p0171 audi b8 2.0t
Shafo
South Africa
C?ID=163752
hi guys
customer brought in his car complaining about a mil light
scanned car and got the p0171 code
replaced pcv as I felt some air blowing out the little hole
customer came back following day with light back on and same fault
I assume this is a vacuum leak somewhere but I cannot seem to find it..anybody have an idea?
odd thing is I feel some air blowing out the little hole on the new pcv aswell...I can confirm it didn't when I just fitted it..
VCDS Version: Release 15.7.3 (x64) Running on Windows 7 x64
Data version: 20151216
Tuesday,09,February,2016,08:34:33:48700
Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 55 56 62 72
VIN: WAUZZZ8K5CA054347   Mileage: 143470km-89148miles
56-Radio -- Status: Sporadic communication error 1000
Address 01: Engine (DET---CDHB)       Labels: 06H-907-115-CAB.clb
   Part No SW: 8K1 907 115 M    HW: 8K1 907 115
   Component: 1.8l R4/4V TF H18 0004
   Revision: A5H18---
   Coding: 0104000C18070120
   Shop #: WSC 06324 000 00000
   ASAM Dataset: EV_ECM18TFS8K1907115M A01004
   ROD: EV_ECM18TFS_AU48.rod
   VCID: 3879906783EDB7FE89-806C
2809 - Fuel Trim; Bank 1
          P0171 00 [236] - System Too Lean
                    Mileage: 143258 km
                    Date: 2016.02.04
                    Time: 16:29:44
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 BF    HW: 8K0 907 379 BF
   Component: ESP8 front    H04 0030
   Coding: 030500
   VCID: 7EF5467FE94949CE03-802A
   Part No SW: 8K0 907 064 CC    HW: 8K0 907 064 CC
   Component: BCM2 2.0      H05 0435
   Coding: 031100
   Shop #: WSC 06325 000 00000
   VCID: 73E3674BD20B14A67C-8026
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H60 0072
00955 - Key 1
                    Fault Frequency: 20
                    Reset counter: 213
                    Mileage: 141285 km
                    Date: 2015.12.29
                    Time: 08:38:24
   Part No SW: 8T2 820 043 AD    HW: 8T2 820 043 AD
   Component: KLIMA 1 ZONE  H08 0180
   Revision: B0000000    Serial number: 01230820111591
   Coding: 64040000
   VCID: 74E16457D705139E65-8020
   Part No SW: 8K0 907 063 N    HW: 8K0 907 063 N
   Component: BCM1 1.0      H30 0392
   Revision: 09030001    Serial number: 00000001024976
   Coding: 2600D0914034AF010001000000001D0D0F1D030802010101000000
   VCID: 3A7D8A6FB5E1A5EE7F-806E
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 260811  H06 0070
   Coding: 00FD11
   Component: RLS  H04 0003
   Coding: 025028
   Component: E1 - LDS  H03 0031
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 L    HW: 8K0 959 655 L
   Component: AirbagVW-AU10 H44 0610
   Serial number: 003JMD0FSP40
   Coding: 30533435363030303030554A3052384B3053
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 4685EE9FF919D10E0B-8012
   Serial number: 6334MSME641147635
   Serial number: 6344MSME632550094
   Serial number: 6352QSME175E206CO
   Serial number: 6362QSME315C20405
   Serial number: 63732SME3B5C52543
   Serial number: 63832SME604F1D7EH
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90372KHQ0019F
   Coding: 000016
   VCID: 3D778173A4CF92D65A-8068
   Component: E221 - MFL  H02 0010
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 900 M    HW: 8K0 920 900 M
   Component: KOMBIINSTR.   H20 0258
   Revision: 00300000    Serial number: EII20XT8C
   Coding: 2F04080002000008010000
   VCID: 3461A4579785539EA5-8060
   Part No SW: 8T0 907 468 AB    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0117
   Revision: GB800053    Serial number: 5300G11813837F
   Coding: 00C303
   VCID: 010F3D8398B736367E-8054
   Component: J367-BDM  H07 0170
            000 -  -  - Intermittent
                    Fault Frequency: 11
                    Reset counter: 220
                    Mileage: 141472 km
                    Date: 2016.01.02
                    Time: 09:34:07
                    Bin. Bits:    10000
                    Voltage: 12.10 V
                    Count: 12
01304 - Radio
                    Reset counter: 246
                    Mileage: 143376 km
                    Date: 2016.02.07
                    Time: 10:36:17
                    Bin. Bits:    10000
                    Voltage: 12.30 V
                    Count: 8
                    Bin. Bits:    10000
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
   Component: TSG FA        H08 1501
   Coding: 011C02204001410001
   VCID: 53A3C7CB324B74A69C-8006
   Revision: 00002001    Serial number: 0157322684
   Coding: 011A062200B900448130013280000000
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
Address 47: Sound System (J525)       Labels: 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 AH    HW: 8T0 035 223
   Component: DSP STD       H07 0230
   Revision: S2200000
   Coding: 0203010101
01304 - Radio
                    Reset counter: 246
                    Mileage: 143376 km
                    Date: 2016.02.07
                    Time: 10:43:42
                    Voltage: 12.50 V
                    Temperature: 46.0°C
                    Bin. Bits: 00000001
   Part No SW: 8T0 959 792 M    HW: 8T0 959 792 D
   Component: TSG BF        H08 1501
   VCID: 52ADC2CF0D517DAE97-8006
   Revision: 00000003    Serial number: 20000000087934
   Part No: 8K5 907 357 B
   Coding: 0000004
   VCID: 397F956370E7AEF676-806C
Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
   Part No SW: 8T2 035 186 P    HW: 8T2 035 186 P
   Component: Concert3      H06 0350
   Revision: 00000011    Serial number: AUZ5Z6K1638736
   Coding: 0502008001010D000159070000
   VCID: 4587E993CC1FDA1602-8010
   Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
   Component: Display
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8T0 959 795 N    HW: 8T0 959 795 B
   Component: TSG HL        H06 1501
   Coding: 010C02204001210001
   VCID: 56A53EDF21B9618E7B-8002
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
   Component: TSG HR        H06 1501
End-------------------------(Elapsed Time: 02:39)--------------------------
Gavra
Melbourne/Belgrade
C?ID=240855
First thing to check when you have P0171 is EVAP system and signals from O2 sensor before catalyst. Then we can help you more.
