Thursday,11,December,2025,12:48:50:53309
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4671.4
VIN: TMBJJ9NE1E0095203 License Plate:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 20 2B 36 42 44 52 55 5F
69 6D
VIN: TMBJJ9NE1E0095203 Mileage: 113131km-70296miles
Address 01: Engine (J623-CKFC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 DT HW: 04L 907 309 D
Component: R4 2,0L EDC H22 5520
Revision: 83H22--- CVN: 4B545CBB
Coding: 111D003A043401091000
Shop #: WSC 73430 031 00134
ASAM Dataset: EV_ECM20TDI01104L906021DT 002004
ROD: EV_ECM20TDI01104L906021DT_002.rod
VCID: 7AADE2052C525A0AC07-802E
VINID: 91D49A6897950550002450800C994C5A06
Part No SW: 0D9 300 040 K HW: 02E 927 770 AN
Component: DQ250-6F MQB H52 4028
Revision: 03252104 Serial number: TFK01309051181 CVN: 0000D49B
ROD: EV_TCMDQ250021.rod
VCID: 1F1BF391D730DF22979-804A
12 Faults Found:
21153 - Gear 1
P072C 00 [00000010] - Not Selectable
21154 - Gear 2
P072D 00 [00000010] - Not Selectable
21155 - Gear 3
P072E 00 [00000010] - Not Selectable
21156 - Gear 4
P072F 00 [00000010] - Not Selectable
21157 - Gear 5
P073A 00 [00000010] - Not Selectable
21158 - Gear 6
P073B 00 [00000010] - Not Selectable
21159 - Gear R
P072B 00 [00000010] - Not Selectable
10731 - Valve 3 in Transmission Part 1
P174A 00 [00000010] - Electrical malfunction
10732 - Valve 3 in Transmission Part 2
P174E 00 [00000010] - Electrical malfunction
10657 - RPM Signal from ECU
P0726 00 [00000010] - Implausible Signal
10906 - Cooling Oil Valve
P179D 00 [00000010] - Electrical Malfunction
P1734 00 [00000010] - -
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 628530000005EA
Coding: 1C076291242909710079060041C6243846249000608224F00061F072C002
Shop #: WSC 73430 031 00063
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_033_SK37.rod
VCID: 4BC377C1334813822B1-801E
Revision: 00021000 Serial number: 0194597629 Dataset Number: 5E0IJ1t____ 0001
Coding: 030C0C
Shop #: WSC 73430 790 00134
ROD: EV_KessyHellaMQBAB_002_VW37.rod
VCID: 3A2D22056CD29A0A807-806E
Part No SW: 5E0 907 044 G HW: 5E0 907 044 G
Component: Climatronic H02 0805
Revision: 00001K06
Coding: 02010104004101011005000000100000
ASAM Dataset: EV_ACClimaBHBVW37X 003017
VCID: 290FED4999742192F9D-807C
Air quality sensor:
328197 - Motor for Right Temperature Flap
B108D 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 138
Mileage: 113082 km
Date: 2025.12.11
Time: 10:56:15
Voltage terminal 30: 13.7 V
Outside temperature: 11.5 °C
Inside temperature: 22.1 °C
Right temperature flap: actual value: 0.0 %
Right temperature flap: actual value: 205
Temperature door right - Specified value: 205
328198 - Position Sensor for Right Temperature Flap Motor
B1095 11 [00001000] - Short to Ground
Reset counter: 178
Mileage: 113084 km
Date: 2025.12.11
Time: 12:03:28
Voltage terminal 30: 12.3 V
Outside temperature: 7.5 °C
Inside temperature: 23.9 °C
Right temperature flap: actual value: 7
Temperature door right - Specified value: 182
Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0112
Serial number: 00011328800047 Dataset Number: 5E0063t____ 0043
Coding: 0C531B56424722FB0FA44004001C17280C08000000000000000000000000
ROD: EV_BCMBOSCH_011.rod
VCID: 77ABFB311F404762BF9-8022
Subsystem 1 - Part No SW: 5E1 955 119 HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 131013 041 0570
Serial number: 131014215705
Coding: 065DDD
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M10D09H23M46S00S1
Coding: 02805D
Sunroof control module:
Subsystem 3 - Part No SW: 5E9 959 591 HW: 7P0 959 591 B
Component: J245 PS24.011 H01 0008
Serial number: WOO24334976
Coding: 991900
Roof shade control module:
Subsystem 4 - Part No SW: 5E9 959 591 A HW: 7P0 959 591 C
Component: J394 PS24.011 H01 0008
Serial number: WOO24450762
Coding: 991900
19210 - Right LED Module for DRL and Parking Lights
