Sound like a ground issue?
dotcom619
C?ID=268657
Ran an auto-scan on my brothers mkv jetta 2.5l and noticed a lot of codes related to electrical faults and communication issues with control modules. Does this sound like a ground issue to you guys?
Sunday,07,February,2016,16:57:30:16812
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: 3VWSF71K35M604286   License Plate:
Mileage: 225820km-140318mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 47 52 56 62 72
VIN: 3VWSF71K35M604286   Mileage: 225820km-140318miles
1C-Position Sensing -- Status: Malfunction 0010
Address 01: Engine        Labels: 06A-906-032-BGP.lbl
   Part No SW: 06A 906 032 QE    HW: Hardware No
   Component: 2.5l R5/4V      G   6607
   Revision: 00000000    Serial number: VWZ7Z0D1141661
   Coding: 0000003
   Shop #: WSC 00066 000 00000
   VCID: 71E9BF1268E8B6B68E-8024
16452 - MAP/MAF <-> Throttle Position Correlation
            P0068 - 002 -  - Intermittent
   Part No: 09G 927 750 AS
   Component: AQ 250 6F           0649
   Coding: 0000008
   VCID: 020BE0DE5D4EBD2E67-8056
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0021122
   VCID: 3A7B583E751E35EE7F-806E
   Part No: 1K0 907 044 BA
   Component: ClimatronicPQ35 066 0606
   VCID: 67DDD14A562C7806D0-8032
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 C    HW: 1K0 937 049 C*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000000036069
   Coding: F4058E02400418000014000000140000002077035C
   Shop #: WSC 02146 444 57498
   VCID: 2F6D796ABE5CE046D8-807A
   Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 02146
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00217125
   Shop #: WSC 02146
01117 - Generator Terminal DF Load Signal
            010 - Open or Short to Plus
   Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
   Component: 1S AIRBAG VW8R  024 6300
   Revision: 03024000    Serial number: 0037KD00CUNM
   Coding: 0012627
   VCID: 2E53646EB956E94ED3-807A
   Subsystem 1 - Part No: 1K0 959 339 B
   Component: BF-Gewichtsens. 006 0003
   Subsystem 2 - Serial number: 6332MSME07427E43C
   Subsystem 3 - Serial number: 6342MSME074D166EN
   Subsystem 4 - Serial number: 6351HSME04351321T
   Subsystem 5 - Serial number: 6361HSME041645682
   Subsystem 6 - Serial number: 63727SME046E411F5
   Subsystem 7 - Serial number: 63827SME050D0501S
   Part No SW: 1K0 953 549 AB    HW: 1K0 953 549 AB
   Component: J0527           010 0045
   Coding: 0010041
   VCID: 72EBB01E6DEE8DAE77-8026
   Part No: 1K0 920 971 CX
   Component: KOMBIINSTRUMENT 3HL 2120
   Coding: 0023203
   Shop #: WSC 02120 444 70618
   VCID: 0305E5DA4254B4266C-8056
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 2700104B020021
   Coding: 3F3F03420F1002
   VCID: 2959977280B88E7606-807C
   Part No SW: 1K5 919 965     HW: 1K5 919 965
   Component: Kompass         002 0001
   Revision: 00002000    Serial number: 0371356TMYRW03
   VCID: 78FF82360B92E7FE49-802C
                    Reset counter: 29
                    Mileage: 149301 km
                    Time: 11:55:58
                    Reset counter: 29
                    Mileage: 149301 km
                    Time: 11:55:58
            015 - Cannot Be Tested at this Time - Intermittent - MIL ON
                    Fault Status: 10111111
                    Fault Frequency: 255
                    Reset counter: 29
                    Time Indication: 15
   Component: IMMO            3HL 2120
   Shop #: WSC 02616 444 85551
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2339
   Coding: 0001271
   Shop #: WSC 07020 993 55679
   VCID: 36634C0E4106D18E9B-8062
01552 - Motor for Central Locking; Drivers Door (V56); Lock
00120 - Outside Warning Light/Door exit Light Driver Side
00109 - Left Mirror Turn Signal Lamp (L131)
   Part No: 1K1 909 144 H
   Component: EPS_ZFLS Kl.3       1502
   VCID: 306F7A16A362FFBEC1-8064
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 AT    HW: 1K0 959 433 AT
   Component:    KSG PQ35 G2  010 0101
   Revision: 00010000    Serial number: 00000000000000
   Coding: 13100F880106281B0906050FA0080F0490A540
   Component: LIN BACKUP HORN H02 1301
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Reset counter: 107
                    Fault Frequency: 9
                    Reset counter: 137
Address 47: Sound System        Labels: 3C0-035-456.lbl
   Part No: 1K6 035 456
   Component: 08K Audioverst.     0003
   Revision: 00002000    Serial number: 00000000000241
   VCID: 69D9D77240384E76C6-803C
   Part No: 1K0 959 702 K
   Coding: 0001271
   VCID: 377D410A460C288680-8062
01553 - Motor for Central Locking; Passenger Door (V57); Lock
00110 - Right Mirror Turn Signal Lamp (L132)
   Part No SW: 1K0 035 180 A    HW: 1K0 035 180 A
   Component: Radio DE2       008 0011
   Revision: 00008000    Serial number: VWZ4Z7D2014704
   Coding: 0010010
   VCID: 1E33B4AEC9F679CE63-804A
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2416
   Coding: 0000144
   VCID: 31697F12A868F6B6CE-8064
   Part No: 1K0 959 704 D
   Coding: 0000144
   VCID: 326B701EAD6ECDAEB7-8066
End-------------------------(Elapsed Time: 01:50)--------------------------
I don't see a common thread. If it were mine, I'd clear 'em all and see what comes back when or under what circumstances.
I'd also consider doing basic MAF tests, and given the mileage on the car, cleaning the TB and doing a TBA.
Gone But Not Forgotten
look at what the code says........
Coding: 0000003
Could be a slight VC breather/booster/N80 internal leak ( stuck open )starting.
This usually means that the MAP sensor in the intake, is not seeing the amount of air coming through the MAF.
Usually meaning false air or, however, in this case since no trim codes yet .......insufficient air through the MAF.
Say a faulty MAF or the boot/pipe from MAF to TV......... is not clamped, torn or leaking at the SAI pipe.
Is there any aftermarket cone filters installed or FOD?
http://wiki.ross-tech.com/wiki/index.php/16452/P0068/000104
