AUDI A4 Avant
Marco Audi TT
Perugia, Italy
C?ID=503954
Good evening
After solving the "00003 - Control Module - 005 - No or Incorrect Basic Setting / Adaptation" problem on the AUDI TT, I'm now having the same problem on the AUDI A4 Avant. If I remember correctly, this problem arose when I tried to set the routine maintenance to 15,000 km (while the car leaves the factory with a 30,000 km mileage setting). I ran a diagnostics before the maintenance, and this error wasn't there. The mechanic probably tried to change the reference parameter. Please help. Thanks.
Saturday,07,February,2026,11:23:06:36078
VCDS Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4671.4
VIN: ---   License Plate:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 52 53 55 56 62 72
VIN: ---   Mileage: 258330 km
Address 01: Engine (J623-CAGA)       Labels:. 03L-906-019-CAG.clb
   Part No SW: 03L 906 022 NN    HW: 03L 906 019 AL
   Component: R4 2.0l TDI   H22 9982
   Revision: 25H22---    CVN: 064FD9DD
   Coding: 12194012230403080000
   Shop #: WSC 26534 005 1048576
   ASAM Dataset: EV_ECM20TDI03L906022NN A02019
   ROD: EV_ECM20TDI03L906022NN.rod
   VCID: 7EA4FDD6C07FBB1AFCF-802A
   VINID: 9D196AAAA21B0114410082451CEB63EE8C
   Part No SW: 8K0 907 379 AK    HW: 8K0 907 379 AK
   Component: ESP8 front    H04 0070
   Coding: 160504
   Shop #: WSC 06325 000 00000
   VCID: 025C8926B407DFFA987-8056
   Part No SW: 8K0 907 064 DP    HW: 8K0 907 064 DP
   Component: BCM2 1.1      H02 0327
   Coding: 032200
   VCID: 015E862AB101C4E281D-8054
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Serial number: 0509000073860005
   Serial number: 0209000100025001
Address 08: Auto HVAC (J255)       Labels:. 8Tx-820-043-1Z.clb
   Part No SW: 8T1 820 043 AG    HW: 8T1 820 043 AG
   Component: KLIMA 1 ZONE  H08 0171
   Revision: A0000000    Serial number: 01091220091404
   Coding: 34200000
   VCID: 76B4E5F6E8CFF35AA4F-8022
                    Reset counter: 195
                    Mileage: 258054 km
                    Date: 2026.02.03
                    Time: 16:05:33
                    Temperature: 12.0°C
                    Temperature: 15.0°C
                    Absolute Pres.: 0.8 bar
                    Current: 0.000 A
                    Temperature: 12.0°C
   Part No SW: 8K0 907 063 N    HW: 8K0 907 063 N
   Component: BCM1 1.0      H25 0380
   Revision: 09025001    Serial number: 00000000537280
   Coding: 26005091403400010001000000001D0D0F1C070804010001000000
   VCID: 3A2C31C69C57573A807-806E
   Component: WWS 121209  H06 0070
   Serial number: SWF09120126161
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 941 531 AK    HW: 8K0 941 531 AK
   Component: E1 - LDS  H08 0090
   Serial number: 00000000000312090632
   Part No SW: 8K0 959 655 G    HW: 8K0 959 655 G
   Component: AirbagVW-AU10 H39 0560
   Serial number: 003EFD08BZX3   Dataset Number: 8K0909602G  0003
   Coding: 30343435363030303030554A304C384B3053
   VCID: 41DE462AF10104E2C1D-8014
   Serial number: 6334MSME4E706B50K
   Serial number: 6344MSME4F0631216
   Serial number: 6352QSME154725001
   Serial number: 6362QSME3A485726N
   Serial number: 63732SME1E474C10%
   Serial number: 63832SME09470812V
   Revision: --------    Serial number: 90304ILE0002A
   Coding: 000013
   VCID: 3D263ADA8D796002A55-8068
   Part No SW: 8K0 920 930 D    HW: 8K0 920 930 D
   Component: KOMBIINSTR.   H20 0255
   Revision: 00100000    Serial number: CIY64AFD9
   Coding: 0F04100002000008040000
   VCID: 2E040D96501F8B9A2CF-807A
                    Fault Status: 01100101
                    Reset counter: 152
                    Mileage: 258054 km
                    Date: 2026.02.03
                    Time: 16:04:22
   Part No SW: 8T0 907 468 R    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0105
   Revision: GB600050    Serial number: 5000G09C068003
   Coding: 00CF07
   VCID: 50F8736E2AEBFD6A5E3-8004
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790864721
   Component: J532_DCDCStab  H15 0038
   Serial number: 09349000910011200180
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000009804488
   Coding: 011C02205000410001
   VCID: 45D6523AE5A928C2FD5-8010
   Revision: 00002001    Serial number: 0124991919
   Coding: 01000620203904C00120023680000000
   Shop #: WSC 06342 000 00000
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000009769821
   VCID: 44D04F3EEE9311CAEAB-8010
   Revision: 00000003    Serial number: 00000000526080
   VCID: 34301FFEBE33A14A5AB-8060
   Part No: 8K5 907 357 A
   Coding: 0000004
   Shop #: WSC 06324 000 00000
   VCID: 38282BCEAE5B452A763-806C
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 195 AA    HW: 8T1 035 195 AA
   Component: Symphony3     H04 0310
   Revision: 00000007    Serial number: AUZ5Z4I1162949
   Coding: 05000480040205000159070000
   Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
   Component: Display
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000102519816
   Coding: 010C02204000210001
   VCID: 42DC4926F4871FFAD87-8016
   Revision:             Serial number: 0000102519820
                    Fault Status: 01101000
                    Reset counter: 152
                    Mileage: 258054 km
                    Date: 2026.02.04
                    Time: 09:42:02
End----------(Elapsed Time: 01:13, VBatt start/end: 12.3V/12.3V)-----------
------------------------------3 Faults Found-------------------------------
Marco Audi TT
Perugia, Italy
C?ID=503954
This is probably about [SRI Reset] resetting the service interval. Instruments have memorized some value that they don't like.
Now how can I fix the error? I decide when to change the engine oil (15,000 km). I don't need my car to remind me.
Marco Audi TT
Perugia, Italy
C?ID=503954
Saturday,07,February,2026,21:31:18:36078
VCDS Release 25.3.2:  SRI Reset
Control Module Part Number: 8K0 920 930 D       Labels:  .8T0-920-xxx-17.clb
Component:KOMBIINSTR.   H20 0255, Coding:0F04100002000008040000
Channel      Description                                           Unit           Current val.              New val.
02 Service Reminder Status                 1        ---
40 Distance since Service      km x100       4        ---
41 Time since Service          Days          4    ---
42 Minimum Distance to Service km x100       300      ---
43 Maximum Distance to Service km x100       300     ---
44 Maximum Time to Service     Days          730      ---
45 Oil Quality                               2             ---
47 Soot Quantity               DIST x100     2            ---
48 Thermal Load            DIST x100     2             ---
49 Minimum Time to Service     Days          730      ---
50 Basic Distance Value
   for Oil Change            km x100       300      ---
51 Basic Time Value
   for Oil Change              Days          730      ---
52 Basic Distance Value
   for Inspection            km x100       300      ---
53 Distance since Inspection km x100       4        ---
54 Basic Time Value
   for Inspection              Days          730      ---
55 Time since Inspection       Days          4       ---
56 Day Counter                 Days          5891     ---
Boki Ar
Arandjelovac, Serbia
C?ID=57300
I had a similar case.
Perform SRI reset (change to fixed service interval, RoW, diesel) and fault gone.
NEtech
Denmark
C?ID=56995
You need to change these adaptation channels values:
42 Minimum Distance to Service km    150
50 Basic Distance Value for Oil Change    150
51 Basic Time Value for Oil Change    365
Then probably do an service reset.
Marco Audi TT
Perugia, Italy
C?ID=503954
Thank you all. I managed to schedule the engine oil change every 15,000 km and fixed the error. I'm increasingly happy with my purchase of the VCDS. It's a valuable tool for enabling the simple user to have a reliable vehicle.
Marco
Marco Audi TT
Perugia, Italy
C?ID=503954
51 Basic Time Value
54 Basic Time Value
Sunday,08,February,2026,10:01:36:36078
Operation: Change to fixed Intervals (Rest of World)
02           Service Reminder Status                                             0                 ---
40           Distance since Service                                km x100       0                 ---
41           Time since Service                                    Days          0                 ---
42           Minimum Distance to Service                           km x100       300               150
43           Maximum Distance to Service                           km x100       300               150
44           Maximum Time to Service                               Days          730               365
45           Oil Quality                                                         1                 1
47           Soot Quantity                                         DIST x100     0                 ---
48           Thermal Load                                          DIST x100     0                 ---
49           Minimum Time to Service                               Days          730               365
50           Basic Distance Value for Oil Change                   km x100       150               150
51           Basic Time Value for Oil Change                       Days          365               365
52           Basic Distance Value for Inspection                   km x100       300               ---
54           Basic Time Value for Inspection                       Days          730               ---
55           Time since Inspection                                 Days          5                 ---
56           Day Counter                                           Days          5892              ---
