Key Remote Programming Help Required
tyroneturbos
C?ID=233767 (NRRT)
Basically fighting a losing battle with a customers 2004 B6 Audi A4
I lost the keys to the car and reordered a new key from from Audi Dealer as instructed by local locksmith
When I received the key the locksmith was unable to marry the key to the car....
So sent the car to an authorised Audi dealer who said clocks are dead and needed new clocks at 900 quid, started to loss will to live at this point and sent car to a ecu specialist who took immo off but still couldn't marry the key (I also failed via VCDS)
But recently been told the CCM in the car is from 2006 B7 Audi and highly possible that the key I lost was a b7 Key replaced some time ago from a previous owner
So my question is will a B6 Key not marry with a B7 CCM and can I solve this simply by replacing either Key remote with a B7 or the CCM with a B6 to match the new key I purchased.
Hopefully some guru can shed some light on this for me I`m a newbie at this game and really need this motor sorted.
Ross N.Ireland
Please post an Auto-Scan so people can see what the car is actually made of.
tyroneturbos
C?ID=233767 (NRRT)
Ok will do tomorrow very new here ill get the swing of it :)
tyroneturbos
C?ID=233767 (NRRT)
VCDS Version: Release 15.7.3 (x64) Running on Windows 10 x64
Data version: 20151216
Tuesday,09,February,2016,13:54:11:42761
          67 69 75 76 77
VIN: WAUZZZ8E03A212961   Mileage: 406140km-252363miles
Address 01: Engine        Labels: 038-906-019-AVF.lbl
   Part No: 038 906 019 LJ
   Component: 1,9l R4 EDC G000SG  5934
   Coding: 00002
   Shop #: WSC 63351
   VCID: 6ADC4E0816D8E06ECF-4B38
Readiness: 0 0 1 1 1
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517
   Component: ABS/ESP front       4529
   Coding: 04155
   VCID: 65C63D34FFC6CF16E2-515C
            35-00 -  -
   Part No: 8E0 820 043 AA
   Component:   A4 Klimaautomat   1324
   Coding: 00000
   Shop #: WSC 63351
   VCID: 60C82C20E0E4AA3E11-517A
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 F
   Component: int. Lastmodul  RDW 0617
   Coding: 00011
   VCID: 3566AD740FE67F9692-4B38
            49-00 - No Communications
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 J
   Component: Airbag 8.4EP        1002
   Coding: 0010602
   Shop #: WSC 63351 000 00000
   VCID: 3E74B2586AD0BCCE43-515C
   Part No: 8E0 953 549 L
   Component: Lenksáulenmodul     0308
   Coding: 00041
   Shop #: WSC 00214
   VCID: 3C70B8502CCCAEDE6D-4B38
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No: 8E0 920 950 J
   Component: KOMBI+WEGFAHRS. RB4 D35
   Coding: 00400
   VCID: 30689C60F0845ABEC1-515C
   WAUZZZ8E03A212961     AUZ6Z0B0215522
Address 37: Navigation        Labels: None
   Component: BNS 4.2 H05    BNO 0050
   VCID: 55A60DF4AFA65F9672-4B1E
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8E0 951 177
   Component: Innenraumueberw.   0704
   Coding: 00001
   VCID: 6BD24B0C1922F966B4-517A
Address 46: Central Conv.        Labels: 8E0-959-433-MIN.lbl
   Part No: 8E0 959 433 AJ
   Component: Komfortgerát T9F    0619
   Coding: 00128
   VCID: 79FE6144637E5BF636-4B38
   Subsystem 1 - Part No: 8E2959802B
   Component: Tõrsteuer.FS BRM 0103
   Subsystem 2 - Part No: 8E2959801B
   Component: Tõrsteuer.BF BRM 0103
End-------------------------(Elapsed Time: 05:50)--------------------------
Gone But Not Forgotten
Get a fresh key with or stand alone proper transponder for the RB4 crypto cluster.
Send me the cluster and ecu + all keys .........I bet I can help.
Have your papers in order.
Wait...
Have we misunderstood the question?
Does this car start and run, and the real problem is just matching the REMOTE fob?
tyroneturbos
C?ID=233767 (NRRT)
Wait...
Yes UWE the car starts and runs but will flash the hazzard lights constantly and I cant seem to get the FOB adapted for the RCL, I`ve a suspicion the ECU still has IMMO OFF
If for an example i bump started the car down hill with key in position 2 car will start but wont flash the hazzards
Ross
tyroneturbos
C?ID=233767 (NRRT)
IGN ON Engine OFF
Instruments
Measuring Blocks
Engine Start Permitted ZERO
Engine ECU Responds ZERO
Key Status ONE
No. of adapted keys THREE ? <this is confusing because I cleared all adapted keys earlier in Channel 000
Variable Code Auz ZERO
Key Status Transponder ZERO
Fixed Code Authorised ZERO
IMMO Status FOUR
Remotes are separate from the Immobilizer in RB4.
