(Need Help) 2009 A4 2.0 will not start...autoscan posted
yodizzle
C?ID=241097
Hey guys, my car will not start at all and it cranks and cranks until battery dies and needs recharged again/ Can someone help me. Have checked all fuses, here's a screen shot of autoscan
Thursday,11,February,2016,18:14:07:48457
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x64(VMWare)
VCDS Version 15.7.3.0 (x64)
Data version: 20151216
VIN: WAULF78KX9N037354   License Plate:
Mileage: 120250km-74719mi   Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 56 62 65 72
          77
VIN: WAULF78KX9N037354   Mileage: 120250km-74719miles
Address 01: Engine (DL0MA-CAEB)       Labels: 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AL    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H14 0001
   Revision: E1H14---
   Coding: 0104010A190F0160
   Shop #: WSC 03327 444 105121
   ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
   ROD: EV_ECM20TFS0118K2907115AL.rod
   VCID: 79F9D36CF8641BF636-802D
4187 - Intake Air Temp. Sensor (G42)
          P0113 00 [039] - Signal too High
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:24:15
Readiness: 1110 0101
Address 02: Auto Trans (J217)       Labels: 0B6-927-156.clb
   Part No SW: 8K0 927 158 C    HW: 0B6 927 156
   Component: 0B6 20TFSIUSA H04 0050
   Revision: --H04---
   Coding: 001002
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_TCMAL651 A01004
   ROD: EV_TCMAL651.rod
   VCID: 3663185089FA348E9B-8063
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 AB    HW: 8K0 907 379 AB
   Component: ESP8 quattro  H04 0060
   Coding: 150500
   Shop #: WSC 02391 823 56573
   VCID: 79F9D36CF0641BF636-802D
                    Fault Status: 00101101
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:02:50
                    Hex Value: 0x00C0
                    Hex Value: 0x0082
                    Hex Value: 0x0013
                    Hex Value: 0x0290
                    Hex Value: 0x00FF
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:05:34
                    Hex Value: 0x0000
                    Hex Value: 0x0080
                    Hex Value: 0x0017
                    Hex Value: 0x1D94
                    Hex Value: 0x00FF
                    Fault Frequency: 8
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:34:51
                    Hex Value: 0x0000
                    Hex Value: 0x1280
                    Hex Value: 0x0021
                    Hex Value: 0x245F
                    Hex Value: 0x00FF
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:35:45
                    Hex Value: 0x0000
                    Hex Value: 0x1280
                    Hex Value: 0x0018
                    Hex Value: 0x0261
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 F    HW: 8K0 907 064 F
   Component: BCM2 1.1      H80 0143
   Coding: 090100
   Shop #: WSC 02399 823 56573
   VCID: 33652144928821A6BC-8067
   Subsystem 1 - Part No SW: 8K0 959 754 B    HW: 8K0 959 754 B
   Component: ELVAUDIB8  H36 0041
02811 - Control Module for Electronic Steering Column Lock (J764)
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:56:22
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Fault Frequency: 11
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:02:48
                    Fault Frequency: 9
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:03:55
                    Fault Frequency: 12
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:07:22
   Part No SW: 8T1 820 043 AA    HW: 8T1 820 043 AA
   Component: KLIMA 1 ZONE  H06 0150
   Revision: A1000000    Serial number: 01131020080428
   Coding: 64002000
   VCID: 70EFEE48A31E5ABE81-8025
                    Fault Status: 01101000
                    Fault Frequency: 9
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:53:35
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:55:51
                    Temperature: -7.0°C
                    Temperature: -12.0°C
                    Absolute Pres.: 0.6 bar
                    RPM: 160 /min
                    Current: 0.000 A
                    Temperature: -7.0°C
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:07:45
                    Voltage: 7.90 V
                    Temperature: -5.0°C
            000 -  -  - Intermittent
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:09:37
   Component: BCM1 1.0      H22 0253
   Revision: 05022001    Serial number: 00000000245753
   Coding: 690000B1063C00010000080300007F5F0F14520800000021000000
   VCID: 306F2E48639E1ABEC1-8065
   Component: WWS 201008  H06 0070
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 941 531 F    HW: 8K0 941 531 F
   Component: E1 - LDS  H07 0070
   Subsystem 3 - Part No SW: 8K0 907 410 A    HW: 8K0 907 410 A
   Component: UGDO HL US  H04 0060
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:07:00
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:35:00
00927 - Terminal 30 (Right)
                    Fault Status: 00101011
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:07:00
                    Fault Status: 00101100
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:07:00
