- Jan 11, 2026
- 51
- 2
- Oregon, USA
- C?ID=640767
Ok, so I am new to the water cooled vw's. This will be a little long but I do not want to leave out anything. I bought this 2013 VW Beetle TDI Fender edition Dec. 22 2025. Here is what I knew when buying it, it has the egr and dpf deleted with a stack. Tunezilla Stage one tune for the delete. It was in limp mode, he said he parked it and the next day it was having issues (I call BULL) 139,665 miles, DSG Trans. It does fire up and run and move but stuck in limp mode, He replaced the engine wiring harness due to original getting damaged some how. it had a few codes with a normal scan tool. Code P13d6, P13d0, P00AF, P0118 and P0641. I replaced all 4 glow plugs to eliminate P13d6 and P13d0. I replaced the actuator to get rid of P00AF, and one of the coolant temp sensors wasn't connected causing P0118. I checked the MAF sensor and cleaned it. Now the only code on my basic scan tool is P0641. still fires up and runs but still in limp mode.
Here is where things start to get weird. The windows worked when I got it, but then they stopped, found the switches on both doors had corrosion in them so I replaced them, Windows switches work, but driver side master will not roll down the passenger window. Plus after a few minutes the windows stop working, I have to unplug then battery then plug it back in and they'll work for a few minutes then stop, plus they don't do the little roll down and back up when opening and closing the doors, I've tried the push the buttons down and hold for 5-15 seconds and on the up, doesn't fix the issue. That's one issue that wasn't there when I first got it. Weird thing is the remote mirrors were not working and now they are working. Door lock sensors on the handles are functioning even tho VCDS is showing something up with them. Sunroof is functioning with no problems. High beams are not turning on. All fuses are good, not sure about relays since I cant seem to find an info on which does what really.
Next the steering wheel controls for the stereo and dash controls worked when I got it, but now they don't and the horn no longer works. Didn't do anything that would affect the clock spring, I pulled the clock spring out, checked all connections, and checked its internal ribbon and connections, All are good. But just don't work or light up. I checked the wiring at the steering wheel and its connections all the way to the main harness into the BCM, no brakes in the wires. Stereo and nav are working even tho vcds shows codes for it, but I am assuming that is do to the steering controls failing.
Back to the motor. I checked all grounds, Good connections and checked with multi meter. Checked alternator output, it was 14.6v at the battery. Motor harness is new. I have checked all fuses, all are good, not sure about relays, partly due to I cant find anything telling me what relay does what, and it doesn't have the infamous 109 relay. I just checked the MAP sensor and tested its voltage at the wires and with the motor off but power on it is getting 5.8v, I know this is to high, should be between 4 and 5v. I am beginning to think the ecu and bcm are having issues.
One of the HVAC Lines is disconnected and system is currently empty so that is why it shows up in the scan.
My first time scanning it with VCDS it gave me a 02- Auto Trans -- Status OK 0000, But now it is giving me a malfuntion with it.
With all the weird working then not working and high voltage at the MAP I am thinking there is a problem with the ECU and possibly the BCM. Here is my scan.
Sunday,11,January,2026,21:16:35:20311
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4671.5
VIN: 3VWJL7AT6DM657138 License Plate:
Chassis Type: AT-VW32 (6R0)
Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 37 44 47 56 B9
VIN: 3VWJL7AT6DM657138 Mileage: 224770km-139665miles
02-Auto Trans -- Status: Malfunction 1010
B9-Aux. Display -- Status: Malfunction 0010
Part No SW: 03L 997 030 G HW: 03L 907 309 AA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H15--- Serial number:
Coding: 0050078
Shop #: WSC 23116 035 00000
VCID: 323AF986F82B94EA487-8066
VINID: 0E69DA70746419474614704320BB1DE6D8
005784 - Please Check DTC Memory of Steering Wheel Electronics
P1698 - 000 -
Mileage: 224772 km
Date: 2026.01.08.
Time: 23:16:02
(no units): 4.0
(no units): 255.0
Bin. Bits: 11000001
001601 - Sensor Reference Voltage A
P0641 - 000 - Open Circuit - MIL ON
Fault Status: 11100000
Mileage: 224772 km
Date: 2026.01.08.
Time: 23:16:03
Voltage: 12.08 V
Temperature: 4.5 C
(no units): 0.0
Torque: -150.0 Nm
000897 - Glow Plug/Heater Indicator Circuit
P0381 - 000 - Implausible Signal - Intermittent
Mileage: 224772 km
Date: 2026.01.11.
