2014 Passat SE 2.5L - Electronic Stabilization Error > Engine Shuts Off > Won't Restart for Awhile > Rinse & Repeat
robf
Winter Garden, FL, USA
C?ID=246080
Hello, everyone. I'm back. You might remember me from the ABS module issue you helped me resolve nearly a year ago (link). Time for something new...
After replacing and coding the ABS module, everything was running fine for several months. It started having a slightly rough idle around September/October, and I replaced the spark plugs in late November. It had been a long time and many miles since I had done it previously. The old plugs had some carbon buildup and 2 or 3 had some oil on the threads. I gapped the new plugs (Bosch iridium) per spec, and replaced the coils in the same order they were in originally. Idle seemed to improve some. I got an oil change and tire rotation, and the tire pressure light came on (which seems to be pretty standard after a rotation and inflation). I cleared it, and everything seemed fine for a little over a week.
On December 8, my son was leaving a friend's house when he called me to tell me that an electronic stabilization error popped up, the car became hard to steer (the engine had spontaneously turned off), and the dash was lit up like a Christmas tree. The engine would not restart. I checked all the fluids, and everything was in the normal range, and I didn't find any leaks. When AAA arrived about an hour later to tow it home, the engine started right up. They brought it home on the flatbed and parked it in the driveway under the car's own power. I plugged in VCDS, and did an auto-scan. I repeatedly cleared codes until all but one was gone. The tire pressure light was still on, and the button in the glove compartment would not clear it. A couple more attempts with VCDS, and I finally got it to clear. Maybe it was a one-time fluke. (It wasn't.) I didn't get a chance to post my story before leaving for vacation, and I didn't bring my VCDS laptop with me.
The car ended up sitting in the driveway for nearly a month. We returned from vacation, and this past Monday (January 5) I took it for a test drive it to the grocery store in our neighborhood a little over 2 miles away. I made it to the end of my street (150 yards) when it happened again:
  1. Error: stabilization control (ESC)
  2. Engine shuts off.
  3. Gauge cluster lights up like a Christmas tree.
  4. Car won't restart. Message says to press brake pedal. (I was.)
Ran auto-scan and tried clearing the codes. No luck. I let it sit for about an hour, and it starts up. I start backing the car down the street towards my house, and it dies again (same sequence as above) about 30 yards later. So, my wife, younger son, and I push it the rest of the way.
I'm thinking the engine control module has kicked the bucket, or maybe I've got a bad circuit breaker, fuse, or relay. Any advice/direction on where to begin to identify the problem would be greatly appreciated. Hopefully it's not the ABS module, but at least I know what to do about that now. :)
Best regards,
Rob
Monday,05,January,2026,18:54:34:00414
VCDS Version: 25.3.2.0 (x64)
VIN: 1VWBH7A39EC014453   License Plate:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 46 4F 52 56 62
          72 75 77
VIN: 1VWBH7A39EC014453   Mileage: 467040km-290205miles
01-Engine -- Status: Malfunction 1110
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Revision: 00086000    Serial number: 0193464145 Dataset Number: 5K0116v____ 560E
   Coding: 030C0C
   Shop #: WSC 09003 957 00200
   ROD: EV_KESSYPQ35G_A02_VW41.rod
   VCID: 346759AA9F3AF13B07-8060
   Part No SW: 561 907 426 C    HW: 561 907 426 C
   Component: AC Manuell    H02 0202
   Revision: 00001K01
   Coding: 0010001002
   ROD: EV_ACManuaElectGen2BHTC_VW41.rod
   VCID: 1B35921612A45E4326-804E
          U1111 00 [00001001] - -
                    Reset counter: 56
                    Mileage: 467046 km
                    Date: 2026.01.05.
                    Time: 18:39:40
   Part No SW: 5K0 937 085 AB    HW: 5K0 937 085 AB
   Component: BCM PQ35 B+   122 0173
   Revision: BH122001
   Coding: EF200E1B802B2AD4098800011600044800F1A08644801DB064806000AC70
   Shop #: WSC 05082 001 1048576
   VCID: 73E59AB6D2B4B603DE-8026
                    Reset counter: 56
                    Mileage: 467046 km
                    Date: 2020.05.28.
