So i am not sure how to test this problem or if i can test it with VCDS as i will not get any error code.
My car went to several dealers. Because when i have the front window down to half or just a little and i will try to roll it up either with manual or auto mode from button will most of the time go up a little then go on its own all the way down. I need to wait for this to happen then i can roll window up.This i happening just to front windows and more to passenger. The driver side is not happening that often.
It does not make a difference if i use the control from passenger or driver door.
Mechanics says they will not change button because is working and they don’t know what the problem is but they know is a common problem with vw and audi...
I read this can be caused also by a safety control module that prevent window from crushing your hand. So i tried making sure the window seals are clean and even tried the Window Anti-Trap Reset Procedure found online:
It is still happening. I would like to ask if someone know what module i can look up and maybe see it live while playing with the window.. maybe i can see what is wrong. Or is any way of testing this safety module or button via vcds? Thank you!
1. Turn the Ignition ON: Turn your vehicle's ignition ON (Engine does not need to be running, but all electronics must be active).
2. Fully Open the Window (Manual Mode): • Push the window switch down to the first detent (manual/non-auto-down mode). • Hold the switch until the window is all the way down.
3. Hold Down for Calibration: • Release the switch. • Immediately press the switch down to the first detent again and hold it for at least 3 to 5 seconds (Some sources suggest up to 10 seconds to be certain). This marks the lower limit.
4. Fully Close the Window (Manual Mode): • Pull the window switch up to the first detent (manual/non-auto-up mode). • Hold the switch until the window is all the way closed.
5. Hold Up for Calibration: • Release the switch. • Immediately pull the switch up to the first detent again and hold it for at least 3 to 5 seconds. This marks the upper limit and calibrates the anti-trap resistance. 6. Test the Auto-Up Function: • Release the switch. • Now, pull the switch all the way up to the second detent (the auto-up position).
Saturday,06,December,2025,15:14:04:15482
VCDS Version: 25.3.2.0 (x64) HEX-NET2 CB: 0.4671.5
VIN: WAUZZZF26KN091174 License Plate:
Mileage: 164494km-102211mi Repair Order:
Chassis Type: F2-AU58 (4N1)
Scan: 01 02 03 06 09 15 16 17 19 22 36 42 44 46 52 5F 69 6D 80 81
A5 AC BB BC D6 D7
VIN: WAUZZZF26KN091174 Mileage: 164494km-102211miles
80-Batt. reg. aux. accum. -- Status: OK 0000
Address 01: Engine (J623-DFBA) Labels:. 04L-907-309-V2.clb
Part No SW: 05L 906 027 F HW: 05L 907 309
Component: R4 2.0l TDI H22 9971
Revision: E1H22--- CVN: 025D03157965F614500CA509500CA509
Coding: 0A6540122536050C34082000000400000000000000000000
Shop #: WSC 30271 004 1048576
ASAM Dataset: EV_ECM20TDI01105L906027F 005009
ROD: EV_ECM20TDI01105L906027AG.rod