B12ED F2 [00001000] - Voltage Supply Open or Short to Plus
Reset counter: 177
Mileage: 113030 km
Date: 2025.12.09
Time: 10:06:03
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: Not operated
Low beam: Not operated
last_wakeup: Pin C14 Kessy Weckleitung
Voltage: 14.6 V
Outside temperature: 1.5 °C
B1263 01 [00001000] - Electrical Failure
Reset counter: 177
Mileage: 113034 km
Date: 2025.12.09
Time: 10:34:37
Terminal 15 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.2 V
Outside temperature: 4.0 °C
Part No SW: 5Q0 919 298 A HW: 5Q0 919 298
Component: PARKHILFE PLA 011 0029
Revision: -------- Serial number: 61131328402253 Dataset Number: 5E0039t____ 0009
Coding: 0031061151
Shop #: WSC 73430 790 00063
ASAM Dataset: EV_EPHVA2CAU3700000 003014
ROD: EV_EPHVA2CAU3700000_003_VW37.rod
VCID: 3D2729197DFCAD32A55-8068
1078802 - Rear Left Parking Aid Sensor
B1076 12 [00001001] - Short to Plus
Fault Frequency: 11
Reset counter: 138
Mileage: 113017 km
Date: 2025.11.24
Time: 10:31:58
1079570 - Rear Right Parking Aid Sensors
B1079 12 [00001001] - Short to Plus
Fault Frequency: 9
Reset counter: 138
Mileage: 113017 km
Date: 2025.11.24
Time: 10:31:58
1111601 - Side Front Left Parking Aid Sensor
B10F6 31 [00001000] - No Signal
Reset counter: 177
Mileage: 113017 km
Date: 2025.12.01
Time: 10:26:37
1112881 - Side Front Right Parking Aid Sensor
B10FB 31 [00001000] - No Signal
Reset counter: 177
Mileage: 113017 km
Date: 2025.12.01
Time: 10:26:35
1111556 - Side Front Left Parking Aid Sensor
B10F6 04 [00001001] - Internal System Fault
Fault Frequency: 13
Reset counter: 137
Mileage: 113017 km
Date: 2025.11.24
Time: 10:31:57
1112836 - Side Front Right Parking Aid Sensor
B10FB 04 [00001001] - Internal System Fault
Fault Frequency: 13
Reset counter: 137
Mileage: 113017 km
Date: 2025.11.24
Time: 10:31:57
Part No SW: 3Q0 959 655 AA HW: 3Q0 959 655 AA
Component: Airbag VW20 011 0189
Revision: -------- Serial number: 003NYPLRJ2YG Dataset Number: 5E0003t____ 0051
Coding: 98FCC000000000005C5400CC000800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7DA7E9193D7C6D32E55-8028
Left seat belt tensioner:
Component: BeltPretRevFL H35 0340
Serial number: 34169593B21101371171
Coding: 333135
Right seat belt tensioner:
Component: BeltPretRevFR H35 0340
Serial number: 34169592B22101370281
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 454 000 510 13
Serial number: 3576U000000BC899FD0%
Subsystem 4 - Part No SW: ----------- HW: 454 000 510 13
Serial number: 3586U00000065189FD0N
Subsystem 5 - Part No SW: ----------- HW: 454 800 510 13
Component: SideSensor_Dr 111 0148
Serial number: 3516R35F30F02000000%
Subsystem 6 - Part No SW: ----------- HW: 454 800 510 13
Component: SideSensor_Pr 111 0148
Serial number: 3526R6FD00202000000
Subsystem 7 - Part No SW: ----------- HW: 454 800 509 13
Component: FrontSensor_D 114 0149
Serial number: 3556V0644E501000000+
Part No SW: 5Q0 953 507 BP HW: 5Q0 953 549
Revision: -------- Serial number: 23101304220016 Dataset Number: ----------
Coding: 1400
ROD: EV_SMLSKLOMQB_009.rod
VCID: 055781F955AC25F2BD5-8050
Part No SW: 5E0 920 871 D HW: 5E0 920 871 D
Component: KOMBI 333 2210
Coding: 07A40A182990000801086A00000000
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 C HW: 5Q0 963 272 C
Component: STH-MQB 006 0069
Coding: 9309
ASAM Dataset: EV_AuxilParkiHeateWOS 002014
VCID: 3635363558CA7E6A64F-8062
Auxiliary heating remote control:
Subsystem 1 - Part No SW: 5Q0 963 513 HW: 5Q0 963 513
Component: R149 T91-LIN 003 0301
Serial number: 00000000000000718683
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
Component: GW MQB High 125 1144
Revision: -------- Serial number: 0001130764 Dataset Number: 5E0067t____ 0012
Coding: 030100040B087300EF00064E1C0F00010001000000000000000000000000
GVL: 01543C0008000700C01C10000004C80000000000000000000000000000000000
ROD: EV_GatewLear_009.rod
