I bought the car from auction repaired all mechanical problems and left with the check sum error i check distance travelled and other paper work on car like service intervals to confirm odometer is where it should be. any help would be awesome!
Thursday,11,December,2025,11:21:55:24048
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4671.5
VIN: 3VWD17AJ9FM347344 License Plate:
Mileage: 209470km-130158mi Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 04 05 08 09 15 17 19 25 2B 2E 37 44 55 56 75 77
VIN: 3VWD17AJ9FM347344 Mileage: 209470km-130158miles
Address 01: Engine (J623-CPRA) Labels:. 06K-907-425-V2.clb
Part No SW: 06K 997 071 C HW: 06K 907 425 C
Component: R4 1.8l TFS H13 9351
Revision: --H13--- CVN: 65E137EC
Coding: 001A0012242400175000
Shop #: WSC 00066 000 00018
ASAM Dataset: EV_ECM18TFS02006K997071C 001004
ROD: EV_ECM18TFS02006K906071C.rod
VCID: 3530C2C795C4A9A26D5-8060
VINID: 0E69D404745A2567431070C41075F93AAB
19868 - No Communication with Instrument Cluster
U0155 00 [00100000] - -
[Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
Mileage: 209473 km
Date: 2025.12.11.
Time: 21:48:35
Engine speed: 0.00 /min
Coolant temperature: 88 °C
Intake air temperature: 33 °C
Voltage terminal 30: 12.402 V
Engine: operating status: ES
ECU_STATE: ENG_STOP
Engine oil temperature: 83.0 °C
Time since engine start: 0.0 s
T_ES: 0 min
Cruise control switch actuation-Main switch: Not operated
Cruise control switch actuation-Set: Not operated
Cruise control switch actuation-Resume: Not operated
Cruise control switch actuation-Accelerate: Not operated
Cruise control switch actuation-DELAY: Not operated
Cruise control switch actuation-Cancel: Not operated
Cruise control switch actuation-Main switch hardware: Not operated
Cruise control switch actuation-Limit button: Not operated
Cruise control switch actuation-Main switch CAN: Not operated
Cruise control switch actuation-Large increment: Not operated
STATE_ERR_ABC_PRED: 0
Readiness: 1010 0101
Address 02: Auto Trans (J217) Labels:* 09G-927-749-V1.clb
Part No SW: 09G 927 749 A HW: 09G 927 749 A
Component: AISIN AG6 G3 129 2856
CVN: 481EBFD0
Coding: 000348
Shop #: WSC 00066 790 00185
ASAM Dataset: EV_TCMAQ250031 001004
ROD: EV_TCMAQ250031_001.rod
VCID: 372CC8CF8FC85BB27F9-8062
22616 - No Communication with Instrument Cluster
U0155 00 [00101000] - -
Reset counter: 120
Mileage: 209473 km
Engine speed: 0.0 /min
Transmission input speed: 0 /min
Engine torque: 76 Nm
ATF temperature: 69 °C
Accelerator pedal position: 0.0 %
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
Lock Up Clutch: Open
Electrical Oil Pump target revolution: 65534 /min
Electrical Oil Pump actual revolution: 65279 /min
Engine Speed signal Current: 65279 /min
Electrical Oil Pump failure status with Electrical Oil Pump without HV 1: Motor normal stop
Electrical Oil Pump target current: 65278 mA
22617 - No Communication with Instrument Cluster
Reset counter: 120
Mileage: 209473 km
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
22618 - No Communication with Instrument Cluster
Reset counter: 120
Mileage: 209473 km
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V4.clb
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: A14B400C49260001850E02E8921D0041A1100012
Shop #: WSC 00066 000 00000
VCID: 04566F038E1EC02AAAB-8050
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0362440619 Dataset Number: 160116v____ 0002
Coding: 000F0F
ROD: EV_KESSYPQ35G_A02_VW32.rod
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 CG HW: 5C0 820 047 CG
Component: J301 Klimaanlage 0208
Revision: 2001001S Serial number: 00000002673615
VCID: 678C588F93680B322F9-8032
Reset counter: 160
Mileage: 209473 km
Date: 2025.12.11.
