1.8T BJX VW POLO 9N Power Loss Timming Issue
tyroneturbos
C?ID=233767 (NRRT)
Wee fault here with a polo just before I do A belt/chain change was wondering is it worth checking out the sensor or is it a common problem for a stretched chain or poor chain tensioner to give these symptoms.
VCDS Version: Release 15.7.3 (x64) Running on Windows 10 x64
Data version: 20151216
Tuesday,09,February,2016,13:24:03:42761
Chassis Type: 9N (9N - VW Polo (2002 > 2010))
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: ****ZZ9NZ****2988   Mileage: 135620km-84270miles
   Part No: 06A 906 032 TL
   Component: 1.8l R4/5VT         0040
   Coding: 11500
   Shop #: WSC 02629
   VCID: 7BF27B4C694269E624-515C
   WVWZZZ9NZ6Y232988     VWZ7Z0F3507256
16705 - Engine Speed Sensor (G28)
            P0321 - 35-10 - Implausible Signal - Intermittent
16395 - Bank 1: Camshaft A (Intake)
            P0011 - 35-10 - Retard Setpoint not Reached (Over-Advanced) - Intermittent
Readiness: 0110 1101
Address 03: ABS Brakes        Labels: 6R0-907-37x-ESP80.lbl
   Part No SW: 6Q0 907 379 AR    HW: 6Q0 907 379 AR
   Component: ESP 8.0 front   H02 0002
   Coding: 0000269
   Shop #: WSC 00788 785 00200
   VCID: 0D16259417F657560A-515C
02214 - Tire Pressure Warning
Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
   Part No: 6Q0 820 045
   Component: Klimaanlage        X0840
   VCID: 6ADC4E0816D8E06ECF-515C
01596 - Motor for Outside/Recirculated Air Flap (V154)
            30-00 - Open or Short to Plus
Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 D
   Component: 00BK BN-SG.         1S34
   Coding: 25742
   Shop #: WSC 00788
   VCID: 3C70B8502CCCAEDE6D-517A
01598 - Drive Battery Voltage
   Part No: 1C0 909 605 K
   Component: 16 AIRBAG VW51 0N   0009
   Coding: 12598
   Shop #: WSC 00788
   VCID: 2C508810DCAC3E5EFD-515C
Address 17: Instruments        Labels: 6Q0-920-xxx-17.lbl
   Part No: 6Q0 920 923 F
   Coding: 01444
   VCID: 3664AA7812E0748E9B-517A
   Part No: 6N0 909 901
   Component: 0B7L GATEWAY CAN    1S34
   Coding: 00014
   Shop #: WSC 00788
   VCID: 70E85C6030041ABE81-517A
   Part No: 6Q0 423 156 AB
   Component: LenkhilfeTRW        V270
   Coding: 10120
   Shop #: WSC 00788
   VCID: 6FEA5F1C2D3A054698-515C
Address 45: Inter. Monitor        Labels: 6Q0-951-171.lbl
   Part No: 6Q0 951 171 C
   Component: Innenraumueberw.    0020
   VCID: 326C9668FE8868AEB7-517A
Address 46: Central Conv.        Labels: 6Q0-959-433.lbl
   Part No: 6Q0 959 433 E
   Component: 63 Komfortgerát     0002
   Coding: 00016
   Shop #: WSC 00788
   VCID: 3D76B55437D6A7D65A-4B38
   Part No SW: 6Q0 035 152 E    HW: 6Q0 035 152 E
   Component: Radio 9NK           0004
   Revision: 00001000    Serial number: VWZ4Z4H9240327
   Coding: 0040402
   Shop #: WSC 00012 210 71232
   VCID: 2C5088108CAC3E5EFD-515C
00871 - Bass Speaker Front Right (R23)
End-------------------------(Elapsed Time: 02:52)--------------------------
Gone But Not Forgotten
Sounds like bad G28........or contaminated with oil + frags.
Intermittent on chain stretch ............possible............more likely oil PSI/volume from sludge particle contaminates .
tyroneturbos
C?ID=233767 (NRRT)
Thanks on the lift tomorrow will remove sump and move upwards after that,
Few areas to check on the timming and tensioner for slack then will swap out G28 after that
Ross
Don't forget to Tyrone shoe laces...... before tripping and slipping on oil slick floor.
Be sure to check oil PSI regulation and if sump over filled.
tyroneturbos
C?ID=233767 (NRRT)
I see what you did there.......
ivagp
C?ID=95551
first check timing belt slack, if its loose? if its not loose check to make sure timing marks are correct, then check for cam correlation its in the 90something group
tyroneturbos
C?ID=233767 (NRRT)
All Good in Group 94
G28 Fitted Sump removed small bit of sludge in there fresh oil and filter
First run no return of codes car has great power fantastic little car to drive
Glad to hear you Tyrone shoelaces and didn't trip........:p
Was the G28 sensor internally contaminated with oil or cracked?
Did the oil make its way to the electrical connector like candle wick?
If you still have it check it out and report back.
This happens from improper oil level .........remediation/seal/piston rings....... causing crank case gases not being removed properly, caused by blow by.
For more information read posts on my rants about synthetic oils and increased levels of gases due to combustion seal imperfections fuel contamination of the oil.
tyroneturbos
C?ID=233767 (NRRT)
Cars gone and in back pocket Jack :)
One thing I did notice was a oil level on the high side, I tend to keep oil a smidgen below full on the dip stick myself, replaced with fully syn VW Spec oil
Ross
Thank you for that confirmation.....
Keep in mind, oil slight low cold, becomes higher through expansion hot......
When higher gets whipped by the crank like mixer......aerated and now becomes a penetrant with fine micro conductive material , that causes such havoc.