VCID: 2F30614AF79E8BD2279-807A
VINID: 9D196AAAA58219B78024104710AEADEE47
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 4K0 927 153 H HW: 0HK 927 156 B
Component: 0CJ 20TDI RdW H01 0004
Revision: --H01--- Serial number: 0000001712 CVN: 89DE2BC800000000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMDL382021 002031
ROD: EV_TCMDL382021_AU58.rod
VCID: 3236683EE4ACA63A487-8066
MTF pump:
Component: V553 MTFP 003 0576
Serial number: 75145041190042001186
Address 03: ABS Brakes (J104) Labels: 4M0-907-379-V1.clb
Part No SW: 4K0 907 379 P HW: 4K0 907 379 A
Component: ESP9 Plus H06 0854
Dataset Number: 4K0909504R 0003 CVN: 1A615F70
Coding: 0CAA49972CAB0A97519F4898208152D2F5B9C0309234508A12044A4BAF9D03
ROD: EV_ESP9BOSCHCMP_004_AU58.rod
VCID: 42D638FE540C16BAD87-8016
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 4M6 959 760 B HW: 4M6 959 760 B
Component: MEM-BFS 009 0044
Serial number: 00000363406657 Dataset Number: 4K8909866B 0012
Coding: 0018B2400001BE810043010101010000810000070700878700000000000000
ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
ROD: EV_SCMPasseSideCONTIAU736_VW38.rod
VCID: 3D2C4B022DF26942A55-8068
Valve block 1 in front seat passenger side:
Subsystem 1 - Part No SW: 4N0 907 182 HW: 4N0 907 182
Component: N477 VB1 BFSv H04 0011
Serial number: SJ800129011940258070
Coding: BF2F00
Address 09: Cent. Elect. (J519) Labels:* 4N0-907-063-V2.clb
Part No SW: 4N0 907 063 GE HW: 4N0 907 063 AE
Component: BCM1 MLBevo H10 0653
Dataset Number: 4K0909514J 0028
Coding: 07000143E11800CD074C87089CFE8C68130B3310040600970100080019331A810841080240100000000001000001001A0000000000010100000000000000000000
ASAM Dataset: EV_BCM1BOSCHAU651 014010
ROD: EV_BCM1BOSCHAU651_014.rod
VCID: 77A0992A4F4E8312BF9-8022
Subsystem 1 - Part No SW: 4K1 955 119 HW: 4K1 955 119
Component: J400FRWISCH 063 0740
Serial number: 00000001812140406353
Coding: 7DC727
Serial number: 22575313X81A955555A0
Coding: 02006E
Subsystem 3 - Part No SW: 4K1 941 501 HW: 4K1 941 501
Component: E1 - LTM H05 0053
Serial number: 16S20.02.1900301533
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE101121823610622
Interior Light Module:
Subsystem 5 - Part No SW: 4K0 947 135 B HW: 4K0 947 135 B
Component: Dachmodul H42 0413
Serial number: C00196715
Coding: 0D0104
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 4N0 959 655 J HW: 4N0 959 655 J
Component: AirbagVW31 H01 2720
Serial number: 003YTM00KYGT Dataset Number: 4K0909602AD 0005
Coding: AACCF0C00CC00000985400FFF00D40AC00C5
ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
VCID: 43D83DFA4B161FB2D31-8016
Subsystem 1 - Part No SW: ----------- HW: 480 002 202 19
Serial number: 35700000000B1924B93M
Subsystem 2 - Part No SW: ----------- HW: 480 002 202 19
Serial number: 3580000000064799693Q
Subsystem 3 - Part No SW: ----------- HW: 480 032 602 19
Component: SideSensor_Dr 002 0149
Serial number: 351001C1CC086DA09CCV
Subsystem 4 - Part No SW: ----------- HW: 480 032 602 19
Component: SideSensor_Pr 002 0149
Serial number: 352001C1CC684EB0ABB.
