2006 jetta 1,9 tdi idle adaptation
maumaumau
C?ID=21355
got a 2006 jetta 1,9 tdi ,customer want to increase idle rpm from actual 820-840 rpm to 900-920,tryed adaptation,it says security login needed,tryed 12233,it says "security code accepted",channel 06 says "error channel not available":banghead:,i was looking thru all 255 channels,nothing available for idle rpm adjustement,i remember i did this before on 1,9 tdi with edc16(can't remember exactly what year,was a european touran),there is any way to adjust the idle in this car using VCDS ? auto-scan attached,thanks:D
Sunday,14,February,2016,10:56:22:35697
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: 3VWDT71K26M0xxxxx   License Plate:
Mileage: 277290km-172300mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 47 52 56 62
          65 72 7D
VIN: 3VWDT71K26M0xxxxx   Mileage: 277290km-172300miles
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine        Labels: 038-906-016-BEW.lbl
   Part No SW: 03G 906 016 AC    HW: 028 101 223 9
   Component: R4 1,9L EDC G000DG  7551
   Revision: --H02---    Serial number: VWZ7Z0F4484819
   Coding: 0050078
   Shop #: WSC 00066 000 00000
   VCID: 64CD5B7FA7D0CE1EF5-8030
005659 - Glowplug for Cylinder 2 (Q11)
               P161B - 000 - Open Circuit - Intermittent
                    Fault Status: 00110000
                    Mileage: 263147 km
                    Time: 19:04:39
                    RPM: 1050 /min
                    Voltage: 12.01 V
                    Bin. Bits: 00001000
                    Temperature: 10.8°C
                    Bin. Bits: 10110000
Readiness: 0 1 0 0 0
   Part No SW: 02E 300 043     HW: 02E 927 770 AE
   Component: GSG DSG         070 1126
   Revision: 04507000    Serial number: 00000607070375
   VCID: 51A382ABC8624BB6AE-8004
   Revision: 00H11001
   Coding: 0021122
   VCID: 73EF2823123E59A67C-8026
   Part No SW: 1K0 907 044 BJ    HW: 1K0 907 044 BJ
   Component: ClimatronicPQ35 090 0909
   Revision: 00090016    Serial number: 00000000000000
   VCID: 70E5272F632862BE81-8024
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
   Component: Bordnetz-SG     H46 1501
   Revision: 00H46000    Serial number: 00000000453255
   Coding: 14018E234004150007140000001400000028770B5C0000
   VCID: 3777DC3346C6F58680-8062
   Component: Wischer 220807 021  0501
   Coding: 00038805
   Shop #: WSC 00066
02092 - Enabling Heated Seat
                    Fault Status: 00101001
                    Reset counter: 106
                    Mileage: 255890 km
                    Voltage: 14.05 V
   Part No SW: 8E0 035 593 D    HW: 8E0 035 593 D
   Component: SDAR SIRIUS     H03 0060
   Revision: 00000000    Serial number: AUZ4Z7F1040388
   VCID: 2A51F5478574586E0F-807E
            000 -  -
                    Reset counter: 39
                    Mileage: 276073 km
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D05LLRL
   Coding: 0013889
   VCID: 6CDD335F4F00865EBD-8038
   Subsystem 1 - Part No: 1K0 959 339 F
   Component: BF-Gewichtsens. 007 0005
   Subsystem 2 - Serial number: 6332MSME110F1241$
   Subsystem 3 - Serial number: 6342MSME117A104D9
   Subsystem 4 - Serial number: 6351HSME0A5A1051%
   Subsystem 5 - Serial number: 6361HSME0A630D38B
   Subsystem 6 - Serial number: 63727SME0A5D0A187
   Subsystem 7 - Serial number: 63827SME0A5F4E7CS
   Part No SW: 1K0 953 549 AS    HW: 1K0 953 549 AS
   Component: J0527           035 0070
   Coding: 0012021
   VCID: 030F78E3429E69266C-8056
   Part No SW: 1K0 920 973 D    HW: 1K0 920 973 D
   Component: KOMBIINSTRUMENT 3HL 1610
   Revision: V0003000    Serial number: VWZ7Z0F4484819
   Coding: 0023203
   Shop #: WSC 03087 444 84487
   VCID: 2E59F957B99C344ED3-807A
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 31001067151158
   Coding: 3FFF0B620F001002
   VCID: 2C5DF35F8F80465EFD-8078
   Part No SW: 1K5 919 965 A    HW: 1K5 919 965 A
   Component: Kompass         005 0003
   Revision: 00005000    Serial number: 1293324T23NE03
   Coding: 0000003
   VCID: 3973DA0B70D2E3F676-806C
   Component: IMMO            3HL 1610
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 C    HW: 3C0 959 760 C
   Component: Sitzverstellung     1001
   Revision: 00004000    Serial number: 00000000000000
   VCID: 2D5BFE5BB49A4F56EA-8078
   Part No SW: 1K0 959 701 Q    HW: 1K0 959 793 M
   Component: J386  TUER-SG FT    1125
   Revision: 11006001    Serial number: 00000502068804
   Coding: 0001463
   VCID: 3C7DC31F7FE0D6DE6D-8068
                    Fault Status: 00100101
                    Reset counter: 81
                    Reset counter: 106
00105 - Signal Central Locking SAVE/LOCK Drivers Side
                    Reset counter: 106
00100 - Drivers Interior Locking Button (E308)
                    Reset counter: 87
                    Mileage: 275064 km
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.070 H07 1806
   Shop #: WSC 02069 000 90108
   VCID: 346DEB3F57B01E9EA5-8060
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 CD    HW: 1K0 959 433 CD
   Component:    KSG PQ35 RDK 051 0215
   Revision: 00051000    Serial number: 00000000000000
   Coding: 13900F880186281B0904058FB0888F0488DC00
   VCID: 74ED2B3F17305E9E65-8020
Address 47: Sound System        Labels: 3C0-035-456.lbl