Time: 00:17:29
Temperature: 5.4 C
Voltage: 12.39 V
Bin. Bits: 01000110
Torque: 219.0 Nm
Temperature: 19.8 C
Readiness: 0 0 0 1 X
Component: GSG DSG AG6 512 9430
Revision: 05651213 Serial number: 00001211131241
Shop #: WSC 00066 000 00000
VCID: 14765F1E627F7ADA3AB-8040
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU - Intermittent
Fault Frequency: 0
Mileage: 224772 km
Date: 2026.01.08.
Time: 23:06:49
01196 - Engine-Transmission Data Bus
Mileage: 224772 km
Date: 2026.01.08.
Time: 23:06:51
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V3.clb
Part No SW: 5C0 907 379 C HW: 5C0 907 379 C
Component: ESP MK60EC1 H31 0156
Revision: 00H31001
Coding: E14B401649270001870C02E792210042A71000
VCID: 2E02EDF6E013B00A2CF-807A
Reset counter: 188
Mileage: 224772 km
Date: 2025.12.08.
Time: 00:03:01
Count: 7
Count: 15
Count: 20992
Count: 128
Count: 24832
Count: 1280
Fault Status: 00101101
Reset counter: 188
Mileage: 216253 km
Date: 2025.09.10.
Time: 20:14:53
Count: 14
Count: 13056
Count: 8193
Count: 48640
Count: 1024
Count: 513
Reset counter: 188
Mileage: 224772 km
Date: 2026.01.08.
Time: 22:52:17
Count: 2
Count: 14
Count: 20736
Count: 8195
Count: 44800
Count: 767
Reset counter: 188
Mileage: 224772 km
Date: 2025.12.08.
Time: 00:02:45
Count: 2
Count: 14
Count: 20992
Count: 8194
Count: 39424
Count: 1280
Reset counter: 188
Mileage: 224763 km
Date: 2025.11.02.
Time: 00:02:43
Count: 2
Count: 12
Count: 4352
Count: 16390
Count: 41984
Count: 768
02214 - Tire Pressure Warning
Fault Status: 01100010
Reset counter: 188
Mileage: 216253 km
Date: 2025.09.10.
Time: 20:14:53
Count: 14
Count: 13056
Count: 16401
Count: 48640
Count: 1024
Count: 513
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Revision: 00086000 Serial number: 0189892323 Dataset Number: 5K0116v____ 5C08
Coding: 030C0C
ASAM Dataset: EV_KESSYPQ35G A02715
ROD: EV_KESSYPQ35G_A02_VW32.rod
VCID: 3436FF9E0EBF9ADA5AB-8060
65794 - Function Restricted due to Insufficient Voltage
U1400 00 [00001000] - -
Reset counter: 228
65813 - Supply voltage
U1011 00 [00001000] - Voltage too Low
Reset counter: 228
1052935 - Touch Sensor on Exterior Door Grip; Driver Side
B116B 11 [00001000] - Short to Ground
Reset counter: 228
1053191 - Touch Sensor on Exterior Door Grip; Passenger Side
B116C 11 [00001000] - Short to Ground
Reset counter: 228
1057547 - Antenna for Keyless Entry System; Interior Antenna 1
B1172 13 [00001000] - Open Circuit
Reset counter: 228
Mileage: 224772 km
Date: 2025.12.08.
Time: 00:05:42
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 BC HW: 5C0 820 047 BC
Component: J301 Klimaanlage 0204
Revision: 2001111S Serial number: 00000001339224
VCID: 629A49C6E84B446AF87-8036
Fault Status: 00101001
Reset counter: 228
Mileage: 216253 km
Date: 2025.09.10.
Time: 20:14:51
Fault Status: 00100001
Reset counter: 228
Reset counter: 228
Mileage: 224772 km
Date: 2025.12.08.
Time: 00:02:44
Reset counter: 228
Mileage: 224772 km
Date: 2025.12.08.
Time: 00:02:58
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 088 C HW: 7H0 937 088 A
Component: BCM25 KDR3 H78 0377
Revision: BP078001 Serial number: 0568 154160066
Coding: 3BBC691B088B080008A82930240984C5AD82622F60000C51B2A004000000
Shop #: WSC 22746 002 1048576
VCID: 3530C29A054583D26D5-8060
Subsystem 1 - Part No SW: 5C5 959 591 HW: 5K0 959 591
Component: J245 PS71.023 H10 0007
Serial number: WRH0007M2YZ
Coding: 381000
7 Faults Found:
Fault Frequency: 112
Reset counter: 188
Mileage: 216253 km
Date: 2025.09.10.
Time: 20:22:08
Reset counter: 228
Mileage: 224772 km
Date: 2025.12.08.
Time: 07:48:40
Reset counter: 228
Mileage: 224772 km
Date: 2025.12.07.
Time: 00:34:15
01326 - Control Module for Multi-Function Steering Wheel (J453)
Reset counter: 228
Mileage: 224772 km
Date: 2025.12.28.
