Saturday,13,December,2025,17:02:21:32627
VCDS Version: 25.3.2.0 HEX-V2 CB: 0.4671.4
VIN: WAUZZZ8P6DA029728 License Plate: BD79113
Mileage: 91140km-56631mi Repair Order: 4321
Chassis Type: 8P-AU35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 20 25 42 44 46 47 52 55 56 61 62
69 72 77
VIN: WAUZZZ8P6DA029728 Mileage: 91140km-56631miles
04-Steering Angle -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Malfunction 1110
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 PP HW: 03L 906 023 KS
Component: R4 1.6l TDI H43 9978
Revision: --H43--- Serial number: AUX7Z0L6FNV098 CVN: 9F9C3C4E
Coding: 00114036032401080000
Shop #: WSC 06314 000 00000
ASAM Dataset: EV_ECM16TDI02103L906023PP 003009
ROD: EV_ECM16TDI021_AU35.rod
VCID: 03539944FB92EF22931-8056
VINID: 9D196AAAA2201944400891C2203273F77D
6078 - No Communications with Steering Angle Sender (G85)
U0126 00 [00100101] - -
Mileage: 91140 km
Date: 2025.12.12
Time: 00:01:18
Engine speed: 0.00 /min
Coolant temperature: 10 °C
Intake air temperature: 10 °C
Voltage terminal 30: 12.198 V
Driver intention torque-TQI_DRIV_SUB: 0.00 Nm
Control Module temperature-TECU: 18 °C
7196 - Function Restriction due to Faults in Other Modules
U1113 00 [01100101] - -
Mileage: 91140 km
Date: 2025.12.12
Time: 00:01:17
Engine speed: 0 /min
Accelerator position: normalized-Accelerator position: 0.00 %
Battery voltage: 12.2 V
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V2.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 1142201249240003881204E692210051380000
VCID: 7BA3E1A483E297E2DB1-802E
7 Faults Found:
01486 - System Function Test Activated
Reset counter: 213
Mileage: 91140 km
Date: 2025.12.12
Time: 00:01:14
Count: 2
Count: 20992
Count: 320
Count: 43776
Count: 512
Reset counter: 213
Mileage: 91140 km
Date: 2025.12.12
Time: 00:01:14
Count: 2
Count: 20992
Count: 166
Count: 43776
Count: 512
Fault Status: 01100101
Reset counter: 213
Mileage: 91140 km
Date: 2025.12.12
Time: 00:01:14
Count: 2
Count: 20992
Count: 212
Count: 43776
Count: 512
Reset counter: 213
Mileage: 91140 km
Date: 2025.12.12
Time: 00:01:14
Count: 2
Count: 20992
Count: 279
Count: 43776
Count: 512
Reset counter: 213
Mileage: 91140 km
Date: 2025.12.12
Time: 00:01:14
Count: 2
Count: 20992
Count: 295
Count: 43776
Count: 512
Reset counter: 213
Mileage: 91140 km
Date: 2025.12.12
Time: 00:01:14
Count: 2
Count: 20992
Count: 270
Count: 43776
Count: 512
Reset counter: 213
Mileage: 91140 km
Date: 2025.12.12
Time: 00:01:14
Count: 2
Count: 20992
Count: 8213
Count: 43776
Count: 512
Part No SW: 8P0 820 043 BN HW: 8P0 820 043 BN
Component: KlimavollautomatH09 0180
Revision: 000020 Serial number: 8P0820043BN
VCID: 79AFFBAC85DEA5F2C9D-802C
Fault Status: 01101000
Reset counter: 213
Mileage: 91140 km
Date: 2025.12.12
Time: 00:00:25
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 N HW: 8P0 907 063 N
Component: BCM PQ35 M 111 0715
Revision: AM111715
Coding: 46000A2FA0051AC0207040E82100095C427E2CAA216DD12AE4008FA40041
VCID: 3FDB55B4D77A4BC2B79-806A
Subsystem 1 - Part No SW: 8P1 955 119 F HW: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H11 0050
Coding: 00DD13
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 024C2D
Reset counter: 213
Mileage: 91140 km
Date: 2025.12.12
Time: 00:01:13
Voltage: 12.10 V
Term 50 On
Reset counter: 213
Mileage: 91140 km
Date: 2025.12.12
