Lets party,
ok, so looking at the link address above this is thread 5303. but looking at the forum statistics it is #5000.
so, maybe i will make this a inquiry.
for the 2002 new beetles, do they show freeze frames? i have the box check to show freeze frames....but they dont show. is it because the car doesnt support Can bus?
here is my auto scan,,,
I was hoping to see what the coolant temp was at time of fault 17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat)
P1296 - 35-10 - - Intermittent
i cleared the codes, but after went for a drive, and this code came back after 45 mins. engine was cool when i scanned it again. so it shows intermittent,, unles its a wiring issue or faulty sensor or thermastat
Saturday,06,February,2016,18:17:33:49733
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: 3VWCB21C02M434363 License Plate:
Chassis Type: 1C (1C - VW New Beetle (1998 > 2010))
Scan: 01 02 03 08 15 17 19 22 25 26 29 35 37 39 46 54 56 65 75
VIN: 3VWCB21C02M434363 Mileage: 183360km-113934miles
Address 01: Engine Labels: 06A-906-032-AZG.clb
Part No: 06A 906 032 GE
Component: 2.0l R4/2V G 4075
Coding: 00001
Shop #: WSC 91518
VCID: 67DDE6B605AF9106D0-5140
3VWCB21C02M434363 VWZ5Z0ZD051284
16804 - Catalyst System; Bank 1
P0420 - 35-10 - Efficiency Below Threshold - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
16705 - Engine Speed Sensor (G28)
P0321 - 35-10 - Implausible Signal - Intermittent
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 J
Component: ABS FRONT MK60 0103
Coding: 0004097
Shop #: WSC 00066 000 00000
VCID: 316948EEABEB1FB6CE-5140
Part No: 1C0 909 605 A
Component: 25 AIRBAG VW51 0E 0004
Coding: 12853
Shop #: WSC 00066
VCID: 224BB7A2AE0DB42E47-4AE8
01218 - Side Airbag Igniter; Passenger Side (N200)
32-10 - Resistance Too High - Intermittent
Address 17: Instruments Labels: 1C0-920-x4x.lbl
Part No: 1C0 920 851 CX
Component: KOMBI+WEGFAHRS. M73 V02
Coding: 03332
Shop #: WSC 91518
VCID: 78FFB5CA58110EFE49-4B00
01039 - Coolant Temperature Sensor (G2)
Part No: 6N0 909 901
Component: Gateway K<->CAN V022
Coding: 00006
Shop #: WSC 91518
VCID: 70EF8DEA306156BE81-4AE8
Part No: 1C0 959 799 G
Component: 2K Komfortgerát HLO 0004
Coding: 00064
Shop #: WSC 00066
VCID: 3B756AC629A7E5E664-4B00
Subsystem 1 - Part No: 1C2959802A
Component: 2K Tõrsteuer.FS KLO 0004
Subsystem 2 - Part No: 1C2959801A
Component: 2K Tõrsteuer.BF KLO 0002
8 Faults Found:
52-10 - Supply Voltage Too High - Intermittent
54-10 - Incorrectly Equipped - Intermittent
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
35-00 - -
End-------------------------(Elapsed Time: 04:19)--------------------------