00910 - Indicator Lamp for Emergency Flashers (K6)
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:02:00
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:05:00
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
   Component: AirbagVW-AU10 H27 0410
   Serial number: 0039KD14DTEK
   Coding: 303836354230303030304A55304C384B3053
   Shop #: WSC 02135 785 00200
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 408F7E88DB3E8A3E31-8015
   Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
   Serial number: 5810000R0800002N8D
   Serial number: 6334MSME41406E29D
   Serial number: 6344MSME427263659
   Serial number: 6352QSME700E5026B
   Serial number: 6362QSME1C0F1A38S
   Serial number: 63732SME72101234J
   Serial number: 63832SME5A0D42360
13697280 - Component Protection
             U1101 00 [008] - Active
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:04:48
13635840 - Supply voltage
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:02:09
             B10B4 00 [008] - Function Restriction due to Undervoltage
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:56:04
   Component: Lenks.Modul   H13 0013
   Revision: --------    Serial number: 90304HJD0001E
   Coding: 000014
   VCID: 3D71077CA4CCE7D65A-8069
                    Fault Frequency: 17
                    Reset counter: 241
                    Reset counter: 241
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 950 A    HW: 8K0 920 950 A
   Component: KOMBIINSTR.   H17 0224
   Revision: 00000000    Serial number: 9DR1997A8
   Coding: 8B1209000300D705020000
   VCID: 2D51373C74AC7756EA-8079
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:56:07
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:05:35
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:07:34
   Part No SW: 8T0 907 468 H    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0094
   Revision: 4GB20042    Serial number: 4200G08A128059
   Coding: 000303
   VCID: 46836890F11AA40E0B-8013
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H04 0150
01304 - Radio
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:00:31
02252 - Generator
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:03:18
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:35:45
Address 2E: Media Player 3 (R199)       Labels: 8T0-035-785.clb
   Part No SW: 8T0 035 785     HW: 8T0 035 785
   Component: SG ext.Player H06 0210
   Revision: 00000000
   Coding: 020302
   VCID: 78FFD668CB6E02FE49-802D
01304 - Radio
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:00:46
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:07:21
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:07:21
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Revision:             Serial number: 0000007848555
   Coding: 011C03204000410001
   VCID: 41897B8CD83483363E-8015
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:07:27
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:35:48
   Revision: 00002001    Serial number: 0115223192
   Coding: 0106023A007A400400B001
   Component: GTO BF  H06 0040
   Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J245 PS039  H06 0041
7 Faults Found:
03177 - Relay for Power Outlets (J807)
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:01:18
03123 - Terminal 30 - 2
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:03:55
03124 - Terminal 30 - 3
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:04:08
00926 - Terminal 30
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:04:16
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:05:35
01512 - Control Module for Sliding Roof
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:08:10
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:02:25
Address 47: Sound System (J525)       Labels: 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
   Component: DSP STD       H07 0220
   Revision: S2100000
   Coding: 0203010102
   VCID: 6ED3F030B92A4C4E93-803B
01304 - Radio
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:53:39
                    Voltage: 13.50 V
                    Temperature: 5.0°C
                    Bin. Bits: 00000001
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:35:38
                    Voltage: 7.90 V
                    Temperature: 11.0°C
                    Bin. Bits: 00000010
                    Bin. Bits: 00000011
                    Bin. Bits: 00000000
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000007831556
   VCID: 408F7E88D33E8A3E31-8015
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:05:02
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:35:48
   Part No SW: 8K0 907 801 F    HW: 8K0 907 801 F
   Component: EPB Audi B8   H06 0070
   Revision: 00000003    Serial number: 00000000252098
   VCID: 326B24406D9228AEB7-8067
7 Faults Found:
                    Reset counter: 201
                    Voltage: 0.00 V
                    Count: 77
                    Hex Value: 0x4060
                    Hex Value: 0x0082
                    Hex Value: 0x4040
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:53:34
                    Voltage: 14.20 V
                    Count: 80
