------
   Coding: 40820000AB2A11C02508030000000000
   VCID: 382259CC1E19EB6A763-806C
Address 11: Engine II (J624)       Labels: None
   ASAM Dataset: EV_ECM60TMP21107C906023AD 001005
   ROD: EV_ECM60TMP07C906023AE.rod
   Part No SW: 3W3 959 655 A    HW: 3W3 959 655 A
   Component: VW10Airbag22I H01 0003
   Revision: --------    Serial number: 003FW0003DP5 Dataset Number: V03935197ZY 0002
   Coding: 000000000000000000000000000000003249
   ASAM Dataset: EV_AirbaVW10BPABY62X 001002
   ROD: EV_AirbaVW10BPABY62X.rod
   VCID: 45DC2038552B8682FD5-8010
   Serial number: 3572DRB40000F72C931Z
   Serial number: 3582DRB40000F72C92B2
   Serial number: 35128RB4000071993F3M
   Serial number: 35228RB400007193DBAU
   Serial number: 35547RB40000730129EG
   Serial number: 35647RB4000073012F9I
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 K
   Component: J527                3601
   Coding: 0000032
   Shop #: WSC 00083 790 00244
   VCID: 47C02A3063E794920F9-8012
Address 17: Instruments        Labels: 3Wx-920-xxx-17.clb
   Part No SW: 3W0 920 851 M    HW: 3W0 920 851 M
   Component: J285 KOMBI-INST.    5555
   Revision: KPH10V04
   Coding: 0038414
   Shop #: WSC 23283 007 1048576
   VCID: 40D2312C4689A3AACE3-8014
Address 19: CAN Gateway        Labels: None
   Part No SW: 3W0 909 901     HW: 3W0 920 851 M
   Component: J533  GW-K-CAN TP20 5555
   Revision: KPH10V04
   Coding: 5FFAFFFFEF551703
   VCID: 76BE97F454CD5D1AA4F-8022
Address 28: HVAC, Rear (J524)       Labels: None
   Part No SW: 4W0 035 008 A    HW: 4W0 035 008 A
   Component: CLIMATE ECU   H06 0070
   Revision: P0H06004    Serial number: 51400119500001
   Coding: 00000001010002
   VCID: 2C0A759CD64157CA02B-8078
   Revision: A1001003    Serial number: 7666466409
   Coding: 030100
   VCID: 2B087680D30F50F20B1-807E
Address 34: Level Control        Labels: None
   Part No: 4W0 907 553
   Component: LUFTFDR.-CDC- 3C3V0 7705
   Coding: 0005541
   Shop #: WSC 00083 790 00169
   VCID: 78A299CC5E992B6AB63-802C
00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
   Component: MEM-FS        H04 0700
   Revision: AA000000    Serial number: 00000102078815
   Coding: D0281F0085870090090001010101012100012727000000
   Shop #: WSC 00083 790 00242
Address 37: Navigation (J0506)       Labels:. 3D0-035-680.clb
   Part No SW: 3W0 035 017 T    HW: 3W0 035 017 T
   Component: RNS-MID       H25 0286
   Revision: AB001001    Serial number: VWZ6Z7P0190032
   Coding: 04010002000000014000
   VCID: 3E2E4FD4307DD55ABCF-806A
Address 38: Roof Electronics        Labels: None
   Part No: 3W0 907 135 H
   Component: Dachmodul           0910
   Coding: 0020493
   VCID: 3B2846C02F2FC0729B1-806E
Address 46: Central Conv.
