Find compatible ABS module for 2010 Jetta. Original is 1K0907379AN, looking for other compatible numbes
liquidzorch
Mexico
As the title states, can anyone help me in letting me know what abs modules are compatible with a 2010 jetta 2.5l? The original one it has is: 1K0907379AN, I can't seem to find that one for sale anywhere here in Mexico where I live. I have found newer modles, like the 1K0907379BJ, but I don't know if it would be compatible by adding zeros to the coding, as it has more bits. I have read a lot, but can't seem to find the trick to know what is compatible with what. I seem to understand that as long as it's newer, it should work. Any Advice?
Once I am sure I can get the module, I will buy the vcds hex v2 to program the module with the coding. anything else I would need?
P.S. I am not sure if I am going to be able to recover the original coding, since the problem seems to be the abs module not communicating with the ecm. I can't remember the exact trouble code, as it was scanned a year ago, but something like data from abs corrupt or inadequate.
Any help would be great! Thanks in advance!
Westbury, UK
Without knowing how your Jetta is equipped it's impossible to give an accurate answer, so please post an Auto-Scan made with the English version of VCDS
liquidzorch
Mexico
Thanks for the reply. Sorry I don't have an autoscan as I don't have vcds yet. I normally don't work on VW cars. The car is a friend's of mine, and I want to make sure I can do everything before buying the needed equipment.
Dr Sheldon
Windsor UK
C?ID=334979
VCDS cannot help you with which part to buy. You need something like PL24 or Information from a dealer. Visitors on this forum could help you but may not if you do not have a VCDS product.
VCDS can help you to code the replacement unit when you get one.
  • Agree
Westbury, UK
WIthout more information we can't help as not all 2010 Jetta are equipped the same.
Suggest you ask a VW dealer what a compatible ABS module would be for that VIN.
  • Agree