                    Hex Value: 0x0273
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Fault Status: 00100011
                    Fault Frequency: 8
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:07:38
                    Voltage: 12.30 V
                    Count: 11
                    Hex Value: 0x0262
                    Hex Value: 0x0018
                    Hex Value: 0x1010
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:35:45
                    Voltage: 7.90 V
                    Count: 44
                    Hex Value: 0x0160
                    Hex Value: 0x0008
                    Hex Value: 0x0101
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:05:34
                    Voltage: 12.10 V
                    Count: 67
                    Hex Value: 0x0270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
02434 - Supply Voltage for Control Module for Left Channel
                    Fault Status: 00101001
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:04:48
                    Voltage: 12.10 V
                    Count: 14
                    Hex Value: 0x0270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
02435 - Supply Voltage for Control Module for Right Channel
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:04:00
                    Voltage: 12.20 V
                    Count: 15
                    Hex Value: 0x0260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
Address 56: Radio
Address 62: Door, Rear Left (J388)       Labels: 4F0-959-795.clb
   Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
   Revision:             Serial number: 0000100362006
   Coding: 010C03204000210001
   VCID: 44877298C726961E15-8011
                    Fault Frequency: 9
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:07:26
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:35:47
Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
   Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
   Component: J502-RDK      H03 0250
   Revision: 00001001    Serial number: 13140781978227
   Coding: 0CD154
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:08:39
                        Not Recogn.
                    Bin. Bits: 00001000 00000001
                    Voltage: 7.40 V
                    Text: -05,0°C;n.erkannt;     n.erkannt
Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.clb
   Revision:             Serial number: 0000100361969
                    Fault Frequency: 9
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:05:01
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:35:47
   Part No SW: 8T0 862 336 C    HW: 8T0 862 336 C
   Component: FSE_256x BT     H33 0550
   Revision: 00000000    Serial number: 00000005023762
   Coding: 0010370
   VCID: 3B7509647AD8E9E664-806F
                    Reset counter: 241
01304 - Radio
                    Fault Frequency: 16
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:53:34
End-------------------------(Elapsed Time: 04:16)--------------------------
Jef
HQ
Charge battery.
Clear all DTCs.
Try to start engine a few times... but don't run the battery down!
Post follow up Auto-Scan.
Use #CODE tags.
Welder75
Canada
C?ID=261654
Did you check your relays ? Grounds? Most of your faults are due to killing your battery. Charge your battery up. Leave charger on it. Clear faults. See if anything is left after that. If all relays and fuse are good...do u hear your fuel pump humming when you turn your key on? If pump is working ..do you have fuel pressure to the injectors? Do u have spark? Do you have compression? Lots of homework to narrow it down.
Gone But Not Forgotten
Please check the terminal 30 relay and ignition switch as per WD.
After recharge and clear of DTC's
When it cranks to dead battery ......is this because when you turn off key it stays running?
yodizzle
C?ID=241097
Here are my codes after i put i a new battery
Thursday,11,February,2016,18:22:55:48457
          77
   Revision: E1H14---
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:41:05
   Revision: --H04---
   Coding: 001002
   Coding: 150500
   Coding: 090100
   Coding: 64002000
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:41:03
   Coding: 00FD11
   Coding: 000014
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:56:07
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:05:35
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:07:34
   Coding: 000303
01304 - Radio
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:41:08
   Revision: 00000000
   Coding: 020302
   Revision: S2100000
   Coding: 0203010102
01304 - Radio
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:41:07
                    Voltage: 11.90 V
                    Temperature: 5.0°C
                    Bin. Bits: 00000001
Address 56: Radio
   Coding: 0CD154
   Coding: 0010370
01304 - Radio
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:41:02
End-------------------------(Elapsed Time: 04:02)--------------------------
Welder75
Canada
C?ID=261654
Pls read the thread how to post autoscan. It is posted as a sticky note at the top of the car repair support. Use the codes.