                    Time: 18:45:29
                    Voltage: 11.50 V
                    Reset counter: 56
                    Mileage: 467046 km
                    Date: 2020.05.28.
                    Time: 18:39:42
                    Voltage: 11.50 V
Address 15: Airbags
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20190227200282
   Coding: 110A140000
   Shop #: WSC 01286 386 08256
   VCID: 020BCF72950E8F8BC5-8056
   Serial number: 00000000000000733057
   Coding: E20000
   Part No SW: 561 920 970 F    HW: 561 920 970 F
   Coding: 231E01
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
   VCID: 1D319C0E0CB05073D8-8048
12648448 - Function Restricted due to Missing Message(s)
                    Reset counter: 56
                    Mileage: 467046 km
                    Date: 2026.01.05.
                    Time: 18:45:10
   Part No SW: 7N0 907 530 AM    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1642
   Revision:   H55       Serial number: 19071303001569
   Coding: 461000
   VCID: 7BF5B296FAE4FE4386-802E
                    Reset counter: 56
                    Mileage: 467046 km
                    Date: 2020.05.28.
                    Time: 18:39:43
   Coding: 000007
   VCID: 6ADB87D28D7E77CB6D-803E
   Revision: 00000000    Serial number: 13000013281001
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X_VW41.rod
   VCID: 306F55BA6B22CD1B63-8064
Address 2E: Media Player 3
   Part No SW: 1K0 035 274 F    HW: 1K0 035 274 F
   Component: RNS315-NAR    H70 0409
   Serial number: VWZAZ2N0314814
   Coding: 0400046104000B0000008000
   ROD: EV_RNS315NARV2UDS_VW41.rod
   VCID: 275DBEE65EEC8AA3B2-8072
   Component: NAR_V4  0041
   Revision: 13110009    Serial number: 0007062177
   Coding: 0404F5
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5BB5D21652241E43E6-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  006 5470
   Serial number: 14202630130722174504
   Coding: 800000
   Component: EZE_2         H55 1642
   Coding: 01030108
   VCID: 6FED96C6BE9C92E33A-803A
   Serial number: 53388786011310700720
   Coding: 181100
   Revision: 15110009    Serial number: 0007065311
   Coding: 0404F4
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5CB7D10A572A197BEF-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  006 5470
   Serial number: 14102631130712150525
   Coding: 800000
   Part No SW: 561 035 285     HW: 561 035 285
   Component: OCULowUSA     014 0086
   Serial number: 000003554140503
   Coding: 02140102C2423A107F1606000000
   ROD: EV_OCULow_001_VW41.rod
   VCID: 53A53A363AF4D6033E-8006
0041 - Databus
                    Reset counter: 56
                    Mileage: 467046 km
                    Date: 2026.01.05.
                    Time: 18:39:40
2103041 - Control Module
          B1788 F0 [00001001] - Start Prohibition Deactivated
                    Fault Priority: 8
                    Reset counter: 56
                    Mileage: 467046 km
                    Date: 2026.01.05.
                    Time: 18:39:40
Address 77: Telephone
End-------------------------(Elapsed Time: 03:13)--------------------------
------------------------------7 Faults Found-------------------------------
Looks like most everything on the Powertrain databus is off-line. You could certainly try disconnecting the ECU and then checking if the other stuff that's showing "Cannot be reached" then talks, but I'm not terribly hopeful.
robf
C?ID=246080
Forgive my ignorance, but where would I find this device—under the dash by the ODB port, in the engine compartment, elsewhere? Do you know where I can find a wiring diagram? Do I need one of these things to diagnose it? Thanks.
robf
C?ID=246080
Update: I was able to start it tonight. The check engine light was on, and the tire pressure light was flashing. Pressing the reset button did not turn off of the tire pressure light. I ran another auto-scan (below), and some of the components seemed to talk back to VCDS. Any new insights from this?
Sunday,11,January,2026,20:12:56:00414
          72 75 77
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 DD    HW: 07K 907 309 A
   Component: 2,5l R5/4V      G01 5685
   Revision: T6H02---    Serial number:
   Coding: 0000075
   Shop #: WSC 26035 002 1048576
   VCID: 73E59AB612B4B603DE-8026
   VINID: 0669D26074432554C00441050C9C3B47CA
001674 - ECM Power Relay Load Circuit
               P068A - 000 - Opens Too Early
                    Temperature: 18.0 C
                    Temperature: 18.0 C
                    Absolute Pres.: 1010.0 mbar
005668 - MIL Request Signal Active (Check TCM for errors too!)