Time: 00:01:13
Voltage: 12.10 V
Term 50 On
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 M HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0140
Revision: 11001001 Serial number: 36861219601750
Coding: 010003
VCID: 48C94E6882B40C7A063-801C
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 S HW: 8P0 959 655 S
Component: Airbag AU1042 H10 0250
Revision: -------- Serial number: 003JU00835M4 Dataset Number: 8P0909602M 0004
Coding: 30314238303830303035554A304C38503053
ROD: EV_Airba10AURB4_AU35.rod
VCID: 52FD6C007468B6AA687-8006
Serial number: 3572DRB40000ECCC8A8J
Serial number: 3582DRB40000ECCCE0BJ
Serial number: 35128RB400006CA7E27X
Serial number: 35228RB400006CAF30AW
Serial number: 35547RB400006C43160C
Serial number: 35647RB400006C43135F
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H38 0070
Coding: 0004042
VCID: 46D5405084A01A0AF4F-8012
Component: E0221 H02 0100
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 932 S HW: 8P0 920 932 S
Component: KOMBIINSTR. VDO H03 0380
Revision: D0H03005 Serial number: 2246L005011160
Coding: 0260128
Shop #: WSC 00999 444 64523
VCID: 44D15A58B29C281AEAB-8010
Part No SW: 7N0 907 530 S HW: 7N0 907 530 J
Component: J533 Gateway H43 1632
Revision: H43 Serial number: 130712F1001922
Coding: 354102
VCID: 40D95648AA84343ACE3-8014
Reset counter: 213
Mileage: 91140 km
Date: 2025.12.12
Time: 00:01:14
Reset counter: 213
Mileage: 91140 km
Date: 2025.12.12
Time: 00:01:14
Part No SW: 8P0 857 511 C HW: 8P0 857 511 C
Component: FLA H04 0004
Revision: AA001002
Coding: 02019464747464545425363E
VCID: 36353090F8408A8A64F-8062
Revision: D0H03005 Serial number: AUX7Z0L6FNV098
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 Q HW: 8P0 959 801 Q
Component: Tuer-SG H04 0101
Coding: 0131324
VCID: 49CF4B6C95BEF57219D-801C
Address 44: Steering Assist
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 E HW: 8P4 035 382 E
Component: AB2 SUBWOOFERBOXH07 0180
Revision: 00006 Serial number: 92158230872032
VCID: 36353090F4408A8A64F-8062
Part No SW: 8P0 959 802 Q HW: 8P0 959 802 Q
Coding: 0131324
VCID: 4ACD746090B8FE6A107-801E
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Serial number: 120723-0002-039
Coding: 1163951010022500
ROD: EV_HeadlRegulBasic_AU35.rod
VCID: 42DD5C40A408262AD87-8016
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 AB HW: 8P0 035 186 AB
Component: R Concert2+ H06 0293
Revision: 00H06000 Serial number: AUZ1Z3M3177282
Coding: 0710011
VCID: 72BDCC80D8A8D6AA887-8026
Part No SW: 7N0 907 534 HW: 7N0 907 530 J
Component: Batt.regelung H43 1632
Coding: F30F185A
VCID: 71BFC38CD1AEEDB271D-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900858380
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0131288
Shop #: WSC 06314 000 1012544
VCID: 42DD5C40A888262AD87-8016
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00008030231713
Coding: 010D000100000000
Shop #: WSC 25364 000 00000
VCID: 303906881A24A4BA3E3-8064
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0131288
VCID: 43D35944B7922F22D31-8016
Part No SW: 8P1 862 335 A HW: 8P1 862 335
Component: FSE_256x BT H44 0660
Revision: 00000000 Serial number: 00000005564571
Coding: 0001292
VCID: 3537379CE94681926D5-8060
End----------(Elapsed Time: 01:34, VBatt start/end: 12.3V/12.0V)-----------
------------------------------14 Faults Found--------------------
