Tuesday,07,February,2017,21:41:02:05573
-- Windows Based VAG/VAS Emulator Running on Windows 7 x86
Version: 17.1.2.0
Data version: 20170131 DS267.1
VIN: WVWZZZAUZFW****** License Plate:
Mileage: 52061km-32349mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 3C 42 44 47 52 55
5F 65 A5 A9 C0
VIN: WVWZZZAUZFW****** Mileage: 52061km-32349miles
03- Brakes -- Status: OK 0000
05-/Start Auth. -- Status: OK 0000
Address 01: Engine (J623-CUNA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 EQ HW: 04L 907 309 A
Component: R4 2,0L H22 8360
Revision: 81H22---
Coding: 091D0032036405083000
Shop #: 01357 011 00200
Dataset: EV_ECM20TDI01104L906021EQ 002011
ROD: EV_ECM20TDI01104L906021ER.rod
VCID: 78F42609C3C68E81DB-802C
Part No SW: 0D9 300 041 Q HW: 02E 927 770 AQ
Component: DQ250-6F H53 4504
Revision: 05853104 Serial number: TFK01504011518
Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 2648387159F2C871B9-8072
Address 03: Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 R HW: 3Q0 907 379 G
Component: ESC H42 0711
Revision: 00000000 Serial number: 60935000002968
Coding: 01FA6BA13423096F077A0608C1C8A980D62C90E0608395F51862508A4289
Shop #: 12345 123 12345
Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
VCID: 499293CDE8ACC70974-801C
Address 05: /Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0365830359
Coding: 030C0C
Dataset: EV_KessyHellaMQBAB 002011
VCID: 3A70FC01BD4A5C91ED-806E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00020114202400011105000200101000
Dataset: EV_ACClimaBHBVW37X 004131
ROD: EV_ACClimaBHBVW37X_004_VW37.rod
VCID: 6AD00C418D6A2C115D-803E
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: MQBAB H H18 0137
Serial number: 01011510602060
Coding: 00111E66C24122FB0BA44080B11C07281800000000000000000000000000
Dataset: EV_BCMCONTI 013000
ROD: EV_BCMBOSCH_013.rod
VCID: 00044EE99B16C641E3-8054
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150403 043 0551
Serial number: 150410040138
Component: 037 0059
Serial number: S3Y15M04D20H00M25S18
Coding: 1EA8DD
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY150750Y1C
Serial number: 00000000000062141643
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.403 H03 0004
Serial number: 0000FST0008DFNN00000
Coding: 181901
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5Q0 919 298 F HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0047
Revision: -------- Serial number: 39431510500062
Coding: 0031165051
Dataset: EV_EPHVA2CAU3700000 003019
ROD: EV_EPHVA2CAU3700000_003_VW37.rod
VCID: 428084E1D59A1451B5-8016
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Component: Bosch H05 0304
Serial number: 24031503273603
Coding: 001C1700FE0739
Dataset: EV_ACCMRRBoschVW372 001015
VCID: 3874E60983464E811B-806C
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 HW: 5Q0 907 376
Component: DAEMPFUNGS-SG H16 0115
Serial number: 24031541350375
Dataset: EV_DRCONTITEMIC 001019
ROD: EV_DRCONTITEMIC.rod
VCID: 76E82831C9D2F8F1C9-8022
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR0DSP8I
Dataset: EV_AirbaVW20SMEVW37X 002130
VCID: 7F06CD15E6E8B9B99A-802A
Belt Pretensioner left:
Component: BeltPretRevFL H36 0350
Serial number: 34169667B19041510022
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H36 0350
Serial number: 34169668B17041570842
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 001 204 15
Serial number: 35767000000007B8B31Q
Subsystem 4 - Part No SW: ----------- HW: 480 001 304 15
Serial number: 35867000000AAB70141U
Subsystem 5 - Part No SW: ----------- HW: 480 400 904 15
Serial number: 3516502AD1A87850B26H
Subsystem 6 - Part No SW: ----------- HW: 480 400 904 15
Serial number: 3526502AB1A878517117
Subsystem 7 - Part No SW: ----------- HW: 480 400 904 15
Serial number: 3556502C9194131463A3
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 EC HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 15041504400949