               P1624 - 000 -
                    Mileage: 467047 km
                    Date: 2020.06.03.
                    Time: 00:54:34
                    RPM: 1297 /min
                    Load: 60.8 %
                    Temperature: 19.0 C
                    Temperature: 19.0 C
Readiness: 1110 0101
   Part No SW: 09G 927 750 LH    HW: 09G 927 750 LH
   Component: AQ 250 6F           2251
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 020BCF725D0E8F8BC5-8056
            004 - No Signal/Communication - Intermittent - MIL ON
                    Fault Status: 00101101
                    Fault Frequency: 14
                    Reset counter: 0
                    Mileage: 173075 km
                    Date: 2017.11.03.
                    Time: 20:27:59
Address 03: ABS Brakes (J104)       Labels:. User\1K0-907-379-60EC1-CC.lbl
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: C54BC0F5492308FEA30F03E9921C1061A0100012
   VCID: 75E1A4AEDCC0A833F0-8020
                    Reset counter: 56
                    Mileage: 467047 km
                    Date: 2020.06.03.
                    Time: 01:19:12
                    Count: 2
                    Count: 4
                    Count: 12288
                    Count: 8193
                    Count: 44032
                    Count: 1022
                    Reset counter: 56
                    Mileage: 467046 km
                    Date: 2020.06.03.
                    Time: 18:56:14
                    Count: 2
                    Count: 12
                    Count: 4608
                    Count: 8194
                    Count: 41728
                    Count: 1022
                    Reset counter: 56
                    Mileage: 467046 km
                    Date: 2020.06.03.
                    Time: 18:56:14
                    Count: 2
                    Count: 12
                    Count: 4608
                    Count: 16390
                    Count: 41728
                    Count: 1022
   Coding: 030C0C
   Revision: 00001K01
   Coding: 0010001002
          U1111 00 [00001000] - -
                    Reset counter: 96
                    Mileage: 467046 km
                    Date: 2026.01.11.
                    Time: 18:56:11
   Revision: BH122001
                    Fault Frequency: 19
                    Reset counter: 96
                    Mileage: 467046 km
                    Date: 2020.06.03.
                    Time: 18:56:33
                    Voltage: 11.85 V
01259 - Fuel Pump Relay (J17)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 56
                    Mileage: 467047 km
                    Date: 2020.06.03.
                    Time: 00:00:39
                    Voltage: 11.95 V
                    Reset counter: 96
                    Mileage: 467046 km
                    Date: 2020.06.03.
                    Time: 18:56:14
                    Voltage: 11.75 V
   Serial number: 003MWM02E0JS   Dataset Number: 560003v____ 0061
   Coding: 00005033
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 75E1A4AED4C0A833F0-8020
   Serial number: 6940000Y130000W6A20L
   Coding: 303044
   Serial number: 3572MSME6E466079ZZZ2
   Serial number: 3582MSME4E312078ZZZX
   Serial number: 3516KSME1D454E24ZZZ-
   Serial number: 3526KSME1A243623ZZZL
   Serial number: 3556LSME24366423ZZZO
   Serial number: 3566LSME45526A23ZZZW
   Coding: 110A140000
   Coding: E20000
   Coding: 231E01
                    Reset counter: 96
                    Mileage: 467046 km
                    Date: 2026.01.11.
                    Time: 18:56:11
   Coding: 461000
                    Fault Status: 00110100
                    Fault Frequency: 8
                    Reset counter: 96
                    Mileage: 467047 km
                    Date: 2020.06.03.
                    Time: 00:00:32
   Coding: 000007
   Coding: 0404F5
   Slave Driver:
   Coding: 800000
68108 - Function Restricted due to Missing Message(s)
                    Reset counter: 96
                    Mileage: 467047 km
                    Date: 2026.01.11.
                    Time: 01:19:09
131584 - Motor for Rear Window Regulator
          B11EE 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 56
   Coding: 01030108
   Coding: 181100
   Coding: 0404F4
   Slave Passenger:
   Coding: 800000
                    Reset counter: 96
                    Mileage: 467047 km
                    Date: 2026.01.11.
