Coding shows all zeros needs new long code recode
nase88
Pearce, AZ, USA
C?ID=439693
Maybe this can be recoded if not then replaced it’s the d/s seat memory module on a 2013 Passat with inop power seat . Vin 1vwcn7a3xdc148402
Don’t have any history on this vehicle.
Ziddywerks
Northern NJ USA
C?ID=208579
I can provide the correct coding for a small fee.
nase88
Pearce, AZ, USA
C?ID=439693
Please post a complete Auto-Scan for better context.
VCDS-Mobile Auto-Scan
Finished
VCDS Mobile: 0.4671
Data Version: 30000060
VIN: 1VWCN7A3XDC148402
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F  52 56 62 72 77
Address 01: Engine  (J623-CKRA) Labels: 03L-906-022-CFC.clb
                Part No SW: 03L 997 009 J      HW: 03L 907 309 S
Component: R4 2.0l TDI   H24 9982
Revision: 71H24---
Coding: 001D0012042400008000
Shop #: WSC 24171 444 00000 ASAM Dataset: EV_ECM20TDI01103L997009J 004005
ROD: N/A
VCID: 3B3994EF3062280B8343B3-806E
No ASAM data for: "EV_ECM20TDI01103L997009J"
No fault codes found.
Address 02: Auto Trans Labels: 02E-927-770.lbl Part No SW: 02E 300 058 M  HW: 02E927770AL
Component: GSG DSG AG6     512  9436
                 Revision: 05651213     Serial Number: 00001302062080
Shop #: WSC 09003 957 00200
VCID: 240B4F93ADDCEFF3D279B0-8071
Address 03: ABS Brakes  (J104) Labels: 1K0-907-379-60EC1F.clb
                Part No SW: 1K0 907 379 BL     HW: 1K0 907 379 BL
Revision: 00H31001
Coding: C54BC0F549260002A30F03E4921B0042A71000
VCID: 7DBD5AF76EF6FE3BFDF75D-8028
02214 - Tire Pressure Warning
Address 05: Acc/Start Auth.  (J518)    Labels: 5K0-959-434.clb
                Part No SW: 5K0 959 434 B      HW: 5K0 959 434
Revision: 00086000
Coding: 130C0C
ROD: N/A
VCID: 342BBFD31D3CE773421900-8061
No ASAM data for: "EV_KESSYPQ35G" No fault codes found.
Address 08: Auto HVAC  (J255)     Labels: 5K0-907-044.clb Part No SW: 561 907 044 AB HW: 561 907 044 AB
Component: Climatronic   H03 0505
Revision: 00001K01
Coding: 0010019012
Shop #: WSC 09003 957 00200 ASAM Dataset: EV_ACClimaBHBVW411 A01001
ROD: N/A
VCID: 57F1285FAC0AEC6B877BFF-8002
No ASAM data for: "EV_ACClimaBHBVW411"
Address 09: Cent. Elect.  (J519)       Labels: 1K0-937-08x-09.clb
                Part No SW: 5K0 937 087 AA     HW: 5K0 937 087 AA
Component: BCM PQ35 H+   121 0168
Revision: BL121001
Coding: 6F200E1B882B2AD408880201360085480071008645A005F064806000BC70
Shop #: WSC 02212 001 1048576
VCID: 74AB7FD35DBCBF738299C0-8021
                  Subsystem 1 - Part No SW: 1K0-955-559-AH      Labels: 1K0-955-559-AG.clb
Component: RLS 130313 0554  0403 Coding: 22300A
03188 - Bulb for Side Marker Light; Front Left
03189 - Bulb for Side Marker Light; Front Right
Address 15: Airbags  (J234) Labels: 5K0-959-655.clb Part No SW: 5C0 959 655 AE HW: 5C0 959 655 AE
Coding: 00005033
Shop #: WSC 09003 957 00200 ASAM Dataset: EV_AirbaVW10SMEVW360 001026
ROD: N/A
VCID: 75AD42D756C6BE7BB58735-8020
No ASAM data for: "EV_AirbaVW10SMEVW360"
Subsystem 1 - Part No SW: 5C6-959-339-B
Component: BF-Gewichtss.H10 0046
Serial Number: 6940000Y130000U82S0$ Coding: 303047
