Ran an auto-scan on my brothers mkv jetta 2.5l and noticed a lot of codes related to electrical faults and communication issues with control modules. Does this sound like a ground issue to you guys?
Sunday,07,February,2016,16:57:30:16812
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: 3VWSF71K35M604286 License Plate:
Mileage: 225820km-140318mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 47 52 56 62 72
VIN: 3VWSF71K35M604286 Mileage: 225820km-140318miles
1C-Position Sensing -- Status: Malfunction 0010
Address 01: Engine Labels: 06A-906-032-BGP.lbl
Part No SW: 06A 906 032 QE HW: Hardware No
Component: 2.5l R5/4V G 6607
Revision: 00000000 Serial number: VWZ7Z0D1141661
Coding: 0000003
Shop #: WSC 00066 000 00000
VCID: 71E9BF1268E8B6B68E-8024
16452 - MAP/MAF <-> Throttle Position Correlation
P0068 - 002 - - Intermittent
Part No: 09G 927 750 AS
Component: AQ 250 6F 0649
Coding: 0000008
VCID: 020BE0DE5D4EBD2E67-8056
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021122
VCID: 3A7B583E751E35EE7F-806E
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 BA
Component: ClimatronicPQ35 066 0606
VCID: 67DDD14A562C7806D0-8032
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 C HW: 1K0 937 049 C*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000000036069
Coding: F4058E02400418000014000000140000002077035C
Shop #: WSC 02146 444 57498
VCID: 2F6D796ABE5CE046D8-807A
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 02146
Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 005 0605
Coding: 00217125
Shop #: WSC 02146
01117 - Generator Terminal DF Load Signal
010 - Open or Short to Plus
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1S AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD00CUNM
Coding: 0012627
VCID: 2E53646EB956E94ED3-807A
Subsystem 1 - Part No: 1K0 959 339 B
Component: BF-Gewichtsens. 006 0003
Subsystem 2 - Serial number: 6332MSME07427E43C
Subsystem 3 - Serial number: 6342MSME074D166EN
Subsystem 4 - Serial number: 6351HSME04351321T
Subsystem 5 - Serial number: 6361HSME041645682
Subsystem 6 - Serial number: 63727SME046E411F5
Subsystem 7 - Serial number: 63827SME050D0501S
Part No SW: 1K0 953 549 AB HW: 1K0 953 549 AB
Component: J0527 010 0045
Coding: 0010041
VCID: 72EBB01E6DEE8DAE77-8026
Part No: 1K0 920 971 CX
Component: KOMBIINSTRUMENT 3HL 2120
Coding: 0023203
Shop #: WSC 02120 444 70618
VCID: 0305E5DA4254B4266C-8056
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 2700104B020021
Coding: 3F3F03420F1002
VCID: 2959977280B88E7606-807C
Part No SW: 1K5 919 965 HW: 1K5 919 965
Component: Kompass 002 0001
Revision: 00002000 Serial number: 0371356TMYRW03
VCID: 78FF82360B92E7FE49-802C
Reset counter: 29
Mileage: 149301 km
Time: 11:55:58
Reset counter: 29
Mileage: 149301 km
Time: 11:55:58
015 - Cannot Be Tested at this Time - Intermittent - MIL ON
Fault Status: 10111111
Fault Frequency: 255
Reset counter: 29
Time Indication: 15
Component: IMMO 3HL 2120
Shop #: WSC 02616 444 85551
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2339
Coding: 0001271
Shop #: WSC 07020 993 55679
VCID: 36634C0E4106D18E9B-8062
01552 - Motor for Central Locking; Drivers Door (V56); Lock
00120 - Outside Warning Light/Door exit Light Driver Side
00109 - Left Mirror Turn Signal Lamp (L131)
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.3 1502
VCID: 306F7A16A362FFBEC1-8064
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AT HW: 1K0 959 433 AT
Component: KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 13100F880106281B0906050FA0080F0490A540
Component: LIN BACKUP HORN H02 1301
003 - Mechanical Failure
Fault Status: 01100011
Reset counter: 107
Fault Frequency: 9
Reset counter: 137
Address 47: Sound System Labels: 3C0-035-456.lbl
Part No: 1K6 035 456
Component: 08K Audioverst. 0003
Revision: 00002000 Serial number: 00000000000241
VCID: 69D9D77240384E76C6-803C
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001271
VCID: 377D410A460C288680-8062
01553 - Motor for Central Locking; Passenger Door (V57); Lock
00110 - Right Mirror Turn Signal Lamp (L132)
Part No SW: 1K0 035 180 A HW: 1K0 035 180 A
Component: Radio DE2 008 0011
Revision: 00008000 Serial number: VWZ4Z7D2014704
Coding: 0010010
VCID: 1E33B4AEC9F679CE63-804A
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2416
Coding: 0000144
VCID: 31697F12A868F6B6CE-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 326B701EAD6ECDAEB7-8066
End-------------------------(Elapsed Time: 01:50)--------------------------