                    Time: 01:19:09
                    Reset counter: 56
0041 - Databus
                    Reset counter: 96
                    Mileage: 467046 km
                    Date: 2026.01.11.
                    Time: 18:56:11
                    Fault Priority: 8
                    Reset counter: 56
                    Mileage: 467047 km
                    Date: 2026.01.11.
                    Time: 01:00:59
   Part No SW: 5N0 035 729 A    HW: 5N0 035 729 A
   Component: TELEFON       H05 0315
   Revision: 1B001001    Serial number: 00007664959318 Dataset Number: 5N0035729A  0001
   Coding: 0A100300A0010110
   ROD: EV_UHVUMI.rod
   VCID: 2E534BC27116DBEB71-807A
End-------------------------(Elapsed Time: 03:12)--------------------------
------------------------------18 Faults Found------------------------------
Looks like an intermittent electrical problem -- either power or databus -- that makes a bunch of control modules go off-line.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
I do nkt think you have problem with Can Gateway, Can Gateway ending wirh 530AM are usually good once , the one I found that always has problem is 530P .
I think you either have problem with ECU or 12V going to it, or some relay that does not power up . On first scan lot of modules was not powered up ,so when problem exist you nerd to chevk 12V and ground at those modules first to see does it exist . If you do not habe 12V then you have power feed problem.
Ziddywerks
Northern NJ USA
C?ID=208579
7N0 gateways have proven to be more reliable than others. Although I do agree that its suspect the powertrain can is down. It would point the bulls eye at the gateway possibly however given the fact this vehicle has 290k miles. I would not be surprised if this was a issue related to the ecm. Also the fact that this is a 07K 2.5 5 cylinder engine with ME17.5.6 ecm points me towards ecm failure or wiring issue. I say this because those ecms are a known issue for failure. Most symptoms include the vehicle dying at random while driving or having no communication to the ecm. In most cases a restart is not possible for 20minutes of so or until the ecm cools. Having said that it would be wise to check powers ground and both can lines going to the ecm when the issue is occuring.Verify you have no comms and then check the wires and relays. If all checks out I would try a used ecm before anything else. If you need a programming solution I can also assist with that.
Jetta 97
C?ID=81680
I agree with EuroX, but one thing gets me confused is what TCU and AbS was also not talking in first scan.
  • Agree
Dr Sheldon
Windsor UK
C?ID=334979
That is just Madness - Wishful thinking and and a sign that if this is a CAN Communication issue, it has the potential to be, you will be out of your depth both in tooling and product knowledge. Let us be realistic from the off, better than offering false hope !!
Moss garages and "technicians" would be stumped with that !!
Thinking is best kept in the head !! It has no place early doors in a diagnostic procedure !! Thinking can start once Tests and Measurements have been made !!
I hope to win the lottery - Has it helped - Not in 40 years and I spend £100 a month on it !!
Yes of course, I can guide you via test and measurement to that fault and solve it in a timely manner - Cherry on top is the abundance of talent and knowledge in the forum from across the globe. There is not a machine on the planet that can not be fixed !!
Can you get factory wiring diagrams from Erwin from this car and be able to read and absorb them ?
Other that VCDS what electrical test tools and knowledge do you have ?
Not necessarily. It can help with the signal-to-noise ratio and seeing what comes back when (immediately after a clear, vs. after an ignition cycle, vs after a test drive) can be useful.
robf
C?ID=246080
The symptoms you list are spot on.
Thanks to all for the advice. I’ve been tied up with a project launch at work this week. Getting the diagrams shortly and jumping back into it today.
robf
C?ID=246080
I downloaded them. I'm a little rusty at it, but I can read and understand electrical diagrams.
I have a Fluke 179 multimeter. Is there anything else I should get? I have knowledge of and experience with troubleshooting and repairing electrical circuits from low voltage to 480V 3-phase. The biggest problem I've had with car electrical systems is finding where the components are located. The erWin diagrams are helpful with this.
robf
C?ID=246080
I've been checking the power to the ECM using the wiring diagrams and repair manuals I downloaded from erWin. Thanks to tutorial videos from our good friends at Ross-Tech, I've been able to interpret them. So far, I haven't found anything out of the ordinary. Power seems good (12V+). Resistance tests between the TCU and the ECU are within limits. I haven't been able to check them between the CAN databus and the ECU yet. I assume the bundle of wires with the large yellow connector is attached to the CAN. I didn't have time to tear apart the console, radio, and AC controls to get to it.