   Part No: 1K6 035 456 A
   Component: 08K Audioverst.     0005
   Revision: 00003000    Serial number: 00000000008468
00877 - Treble Speaker Rear Right (R16)
   Part No SW: 1K0 959 702 Q    HW: 1K0 959 792 M
   Component: J387  TUER-SG BT    1125
   Revision: 11006001    Serial number: 00000071968804
   Coding: 0001462
   VCID: 3D7BCE1B64FADFD65A-8068
   Part No SW: 1K0 035 180 G    HW: 1K0 035 180 G
   Component: Radio DE2       145 0175
   Revision: 00145000    Serial number: VWZ4Z7F2127580
   Coding: 0010400
   VCID: 244D1B7FE7508E1E35-8070
00871 - Bass Speaker Front Right (R23)
00003 - Control Module
            014 - Defective
   Component: J388   TUER-SG HL   1115
   Revision: 12005001    Serial number: 00000000446234
   Coding: 0001168
   VCID: 3E79C91769FCC4CE43-806A
   Component:    RDK              0420
   Coding: 0100101
                    Fault Status: 00110100
                    Reset counter: 100
                    Mileage: 276555 km
                    Time: 00:57:51
   Component: J389   TUER-SG HR   1115
   Revision: 12005001    Serial number: 00000000414207
   Coding: 0001168
   VCID: 3F87B4136EF6CDC648-806A
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
00361 - Heater Element for Auxiliary Heater (Z35)
            014 - Defective
End-------------------------(Elapsed Time: 02:21)--------------------------
It should indeed be Channel 6, but it's entirely possible that the software in this car's ECU doesn't allow access to that channel.
Welder75
Canada
C?ID=261654
Special adaptations: Login code 12233:
These procedures do NOT apply to the PD engines, which use a completely different type of EGR system and for which there is no known modification. !
To perform the following adaptations (except idle) you need to use the Login function.
Enter 12233 as a Login code.
Misuse of some of the adaptations can lead to engine failure.
This is done at your own risk!
Note that the EGR setting is for off-road use only...
[Select]
[01 - Engine]
[Login - 11]
Enter 12233 to activate special adaptations,
[Do It!]
[Adaptation - 10]
Enter the "channel number" below to select each channel.
Put in the suggested value(s) in "new value".
[Test]
Observe the "test value" field to make sure the adaptation setting is acceptable.
[Save]
Channel 1: injected quantity
Check the injected quantity at idle, engine warm and all power consuming devices turned off.
Specification is 2.5 to 9 mg/h.
To change the amount of injected fuel perceived by the ECU, go to adaptation channel 1.
If you have driveability problems, you may want to increase it to 3-4 mg/h.
For slightly improved throttle response, you may try to decrease the value.
Channel 2: idle speed
No login required
The stock adaptation value should be 32768 (corresponds to 903 rpm).
Increase or decrease this to change idle speed.
Channel 3: EGR
To decrease the EGR rate, increase the number to the highest possible value (typically 33768).
This will prevent/slow down the intake manifold clogging problem and reduce smoke.
Though the MAF at idle is still within specifications (370 mg/h) do not use this adaptation on the road :-)
Again, this EGR setting is for off-road use only !!!
Channel 4:
Don’t mess with it!
Channel 5: starting conditions
Though undocumented, this channel effects the injected quantity the ECU allows when starting.
You may want to experiment with it as a temporary fix for bad-start problems
Channel 18:
On some EDC-15 ECUs, this channel has a non-zero value in it like 190.
Yes, that's the "speed limiter". Don't mess with it!
It can only be adjusted downward, and it's one-way! You cannot increase the value, and if you decrease it, you're stuck with it.
So unless you want to permanently decrease your car's top speed, Don't mess with it!
If you do mess with it and your car ends up with a lower top speed than it had before, don't call us, don't e-mail us, and don't complain that we didn't warn you!
you can find this and more info HERE
Welder75
Canada
C?ID=261654
Can you please show me Throttle body on Diesel engine and how to do TBA :D ?
I was just testing to see if any one would notice!!!:facepalm:
What does JAck say about a vortex or black hole!???
ERASE ERASE!! lol
The main point of the post is that a PD TDI , the idle rpm can't be modified.
but isn't 820 rpm low? stock would be 900-920 wouldn't it?
Gone But Not Forgotten
Whoretex?.........
Everyone makes mistakes even me..........
What looks like a TV in a TDI........ is a anti stutter or emergency shut off all air valve to help kill the engine after the key is turned off.....in a run away situation.
It should be noted it does store adaption points in the eeprom and does have the ability to move to more than one position.
Personally I feel you will be seeing a TV added to TDI or SCCI gasoline engines, as "Compression Fire" "CF" gasoline engines are developed.
I have personal experience with development and experimentation of CF Gasoline and vapor converted gasoline engines.
All I can tell you is GAS or internal combustion isn't going anywhere.......... and solar or batteries are not yet a match for this, lowered Hazmat waste, Power or MPG.
I look forward to VW-Audi-Porsche and Bosch/Siemens releasing these prototypes to tip the preverbal scale.
