Problem seat leon 2006 2.0d 170hp fr
georgi931
Pirate
Walking the Plank
Bulgaria
Прозорците, огледалата и вратата на пътника не работят и не мога да продам проблема, моля, помогнете. Купих колата след 6-тия монтаж и всичко беше наред, но електрическата система се повреди 2 пъти и сега колата е луда, моля, помогнете.
I replaced the terminal block of the socket switch, the problem remained, all the fuses in the 2nd compartment are strong, the cables too, the letters are fine.
Removed.  Data from a clone/pirate copy of VCDS is not acceptable in Ross-Tech's forum.
  • Disagree
georgi931
Pirate
Walking the Plank
Bulgaria
The car went crazy. There is no moisture anywhere, but everything does not work correctly. Everything looks sturdy. The right door shows constantly open, I replaced the lock with a brand new one, the problem was fixed for a while and came again. Mirrors do not work correctly when closed, and when it is lit they do not work at all. Lights up on the dashboard light for a burnt out light bulb, and it is strong.
Everything happened after a few times, after I stood for 6, 7 days and was not driven, the battery had fallen and I had to supply electricity from another car. Then I replaced the battery with a new one, but the problem remained. I see that my can gateway module has been replaced and is numbered P..
  • Disagree
georgi931
Pirate
Walking the Plank
Bulgaria
Everything happened after a few times, after I stood for 6, 7 days and was not driven, the battery had fallen and I had to supply electricity from another car. Then I replaced the battery with a new one, but the problem remained. I see that my can gateway module has been replaced and is numbered P..I replaced the terminal block of the socket switch, the problem remained, all the fuses in the 2nd compartment are strong, the cables too, the letters are fine.The car went crazy. There is no moisture anywhere, but everything does not work correctly. Everything looks sturdy. The right door shows constantly open, I replaced the lock with a brand new one, the problem was fixed for a while and came again. Mirrors do not work correctly when closed, and when it is lit they do not work at all. Lights up on the dashboard light for a burnt out light bulb, and it is strong.
  • Disagree
