ST?ID=118489
2010 Audi S5 Cabrio with a 0B5 transmission, the mechatronics unit was replaced by some shop. As one might expect in this case, the engine runs fine, but the transmission won't take any gear and move under its own power. So the vehilce is towed to one "Mr.B". Here is the Auto-Scan that was submitted to us:
So standard mecha unit replaced, trans locked... no bid deal, Mr.B has full ODIS and knows how to use it, this should of been a simple task.
When I talked to Mr.B over the phone he was asking me if I knew of any issues with ODIS. Lulz.... but none specific to this. When he was trying match the mecha to the car and fail, it would give an vague message about an "invalid key" and was wondering what that meant. Car fires up just fine, no immobilizer codes so I'm thinking maybe the "key" is some sort of security verification with ODIS or something and that is where we left the call.
Following day, Mr.B notices something about the actual key:
It doesn't have any Audi logo on there... that is an aftermarket key. Contacts the owner of the vehicle and gets a factory original key from them:
With the factory key used in the car, ODIS was able to unlock the mecha unit without issue. So while the aftermarket key functioned as one would expect a key to function, it became an issue when the mecha unit was replaced. This is the first time we've come across tihs kind of issue.
Wednesday,17,December,2025,11:10:11:35342
VCDS Version: 25.3.2.0 (x64) HEX-NET CB: 0.4671.4
VIN: WAUVGAFH0AN000000 License Plate:
Mileage: 179890km-111778mi Repair Order: AUDI S5 CONV
Chassis Type: FH-AU48 (8T0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 26 36 3C 42 46 47 52 53
55 56 5F 62 6C 72
VIN: WAUVGAFH0AN000000 Mileage: 179890km-111778miles
26-Auto Roof -- Status: Cannot be reached 1100
3C-Lane Change -- Status: Cannot be reached 1100
Address 01: Engine (J623-CCBA) Labels:. 06E-907-551-CAK.clb
Part No SW: 8K0 907 551 D HW: 8K0 907 551 A
Component: 3.0T SIMOS84 H02 0003
Revision: --H02--- CVN: 95BDF015
Coding: 011C000A240F0128
Shop #: WSC 99999 999 2097151
ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
ROD: EV_ECM30TFS0218K0907551D.rod
VCID: 3228C67865A56F0B15-8066
VINID: 9D19665D15980117800052441C5257E0EB
Readiness: 1110 1101
Part No SW: 8K5 927 156 J HW: 0B5 927 156 K
Component: 0B5 30TFSINAR H08 0009
Revision: --H08--- Serial number: 0000000022 CVN: 0000F5A9
Shop #: WSC 00001 000 00000
ASAM Dataset: EV_TCMDL501021 A03005
ROD: EV_TCMDL501021_A03.rod
VCID: 40CC9CB0DB09CD9B93-8014
7971 - Transmission Control Unit
P1701 00 [10100111] - Locked
Mileage: 179896 km
Date: 2009.04.30
Time: 02:36:03
Engine speed: 0 /min
Transmission input speed: 0 /min
Engine torque: -28 Nm
ATF temperature: 37 C
Accelerator pedal position: 0.0 %
Clutch status: Beide Kupplungen offen
7977 - Transmission Control Unit
Mileage: 179896 km
Date: 2009.04.30
Time: 02:36:03
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CA HW: 8K0 907 379 AN
Component: ESP8 quattro H04 0010
Coding: 290D18
Shop #: WSC 00017 666 00729
VCID: 7AB82E58F555574B9D-802E
Part No SW: 8K0 907 064 DS HW: 8K0 907 064 DS
Component: BCM2 1.1 H02 0321
Coding: 0D0300
Shop #: WSC 02399 823 56573
VCID: 044450A0879111BBF7-8050
Subsystem 1 - Part No SW: 8Tz y59 u4 Cz HW: 8T: y59 7u4 C"
Component: FBSAUDIB8 IDG H50 00}