Time: 00:07:55
03020 - Local databus 2
Fault Status: 01101100
Fault Frequency: 9
Reset counter: 188
Mileage: 224772 km
Date: 2025.12.28.
Time: 00:09:58
03591 - Control Circuit for Horn
Fault Status: 00101011
Mileage: 216253 km
Date: 2025.09.10.
Time: 20:14:54
Reset counter: 188
Mileage: 224772 km
Date: 2025.12.08.
Time: 00:02:44
Part No SW: 5C0 959 655 Q HW: 5C0 959 655 Q
Component: AirbagVW10G 014 0851
Serial number: 003LKM05E7TZ Dataset Number: v00301625C5 0162
Coding: 00004E45
Shop #: WSC 40269 001 1048576
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 40DEA34E4A07367ACE3-8014
Serial number: 6940000Y120000M8TC0+
Coding: 30304C
Serial number: 3572MSME64440574ZZZR
Serial number: 3582MSME4A413174ZZZS
Subsystem 4 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME07132C35ZZZR
9443861 - Driver's Front Airbag Crash Sensor
B101A 15 [10001000] - Open or Short to Plus
Mileage: 224772 km
Date: 2025.12.07.
Time: 00:26:33
9444117 - Front Passenger's Front Airbag Crash Sensor
B101B 15 [10001001] - Open or Short to Plus
Mileage: 224772 km
Date: 2025.12.07.
Time: 00:26:33
B10B4 00 [00001000] - Function Restriction due to Undervoltage
Reset counter: 228
Mileage: 224772 km
Date: 2025.12.08.
Time: 00:54:18
Part No SW: 5C5 920 970 G HW: 5C5 920 970 G
Component: KOMBI H23 0103
Revision: X0023005 Serial number:
Coding: 250E01
Shop #: WSC 00066 000 00126
ASAM Dataset: EV_KombiUDSMM9RM10 A04712
ROD: EV_KombiUDSMM9RM10_A04_VW12.rod
VCID: 2F3CF0F2E799B902279-807A
13635840 - Supply voltage
[Supply voltage too low]
Reset counter: 228
Reset counter: 228
13639424 - Please Check Fault Codes in Engine Control Module
U101F 00 [00001000] - -
[Steuerger t f r Motor: bitte Fehlerspeicher auslesen K hlmitteltemperatur]
Reset counter: 228
Mileage: 216253 km
Date: 2025.09.10.
Time: 20:14:53
12648448 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
[Steuerger t f r Motor: keine Kommunikation]
Reset counter: 228
Mileage: 224772 km
Date: 2025.12.08.
Time: 00:02:45
12648704 - Function Restricted due to Missing Message(s)
[Steuerger t f r Getriebe: keine Kommunikation]
Reset counter: 228
Mileage: 224772 km
Date: 2026.01.08.
Time: 22:52:17
Address 19: CAN Gateway (J533) Labels:. 6R0-907-530-V2.clb
Part No SW: 6R0 907 530 F HW: 1K0 907 951
Component: J533 Gateway H39 0042
Revision: H39 Serial number: 20011303300364
Coding: 254080
VCID: 3632C596184388CA64F-8062
Fault Status: 00110100
Reset counter: 228
Mileage: 224772 km
Date: 2025.12.08.
Time: 00:02:44
Reset counter: 228
Mileage: 224772 km
Date: 2026.01.08.
Time: 22:52:18
Part No SW: 5K0 953 234 HW: 5C5 920 970 G
Component: IMMO H23 0103
Coding: 000007
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
VCID: 6A8A21E61CFB1C2A307-803E
9456681 - Key
B104C 29 [00001000] - Implausible Signal
Fault Frequency: 11
Reset counter: 228
Mileage: 224772 km
Date: 2025.12.26.
Time: 16:03:11
Part No SW: 5K0 905 861 B HW: 5K0 905 861 B
Component: ELV-PQ35 H20 0240
Revision: 00000000 Serial number: 12000268177003
Coding: 4900000000000000
Shop #: WSC 00066 790 50316
ROD: EV_ELVMarquMPVW36X_VW32.rod
13893888 - Function Restricted due to Excessive Voltage
U1401 00 [00001000] - -
[Over volatage (temporary)]
Reset counter: 228
Mileage: 224772 km
Date: 2025.12.08.
Time: 00:00:02
ELV State: 0A
Information Clamps: 00 00
CoCo State: F0 01
WFS State: 00 1A
Vehicle speed: 655.35 km/h
Voltage: 89
[Under voltage (temporary)]
Reset counter: 228
Mileage: 224772 km
Date: 2025.12.07.