Coding: 0C10
Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 7BFE3905F2F0A599B6-802E
Part No SW: 5G1 920 757 HW: 5G1 920 757
Component: KOMBI 301 4310
Coding: 07AD09987E9C000804887E0F5400000000000000
Dataset: EV_DashBoardVDDMQBAB 009043
VCID: 6BDE09458290351926-803E
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 F
Component: GW High 128 1204
Revision: -------- Serial number: 0003390353
Coding: 030100040F087300FF00027E9D0F00010001050000000000000000000000
Dataset: EV_GatewLear 011020
ROD: EV_GatewLear_011.rod
VCID: 72E01421A5BAE4D1E5-8026
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H10 0040
Serial number: 29150000730720045153
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 2520616303
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000091730001
Coding: 5D00000000000000
Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB_SK25.rod
VCID: 346CD2399F2EAAE137-8060
Address 3C: Lane Change (J1086) Labels: None
Part No SW: 5Q0 907 686 A HW: 5Q0 907 686 A
Component: HRE_Master H11 0066
Serial number: 0364164866
Coding: 02011103
Dataset: EV_HREntryHella 001024
ROD: EV_HREntryHella.rod
VCID: 3B7EF905B2706599F6-806E
Lane Change Assistant 2:
Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: FS 020 0028
Serial number: 230315BCM00796
Coding: 003F1220D000048000001000
Dataset: EV_DCUDriveSideEWMAXKLO 006003
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Serial number: 00000000000005805248
Coding: 110000
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Coding: 9303
Dataset: EV_SteerAssisMQB 012140
VCID: 3776E5358E5841F912-8062
Part No SW: 5G0 035 456 HW: 5G0 035 456
Component: MIB_lite_amp H40 0070
Serial number: VWZ8Z1FC402M79+
Coding: 120000008AAA8A0000
Dataset: EV_AMPMst11CALPI 001007
ROD: EV_AMPMst11CALPI.rod
VCID: 63CE61656A407D599E-8036
Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
Component: BFS 020 0028
Serial number: 020415BD205411
Coding: 003F1020DE00048000801000
Dataset: EV_DCUPasseSideEWMAXKLO 006003
VCID: 41828BEDD09C0F49AC-8014
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Serial number: 00000000000005921294
Coding: 090000
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: - H07 0090
Coding: 029203104F010200
Dataset: EV_HeadlRegulVWAFSMQB 001120
VCID: 40848EE9DB960641A3-8014
Subsystem 1 - Part No SW: 3D0 941 329 D HW: 3D0 941 329 D Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 900000
Subsystem 2 - Part No SW: 3D0 941 329 D HW: 3D0 941 329 D Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 900000
Address 5F: Information Electr. (J794) Labels: 5G0-035--HGH1.clb
Part No SW: 5G0 035 021 C HW: 5G0 035 021 B
Component: MU-H-TND-EU H44 0376
Serial number: A330D0F7520223
Coding: 027300010000000011111202000800101F0202F4010001009F
Shop #: 131071 1023 2097151
Dataset: EV_MUHig4CHBAS 001040
ROD: EV_MUHig4CHBAS_VW37.rod
VCID: 1A301C811D8A7C910D-804E
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H62 0031
Serial number: VWZ8Z9RU301E7E
Subsystem 2 - Part No SW: V03 959 800 KF HW: -----------
Component: ECE 2017 --- 0157
Compact Disc Database:
Component: Gracenote --- 1010
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 30000000019474
Dataset: EV_RDKBERU30 006001
ROD: EV_RDKBERU30_006.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels: 5Q0-980-653.clb
Part No SW: 5Q0 980 653 F HW: 5Q0 980 653
Component: MQB_MFK H06 0052
Serial number: 10000341309
Coding: 0101020001020303020400010100000100
Dataset: EV_MFKBoschAU370 001001
ROD: EV_MFKBoschAU370.rod
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 150311200428
Dataset: EV_SoundActuaGen2AU64X 003010
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 5G0 907 160 HW: 4G0 907 160 B
Component: SAS-GEN 2 H09 0006
Serial number: 150324201384
Dataset: EV_ActuaForExterNoiseUDS 003013
ROD: EV_ActuaForExterNoiseUDS_VW12.rod
End-------------------------(Elapsed Time: 06:04)--------------------------