Serial number: 081p000p905w700w
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H36 0042
Serial number: 0209000036872015
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 D HW: 8T0 959 760 D
Component: MEM-BFS H10 0073
Revision: AA000000 Serial number: 00001001277546
Coding: C80170250D2400001000
Shop #: WSC 02391 823 56573
VCID: 44C490A0C711D1BBB7-8010
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AL HW: 8T1 820 043 AL
Component: KLIMA 3 ZONEN H08 0160
Revision: C3000000 Serial number: 01260520090506
Coding: 6613200E
VCID: 7BB62B5CFA6F6E4386-802E
00830 - Convertible Top Control Module (J256)
Reset counter: 35
Mileage: 179896 km
Date: 2009.04.30
Time: 02:35:59
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000273636
Coding: 26001091063CAF010000080000003D3D0F1C528800010161000003
VCID: 3C34E840BFE1A97BCF-8068
Subsystem 1 - Part No SW: 8F1 955 119 HW: 8K1 955 119 Labels:
1KX-955-119.CLB
Component: WWS 250509 H06 0021
Serial number: SWF09050255340
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels:
8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10476733
Coding: 02562A
Subsystem 3 - Part No SW: 8K0 941 531 AN HW: 8K0 941 531 AN
Component: E1 - LDS H08 0090
Serial number: 00000000001905090219
02258 - Door Opener Transmitter
Reset counter: 35
Mileage: 179896 km
Date: 2009.04.30
Time: 02:35:00
03457 - Control Module for Right Cabin Heater
Reset counter: 35
Mileage: 179896 km
Date: 2009.04.30
Time: 02:35:00
Reset counter: 35
Mileage: 179896 km
Date: 2009.04.30
Time: 02:35:00
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 H HW: 8K0 919 475
Component: PARKHILFE 4K H06 0050
Revision: 11001001 Serial number: 39940914103060
Coding: 200102
VCID: 3E30E248A9FDBB6BE1-806A
Address 15: Airbags (J234) Labels:| 8F0-959-655.clb
Part No SW: 8F0 959 655 A HW: 8F0 959 655 A
Component: AirbagVW-AU10 H09 0430
Serial number: 003A5D0503FB Dataset Number: 8F0909602B0020
Coding: 303737353631303030304A55304C38463053
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_AirbaAU10SMEAU485 001004
ROD: EV_AirbaAU10SMEAU485.rod
VCID: 3620FA6889CD732B39-8062
Subsystem 1 - Part No SW: 8K0 959 339 HW: 8K0 959 339
Component: BF-Gewichtss. H01 0050
Serial number: 5810000R0900004ALB
Serial number: 6334MSME48307A4CL
Serial number: 6344MSME47660A2BK
Serial number: 6352QSME63253F3AO
Serial number: 6362QSME5F294506O
Serial number: 63732SME01260F1C-
Serial number: 63832SME5C26191A3
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90304IEM0004K
Coding: 000036
VCID: 3D32E544A4FBA073F8-8068
Component: E221 - MFL H02 0003
Part No SW: 8T0 920 981 N HW: 8T0 920 981 N
Component: KOMBIINSTR. H33 0253
Revision: 00000000 Serial number: BYM66HU59
Coding: 8B1719000300D705020000
VCID: 47DE87ACF627FAA352-8012
Part No SW: 8T0 907 468 AA HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0101
Revision: FB800054 Serial number: 5400F095108007
Coding: 00C303
VCID: 004C5CB093890D9BD3-8054
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Serial number: 18049BC2220908
02849 - Control Module for Lane Change Assistance (J769)
Reset counter: 35
Mileage: 179896 km
Date: 2009.04.30
Time: 02:36:00
Bin. Bits: 10111
Voltage: 13.70 V
Count: 6
Bin. Bits: 10011
Time: 25.40 s
Reset counter: 35
Mileage: 179896 km
Date: 2009.04.30
Time: 02:36:01
Bin. Bits: 10111
Voltage: 13.60 V
Count: 6
