Hi all.
Im am trying to retrofit a RVC to a 2023 polo AW. ( This car has the new style dash but doesnt seem to have SFD of any kind)
I have done the standard coding for these cars as bellow:
Coding:
1. Register the module in the 19-gateway (6C or "Camera System Rear View") -> coded
2. Module 76 (or module 10, depends on the car) Parking Assistance - Long code helper - (active rear camera -> installed)
or byte 02, bit 4 -> set to "1" (depends on the car)
3. Module 6C code
4. Finally you have to enter the Module 5F
Adaptation
Car_Funktion_List_BAP_Gen2_VPS_0x0B Switch to activated
Car_Funktion_List_BAP_Gen2_VPS_0x0B_msg_bus dial terminal 15
This isnt working on this car, the 5f unit makes no attempt to switch to the RVC input channel.
we have full comms with the 6c module and its showing no errors, any advice would be great.
Coding:
3. Module 6C code
Adaptation
Monday,15,December,2025,13:10:20:56476
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4671.4
Dealer/Shop Name: Coding & Corrections LTD
Workshop Code: 000 22038 000000
VIN: WVWZZZAWZPU107237 License Plate: POLO-RVC
Mileage: 25907km-16097mi Repair Order:
Chassis Type: AW-VW27 (2Q0)
Scan: 01 03 08 09 13 15 17 19 44 5F 6C 75 A5
VIN: WVWZZZAWZPU107237 Mileage: 25907km-16097miles
Address 01: Engine (J623-DSGD) Labels: None
Part No SW: 05C 906 034 N HW: 05C 907 445 C
Component: R3 1.0l MPI H01 2694
Revision: GVMuDSer CVN: 3EEEE567
Coding: 0111005402240D0800000000000000000000000000000000
Shop #: WSC 31414 790 00200
ASAM Dataset: EV_ECM10MPI04205C906034N 005006
ROD: EV_ECM10MPI04205C906034N.rod
VCID: 2C010FCCF686FEAA02B-8078
VINID: 9E69EAAAA467AA09410070831CB82B8E82
Radiator shutter:
Readiness: 1110 0001
Address 03: ABS Brakes (J104) Labels:. 2Q0-614-517.clb
Part No SW: 2Q0 614 517 AP HW: 2Q0 614 517 N
Component: ESC_base_vFGS H23 0262
Serial number: 36905095230617
Coding: 09034A64154190B452FEA81924E142A649124506114A245844541255452442659248A2608852241A222A48AAA251D6433F8A6BC2FC242424242424
ASAM Dataset: EV_Brake1BOSCHESPMQBA0 005001
ROD: EV_Brake1BOSCHESPMQBA0_005_VW27.rod
VCID: 7CA1FF8C4666AE2AD2B-8028
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 2G2 820 045 P HW: 2G2 820 045 P
Component: SG_AC_Manuell H70 0601
Coding: 012100000800010011000400020000000010000000000000000000000000
ASAM Dataset: EV_ACManuePrehMQBA0 001013
ROD: EV_ACManuePrehMQBA0.rod
VCID: 2E0505C4C09A8CBA2CF-807A
Address 09: Cent. Elect. (J519) Labels: 2QX-937-BCM-V1.clb
Part No SW: 2Q0 937 089 E HW: 2Q0 937 089 C
Component: BCM A0 Std H12 0963
Serial number: 02102317001269 Dataset Number: V03935379HB 0001
ASAM Dataset: EV_BCMA0 208001
ROD: EV_BCMA0_208_VW27.rod
VCID: 3C213F8C06E66E2A92B-8068
Subsystem 1 - Part No SW: 5Q0 955 559 C HW: 5Q0 955 559 C Labels: 5Q0-955-547.CLB
Component: RLS 054 0206
Serial number: S2Y23M07D27H04M28S29
Coding: 0018DD
Driver door control module:
Subsystem 2 - Part No SW: 2Q2 959 405 G HW: 2Q2 959 163 F
Component: FHSG_DRV 003 0004
Serial number: 00000000000070751154
Coding: 1F0007
Front passenger door control module:
Subsystem 3 - Part No SW: 2Q2 959 406 G HW: 2Q2 959 164 F
Component: FHSG_PSG 003 0004
Serial number: 00000000000070884042
Coding: 058007
Subsystem 4 - Part No SW: 5Q0 951 172 A HW: 5Q0 951 172 B
Component: Sensor, DWA 005 0403
Serial number: 000000000ZL2313203H6
Serial number: 00000000000039509014
Subsystem 6 - Part No SW: 5Q0 959 408 D HW: 5Q0 959 164 C
Component: FOND_FHSG_DRV 007 0011
Serial number: 00000000000072196101
Coding: 1F0000
Subsystem 7 - Part No SW: 5Q0 959 407 D HW: 5Q0 959 163 C
Component: FOND_FHSG_PSG 007 0011
Serial number: 00000000000072334335
Coding: 070000
Part No SW: 2Q0 907 572 AA HW: 2Q0 907 572 D
Component: ACCCONTIMQB H09 0396
Dataset Number: V03935397VH 0001
Coding: 2804600108FF8748949C812500508700000000000000000004
ASAM Dataset: EV_ACCMRRCONTIVW376 003018
ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
VCID: 73B3D4B06B38E152831-8026
Address 15: Airbags (J234) Labels:| 2Q0-959-655.clb
Part No SW: 2Q0 959 655 BJ HW: 2Q0 959 655 BJ
Component: VW22Airbag 021 0412
Revision: -------- Dataset Number: V03935372YR 0001
Coding: 88CCCCC0800000035C5400CF008C40FC0065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001036
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 06559D6408AAE4FAB4F-8052
Subsystem 1 - Part No SW: ----------- HW: 442 062 006 23
Serial number: 3577Y51BF0E80492F05G
Subsystem 2 - Part No SW: ----------- HW: 442 061 306 23
Serial number: 3587Y53B31083F91E3EI
Subsystem 3 - Part No SW: ----------- HW: 442 0B1 104 23
Serial number: 3517735A70CB84E0F1C$
Subsystem 4 - Part No SW: ----------- HW: 442 0B0 806 23
Serial number: 3527781B90CCB623C41U
Subsystem 5 - Part No SW: ----------- HW: 442 131 805 23
Component: FrontSensor_D 290 118A
Serial number: 355AG63B8A150B97882%
Part No SW: 2GP 920 310 B HW: 2GP 920 310 B
Component: KOMBI 066 4848
Coding: 24A4000061802600018862031000000000600400
ASAM Dataset: EV_DashBoardJCIMQBAB 010007
ROD: EV_DashBoardJCIMQBAB_010_VW27.rod
VCID: 3A2D39940CD2501A807-806E
Address 19: CAN Gateway (J533) Labels:* Redir Fail!