Subsystem 5 - Part No SW: ----------- HW: 480 032 602 19
Component: FrontSensor_D 002 0149
Serial number: 355001C1CD834250AC2C
Subsystem 6 - Part No SW: ----------- HW: 480 032 602 19
Component: FrontSensor_P 002 0149
Serial number: 356001C1CD8ACDA0C986
Subsystem 7 - Part No SW: ----------- HW: 480 032 202 19
Component: PedP_Sensor_C 002 0149
Serial number: 230001C1C2AC14409FBD
Subsystem 8 - Part No SW: ----------- HW: 480 001 602 19
Serial number: I0M0000000051AE4A8BH
Subsystem 9 - Part No SW: ----------- HW: 480 001 602 19
Serial number: I0N0000000061AE4A8BJ
Part No SW: 4N0 907 129 AB HW: 4N0 907 129 AB
Component: Lenks.Modul H03 0005
ROD: EV_SMLSKLOAU736_VW53.rod
VCID: 71B4A732212ADD2271D-8024
Address 17: Instruments
Part No SW: 4N1 907 468 AL HW: 4N1 907 468 AB
Component: Gateway H14 0045
Revision: AA010003 Serial number: 038AA551219227 Dataset Number: 4K0909515D 0031
Coding: 02010005002006405A860002005B0132C83A000710000000097D078E10000000
Shop #: WSC 15223 005 1048576
GVL: 01D03C000804000080BC08000000C80000080000004000000000000000000000
ASAM Dataset: EV_CGateCONTIAU491 003170
ROD: EV_CGateCONTIAU491_003_AU58.rod
VCID: 0256F8FE148CD6BA987-8056
Subsystem 1 - Part No SW: 4K0 951 523 H HW: 4K0 951 523 H
Component: E221__MFL H06 0003
Subsystem 2 - Part No SW: 4K0 915 181 HW: 4K0 915 181
Serial number: 7418631200190221168A
Address 22: AWD (J492) Labels:| 0CJ-927-749.clb
Part No SW: 4K0 927 755 A HW: 0CJ 927 749 A
Component: C8_DL3_N_SD1 H01 0007
Serial number: 18256B6945
Coding: 010C0000
ASAM Dataset: EV_AWDCQUOD31 001052
ROD: EV_AWDCQUOD31.rod
VCID: 33386D3A1BB6AF32431-8066
Component: MEM-FS 009 0044
Serial number: 00000363406771 Dataset Number: 4K8909856B 0014
Coding: 00189A400001BE810003010101010000810000070700878700000000004000
Valve block 1 in front seat driver side:
Component: N475 VB1 FSv H04 0011
Serial number: SJ800129011940258069
Coding: BF2F00
Part No SW: 4M1 959 593 J HW: 4M1 959 593 D
Component: TSG FS001 0425
Serial number: YE007SAQ25944 Dataset Number: 4K8909872C 0036
Coding: 001FCB0052000402A000B000
Shop #: WSC 01036 202 00000
ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
VCID: 44DA3EE64E18188AEAB-8010
Part No SW: 4N0 909 144 E HW: 4N0 909 144 A
Component: EPS_MLBEVO2BS H21 0505
Dataset Number: 4K0909852K 0001
Coding: 94002101010000
ROD: EV_EPSVWBSAU426_010.rod
Part No SW: 4N0 907 064 CP HW: 4N0 907 064 P
Component: BCM2 MLBevo H14 0164
Dataset Number: 4K8909501G 0041
Coding: 01340000002000E06309A0000C00C80203024000804304502F0400000504823F001F0100000011
ASAM Dataset: EV_BCM2CONTIAU651 009009
ROD: EV_BCM2CONTIAU651_009_AU58.rod
VCID: 7F50710A677EBB52F79-802A
ID - sensor:
Subsystem 2 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 11479184
Part No SW: 4M1 959 592 J HW: 4M1 959 592 D
Component: TSG BFS001 0425
Serial number: YE007SAQ3008D Dataset Number: 4K8909873C 0036
Coding: 001FCB005E000402A000B000
ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
Address 5F: Information Electr. (J794) Labels:| 4G1-035-MIB-HGH2.clb
Part No SW: 4K0 035 064 F HW: 4K0 035 064 A
Component: MU-H-LN-EU 046 2873
Dataset Number: 4K0909545C 0036
