Adapting key remote central locking
rajjinator
C?ID=580024
Hi all, apologies if this has been asked before, just can't see it for my age of vehicle...
I have a 2018 crafter and would like an additional key for it. I realise I cannot code the immobiliser in with vcds, however if I were to purchase a replacement key from a dealer (which come pre-coded for immo) would I be able to use VCDS to adapt/code the remote central locking side of things?
This would be more convenient by not having to give the van to the dealer for them to code it and save some money too.
downtime
Finland
C?ID=280813
Dealer will only get you a pre-coded key which you still need to adapt to your IMMO. That needs online connection.
Not sure about the cars equipment as there's no autoscan so cannot really tell if the remote can or cannot be done without online connection.
rajjinator
C?ID=580024
A friend recently bought a key from a dealer and it starts the van no problem. They never saw the van. But the remote central locking does not work obviously.
downtime
Finland
C?ID=280813
Again, please post an autoscan so we'll see the modules the car has
rajjinator
C?ID=580024
See below. I obscured my VIN due to general paranoia.
Sunday,01,February,2026,14:56:39:17795
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4671.4
VIN: WV1ZZZSYZJ0000000   License Plate:
Chassis Type: SY-VN54 (3Q0)
Scan: 01 03 08 09 13 15 16 17 19 42 44 52 5F 69
VIN: WV1ZZZSYZJ0000000   Mileage: 208326km-129447miles
Address 01: Engine (J623-DAUA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 NB    HW: 04L 907 445 C
   Component: R4 2.0l TDI   H01 6406
   Revision: 23201001
   Coding: 001940106324050800000000000000000000000000000000
   Shop #: WSC 00069 790 00013
   ASAM Dataset: EV_ECM20TDI03004L906056NB 005006
   ROD: EV_ECM20TDI03004L906056NB_005.rod
   VCID: 7AADE545DC5B01EAC07-802E
   VINID: 9E606AAAA8E9A9A24008308200B874AD77
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: 2N0-907-379-V1.clb
   Part No SW: 2N0 907 379 C    HW: 2N0 907 379 C
   Component: ESC_base      H02 0850
   Serial number: 08512245171024
   Coding: 29A82477483FB6859449246212436D063DF10078
   ASAM Dataset: EV_Brake1ESP90iBOSCHVN54X 701028
   ROD: EV_Brake1ESP90iBOSCHVN54X_701.rod
   VCID: 36353175A8C3258A64F-8062
Address 08: Auto HVAC (J65)       Labels:* Redir Fail!
   Part No SW: 7C0 907 184 K    HW: 7C0 907 184 K
   Component: Heizung       H01 0301
   Coding: A03110000800030001000800500101000000000000000000000000000000
   Shop #: WSC 00069 790 00017
   ASAM Dataset: EV_AirCondiBHTCVN54X 003018
   ROD: EV_AirCondiBHTCVN54X_003_VN54.rod
   VCID: 323D0D6544AB39AA487-8066
   Part No SW: 5Q0 937 084 CM    HW: 5Q0 937 084 CD
   Component: BCM MQBAB B   H36 0253
   Serial number: 01001733400596 Dataset Number: V03935325WR 0001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 055786B9A5A57E12BD5-8050
   Component: ACCCONTIMQB   H02 0233
   Dataset Number: V03935262VY 0001
   Coding: 2A00400900FF8448949C814D003007
   ROD: EV_ACCMRRCONTIVW376_002_VN54.rod
   VCID: 3E25295580F3EDCABCF-806A
   Part No SW: 3Q0 959 655 BG    HW: 3Q0 959 655 BG
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W3PR1KJ67 Dataset Number: V03935271TG 0001
   Coding: 800080000000000040000000008800000065
   ROD: EV_AirbaVW21TS6VW48X_VN54.rod
   VCID: 04519BBDAE9F471AAAB-8050
   Subsystem 1 - Part No SW: -----------    HW: 454 802 110 17
   Component: FrontSensor_D  305 0109
   Serial number: 35500C3A08610000000A
   Subsystem 2 - Part No SW: -----------    HW: 454 802 010 17
   Component: FrontSensor_P  305 0109
   Serial number: 356006C289B11000000L
   Part No SW: 5Q0 953 521     HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20171124400047
   Coding: 0000
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 6FBBC41197195442679-803A
Address 17: Instruments (J285)       Labels:| 7LA-920-XXX-V1.clb-SRI3
   Part No SW: 7C0 920 941 A    HW: 7C0 920 941 A
   Component: KOMBI         204 0310
   Coding: 27A411002080260001882A010400000000000000
   ROD: EV_DashBoardVDDMQBAB_VN54.rod
   VCID: 2411FB3D0E5FA71ACAB-8070
1048578 - No Basic Setting
          B2010 00 [00001001] - -
          [Steuergerät keine oder falsche Grundeinstellung]
                    Reset counter: 37
                    Mileage: 206215 km
                    Date: 2025.05.14
                    Time: 09:04:41
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007097384 Dataset Number: V03935272LN 0001
   Coding: 030100044F05730000000000000F00010001070000000000000000000000
   GVL: 01503C0000000000C00C80000000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VN54.rod
   VCID: 38293F4DA2D7D3FA763-806C
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0103
   Serial number: 29170002129890107384
   Coding: 28FFFF
   Subsystem 3 - Part No SW: 2N0 915 181     HW: 2N0 915 181
   Serial number: 75884900001711190188
   Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
   Serial number: 0000291409848  Dataset Number: V03935244SE 0001
