- Sep 25, 2025
- 5
- 2
- Florida, USA
- C?ID=631408
So, I am having a few issues with my manual trans swapped 2021 Arteon 4motion. I am unable to lock the car after driving it, until I clear codes. I believe it to be an issue with the J519 module. I have 2 scans of the car, one before clearing codes and one after, the only difference is the fault code 267784 for “Park lever position lock switch” in the J519 module. I believe this fault code and the J519 module to be the issue, as the car thinks it is not in park and does not allow the doors to be locked. I removed the old auto transmission selector lever with the switch for the manual one, so its not there anymore and the car is unhappy about it lol.
Does anyone have any info on how I can fix this issue? I believe it to be a remnant of the coding for the automatic trans, but I am unable to change coding on the J519 module in VCDS, and am not sure where to start/if there are any adaptation changes I can make to solve this issue.
Any info on other changes I need to make to get rid of more fault codes would be greatly appreciated!
Another thing I am interested in is what I need to do to get rid of AWD module fault code. There were no codes in the AWD module, but I pulled out the fuse (SB21) for the transmission control module to get rid of multiple faults associated with it, which then caused the one AWD fault present. I will be looking into how the TCU and AWD control module are connected in wiring and see if it is possibly a hardware issue, but I currently believe it to be an issue with coding. Also, just ignore the faults related to airbags, I broke the connector to the driver side knee airbag when installing the manual pedals and have not received the replacement yet. The ABS module and parking brake faults are probably also not a coding issue, I have not yet wired in the sensor wire from the clutch position sensor to the ABS module, which both faults seem related to.
Also, some background information for anyone interested, I recently swapped a Mk8 Golf R manual trans, transfer case, and other supporting parts into my Arteon (also I have a post on VWVortex with more info, I’ll be updating that more soon too). I have everything mechanically sorted out, as well as some of the coding already changed. It runs and drives great, I have put about 100 miles on it so far since the swap. There are minimal lights on the dash and a decent amount of trouble codes disappeared when I changed module coding. I have wired in the clutch position sensor to the ECU, after wiring that and changing the engine and instruments coding the car starts from pushing the clutch like it should. The wiring of the clutch position sensor is to the same pins/location as the Mk7/7.5 Golf R, for anyone curious. The Arteon wiring diagrams did not include all the wire routing, so I just tried the Golf setup as what included in the Arteon diagrams was the same, and it just worked.
Previous Coding Changes:
-Can gateway = un-check 02 auto trans
-Engine control module = 092A00122466010EB004 to 092900122466010EB004
-Instruments = 08B41098FE8CCF050280624F10010008A0600005 to 08B41090FE8CCF050280624F10010008A0600005
-Park steer assist = 8471155811 to 8471155801
-Engine control module = 092900122466010EB004 to 091900122466010EB004
-Back up cam = 0184030162002017300040 to 0184030142002017300040
-Acc/start = 1F20000723 to 1F20000623
-Auto dis reg = 320107D25CFF8728749C810530409700000000000000000074 to 2A0107D25CFF8728749C810530409700000000000000000074
-Steering column lock = 0800000000000000 to 0000000000000000
One more thing, please no discussions on opinions/preferences for Auto/DSG/Manual or what’s best etc. I like what I like and wanted a manual Arteon, I have already had multiple discussions and heard many opinions on whether I should/shouldn’t attempt the manual swap. Thanks!