Address 47: Sound System        Labels: None
   Part No SW: 4W0 035 465     HW: 4W0 035 465
   Component: DSP 10 Kanal        0010
   Revision: 00H08001    Serial number: 75824013234204
   VCID: 72B6ABE438A5413A887-8026
Address 48: Seat, Rear, DS
Address 53: Parking Brake (J540)       Labels: None
   Part No SW: 4W0 907 801     HW: 4W0 907 801
   Component: EPB-4         H01 0002
   Revision: --------    Serial number: 00000000002628 Dataset Number: V03935199CZ 0001
   ASAM Dataset: EV_BY62XParkiBrake 001008
   ROD: EV_BY62XParkiBrake.rod
   VCID: 74BAADFC4E314F0A9AB-8020
Address 56: Radio (J0506)       Labels:. 3D0-035-680.clb
Address 57: TV Tuner        Labels: None
   Part No SW: 3W0 919 148     HW: 3W0 919 148
   Component: DVBT-DTV            0080
   Revision: R0H03000    Serial number: 13000500126401
   Coding: 0000003
   VCID: 7AA683C460D5397AC07-802E
Address 5D: Operations
Address 65: Tire Pressure        Labels: 3D0-907-273-V5.clb
   Part No SW: 3W7 907 273 D    HW: 3W7 907 273 D
   Component: J0502 RDK           0007
   Revision:   004007    Serial number: 00000600002019
   Coding: 3000E03175CA4286EB75B9FD52EB0097FC004B6E4B6E4B6E4B6E4B64
   Shop #: WSC 00083 790 00215
   VCID: 41D434284DC3AAA2C1D-8014
Address 66: Seat, Rear (J877)       Labels: None
   Component: MEM-BFS-Fond  H04 0700
   Revision: AA000000    Serial number: 00000107815291
   Coding: C0281E8085810000090021000001000000002727000000
   Shop #: WSC 00083 790 00190
Address 68: Wiper Electr.        Labels: 3Wx-955-023.clb
   Part No: 3W5 955 023 N
   Component: Wischermodul       ™0401
   Shop #: WSC 00000 725 65552
   VCID: 45DC203859EB8682FD5-8010
Address 6C: Back-up Cam.        Labels: None
   Part No SW: 4W0 907 441     HW: 4W0 907 441
   Revision: 00H13000    Serial number: 525 PA8J470100
   Coding: 2022003
   VCID: 74BAADFC42B14F0A9AB-8020
Address 6D: Trunk Elect.        Labels:. 7N0-959-107.clb
   Part No SW: 4W0 959 107     HW: 4W0 959 107
   Dataset Number: V03935220VP 0002
   Shop #: WSC 47386 001 1048576
   ASAM Dataset: EV_HDSGBY621 001002
   ROD: EV_HDSGBY621.rod
   VCID: 7AA683C46C55397AC07-802E
Address 71: Battery Charger (J367)       Labels:* None
   Part No SW: 3W3 915 181 B    HW: 3W3 915 181 B
   Component: EMM Batt Man  H05 0570
   Serial number: 0000000001
   Coding: 5E0100
   ASAM Dataset: EV_BatteChargVaria1 002019
   ROD: EV_BatteChargVaria1_002.rod
   VCID: 382259CC12D9EB6A763-806C
Address 76: Park Assist        Labels: 3W0-919-283-V3.clb
   Part No SW: 3W0 919 283 G    HW: 3W0 919 283 E
   Component: J446  ST Parkhilfe  0111
   Revision: 11H02001    Serial number: 58131419001280
   Coding: 0308066
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3D0 035 730 D    HW: 3D0 035 730 D
   Component: Telefon       024 0982
   Revision: --------    Serial number: 35502105166795
   Coding: 020106010100010000000001
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi_002_VW32.rod
   VCID: 1D6CA8589D3BAE42855-8048
End----------(Elapsed Time: 03:07, VBatt start/end: 14.5V/14.4V)-----------
------------------------------2 Faults Found-------------------------------
TTT
C?ID=547002
Never heard of such a thing. And I have some years ...
My guess is it's the other way around; i.e. the radio learns the car it's supposed to be in.
That said, the radio's PIN isn't going to change, and since you have it, I wouldn't worry much about it one way or another.
Dr Sheldon
Windsor UK
C?ID=334979
That is the rumour - The radio will marry itself to the car.
Quite likely it will learn the VIN of your vehicle and not need that pin code until it is fitted to another vehicle..
I'll try to remember to report back on the results next time I have to disconnect the battery....
For science, why not disconnect it now to see what happens?
JeffYoung
Ireland
C?ID=632815
I got scared off by all the steering angle sensor faults last time around....
