My 2013 Audi A4 Allroad 2.0TDI(CGLC) is gutless
Artoalexander
Sunne, Sweden
C?ID=578842
As the title says my Audi barely has any power in the engine.
It all started half a year ago with P0299 code popping up as soon as I depressed the throttle a little too much and it progressively got worse until just thinking about passing someone threw the code, bought a Max gear brand turbo pressure regulator and it did not change much except it was back to how it was before all this for two seconds and then threw the code again(like it broke instantly).
A couple of weeks ago the car suddenly stalled after having refueled(only got 4.5km from the fuel station) and it became a crank no start problem, towed the car back home and checked fuel pump in tank and it was flowing but the filter was hard to blow through so I replaced that and primed the hpfp before attempting to start, now the car runs but is gutless as heck so can't drive it, and I just got myself a HEX-V2 to diagnose the car, clearing DTCs removes the P0299 but the car feels like it has gone naturally aspirated instead of turbocharged.
Tried to burn the diesel to see if it was contaminated with gasoline but it did not burn and does not smell like gasoline.
Sunday,14,December,2025,22:33:31:44491
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4671.4
VIN: WAUZZZ8K3DA217417   License Plate: MPN879
Mileage: 230930km-143493mi   Repair Order:
                Address 01: Engine  (03L 906 018 KD)
22:33:02
  IDE00086   Accelerator pedal position 14.9 %
  IDE00188   Fuel high-pressure: actual value 334400 hPa
  IDE00190   Charge air pressure: specified value 1050 hPa
  IDE00191   Charge air pressure: actual value 996 hPa
  IDE00350   Air mass: specified value 386.4 mg/stroke
  IDE00434   Particle filter: soot mass calculated 25.14 g
  IDE00435   Particle filter: soot mass measured 26.43 g
  IDE00475   Fuel Pressure Regulator Valve 16.89 %
  IDE01386   Soot index 7 m
  IDE06059   Particulate filter: oil ash mass 67.3 g
Sunday,14,December,2025,23:05:54:44491
Chassis Type: 8K-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 52 53 56 62 72 77
VIN: WAUZZZ8K3DA217417   Mileage: 230930km-143493miles
Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 KD    HW: 03L 906 018 JL
   Component: R4 2.0l TDI   H25 9978
   Revision: 45H25---    CVN: 2D824C9C
   Coding: 32194012242601080000
   Shop #: WSC 15486 002 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018KD 003005
   ROD: EV_ECM20TDI01103L906018JG.rod
   VCID: 76B5F14EE84DE10AA4F-8022
   VINID: 9D196AAAA21B0D44420471011C45AACFFD
5171 - Boost Pressure Regulation
          P0299 00 [10100111] - Control Range Not Reached
                    Mileage: 230938 km
                    Date: 2025.12.10
                    Time: 03:34:17
                    Engine speed: 1859.50 /min
                    Normed load value: 99.6 %
                    Coolant temperature: 86 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 14.620 V
                    Charge air pressure: specified value: 2510 hPa
                    Charge air pressure: actual value: 1006 hPa
                    Air mass: actual value (mg/stroke): 307.5 mg/stroke
                    EGR Solen.val.: actual value: 99.57 %
                    Throttle valve adapter: actual value: 99.98 %
                    Charge air pressure actuator: acknowledgment: 98.60 %
                    Mean injection quantity: 33.44 mg/stroke
   Part No SW: 8K9 907 379 M    HW: 8K9 907 379 M
   Component: ESP8 quattro  H09 0100
   Coding: 06554C
   Shop #: WSC 06335 000 00000
   VCID: 4CC173A6C6C1CBDA22B-8018
   Part No SW: 8K0 907 064 GE    HW: 8K0 907 064 FE
   Component: BCM2 2.0      H12 0633
   Coding: 03A24000000000000000
   VCID: 79AFFA72D9D38E72C9D-802C
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0513000013555005
   Serial number: 2313000029776006
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-1Z.clb
   Part No SW: 8K1 820 043 AG    HW: 8K1 820 043 AG
   Component: KLIMA 1 ZONE  H02 0123
   Revision: A1000000    Serial number: 01280220131017
   Coding: 342002E000
   VCID: 6D87DE229D9B22D2555-8038
   Part No SW: 8K0 907 063 DF    HW: 8K0 907 063 DF
   Revision: 06016001    Serial number: 00000547388301
   Coding: 2600C0108034AFC00081400300001D0D0F1C070826090201000004000400030100000000000000
   VCID: 76B5F14EE8CDE10AA4F-8022
   Component: WWS 220213  H07 0080
   Serial number: SWF13020226573
   Coding: 00FD11