   Coding: 00300B208001040100001000
   ROD: EV_DCUDriveSideEWMAXCONT_VN54.rod
   VCID: 45D746B9E525BE12FD5-8010
Address 44: Steering Assist (J500)       Labels:| 2N0-909-143.clb
   Part No SW: 2N0 909 143 E    HW: 2N0 909 143 C
   Component: EPS_MQB_ZFLS  701 7021
   Dataset Number: V03935286NR 0001
   Coding: 0107
   ASAM Dataset: EV_SteerAssisMNB 002001
   ROD: EV_SteerAssisMNB.rod
   VCID: 2F3B041157991442279-807A
   Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
   Serial number: 0000291858929  Dataset Number: V03935244SF 0001
   ROD: EV_DCUPasseSideEWMAXCONT_VN54.rod
   VCID: 44D15BBDEE1F871AEAB-8010
65586 - Window Regulator Switch
          B132C 29 [00001000] - Signal Implausible
                    Reset counter: 108
                    Mileage: 207953 km
                    Date: 2025.08.31
                    Time: 10:02:47
   Part No SW: 3Q0 035 842 C    HW: 3Q0 035 842 C
   Component: MU-S-D-ER     721 0842
   Serial number:                Dataset Number: V03935271HU 0001
   Coding: 064500003C00000051110101008808001F0500C60120050003
   ROD: EV_MUStd4CDELP_VN47.rod
   VCID: 2D071E195D956652155-8078
   Subsystem 1 - Part No SW: 7C0 919 606     HW: 7C0 919 606
   Component: ABT_HIGH  H54 1031
   Serial number: VWZ8Z9TGY01N3Z
   Part No SW: 6C0 907 383     HW: 6C0 907 383
   Component: ConWysTrailer H14 0137
   Serial number: 00000181563668
   Coding: 0100000200000000
   ROD: EV_TrailFunctGener2Hella_VN54.rod
   VCID: 678BAC31BFE98C022F9-8032
End----------(Elapsed Time: 01:17, VBatt start/end: 12.2V/12.2V)-----------
------------------------------2 Faults Found-------------------------------
downtime
Finland
C?ID=280813
For you car, dealer visit needed to get the key working. Also remote matching is done the same time as IMMO is adapted to accept the new key.
And I seriously doubt that your friend got a working key from dealer and did not have to do anything on the car. The IMMO system just does not work that way, your car IMMO has specific number of keys adapted all with their own crypto. You get a new key with precoded part, you then need to adapt it to the car so the car knows now there's an extra key available or you replace one key with another and at this point it stores the crypto id from the key to the car system. This allows the car to start with that key.
Most likely existing key was just cloned and that's it. It works that way because all the data on the chip is the same and car does not see it as extra key.
if you need spare key, easiest is to take a blank key fob, take it locksmith who does also car keys. They'll cut the key blade and clone the existing key crypto to the new one. This does not solve the remote issue probably though.
rajjinator
C?ID=580024
I have double checked with my friend. He has same van but a few years newer. He bought the key direct from VW it came with the blade cut and immobiliser pre programmed. Starts the engine just the remote central locking doesn't work
2kaa52
Ceska Republica, Praha
C?ID=319193
VW Keys NEVER come Immo pre Programmed ready for engine start
rajjinator
C?ID=580024
Oh right someone must have disabled his immobiliser then because that's exactly what he did and is happening.
downtime
Finland
C?ID=280813
My guess is the dealer cloned your friends existing key. It he behaves exactly like that.
In your car it’s dealer visit as remotes are configured to car via immo adaptation.
rajjinator
C?ID=580024
His key was water damaged as it went through the washing machine but I guess it is possible.
Dr Sheldon
Windsor UK
C?ID=334979
But Mercedes Benz keys do !! They work straight off !!
And this is a Crafter !!
Dr Sheldon
Windsor UK
C?ID=334979
Blablabla
VW Keys NEVER Work without adapting, it is what it is
Perhaps not !! The Crafter Immo is Mercedes not VW !!
Although I have not ever bought a key for a Crafter from the dealer I can believe what OP is saying.
How many crafter keys have you bought from a dealer ?
If you buy a replacement key from Mercedes it will come programmed and the blade cut. Ready to go !! That is a fact !!
downtime
Finland
C?ID=280813
I’ve done few of these 2016+ Crafters IMMO adaptation and it’s the same procedure as other VW cars.
First gen Crafter is MB platform, this one OP has is second gen and is also sold under MAN TGE brand but is VW design.
It's an SY chassis Crafter. All the systems in it are VAG, no more MBZ.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Rule of thumb, everything up to immobilizer generation 4a (adaptation) w/o kessy will allow you to match remotes separately. Starting with immobilizer 4c/4d (download), remotes are matched during the immobilizer process.
rajjinator
C?ID=580024
Please excuse my ignorance, how do I know what immobilizer generation my van is?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
The latter, as others indicated already - remotes are matched during the immobilizer matching process. I am working on an updated knowledge base which will have better coverage / information on such subjects.