16497/P0113/000275 - Intake Air Temp. Sensor (G42): Signal too High
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Possible Causes
Fuse(s) faulty
Wiring and/or Connector(s) from/to Intake Air Temp. Sensor (G42) faulty
Possible Solutions
Check Fuse(s)
Check Wiring and/or Connector(s) from/to Intake Air Temp. Sensor (G42)
Check/Replace Intake Air Temp. Sensor (G42)
Possible Causes
Ignition Switch faulty
Wiring between Instrument Cluster (J285) and Climatronic Control (J255) faulty
Instrument Cluster (J285) faulty
Possible Solutions
Check Ignition Switch
Check Wiring between Instrument Cluster (J285) and Climatronic Control (J255)
Check Instrument Cluster (J285)
Check Climatronic Control (J255)
also for a new battery...... Freeze Frame:Voltage: 11.90 V ??
keep your battery hooked up to a charger, you need a solid 12.5 + voltage to insure electronics are properly powered and function proper.
maybe check to see if you have a parasitic draw draining your battery. that short can cause havoc.
Welder75
Canada
C?ID=261654
for my own information .... anyone know why Address 08: Auto HVAC (J255) has Labels: Redir Fail!
Other_Erik
Northern VA (DC Area)
C?ID=192416
Also saw in first post that you have 02811 - same issue I've been having with my 2005 A6 3.2 - Electronic Steering Column Lock (J764) - this code is what keeps my A6 from starting, and clearing that code gets me back on the road again. Seems I'm nowhere near the only one with this issue, as I called my local stealership to see how much it would be to fix, and I quote - "This is for a 2005, right? I just quoted that to someone else earlier this morning, your total is going to be $3,220 plus misc shop fees." If I were the litigious type, I'd be considering going in on a class action over this, as it seems to be a VERY common fault, and one that they want more than the car is worth to fix... Probably not so much the case for you, but then you may be one of the lucky ones where they didn't rivet the J764 to the steering column - them doing so has made it impossible to replace with the same part without replacing the entire steering column...
O_E
yodizzle
C?ID=241097
Really! What exactly does the Electronic Steering Column Lock (J764) Do? Gonna clear it and test.
Does your car crank when it's in that state?
yodizzle
C?ID=241097
Car still does not start, when i push key the motor turns and spits and sputters and chugs. Sounds like an old steam machine.
I've charged my battery and now am leaving the charger on it even when i start so that the battery doesn't drain.
ANYONE SEE ANYTHING STRANGE THAT WOULD STOP MY CAR FROM RUNNING??????????? RAN ADVANCE MEASURE ON MODULE "5" OPTION 002 AND INSIDE OF THE 4TH BOX THE VALUE WAS "02". OTHER 3 BOXES ALL READ 12.4 VOLTS.
ALSO, THE ENGINE CONTROL MODULE IS READING " 4629 - ECM Power Relay Load Circuit P068A 00 [036] - Opens Too Early"?????? IS THAT THE ACTUAL RELAY OR ECM, ANY HELP IS APPRECIATED, THANKS GUYS.
