Version: Release 15.7.3 (x64) Running on Windows 7 x64
Data version: 20151216
Tuesday,09,February,2016,08:34:33:48700
Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 55 56 62 72
VIN: WAUZZZ8K5CA054347 Mileage: 143470km-89148miles
03- Brakes -- Status: OK 0000
05-/Start Auth. -- Status: Malfunction 0010
56-Radio -- Status: Sporadic communication error 1000
Address 01: Engine (DET---CDHB) Labels: 06H-907-115-CAB.clb
Part No SW: 8K1 907 115 M HW: 8K1 907 115
Component: 1.8l R4/4V TF H18 0004
Revision: A5H18---
Coding: 0104000C18070120
Shop #: 06324 000 00000
Dataset: EV_ECM18TFS8K1907115M A01004
ROD: EV_ECM18TFS_AU48.rod
VCID: 3879906783EDB7FE89-806C
2809 - Fuel Trim; Bank 1
P0171 00 [236] - System Too Lean
Mileage: 143258 km
Date: 2016.02.04
Time: 16:29:44
Address 03: Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 BF HW: 8K0 907 379 BF
Component: ESP8 front H04 0030
Coding: 030500
VCID: 7EF5467FE94949CE03-802A
Address 05: /Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 CC HW: 8K0 907 064 CC
Component: BCM2 2.0 H05 0435
Coding: 031100
Shop #: 06325 000 00000
VCID: 73E3674BD20B14A67C-8026
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H60 0072
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV H37 0042
00955 - Key 1
Fault Frequency: 20
Reset counter: 213
Mileage: 141285 km
Date: 2015.12.29
Time: 08:38:24
Part No SW: 8T2 820 043 AD HW: 8T2 820 043 AD
Component: KLIMA 1 ZONE H08 0180
Revision: B0000000 Serial number: 01230820111591
Coding: 64040000
VCID: 74E16457D705139E65-8020
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
Component: BCM1 1.0 H30 0392
Revision: 09030001 Serial number: 00000001024976
Coding: 2600D0914034AF010001000000001D0D0F1D030802010101000000
VCID: 3A7D8A6FB5E1A5EE7F-806E
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 260811 H06 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: H04 0003
Coding: 025028
Component: E1 - H03 0031
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 L HW: 8K0 959 655 L
Component: AirbagVW-AU10 H44 0610
Serial number: 003JMD0FSP40
Coding: 30533435363030303030554A3052384B3053
Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 4685EE9FF919D10E0B-8012
Serial number: 6334MSME641147635
Serial number: 6344MSME632550094
Serial number: 6352QSME175E206CO
Serial number: 6362QSME315C20405
Serial number: 63732SME3B5C52543
Serial number: 63832SME604F1D7EH
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372KHQ0019F
Coding: 000016
VCID: 3D778173A4CF92D65A-8068
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 900 M HW: 8K0 920 900 M
Component: KOMBIINSTR. H20 0258
Revision: 00300000 Serial number: EII20XT8C
Coding: 2F04080002000008010000
VCID: 3461A4579785539EA5-8060
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0117
Revision: GB800053 Serial number: 5300G11813837F
Coding: 00C303
VCID: 010F3D8398B736367E-8054
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Fault Frequency: 11
Reset counter: 220
Mileage: 141472 km
Date: 2016.01.02
Time: 09:34:07
Bin. Bits: 10000
Voltage: 12.10 V
Count: 12
01304 - Radio
Reset counter: 246
Mileage: 143376 km
Date: 2016.02.07
Time: 10:36:17
Bin. Bits: 10000
Voltage: 12.30 V
Count: 8
Bin. Bits: 10000
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: FA H08 1501
Coding: 011C02204001410001
VCID: 53A3C7CB324B74A69C-8006
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0157322684
Coding: 011A062200B900448130013280000000
Component: BACKUP HO H05 1501
Subsystem 3 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
Component: J245 PS050 H08 0043
Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AH HW: 8T0 035 223
Component: DSP STD H07 0230
Revision: S2200000
Coding: 0203010101
01304 - Radio
Reset counter: 246
Mileage: 143376 km
Date: 2016.02.07
Time: 10:43:42
Voltage: 12.50 V
Temperature: 46.0°C
Bin. Bits: 00000001
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: BF H08 1501
VCID: 52ADC2CF0D517DAE97-8006
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: Audi B8 H09 0100
Revision: 00000003 Serial number: 20000000087934
Shop #: 00000 000 00000
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357 B
Component: Dynamische LWR H01 0010
Coding: 0000004
VCID: 397F956370E7AEF676-806C
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T2 035 186 P HW: 8T2 035 186 P
Component: Concert3 H06 0350
Revision: 00000011 Serial number: AUZ5Z6K1638736
Coding: 0502008001010D000159070000
VCID: 4587E993CC1FDA1602-8010
Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
Component: Display
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
Component: HL H06 1501
Coding: 010C02204001210001
VCID: 56A53EDF21B9618E7B-8002
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Component: HR H06 1501
End-------------------------(Elapsed Time: 02:39)--------------------------