I do see a no COM for immobilizer in 0x09.....
This cluster is just that.......a cluster if someone tampers with cheap china tools.
Yeah the engine won't answer the cluster if defeated in 0x01-10-091? Status 01
tyroneturbos
C?ID=233767 (NRRT)
Would a 2004 ECU KEY Cluster CCM solve this problem and get the car sorted if lifted from a running vehicle will any coding need to be done other than FOB and convenience preferences ?
I paid allot of money so far to get the car back in this state now from a "ECU Specialist" I repair turbos and light diagnostics and purchased vcds to cover vag range.
Only fault thats simple is the G58 Squib thats also been damaged since the car being returned
tyroneturbos
C?ID=233767 (NRRT)
Tuesday,09,February,2016,18:50:34:42761
          67 69 75 76 77
   Coding: 00002
   Shop #: WSC 63351
   Coding: 04155
   VCID: 65C63D34FFC6CF16E2-513E
            35-00 -  -
   Coding: 00000
   Shop #: WSC 63351
   Coding: 00001
            57-00 - Electric Circuit Failure
   Coding: 0010602
   Coding: 00041
   Shop #: WSC 00214
   Coding: 00400
01304 - Radio
   VCID: 55A60DF4AFA65F9672-4B04
   Coding: 00001
   VCID: 6BD24B0C1922F966B4-515C
   Component: Komfortgerát T9F    0617
   Coding: 16232
   Shop #: WSC 00112
01581 - Incorrect Component Detected
            35-00 -  -
01561 - Rear left door
            59-10 - Can't Unlock - Intermittent
            61-10 - Won't De-Safe - Intermittent
01562 - Rear right door
01403 - Glass-Break Sensors; Rear
            36-10 - Open Circuit - Intermittent
End-------------------------(Elapsed Time: 05:48)--------------------------
Probably, but then the electronics in the car would forever have the wrong VIN in them. Not sure of that's a problem for your MOT inspections; it definitely is for some of our emissions inspections here.
Incidentally, based on the VIN that's visible in the scan, this car is a 2003.
WAUZZZ8E03A212961
tyroneturbos
C?ID=233767 (NRRT)
Yes Jack Status is 01 in there listed as Immo Deactivated
tyroneturbos
C?ID=233767 (NRRT)
WAUZZZ8E03A212961
It seems the ECU has been swapped out now as well, as you pointed out the VIN listed on the scan does not match the chassis VIN but thats not a problem for MOT inspection over here
Ross
tyroneturbos
C?ID=233767 (NRRT)
Any other input before I go tomorrow morning for ECU key/clock set from same car think its the only option now to be fair
Since the remotes are handled by the Central Convenience system, I don't have high confidence that an ECU and Cluster will fix this.
tyroneturbos
C?ID=233767 (NRRT)
I am also getting a new key and ign barrel, but previous garage has IMMOB off on this ECU
What component causes the hazzard lights to flash when key is cycled, Is it because the engine start is not permitted and will start due to IMMOB off.
Quite possible Audi has ballsed up the new key I ordered
Ill post an update next week
Ross
tyroneturbos
C?ID=233767 (NRRT)
Hi Audi is back :(
Got the Immo sorted since last time just swithced over ecu/clocks and changed blade in key car starts and runs great only problem I have is the key remote programming
VCDS Version: Release 15.7.4 (x64) Running on Windows 10 x64
Data version: 20160216
Thursday,25,February,2016,17:02:24:42761
          67 69 75 76 77
VIN: WAUZZZ8E64A198663   Mileage: 266290km-165464miles
   Coding: 00002
   Shop #: WSC 63351
   VCID: 6ADC4E0816D8E06EC0-4B38
   WAUZZZ8E64A198663     AUZ6Z0C0447742
   Coding: 04155
   VCID: 65C63D34FFC6CF16ED-513E
   Coding: 00000
   Shop #: WSC 63351
   VCID: 60C82C20E0E4AA3E1E-517A
01794 - Control Module - Incorrect Chassis (VIN) Number
            35-00 -  -
   Coding: 00001
   VCID: 3566AD740FE67F969D-4B50
   Coding: 0010602
   VCID: 3E74B2586AD0BCCE4C-517A
   Coding: 00041
   Shop #: WSC 00214
   VCID: 3C70B8502CCCAEDE62-4B38
            35-00 -  -
   Part No: 8E0 920 950 M
   Component: KOMBI+WEGFAHRS. RB4 D42
   Coding: 00401
   Shop #: WSC 00751
   VCID: 3362936C019261A6B3-517A
01176 - Key
            07-00 - Signal too Low
01304 - Radio
   VCID: 55A60DF4AFA65F967D-4B1E
   Coding: 00001
   VCID: 6BD24B0C1922F966BB-517A
   Coding: 00128
   Shop #: WSC 00001
   VCID: 79FE6144637E5BF639-4B38
            61-00 - Won't De-Safe
End-------------------------(Elapsed Time: 05:39)--------------------------