NO LOCK Scan
LOCK Scan
NO LOCK Scan
Thursday,05,February,2026,10:50:55:36627
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4671.5
VIN: WVWSR7ANXME012750 License Plate:
Chassis Type: AN-VW48 (3Q0)
Scan: 01 03 05 08 09 10 13 14 15 17 19 22 23 2B 36 3C 42 44 4B 52
5F 65 6C 75 A5 BB BC CA D6 D7
VIN: WVWSR7ANXME012750 Mileage: 58016km-36049miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DLRB) Labels:. 06K-907-425-V1.clb
Part No SW: 3G0 906 259 P HW: 06K 907 425 J
Component: R4 2.0l TFS H13 0001
Revision: --H13--- CVN: 77F54682
Coding: 091900122466010EB004
Shop #: WSC 05311 115 00312
ASAM Dataset: EV_ECM20TFS0203G0906259P 001001
ROD: EV_ECM20TFS0203G0906259P.rod
VCID: 3928F1A789D163F289D-806C
VINID: 9E69E388745EA1D5400421C500E17FBDC8
15217 - Please Check Fault Codes in Control Module for Electrical Parking Brake
U1010 00 [00101111] - -
Mileage: 58012 km
Date: 2026.02.01
Time: 00:39:54
Engine speed: 0.00 /min
Coolant temperature: 85 C
Intake air temperature: 2 C
Voltage terminal 30: 12.246 V
Engine: operating status: ES
PV: 0.00 %
T_IGK: 106.25 s
TQI_ADD_ACT: 0.03125 Nm
Time since engine start: 0.0 s
selected gear: Shifting process active
N_TOOTH: 0 /min
Readiness: 0010 0101
Part No SW: 5Q0 614 517 GD HW: 5Q0 614 517 BR
Component: ESC H82 0114
Revision: 00000000 Serial number: 61421000000200
Coding: 0DFA7B9A51213B6EC57E0305A0C369B0DE8ADCA3C00596743841508852A94A0B0003010312121212B435351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
VCID: 79A831A7C951A3F2C9D-802C
32995 - Clutch Position Sensor
C10BF 01 [10001001] - Electrical Failure
[IPB-Sensor: clutch sensor: electrical failure]
Reset counter: 85
Mileage: 58012 km
Date: 2026.02.01
Time: 00:39:53
32997 - Clutch Position Sensor
C10BF 15 [10001001] - Open or Short to Plus
[IPB-Sensor: clutch sensor: short to KL30]
Reset counter: 85
Mileage: 58012 km
Date: 2026.02.01
Time: 00:39:53
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0577900757 Dataset Number: V03935315RP 0001
Coding: 1F20000623
VCID: 45D08D57F5291712FD5-8010
Part No SW: 3G8 907 044 A HW: 3G8 907 044 A
Component: Climatronic H10 0205
Coding: 14020014200114001115010092101810
Shop #: WSC 00015 115 08193
ASAM Dataset: EV_AirCondiBHTCMQB3rTranc 001050
ROD: EV_AirCondiBHTCMQB3rTranc_001_VW37.rod
VCID: 2B04DBEF738DC1620B1-807E
Air quality sensor:
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 C HW: 4H0 907 658 C
Component: G935 MuFu H05 0010
Serial number: AAE90D9000PAG0MUFU04
Part No SW: 5Q0 937 087 BL HW: 5Q0 937 087 BB
Component: BCM PQ37BOSCH 040 0400
Revision: -------- Serial number: J53F2305212039 Dataset Number: V03935348NX 0001
ASAM Dataset: EV_BodyContrModul1UDSBosc 021001
ROD: EV_BCMBOSCH_021_VW27.rod
VCID: 06524A5B88AFDC0AB4F-8052
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 210315 042 0607
Serial number: 210323063305
Subsystem 2 - Part No SW: 5Q0 955 555 A HW: 5Q0 955 555 A
Component: RLHSS 054 0207
Serial number: S7Y21M05D26H14M10S05
Coding: 0008DD
Subsystem 3 - Part No SW: 3G8 941 633 A HW: 3G8 941 633 A
Component: E1 - LDS MQB H01 0032
Serial number: 29 08 2020 10000202
Humidity sensor: interior:
Steering Column Switch:
Subsystem 5 - Part No SW: 5Q1 953 521 MH HW: 5Q1 953 569 H
Component: Lenks.Modul H04 0190
Serial number: 0100190520210C200738
555797 - Databus
[Getriebe_11_alt aktiv]
Reset counter: 85
Mileage: 58012 km
Date: 2026.02.01
Time: 00:39:52
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: operated
Low beam: Not operated
Voltage: 12.2 V
Outside temperature: -15.0 C
267784 - Selector Lever Park Position Lock Switch