Time: 21:48:35
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 E HW: 7H0 937 090 A
Component: BCM PQ25 Max3 H78 0725
Revision: B8078001 Serial number: 78003113150676
Coding: 7B994B1808AB0B0000382081240884C552C6760E608550D0B0A050022844
VCID: 303EF3D36A268C8A3E3-8064
Subsystem 1 - Part No SW: 6R0 959 801 AN HW: 6R0 959 801 AN Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 5461
Serial number: 14102585150316123648
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AS HW: 6R0 959 802 AS Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 5461
Serial number: 14102584150325135526
Coding: 820000
Subsystem 3 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A
Component: E221__MFL-TAT H04 0019
Serial number: 0451508090100874AD1B
Coding: 280000
Subsystem 4 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
Component: J388__TSG_HL 006 5460
Serial number: 14102587150326175551
Coding: 800000
Subsystem 5 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
Component: J389__TSG_HR 006 5460
Serial number: 14202586150324134346
Coding: 800000
Part No SW: 5C0 959 655 AB HW: 5C0 959 655 AB
Component: AirbagVW10 500 0975
Serial number: 003LZD06V60T Dataset Number: 160003V____ 0312
Coding: 00004B32
ASAM Dataset: EV_AirbaVW10SMEVW360 001030
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 72BA39DBA42AFE9A887-8026
Component: BF-Gewichtss. H10 0021
Serial number: IBH0000J150002NM7H0D
Coding: 30314C
Serial number: 3572MSME2C6C5C4EZZZH
Serial number: 3582MSME276C5C4EZZZD
Serial number: 3516KSME2B586035ZZZT
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME74606035ZZZL
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME4F1F3035ZZZ/
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME52143035ZZZI
12674816 - Immobilizer Control Module
U0167 00 [00001000] - No Communications
[Lost Comminication with Immobilizer]
Reset counter: 160
Mileage: 209473 km
Date: 2025.12.11.
Time: 21:48:36
12670208 - No Communication with Instrument Cluster
U0155 00 [00001000] - -
Reset counter: 160
Mileage: 209473 km
Date: 2025.12.11.
Time: 21:48:35
Part No SW: 5C6 920 974 E HW: 5C6 920 974 E
Component: KOMBI H05 0807
Coding: 271A01
Shop #: WSC 00066 000 00319
VCID: 323AF9DB64AABE9A487-8066
10485825 - Internal Control Module Memory Check Sum Error
B2000 41 [10001001] - General Checksum Failure
[Steuergerät defekt (EEPROM-Bereich Gesamtwegstrecke)]
10485824 - Internal Control Module Memory Check Sum Error
[Steuergerät defekt (EEPROM-Bereich Tachokennlinie)]
Part No SW: 6N0 909 901 HW: 7H0 937 090 A
Component: GW-K-CAN TP20 H78 0725
Revision: B8078001
Coding: 102200
VCID: 70BE33D3AAA6CC8A7E3-8024
Component: IMMO H05 0807
Coding: 000007
VCID: 6A8A21BB8CFA365A307-803E
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 15000034245003
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X_VW32.rod
VCID: 303EF3D36AA68C8A3E3-8064
12670208 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
[Timeout Message mKombi_K1]
Reset counter: 160
Mileage: 209473 km
Date: 2025.12.11.
Time: 21:48:36
ELV State: 0C
Information Clamps: 77 60
CoCo State: B0 01
WFS State: 67 1A
Vehicle speed: 0.00 km/h
Voltage: 6B
Address 2E: Media Player 3
Part No SW: 1Q0 035 274 K HW: 1Q0 035 274 K
Component: RNS315-NAR H85 0501
Serial number: VWZAZ2R0753079
Coding: 040004610200060000008000
ROD: EV_RNS315NARV2UDS_VW32.rod
Component: NAR_V7N 0060
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 306 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 3928CEF7B55C4DC289D-806C
Reset counter: 160
Mileage: 209473 km
Date: 2025.12.11.
Time: 21:48:35
Voltage: 12.50 V
DD
Temperature: 16.0°C
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Revision: -------- Serial number: -------------- Dataset Number: V03935195PL 0001
Coding: 081200010B000200
Shop #: WSC 01383 790 50316
Subsystem 1 - Part No: 5N0 941 329 Labels: 3D0-941-329.CLB
Subsystem 2 - Part No: 5N0 941 329 Labels: 3D0-941-329.CLB
13705477 - Databus
[Timoout mKombi_3]
Reset counter: 160
Mileage: 209473 km
Date: 2025.12.11.
Time: 21:48:35
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 A HW: 561 035 285 A
Component: OCULowUSA 020 0156
Serial number: 000003554140536 Dataset Number: V03935214WB 0018
Coding: 02630102C24212107F1606000000
ASAM Dataset: EV_OCULow 002009
ROD: EV_OCULow_002_VW12.rod
VCID: 14765F43FEFE50AA3AB-8040
12608769 - Comfort System CAN Bus (SAE Medium Speed Bus)
U0011 00 [00001000] - Performance
[CAN TO K-CAN]
12670208 - Databus
[CAN TO instrument cluster]
Reset counter: 160
Mileage: 209473 km
Date: 2025.12.11.
Time: 21:48:36
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 E HW: 5N0 035 729 E
Component: TELEFON H07 0593
Revision: 1B001001 Serial number: 00007670239856 Dataset Number: 5N0035729E 0001
Coding: 0A100300A0010110
ROD: EV_UHVUMI.rod
[Kombiinstument: keine Kommunikation]
Reset counter: 160
Mileage: 209473 km
Date: 2025.12.11.
Time: 21:48:35
End----------(Elapsed Time: 01:58, VBatt start/end: 14.0V/14.0V)-----------
------------------------------15 Faults Found------------------------------