Bin. Bits: 10011
Time: 25.40 s
02001 - Data-Bus Automatic Distance Regulation
Reset counter: 35
Mileage: 179896 km
Date: 2009.04.30
Time: 02:36:01
Bin. Bits: 10111
Voltage: 13.50 V
Count: 6
Bin. Bits: 10011
Address 26: Auto Roof
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Component: MEM-FS H10 0073
Revision: AA000000 Serial number: 00001001277541
Coding: C8197B250D2400001000
Address 3C: Lane Change
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000008871961
Coding: 011C53724E08332C03
VCID: 45C28DA4CC2BE8B3A0-8010
Reset counter: 35
Mileage: 179896 km
Date: 2009.04.30
Time: 02:35:59
Revision: 00002001 Serial number: 0118552362
Coding: 010602BA007A442100B0030000000000
Subsystem 1 - Part No SW: 8F0 959 719 HW: 8F0 959 719
Component: GTO BF H06 0040
Serial number: 00000000000000115125
Component: LIN BACKUP HO H03 1301
Reset counter: 35
Mileage: 179896 km
Date: 2009.04.30
Time: 02:35:59
Part No SW: 8F0 035 223 C HW: 8F0 035 223 C
Component: DSP Prem H08 0170
Revision: 00008001 Serial number: 34862000215902
VCID: 200C3C303349ED9BF3-8074
Reset counter: 35
Mileage: 179896 km
Date: 2009.04.30
Time: 02:36:03
Voltage: 13.80 V
Temperature: 30.0 C
Temperature: 35.0 C
Bin. Bits: 00000100
Bin. Bits: 00010000
Bin. Bits: 00000000
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000008769179
Coding: 011C53324E08332C03
Reset counter: 35
Mileage: 179896 km
Date: 2009.04.30
Time: 02:35:59
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0090
Revision: 00000003 Serial number: 10000000238185
VCID: 3424C06097B1613B07-8060
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357
Component: Dynamische LWR H01 0010
Coding: 0000002
VCID: 77BE376C06474A23E2-8022
Part No SW: 4F0 035 082 A HW: 4F0 035 082
Component: Radio U SIRIU H45 0021
Revision: AB001007 Serial number: 335GV097523615
Coding: 020000010000000101
VCID: 1D7205C4043BC073D8-8048
Reset counter: 35
Mileage: 179896 km
Date: 2009.04.30
Time: 02:36:00
Reset counter: 35
Mileage: 179896 km
Date: 2009.04.30
Time: 02:36:03
Bin. Bits: 00000000 00010000
Part No SW: 8T1 035 664 A HW: 8T1 035 664 A
Component: H-BN-NA H41 0042
Revision: -------- Serial number: 490E-097505827
Coding: 010200030206A1EF51000B0E000000010100
VCID: 3620FA6881CD732B39-8062
Subsystem 1 - Part No: 8R0 060 884 F
Component: NAR 2009/2010 5304
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356EO091104582
Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
Serial number: 00000000287445
Component: CD-Database 1293
Reset counter: 35
Mileage: 179896 km
Date: 2009.04.30
Time: 02:36:05
Bin. Bits: 00000000 00000000
Bin. Bits: 00000100 00000000
Part No SW: 8K0 959 795 E HW: 4F0 959 795 L
Component: TSG HL H10 0306
Revision: Serial number: 0000101120227
Coding: 010C13324008372C03
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8F0 907 441 HW: 4L0 907 441 B
Revision: --H03--- Serial number: 525PA8-J94B03J
Coding: 1000009
VCID: 679E672C56E7DAA372-8032
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000101120214
Reset counter: 35
Mileage: 179896 km
Date: 2009.04.30
Time: 02:36:00
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 35
Mileage: 179896 km
Date: 2009.04.30
Time: 02:36:00
End----------(Elapsed Time: 01:51, VBatt start/end: 13.7V/13.6V)-----------
------------------------------18 Faults Found------------------------------