B1162 29 [00001001] - Signal Implausible
Reset counter: 85
Mileage: 58012 km
Date: 2026.02.01
Time: 11:42:21
CAN-Bus_aktiv: On
OFF: operated
Position lamps: Not operated
last_wakeup: Pin C14 Kessy Weckleitung
Voltage: 14.9 V
Outside temperature: -6.0 C
Part No SW: 5QA 919 294 J HW: 5QA 919 294
Component: PDC 8 Kanal H08 0073
Serial number: 000150058321141 Dataset Number: V03935333RX 0001
Coding: 8471155801
Shop #: WSC 05311 115 00065
ASAM Dataset: EV_EPHVA18AU3700000 009053
VCID: 53F4A30F0B7DB9A2631-8006
Part No SW: 2Q0 907 572 T HW: 2Q0 907 572 B
Component: ACCCONTIMQB H04 0383
Dataset Number: V03935346NP 0001
Coding: 2A0107D25CFF8728749C810530409700000000000000000074
ASAM Dataset: EV_ACCMRRCONTIVW376 003018
ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
2068 - Databus
[FAULT_TSK_IRREV_FAIL]
Reset counter: 85
Mileage: 58012 km
Date: 2026.02.01
Time: 00:39:53
Voltage terminal 15: 12.3 V
Control Module temperature: 7 C
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.00 m/s
Adaptive distance regulation: status: ACC_irreversible error
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 C HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0130
Serial number: 20052141350498 Dataset Number: V03935317XE 0001
ROD: EV_DRCONTITEMIC_VW37.rod
Part No SW: 3Q0 959 655 DL HW: 3Q0 959 655 DL
Component: Airbag VW21 007 0732
Revision: -------- Serial number: 003013UP5AWQ Dataset Number: V03935341YR 0001
Coding: 9DCCFCC00C0000005000001FC20840000065
Shop #: WSC 05311 000 08193
VCID: 0B447B6F93CDA162EB1-805E
Component: Occ.Detection H16 0022
Serial number: IBH0000D21000G02N70O
Coding: 303438
Subsystem 2 - Part No SW: ----------- HW: 454 002 604 21
Serial number: 357000000000A530B056
Subsystem 3 - Part No SW: ----------- HW: 454 002 604 21
Serial number: 35800000000F3810B05G
Subsystem 4 - Part No SW: ----------- HW: 454 800 506 21
Serial number: 3510090522B1E000000A
Subsystem 5 - Part No SW: ----------- HW: 454 800 506 21
Serial number: 3520011472B1E0000008
Subsystem 6 - Part No SW: ----------- HW: 454 802 504 21
Serial number: 355006A39B91D000000W
Subsystem 7 - Part No SW: ----------- HW: 454 802 504 21
Component: FrontSensor_P 304 0149
Serial number: 35600E12EB91D000000-
Subsystem 8 - Part No SW: ----------- HW: 454 802 604 21
Component: PedP_Sensor_D 30D 014A
Serial number: 22800306D591D000000J
Subsystem 9 - Part No SW: ----------- HW: 454 802 604 21
Component: PedP_Sensor_P 30D 014A
Serial number: 22900CA77BB1D000000%
Subsystem 10 - Part No SW: ----------- HW: 454 802 604 21
Component: PedP_Sensor_C 30D 014A
Serial number: 230000A69591D000000F
Subsystem 11 - Part No SW: ----------- HW: 454 002 703 21
Component: PedP_Sens_D_2 008 0887
Serial number: I0M00000000F3B992159
Subsystem 12 - Part No SW: ----------- HW: 454 002 703 21
Component: PedP_Sens_P_2 008 0887
Serial number: I0N00000000B3471825$
9440283 - Driver side knee airbag igniter
B100C 1B [10001001] - Resistance Too High
Mileage: 58012 km
Date: 2026.02.01
Time: 00:39:52
Part No SW: 3G0 920 420 B HW: 3G0 920 420 B
Component: KOMBI 502 5178
Coding: 08B41090FE8CCF050280624F10010008A0600005
ASAM Dataset: EV_DashBoardVDDMQBA0 001044
ROD: EV_DashBoardVDDMQBA0_001_VW37.rod
VCID: 1D6005373D393FD2855-8048
Part No SW: 3Q0 907 530 AG HW: 3Q0 907 530 C
Component: GW MQB High 521 5423
Serial number: 28052111600313 Dataset Number: V03935338PA 0001
Coding: 030900047F085900FB0002DA9C0F00010001070000000000000000000000
GVL: 01CE3C000000060840DC800080024C0010000000000200000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 74B60093EE33DE9A9AB-8020