VCID: 3B23270163E8A3029B1-806E
Generator:
Subsystem 2 - Part No SW: 5E0 919 719 B HW: 5E0 919 719 B
Component: E221__MFL-PR6 H04 0120
Serial number: 000000000C0687041013
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 0064561503
Address 20: High Beam Assist. (J844) Labels:| 8X0-857-511.clb
Part No SW: 5G0 857 511 D HW: 5G0 857 511
Component: FLA H04 0002
Revision: AA001001
Coding: 02018F6B76765D525220343E01
ASAM Dataset: EV_HighBeamAssisAU37X 001009
ROD: EV_HighBeamAssisAU37X.rod
VCID: 2B031741938833820B1-807E
Part No SW: 5Q0 905 861 HW: 5Q0 905 861
Component: ELV-MQBA H06 0010
Revision: 00000000 Serial number: 13000225942004
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMQB 003008
ROD: EV_ELVMarquMQB_003.rod
VCID: 73B3CF210B382B42831-8026
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 A HW: 5Q0 959 760 A
Component: Sitzmemory H06 0009
Serial number: Y0006MIK10038
Coding: 001000000000010001A081808080000000008181000000D4
ASAM Dataset: EV_SeatMemorDriveSide 001015
ROD: EV_SeatMemorDriveSide_001.rod
Part No SW: 5Q4 959 593 HW: 5Q4 959 593
Component: TSG FS 007 0006
Serial number: 0000080160727 Dataset Number: 5E0222t____ 0009
Coding: 00150820DE00028000001100
VCID: 025D9AE5448212CA987-8056
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 005 0004
Serial number: 00000000000000875484
Coding: 010200
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 M
Component: EPS_MQB_ZFLS 127 1021
Dataset Number: 5E0074t____ 0006
Coding: 83
ROD: EV_SteerAssisMQB_008.rod
Part No SW: 5Q4 959 592 HW: 5Q4 959 592
Component: TSG BFS 007 0006
Serial number: 0000079559777 Dataset Number: 5E0157t____ 0009
Coding: 00150020DE00028000001100
VCID: 015F95E9418409D281D-8054
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 005 0004
Serial number: 00000000000000915427
Coding: 190200
65558 - Heated Exterior Mirror
B11F8 14 [00001001] - Open or Short to Ground
Fault Frequency: 192
Reset counter: 138
Mileage: 109670 km
Date: 2025.08.29
Time: 10:06:26
Part No SW: 7P6 907 357 A HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Revision: -------- Serial number: -------------- Dataset Number: 5E0036t____ 0007
Coding: 03CA02003F010000
ROD: EV_HeadlRegulVWAFS_VW37.rod
Subsystem 1 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0009
Coding: 3E0000
Subsystem 2 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0009
Coding: 3E0000
Address 5F: Information Electr. (J794) Labels:| 5E0-035-MIB-HGH1.clb
Part No SW: 5E0 035 020 C HW: 5E0 035 020
Component: MU-H-ND-EU H41 0390
Serial number: A313J0D7512121 Dataset Number: 5E0CV1t____ 0037
Coding: 03730201FF0000001111120100A800002F0000840100010076
ASAM Dataset: EV_MUHig6C3HBAS 001041
ROD: EV_MUHig6C3HBAS_VW37.rod
VCID: 176BDBB13F00A7625F9-8042
Subsystem 1 - Part No SW: 5E0 919 606 HW: 5E0 919 606
Component: ABT_High H50 0022
Serial number: SKZ8Z9NL1004QY
Subsystem 2 - Part No SW: V03 959 801 BK HW: -----------
Component: ECE 2017 --- 0157
U1400 00 [00001000] - -
[Function restriction due to insufficient voltage - lower limit value not reached]
Reset counter: 137
Mileage: 113030 km
Date: 2025.12.08
Time: 13:46:04
Voltage terminal 30: 7.5 V
Part No SW: 5Q0 907 383 HW: 5Q0 907 383
Component: Anhaenger H11 0030
Revision: 6A001003 Serial number: 00000194674317
Coding: 0100000200000000
ASAM Dataset: EV_TrailFunctDemouHella 001001
ROD: EV_TrailFunctDemouHella.rod
VCID: 74B1CC3D0E362C7A9AB-8020
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 5E0 959 107 HW: 5E0 959 107
Component: HDSG-Modul H01 0744
Revision: 42001001 Serial number: 277300982 Dataset Number: 5e0771t____ 0008
Coding: 1233074003
ASAM Dataset: EV_HDSGSk462 301136
ROD: EV_HDSGSk462.rod
VCID: 698FAD4959F4E19239D-803C
End----------(Elapsed Time: 01:45, VBatt start/end: 12.9V/12.9V)-----------
------------------------------24 Faults Found------------------------------