Subsystem 2 - Part No SW: 5K0-959-354
Component: S.Sens.Fahr.VH02 ----
Serial Number: 3572MSME6432037BZZZT
Subsystem 3 - Part No SW: 5K0-959-354
Component: S.Sens.Beif.VH02 ----
Serial Number: 3582MSME3B33017BZZZX
Subsystem 4 - Part No SW: 5K0-959-351-A
Component: S.Sens.Fahr.HH02 ----
Serial Number: 3516KSME35615723ZZZL
Subsystem 5 - Part No SW: 5K0-959-351-A
Component: S.Sens.Beif.HH02 ----
Serial Number: 3526KSME113C2024ZZZF
Subsystem 6 - Part No SW: 5K0-959-659-A
Serial Number: 3556LSME520A6921ZZZT
Subsystem 7 - Part No SW: 5K0-959-659-A
Serial Number: 3566LSME1B1E6B21ZZZ%
9442836 - ROD - Unknown faultcode
----------------------------------------------------------------Address 16: Steering wheel  (J527)     Labels: 1K-16.lbl
                Part No SW: 1K5 953 521 AR     HW: 5K0 953 569 E
Revision: FF010041
Coding: 000A140000
Shop #: WSC 09003 957 00200 ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: N/A
VCID: 7DBD5AF76EF6E63BFDF75D-8028
No ASAM data for: "EV_SMLSNGVOLWSXS" No fault codes found.
Address 17: Instruments  (J285) Labels: 5K0-920-xxx-17.clb
                Part No SW: 561 920 970 E      HW: 561 920 970 E
Component: KOMBI         H07 0705
Coding: 231E01
Shop #: WSC 09003 957 00200 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: N/A
VCID: 1C7B777395AC4F336A0908-8049
No ASAM data for: "EV_Kombi_UDS_VDD_RM09"
Address 19: CAN Gateway  (J533) Labels: 7N0-907-530-V2.clb Part No SW: 7N0 907 530 AH     HW: 7N0 907 530 AH
Component: J533  Gateway H50 1634
Revision:   H50
Coding: 461000
VCID: 76AF45DB4BC0AD63BC8D2A-8023
Address 25: Immobilizer  (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO          H07 0705
Coding: 000007
Shop #: WSC 09003 957 00200 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: N/A
VCID: EA97E1AB8F78E183A8352E-80BF
No ASAM data for: "EV_Immo_UDS_VDD_RM09"
Address 2B: Steer. Col. Lock  (J764)   Labels: 5K0-905-861.clb
                Part No SW: 5K0 905 861 C      HW: 5K0 905 861 C
Revision: 00000000
Coding: 4900000000000000
Shop #: WSC 09003 957 00200 ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: N/A
VCID: 3023B3C3E924DB5326F12C-8065
No ASAM data for: "EV_ELVMarquMPVW36X"
Address 2E: Media Player 3  (J650)     Labels: 5N0-035-342.lbl
                Part No SW: 5N0 035 342 F      HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003
Coding: 010100
VCID: 2A17A1ABCFF8B983E8B5EE-807F
Address 36: Seat Mem. Drvr  (J136)     Labels: None
Part No SW: 561 959 760 HW: 561 959 760
Component: MEM-FS        H04 0181
Revision: AA000000
Coding: 0000000000000000000000000000000000000000000000
VCID: E08383837944B3D376D19C-80B5
Address 37: Navigation  (J0506) Labels: 1T0-035-680.clb Part No SW: 3C0 035 684 G    HW: 3C0 035 684 G
Component: RNS-MID       H03 3696
Revision: AB001001
Coding: 04090042010000A6000B
VCID: 2711589FDCEA84EBF79B8F-8072
01523 - Microphone for Telephone (R38) 011 - Open Circuit
Address 42: Door Elect, Driver  (J386) Labels: 3C0-959-70X-GEN4.clb
                Part No SW: 561 959 701 A              VCID: 1C7B777395AC4F336A0908-8049