I pulled the ECM relay for a visual inspection, and it looked fine. Then I popped it back in. (Yeah, I know... Any real damage would likely be internal.)
I haven't exhausted tracing and inspecting all wiring harnesses and grounds for any issues.
I also haven't been able to reproduce the issue again. I had the engine running in my driveway for 2 hours Saturday night. For about 45 minutes of that, I alternated between shifting into drive and reverse and revving the engine up to around 2000 rpm while in neutral and park. It got nice and warm, but it just hummed right along.
Yesterday, for fun, I disconnected the T94 from the ECM and tried to start the engine, knowing full well it wouldn't. (The shear bolts were fun to deal with, but they were no match for a cutting disc on my Dremel.) I then ran an auto-scan (see below). I cleared all codes and took it for a test drive up and down my block--five times with no issues. I may try a longer test drive this weekend.
Is it worth pulling the ECM and opening it up to look for any obvious issues like singed components?
I really don't like these intermittent electrical issues that I can't replicate.
Sunday,25,January,2026,18:18:20:00414
          72 75 77
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.CLB
   Coding: 0000075
Readiness: 0110 0101
Address 02: Auto Trans        Labels: 09G-927-750.CLB
   Coding: 0000840
Address 03: ABS Brakes (J104)       Labels:. USER\1K0-907-379-60EC1-CC.LBL
   Revision: 00H46001
   Coding: 030C0C
   Revision: 00001K01
   Coding: 0010001002
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08X-09.CLB
   Revision: BH122001
   Coding: 00005033
   Coding: 303044
   Coding: 110A140000
   Coding: E20000
   Coding: 231E01
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.CLB
   Coding: 461000
   Coding: 000007
   Coding: 0404F5
   Slave Driver:
   Coding: 800000
                    Reset counter: 57
                    Mileage: 467047 km
                    Date: 2026.01.25.
                    Time: 00:12:51
Address 4F: Centr. Electr. II (J520)       Labels:. 1K0-907-532.CLB
   Coding: 01030108
   Coding: 181100
   Coding: 0404F4
   Slave Passenger:
   Coding: 800000
                    Reset counter: 57
                    Mileage: 467047 km
                    Date: 2026.01.25.
                    Time: 00:12:51
                    Fault Priority: 8
                    Reset counter: 57
                    Mileage: 467047 km
                    Date: 2026.01.25.
                    Time: 00:12:51
   ROD: EV_UHVUMI.rod
End-------------------------(Elapsed Time: 06:43)--------------------------
------------------------------3 Faults Found-------------------------------
robf
C?ID=246080
@Ziddywerks @Jetta 97 @Uwe @Dr Sheldon
Yesterday I let it idle in the driveway for about an hour with no issues. Today I started it up cold and drove it around the block 8-10 times, both with and without the AC and radio on. When I started it, it revved around 1,400 RPM before settling down to 800. It didn't spontaneously shut off, though.
I can't imagine I've exorcised the demons out of it or that unplugging and reseating a relay and three large connectors did anything to reset something. I don't want my son driving it across town on expressways, and I'm at a loss of what to chase next.
Ziddywerks
Northern NJ USA
C?ID=208579
So what your saying is it still needs a ECM like I mentioned in post#9. If the gateway has been addressed. Unless you have a wiring issue and comms are dropping at random,but It looks to be related to powertrain.
robf
C?ID=246080
Yes, I agree that this would be the next step. Any recommendations for a source?
Ziddywerks
Northern NJ USA
C?ID=208579
Its gonna need immobilizer programming. I can probably do it with a supplied dongle. Finding a good used unit is key. I would find out what is the latest ecm part number.
robf
C?ID=246080
The joys of working on a car that's 12+ years old.
As far as I can tell, the 07K 906 055 DD is the latest version of the ECM for my car. Later revisions (DE, DK, EK, etc.) come up for use in other vehicles. Are they interchangeable? There are lots of them on eBay (the link to Weird Al's song is very funny!).
If/when I get one, I'd be more than happy to send it your way. What dongle would you need?