Generator:
Component: 4-01-09-01-04
Subsystem 2 - Part No SW: 1EA 959 442 E HW: 1EA 959 442 E
Component: MFL H50 0420
Serial number: 17044951021042100038
Coding: 2D2B00
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1051
Serial number: 7588600300210428064C
Address 22: AWD (-----) Labels:| 0CQ-907-554-V1.clb
Part No SW: 5WA 907 554 P HW: 5WA 525 130
Component: 4Motion H65 0724
Serial number: HA1-00022.04.21
Coding: 0301
ASAM Dataset: EV_AllWheelContrHA1VW37X 005001
ROD: EV_AllWheelContrHA1VW37X_005.rod
VCID: 5BE44B2F63AD71E2BB1-800E
16652 - Databus
U1121 00 [00101111] - Missing Message
[Getriebe - TO -- Get_11]
Reset counter: 0
Mileage: 58012 km
Date: 2026.02.01
Time: 00:39:53
Voltage terminal 30: 12.2 V
Haldex clutch pump: current: 0.000 A
Address 23: Brake Booster (J539) Labels:. 5QE-909-059.clb
Part No SW: 3Q0 909 059 AA HW: 3Q0 909 059 B
Component: EBKV H06 0074
Serial number: BPA085220521013
Coding: 4103C500460000B5D65A6BAD000049922449920400
ASAM Dataset: EV_BrakeBoostG2BoschVW48X 012121
ROD: EV_BrakeBoostG2BoschVW48X_012.rod
VCID: 76B23A9BF84FCC8AA4F-8022
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H06 0020
Serial number: 21000134624011
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 3334C38FABBD99A2431-8066
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 F HW: 5Q0 959 760 F
Component: Sitzmemory H10 0026
Serial number: Y0007UD322943
Coding: 001000020000050001C281808080000000008181000000F440
ASAM Dataset: EV_SeatMemorDriveSide 002022
ROD: EV_SeatMemorDriveSide_002_VW48.rod
VCID: 40DE9C43EA0B323ACE3-8014
Address 3C: Lane Change (J1086) Labels:| 2Qx-907-686-V2.clb
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0150
Serial number: 14520009313517 Dataset Number: V03935334PN 0001
Coding: 52954640
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2Q0 907 685 B
Component: HRE3_Kl15_Slv H06 0150
Serial number: 14520009297745
2240558 - Databus
[databus error value received - ESP_33 - ESC_Verz_Reg_nicht_verfuegbar]
Mileage: 58012 km
Date: 2026.02.01
Time: 00:39:55
Part No SW: 5Q0 959 593 K HW: 5Q0 959 593 F
Component: TSG FS003 0330
Serial number: YE007UER25463 Dataset Number: V03935343BL 0001
Coding: 003F5B42D200020000000000
ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
VCID: 49C88167D931F37219D-801C
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
Dataset Number: V03935346HX 0001
Coding: 911F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 3C26E8B386E356DA92B-8068
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 E HW: 3Q0 907 338 E
Component: FCM MQB Low 003 0367
Serial number: 12052110521693 Dataset Number: V03935340AL 0001
Coding: 000000070900045207312300030000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X_003_VW27.rod
VCID: 372CF79FBFC575827F9-8062
Part No SW: 5Q0 959 592 K HW: 5Q0 959 592 F
Component: TSG BFS003 0330
Serial number: YE007UE91127B Dataset Number: V03935343BN 0001
Coding: 003F5342DE00020000000000
ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
VCID: 48CE8463C23B0A7A063-801C
Address 5F: Information Electr. (J794) Labels:| 3G5-035-MIB-HGH3.clb
Part No SW: 3G5 035 842 B HW: 3G5 035 842
Component: MU-O-NS-US H56 0813
Serial number: WG8LGM210521000 Dataset Number: V03935343FJ 0001
Coding: 24830000000020000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 001002
ROD: EV_MUOIMQB_001_VW48.rod
VCID: 270C27DF6F65E502EF9-8072
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav H61 8214
Serial number: VWZ6ZJY1530151