   Serial number: 21036427
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001902130739
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: BBC80596000000000001
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Serial number: 003KFD98L19D   Dataset Number: 8K0909602Q  0001
   Coding: 30514435363030303030554A304C384B3053
   Shop #: WSC 02487 002 1048576
   VCID: 48C94FB6D23927FA063-801C
   Serial number: 6334MSME76426973H
   Serial number: 6344MSME76217419B
   Serial number: 6352QSME50284F64L
   Serial number: 6362QSME4F2C1B50S
   Serial number: 63732SME50281E42Z
   Serial number: 63832SME5428355C1
   Part No SW: 8R0 953 568 P    HW: 8R0 953 568 P
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20130218000519
   Coding: 000007
   VCID: 4EC579AE30DDF9CA4CF-801A
   Part No SW: 8K0 920 931 J    HW: 8K0 920 931 J
   Component: KOMBIINSTR.   H35 0556
   Revision: 00400000    Serial number: UVP66KU2E
   Coding: 1384290202010008010000
   VCID: 35373642B54BAA126D5-8060
   Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H11 0055
   Revision: 1V070026    Serial number: 2641V132188182
   Coding: 80CF07FF00
   VCID: 48C94FB6D2B927FA063-801C
   Serial number: 3235819101
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Serial number: 13053000759011200410
   Component: TSG FA        H02 0508
   Revision:             Serial number: 0000052971793
   Coding: 011C02204000410001
   VCID: 4FFB64AA37D7F0C2479-801A
   Component: RCEPS         H37 0507
   Revision: 00001000    Serial number: 0004246624 Dataset Number: 8K0909852H  0023
   Coding: 100000000001
   Shop #: WSC 06334 000 00000
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 34310B46BEB1B31A5AB-8060
   Revision: 00002001    Serial number: 0301290358
   Coding: 013A062020B900408020023680000000
   Component: TSG BF        H02 0508
   Revision:             Serial number: 0000053143768
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 30000000019882
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 38293F76A2D9577A763-806C
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8R1 035 186 N    HW: 8R1 035 186 N
   Component: Concert3      H09 0470
   Revision: 00000002    Serial number: AUZ5Z6M1860956
   Coding: 05000482040281000159071000
   VCID: 40D95796FA891FBACE3-8014
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000052597332
   Coding: 010C02204000210001
   VCID: 46D5418ED8AD318AF4F-8012
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000052597137
   Part No SW: 8T0 862 335 F    HW: 8T0 862 335 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005626213
   Coding: 0010300
   VCID: 3D272E62817B7252A55-8068
End----------(Elapsed Time: 01:31, VBatt start/end: 14.5V/14.5V)-----------
-------------------------------1 Fault Found-------------------------------
Artoalexander
Sunne, Sweden
C?ID=578842
Took apart the intake tube between filter box and turbo, tried to spin turbo and it was possible to spin the turbo with slight resistance and absolutely no play at all in the bushings, and no play at all axially. There was a small pool of oil on the filter box side of the turbo(1-2mL)
Did my turbo hand in the towel? Might be a lot of soot deposits because the car asked for 1L of oil per ~1000km
Artoalexander
Sunne, Sweden
C?ID=578842
A long awaited update on my Audi.
I left it at a mechanic a few weeks ago and what he saw on his scan tool was that the cylinder no 1 injector had failed open because the calibration value indicated it and as a result the DPF has become completely clogged, I was told that the injector could have been slightly open since last summer until November last year when it became wide open and that extra diesel could have produced all that extra soot as well.
More updates shortly as after the injector was replaced the car ran normally but not for long, after the mechanic took out a sensor from before the DPF the car ran normally for once but with a lot of black smoke and some blue smoke(I guess accumulated soot and unburnt diesel during diagnostic runs)
The mechanic could not program the timing right on the new injector and there was a lot of AAAAAA in the code, What could that mean?
Up next on the replacement list is the DPF and my current mechanic refused the job as it was too large of a job for his shop, but he has asked another mechanic to take on the job and I'll get an answer tomorrow if that mechanic accepts the challenge.
I don't buy any of this story!