No ASAM data for: "EV_TSGFPQ25BRFVW46X"
131584 - ROD - Unknown faultcode
Address 44: Steering Assist    Labels: 1Kx-909-14x-44.clb
Part No SW: 1K0 909 144 P Component: EPS_ZFLS Kl. 290     3305
Revision: 00H22000
VCID: 373188DF0C4A946B673B5F-8062
Address 46: Failed to respond
Address 47: Sound System  (R12) Labels: 5K0-035-456.clb Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
Component: KonzernAmp10K H07 6813
Revision: --------
Shop #: WSC 00000 000
ROD: N/A
VCID: 260F559BDBE085E3CC6D9A-8073
No ASAM data for: "EV_AudioVerst10KanalSTT3"
Address 4F: Centr. Electr. II  (J520)  Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AH
Component: EZE_2         H50 1634
Revision:   H50
Coding: 01030108
VCID: EFA1F0BFB49A1CABFF4B77-80BA
Subsystem 1 - Part No SW: 561-959-591
Component: J245 P05 FFD7H07 0004
Coding: 181100
Subsystem 2 - Part No SW: 561-919-204-B Component: Analoguhr    008 0005
Address 52: Door Elect, Pass.  (J387)  Labels: 3C0-959-70X-GEN4.clb
                Part No SW: 561 959 702 A      HW: 3C0 959 792 C
Revision: 14110009
Coding: 0405FC
Shop #: WSC 09003 957 00200 ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: N/A
VCID: 1D7D7A778EB6463B9D377D-8048
No ASAM data for: "EV_TSGBPQ25BRFVW46X"
066562 - ROD - Unknown faultcode
Address 56: Radio  (J0506)  Labels: 1T0-035-680.clb Part No SW: 3C0 035 684 G  HW: 3C0 035 684 G
Revision: AB001001
Address 77: Telephone  (J412)     Labels: 7P6-035-730.clb Part No SW: 7P6 035 730 K  HW: 7P6 035 730 K
Revision: 1B001001
Coding: 0A10040000010110
ASAM Dataset: EV_UHVNA 002720
ROD: N/A
VCID: 3A3791EB3F5811039855BE-806F
No ASAM data for: "EV_UHVNA" No fault codes found.
End--(Elapsed Time: 03:16, VBatt start/end: 11.2/11.4 Vign: 11.4)-
Boki Ar
Arandjelovac, Serbia
C?ID=57300
nase88
Pearce, AZ, USA
C?ID=439693
Hi thx for the code but it says error 31 code out of range
Westbury, UK
That suggests the ABS you have fitted may not be directly equivalent to the old ABS.
Please can you post the part numbers of both the old ABS and thenew ABS.
'Tis 36-Drivers Seat Memory module that was replaced, not ABS. ;)
nase88
Pearce, AZ, USA
C?ID=439693
Hi all I didn’t replace any modules this vehicle is my neighbors sons car he left back to tx so not sure if I’ll see it soon, but he didn’t mention any modules being replaced. , just that the d/s seat stopped working and the scan showed all zero’s. I’ll have to see what his outcome turns out to be , but in meantime thank you all who replied/helped on this.
Ziddywerks
Northern NJ USA
C?ID=208579
The fact that coding is blank could be a sign of a failing module. Although I have never seen a module do that itself. Usually you'll have the correct coding with a fault for incorrect coding in a module condeming a module if it wasnt changed. But reset to all 0's is a new one.
Westbury, UK
My bad, apologies :cry:
I saw a fault code on 03 and stopped scrolling!
nase88
Pearce, AZ, USA
C?ID=439693
Again thank you to all I’ll just wait and see if he gets this resolved back in tx