Friday,12,February,2016,23:31:00:48457
          77
   Revision: E1H14---
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:36:12
4261 - System Voltage
          P0562 00 [101] - Too Low
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 01:11:00
   Revision: --H04---
   Coding: 001002
   Coding: 150500
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:41:30
                    Hex Value: 0x0000
                    Hex Value: 0x1082
                    Hex Value: 0x0013
                    Hex Value: 0x0272
                    Hex Value: 0x00FF
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 02:18:23
                    Hex Value: 0x0000
                    Hex Value: 0x1082
                    Hex Value: 0x0021
                    Hex Value: 0x245F
                    Hex Value: 0x00FF
   Coding: 090100
                    Fault Frequency: 20
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:40:06
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 02:17:31
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 02:18:29
   Coding: 64002000
                    Fault Status: 01100010
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:23:01
                    Temperature: -1.0°C
                    Temperature: -3.0°C
                    Absolute Pres.: 0.8 bar
                    Current: 0.000 A
                    Temperature: -1.0°C
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:23:01
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 02:39:16
                    Voltage: 8.40 V
                    Temperature: -1.0°C
   Coding: 00FD11
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 02:17:00
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 02:18:00
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:40:00
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:41:38
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:40:54
   Coding: 000014
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 02:12:06
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 02:12:06
   Coding: 000303
01304 - Radio
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:23:07
            000 -  -
                    Fault Frequency: 15
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:38:00
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 01:02:16
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 02:39:47
   Revision: 00000000
   Coding: 020302
01304 - Radio
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:35:07
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:40:06
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 02:39:15
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:40:17
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 02:17:48
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 02:18:29
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:40:23
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 02:18:29
   Revision: S2100000
   Coding: 0203010102
01304 - Radio
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:23:06
                    Voltage: 11.70 V
                    Temperature: 1.0°C
                    Bin. Bits: 00000001
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 02:40:16
                    Voltage: 6.30 V
                    Temperature: -3.0°C
                    Bin. Bits: 00000010
                    Bin. Bits: 00000001
                    Bin. Bits: 00000000
            000 -  -
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:23:01
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:23:01
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 02:41:05
                    Voltage: 6.60 V
                    Count: 44
                    Hex Value: 0x0270
                    Hex Value: 0x0082
                    Hex Value: 0x0101
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:41:30
                    Voltage: 9.40 V
                    Count: 80
                    Hex Value: 0x0260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
02442 - Function Lamp in Control Head
                    Fault Status: 01101001
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:23:02
                    Voltage: 11.80 V
                    Count: 72
                    Hex Value: 0x0260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
Address 56: Radio
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 02:17:48
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 02:18:29
   Coding: 0CD154
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 02:40:14
                        Not Recogn.
                    Bin. Bits: 00000000 00001001
                    Voltage: 6.20 V
                    Text: -01,0°C;n.erkannt;     n.erkannt
            000 -  -
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:23:02
                    Reset counter: 201
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:23:02
   Coding: 0010370
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 02:39:16
01304 - Radio
                    Fault Frequency: 9
                    Reset counter: 241
                    Mileage: 120250 km
                    Date: 2008.05.27
                    Time: 00:23:01
End-------------------------(Elapsed Time: 04:13)--------------------------
yodizzle
C?ID=241097
Motor has great compression. 1st thing that was checked.
Have you addressed why the intake air temp sensor is with a DTC, further using WD and specification tests with a DVOM in the repair manual?
Welder75
Canada
C?ID=261654
Welder75
Canada
C?ID=261654
Possible Symptoms
Possible Causes
Fuse(s) faulty
Possible Solutions
Check Fuse(s)
Possible Causes
Possible Solutions
between all 3 auto scans these are the only 2 faults that stayed constant.... focus on these first. like Jack says above check G42
you have a aftermarket radio install?
OP Please relive post #4
Do you have a WD yet?
You guys can add the clouds and vortices .............:p
yodizzle
C?ID=241097
What is a WD? Sorry I'm not familiar yet
yodizzle
C?ID=241097
Terminal 30 relay? Where is this located and whats the procedure to check the ignition switch
yodizzle
C?ID=241097
Yes, it was cranking and you could not stop it at one point. But since i have gotten a new battery it only cranks for 10 seconds or so and then stops.