Get away from that mechanic, and either learn how to do your own diagnostics, or go to one that isn't just taking your money and throwing parts at it.
nugentp
C?ID=6386
^^^ what he said ^^^ 100%
Artoalexander
Sunne, Sweden
C?ID=578842
Update on the Audi
Got it back from the mechanic today(he was actually done with the car a month ago but had messed up a number from my phone number while writing it down, I called him today to ask how it's going) and he clarified that with all the different programming tools he had he could not program the new OEM injector as if it was locked, he said that all the lines had --------- instead of actual values.
They unhooked the DPF and saw that it was completely clogged so they drilled 3 holes with a 12mm drillbit trough the medium instead of replacing it, ran a forced regen and now the car runs normally but the glowplug light is flashing all the time.
I have yet to hook up the scan-tool and do a diagnostic on it and most likely put the OEM turbo pressure regulator back as the MaxxForce regulator might be a stupid third party option.
Luckily the inspection does not count particles from the exhaust yet but the flashing light might pose a problem to get it through.
If i had the knowledge on how to do the diagnosis and immediately seen what was wrong I would have tried to fix it myself but with so much going on at the time of failure I opted for a mechanic to do the job, I bought another car moved on with working myself to the bone and basically forgot about the Audi at the workshop until my mother asked how it was going, she has the 2014 model and is scared the same is going to happen to her car.
nugentp
C?ID=6386
Oh my lord ! You need to find a new mechanic. I suggest you take a trip to Chester zoo and smuggle one of the chimpanzees out of the monkey house. Stick it in front of ChatGPT for a couple of nights and it will be better than the last guy.
Valeo
Serbia
C?ID=613283
7 days ago, done injectors coding for Audi A6 with same engine as yours. Thing is you need to re-code all of them even if you replace only one, starting from number 1 injector to number 4. Glowplug flashing cuz you don't have injector coded in ECU. And then get DPF replaced (cheaper one from scrapyard or expensive new one, choice is yours)
Dr Sheldon
Windsor UK
C?ID=334979
Not for long !!!
Do you really believe that the ECU will not detect that the DPF has been ripped up ?
Dpf deletes are possible but the ECU software needs to be altered for it to work.
Artoalexander
Sunne, Sweden
C?ID=578842
Coded all injectors this evening and the glowplug light stopped blinking, saw a bunch of AAAAAAAA in VCDS so the mechanic might have mistaken the I on the new injector code for a 1(AAHM4I2) or he didn't know that coding all of them was required.
After a short drive(few minutes) the car started to regen by itself and it smelled like a charcoal grill with lots of smoke, the smoking stopped after ~15min.
The guy who drilled the DPF might have done something to the ECU, I'll ask tomorrow.
Also coded a new battery since I replaced it but had no knowledge how to code it until now.
nugentp
C?ID=6386
Well I hope his ECU hacking skills are better than his welding lol
Ziddywerks
Northern NJ USA
C?ID=208579
You left the car with a butcher. Not good.
Vdub
C?ID=57533
oh man... what have you been into... :popcorn:
Artoalexander
Sunne, Sweden
C?ID=578842
Called on Tuesday and asked about if the ECU had been tampered with and got told that the only thing they did after the drilling was re-calibrating the pressure transmitters to the new pressure difference, he also told me that they refuse to do DPF deletes in his workshop since inspection might implement particle measurement in the near future and then it becomes illegal to delete the DPF, I will replace the DPF in the near future but I will run it as it is until I have to(might be really soon if it doesn't pass inspection).
The Audi smoked like this on Tuesday.
After driving today, the car didn't smoke after a 80km trip but it still smells like unburnt diesel(there is some in the exhaust from when the injector failed).
Ziddywerks
Northern NJ USA
C?ID=208579
I still cant believe you paid a butcher to touch that vehicle. It would be common sense to come to the conclusion that drilling 3 holes in a DPF is not a good ideas otherwise it would of been done this way from the factory. They definitely wiped the injector data calibration values because they are butchers and don't know WTF they are doing. Thats that.
Artoalexander
Sunne, Sweden
C?ID=578842
I only paid for the "new"(reman) injector and the work to put it in, the drilling was on the house, the DPF had to be replaced anyway since it was completely clogged shut and no shops around me cleans DPFs unfortunately, do you know the exact procedure on how to easily replace the DPF at home in a garage with basic tools and a crane?
Ziddywerks
Northern NJ USA
C?ID=208579
Yes I have a factory repair manual and can do that type of work without issues. It's not hard just time consuming and you have to be careful not to break anything else.