Coding: 01850201FF0A000043110001000800102F0001E403F008008E
VCID: 2700896ADF6ED392EF9-8072
Subsystem 1 - Part No: V03 959 807 ST
Component: MIB2P_EU_Q124 0720
Multimedia display unit 1:
Subsystem 2 - Part No SW: 4K0 919 605 C HW: 4K0 919 605 A
Component: DU AU58x High H42 0147
Serial number: INX00128121800060065
Compact disc data bank:
Component: Gracenote2 1009
Volume Control 1:
Subsystem 4 - Part No SW: 4K1 919 616 B HW: 4K1 919 616 A
Component: LSR-D5/C8 H33 0110
Serial number: 00004419000019686020
Multimedia display unit 5:
Subsystem 5 - Part No SW: 4K0 919 603 B HW: 4K0 919 603
Component: DU AU58x Bot H41 0147
Serial number: INX00111011900080052
Media socket:
Subsystem 6 - Part No SW: 4N0 035 736 A HW: 4N0 035 736
Component: MediaConnectH 014 0133
Serial number: 051900084833005
Part No SW: 4M0 907 383 F HW: 4M0 907 383 B
Component: Anhaenger H27 0253
Revision: 9A001003 Serial number: 0507980891 Dataset Number: 4K0909527A 0004
Coding: 0110000202000000
ROD: EV_TrailFunctGener2Hella_VW27.rod
VCID: 353C532215C2B1026D5-8060
Part No SW: 4M0 959 107 D HW: 4M0 959 107 A
Component: HDSG-Modul H13 0170
Revision: -------- Serial number: A2-C737-6252-2 Dataset Number: 4K0909541C 0012
Coding: 12F0
VCID: 343A6E261EB8A80A5AB-8060
Address 80: Batt. reg. aux. accum. (A1) Labels: 8W0-915-101.clb
Part No SW: 4K0 915 101 HW: 4K0 915 101
Component: MQ-BMS H20 0127
Serial number: 18000124077002
ASAM Dataset: EV_BMS12VLiIonSDIAU49X 001001
ROD: EV_BMS12VLiIonSDIAU49X.rod
VCID: 6092D276FAC064AAEE3-8034
Address 81: Gear Shift (J587) Labels: 4KX-713-041-81.clb
Part No SW: 4K1 713 041 H HW: 4K1 713 041 H
Component: GSM-LL H14 0051
Serial number: 19.016 40544
ASAM Dataset: EV_GSMKAMAU581 001005
ROD: EV_GSMKAMAU581.rod
VCID: 28028A56D270DCEAE63-807C
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* 4N0-907-107-V2.clb
Part No SW: 4KE 907 107 AC HW: 4N0 907 107 H
Component: zFAS Var C H09 0291
Dataset Number: 4K0909466M 0043
Coding: 04018200000000000003D6000030060C189D560000000000000000000096D401009BA8000000000000000080000000000000000000000000000040000000000000007200008000B000000000000000000080400000B0
ASAM Dataset: EV_ZFASAU516 001003
ROD: EV_ZFASAU516_001.rod
VCID: 0052F2F61A80C4AA8E3-8054
Address AC: Reductant Control (J880) Labels: 80A-907-355.clb
Part No SW: 80A 907 355 F HW: 80A 907 355 D
Component: SCR-Stg-G4H08 0004
Dataset Number: 4K0909571D 0003
ASAM Dataset: EV_RDCMHelbaAU426 003011
ROD: EV_RDCMHelbaAU426_003.rod
VCID: 2C0A7646C688F0CA02B-8078
Part No SW: 4M1 959 595 J HW: 4M1 959 595 D
Component: TSG HFS003 0425
Serial number: YE007SAQ01613 Dataset Number: 4K8909897C 0037
Coding: 000FC90000000402A000B000
VCID: 46DE24EE78242A9AF4F-8012
Component: TSG HBFS003 0425
Serial number: YE007SAP35294 Dataset Number: 4K8909896C 0036
Part No SW: 4K0 941 572 DC HW: 4K0 941 572 D
Component: LMS_MLBevo H06 0031
Dataset Number: 4K0909471K 0018
ROD: EV_LMSLeftHELLAAU58X_AU27.rod
VCID: 72B6A83E242CE63A887-8026
Dataset Number: 4K0909472K 0018
ROD: EV_LMSRightHELLAAU58X_AU27.rod
End----------(Elapsed Time: 02:02, VBatt start/end: 12.7V/12.2V)-----------
---------------------------No fault code found.----------------------------