Subsystem 2 - Part No SW: V03 959 809 CR HW: -----------
Component: NAR 2021 --- 5041
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H06 0009
Serial number: 40000000553332 Dataset Number: V03935349AU 0001
ROD: EV_RDKBERU30_006_VW37.rod
VCID: 3436C093AEB39E9A5AB-8060
Component: RVC Compact H18 0231
Dataset Number: V03935320P 0001
Coding: 0184030142002017300040
Address 75: Telematics (J949) Labels:* 5WA-035-28X-V1.clb
Part No SW: 5WA 035 285 B HW: 5WA 035 285
Component: OCUGen3High H12 0318
Serial number: 0000000105VITD9 Dataset Number: V03935341ZP 0001
Coding: 024830201968AC209025460160102E07
ASAM Dataset: EV_OCUGen3High 003007
ROD: EV_OCUGen3High_003_VW27.rod
VCID: 46D28A5BC82F1C0AF4F-8012
12866049 - Databus
[Airbag: Error value received]
Mileage: 58012 km
Date: 2026.02.01
Time: 00:39:54
Voltage terminal 30: 12.3 V
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 2Q0-980-653.clb
Part No SW: 2Q0 980 653 B HW: 2Q0 980 653
Component: MQB MFK 3.0 H14 1202
Serial number: E78901612211470 Dataset Number: V03935342LU 0001
Coding: 00000A88116E4020089F10001030002000418000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 007042
ROD: EV_MFK3ValeoMQB_007_VW48.rod
Part No SW: 5Q0 959 595 K HW: 8W1 959 595 D
Component: TSG HFS005 0330
Serial number: YE007UDU0201C Dataset Number: V03935319JE 0001
Coding: 000A51420100020000000000
VCID: 4BC4BB6FD34DE1622B1-801E
Component: TSG HBFS005 0330
Serial number: YE007UDT28261 Dataset Number: V03935319JD 0001
Part No SW: 4K0 907 594 AD HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Dataset Number: V03935282GT 0001
Coding: 008000748301
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
Part No SW: 992 941 572 AA HW: 992 941 572 A
Component: LED1L H08 9002
ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
VCID: 629A76CB44C7402AF87-8036
Component: LED1R H08 9002
End----------(Elapsed Time: 02:08, VBatt start/end: 13.4V/14.9V)-----------
------------------------------10 Faults Found------------------------------
LOCK Scan
Thursday,05,February,2026,10:54:02:36627
U1010 00 [00100111] - -
Mileage: 58016 km
Date: 2026.02.01
Time: 12:11:06
Engine speed: 700.00 /min
Normed load value: 12.5 %
Coolant temperature: 86 C
Intake air temperature: 19 C
Voltage terminal 30: 14.804 V
Engine: operating status: IS
PV: 0.00 %
T_IGK: 180.97 s
TQI_ADD_ACT: 32.93750 Nm
Time since engine start: 180.2 s
N_TOOTH: 710 /min
Readiness: 1010 0101
Reset counter: 85
Mileage: 58016 km
Date: 2026.02.01
Time: 12:11:04
Reset counter: 85
Mileage: 58016 km
Date: 2026.02.01
Time: 12:11:04
Coding: 1F20000623
Air quality sensor:
Coding: 0008DD
555797 - Databus
Reset counter: 85
Mileage: 58016 km
Date: 2026.02.01
Time: 12:11:03
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 14.8 V
Outside temperature: -3.5 C
Coding: 8471155801
2068 - Databus
Reset counter: 85
Mileage: 58016 km
Date: 2026.02.01
Time: 12:11:04
Voltage terminal 15: 14.9 V
Control Module temperature: 33 C
Coding: 303438
Mileage: 58016 km
Date: 2026.02.01
Time: 12:11:04
Generator:
Coding: 2D2B00
Coding: 0301
16652 - Databus
Reset counter: 0
Mileage: 58016 km
Date: 2026.02.01
Time: 12:11:03
Engine speed: 695.00 /min
Voltage terminal 30: 14.7 V
Coding: 52954640
2240558 - Databus
Mileage: 58016 km
Date: 2026.02.01
Time: 12:11:06
Coding: 911F0000
12866049 - Databus
Mileage: 58016 km
Date: 2026.02.01
Time: 12:11:06
Voltage terminal 30: 14.8 V
End----------(Elapsed Time: 02:06, VBatt start/end: 14.9V/14.9V)-----------
------------------------------9 Faults Found-------------------------------
. I'll probably have to own a