Part No SW: 2Q0 909 901 F HW: 2Q0 937 089 C
Component: GW MQB A0 H12 0963
Serial number: 02102317001269 Dataset Number: V03935391FG 0001
Coding: 030100046F08640022000048080F00010001270000000000000000000000
GVL: 01403C0000000000408080008002480000000000000000000000000000000000
ASAM Dataset: EV_GatewA0 013028
ROD: EV_GatewA0_VW27.rod
VCID: 35372AA825CCBF626D5-8060
Generator:
Component: 5-00-14-00-04
Subsystem 2 - Part No SW: 3G0 959 442 AH HW: 3G0 959 442 AH Labels: 3C8-959-537.CLB
Component: E221__MFL-PR6 H50 0500
Serial number: PR6-0440071151230342
Coding: 280C00
Subsystem 3 - Part No SW: 2Q0 915 181 B HW: 2Q0 915 181 B
Component: J367-BDMBOSCH H03 2012
Serial number: 103B409F
Address 44: Steering Assist (J792) Labels:| 2Qx-909-144-V1.clb
Part No SW: 2Q2 909 144 AB HW: 2Q2 909 144 AB
Component: TRW_G4L_MQBA0 623 6050
Serial number: 03823322CB4P178 Dataset Number: V03935378KZ 0001
Coding: 010000000100000001010201010001000000010101
ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
ROD: EV_SteerAssisTRWG4LMQBA0.rod
Address 5F: Information Electr. (J794) Labels:| 3G5-035-MIB-HGH3.clb
Part No SW: 3G5 035 820 M HW: 3G5 035 820 M
Component: MU-O-ND-EU H25 0330
Serial number: VWZAZ2B0873867 Dataset Number: V03935379YU 0001
Coding: 22700008000000000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 001001
ROD: EV_MUOIMQB_001_VW27.rod
Subsystem 1 - Part No SW: 5NN 919 605 B HW: 5NN 919 605 B
Component: ABT_Std-2_Nav 382 8310
Serial number: VWZ6ZHB1803244
Subsystem 2 - Part No: V03 959 817 SN
Component: EUR 2023 8073
7178 - Function Restricted due to Interrupted Communications
U1110 00 [00001001] - -
[Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
Mileage: 25907 km
Date: 2025.12.15
Time: 14:08:23
BAP: 02
Voltage terminal 30: 12.6 V
Part No SW: 5Q0 980 556 B HW: 4M0 980 556 A
Component: RVC Compact H19 0231
Dataset Number: V03935246NT 0001
Coding: 0184010140002017000040
Shop #: WSC 22038 000 00000
VCID: 392F269809D45B0289D-806C
10489856 - No Basic Setting
B2010 00 [00001001] - -
Reset counter: 242
Mileage: 25907 km
Date: 2025.12.15
Time: 14:08:19
passive
Address 75: Telematics (J949) Labels:* 5WA-035-28X-V1.clb
Part No SW: 5WA 035 284 G HW: 5WA 035 284 B
Component: OCUGen3High H22 0143
Serial number: 0000000304VIYKF Dataset Number: V03935446GK 0001
Coding: 022700001968A8009005460161002607
ASAM Dataset: EV_OCUGen3High 003007
ROD: EV_OCUGen3High_003_VW27.rod
VCID: 4ACD69545C32C09A107-801E
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 2Q0-980-653.clb
Part No SW: 2Q0 980 653 D HW: 2Q0 980 653
Component: MQB MFK 3.0 H16 1401
Serial number: EA1567403231700 Dataset Number: V03935410VR 0001
Coding: 0000091011484020409E00000020000000018000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 007042
VCID: 36352DA438CAB47A64F-8062
End----------(Elapsed Time: 01:21, VBatt start/end: 12.6V/12.6V)-----------
------------------------------2 Faults Found-------------------------------