Time: 00:34:16
ELV State: 0C
Information Clamps: 77 60
CoCo State: B0 01
WFS State: 00 1A
Vehicle speed: 0.00 km/h
Voltage: 47
1049345 - Comfort System CAN Bus (SAE Medium Speed Bus)
U0011 00 [00001000] - Performance
[CAN-Bus off]
Reset counter: 228
Mileage: 224772 km
Date: 2025.12.08.
Time: 00:33:45
ELV State: 0A
CoCo State: F0 01
WFS State: 00 1A
Voltage: 2F
1048836 - Terminal S
B11A5 12 [00001000] - Short to Plus
Fault Frequency: 15
Reset counter: 228
Mileage: 224772 km
Date: 2025.12.13.
Time: 00:00:02
ELV State: 0C
Information Clamps: 02 00
CoCo State: 30 01
WFS State: 00 1A
Voltage: 7A
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Revision: A1001003 Serial number: 7663593968
Coding: 020100
VCID: 2A0AE1E6DCFBDC2AF07-807E
Reset counter: 228
Mileage: 224772 km
Date: 2025.12.08.
Time: 00:02:49
Reset counter: 228
Mileage: 224772 km
Date: 2025.12.08.
Time: 00:54:17
Part No SW: 1K0 035 274 D HW: 1K0 035 274 D
Component: RNS315-NAR H55 0319
Serial number: VWZAZ2M4298211
Coding: 04090001010002000000100A
Shop #: WSC 01383 790 50316
ROD: EV_RNS315NARV2UDS_VW32.rod
VCID: 251012DAB565F352DD5-8070
Component: NAR_V3_(0037) 0037
1048580 - Function Restricted due to Insufficient Voltage
[restriction due to undervoltage]
Reset counter: 228
Mileage: 224772 km
Date: 2025.12.08.
Time: 00:54:22
Reset counter: 188
Mileage: 216253 km
Date: 2025.09.10.
Time: 20:14:53
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 372CC892134971C27F9-8062
Reset counter: 228
Mileage: 224772 km
Date: 2026.01.08.
Time: 23:06:49
Voltage: 12.50 V
DU
Temperature: 14.0 C
RPM: 1498 /min
Mileage: 224772 km
Date: 2025.12.08.
Time: 01:20:18
Battery Volts: 7.7 V
PD
Temperature: 30.0 C
Torque: 0.000 Nm
Torque: 0.0 Nm
RPM: 1 /min
Drive Current: 0.0 A
Part No SW: 5C6 035 456 A HW: 5C6 035 456 A
Component: KonzernAmp10K H07 6813
Revision: -------- Serial number: EAA098A0006569 Dataset Number: 560050v____ 0001
ROD: EV_AudioVerst10KanalSTT3_VW32.rod
VCID: 261215D6C863F84AD4F-8072
9457664 - Function limitation due to excessive temperature
B1050 00 [00001000] - -
[Funktioneinschr nkung durch bertemperatur]
Fault Frequency: 9
Reset counter: 228
Mileage: 218400 km
Date: 2025.09.25.
Time: 16:41:54
9637138 - Loudspeaker 2 in Double-Subwoofer
B130D 12 [00001001] - Short to Plus
Reset counter: 188
Mileage: 216253 km
Date: 2025.09.10.
Time: 20:14:53
U1111 00 [00001001] - -
[Funktionseinschr nkung wegen fehlende Botschaft]
Reset counter: 188
Mileage: 224772 km
Date: 2026.01.08.
Time: 23:06:49
Address B9: Aux. Display (J285) Labels:* 5C5-919-527.clb
Part No SW: 5C5 919 527 C HW: 5C5 919 527 C
Component: ZUSATZANZEIGE H16 0014
Coding: 05
ASAM Dataset: EV_Auxi_Disp_Unit_UDS_VDD 001007
ROD: EV_Auxi_Disp_Unit_UDS_VDD.rod
VCID: 3138F68AF1ADAFF231D-8064
1048577 - Function Restricted due to Insufficient Voltage
["Function ristriction through under-voltage]
Reset counter: 228
Mileage: 224772 km
Date: 2025.12.07.
Time: 00:34:18
1048578 - Function Restricted due to Excessive Voltage
["Function ristriction through over-voltage]
Reset counter: 228
Mileage: 224772 km
Date: 2025.12.08.
Time: 00:00:02
2097156 - Databus
[Control unit for engine: no communication]
Reset counter: 228
Mileage: 224772 km
Date: 2025.12.08.
Time: 00:02:45
2097157 - Databus
[Control unit for engine: please read out error memory oil temperature]
Fault Frequency: 9
Reset counter: 228
Mileage: 216319 km
Date: 2025.09.11.
Time: 18:10:06
End----------(Elapsed Time: 01:06, VBatt start/end: 12.1V/12.1V)-----------
------------------------------55 Faults Found------------------------------
